Securing Rich Content Execution in NICE CXone Web Messaging with Go Middleware
- A Go HTTP middleware that intercepts incoming rich content payloads, sanitizes HTML using a DOM vulnerability scanner, enforces strict Content Security Policy headers, and serves media assets via AWS S3 pre-signed URLs before forwarding to the NICE CXone Messaging API.
- This implementation uses the NICE CXone v2 Messaging API and standard Go
net/httpmiddleware patterns. - The tutorial covers Go 1.21+ with production-grade error handling, OAuth 2.0 token management, and exponential backoff for rate limiting.
- NICE CXone OAuth 2.0 client credentials with
messaging:sendandinteractions:readscopes - CXone API version v2
- Go 1.21 or later installed
- AWS S3 bucket for asset storage with IAM credentials configured
- External dependencies:
github.com/microcosm-cc/bluemonday,golang.org/x/net/html,github.com/aws/aws-sdk-go-v2,github.com/aws/aws-sdk-go-v2/config,github.com/aws/aws-sdk-go-v2/service/s3,github.com/google/uuid
NICE CXone uses OAuth 2.0 client credentials flow. The middleware requires a valid bearer token for all API calls. The following implementation caches the token and refreshes it automatically before expiration.
package auth
import (
"context"
"encoding/json"
"fmt"
"net/http"
"time"
type CxoneToken struct {
FetchedAt time.Time
type CxoneAuthClient struct {
BaseURL string
ClientID string
ClientSec string
token *CxoneToken
httpClient *http.Client
func NewCxoneAuthClient(clientID, clientSecret string) *CxoneAuthClient {
return &CxoneAuthClient{
BaseURL: "https://api.nicecxone.com",
ClientID: clientID,
ClientSec: clientSecret,
httpClient: &http.Client{Timeout: 10 * time.Second},
func (c *CxoneAuthClient) GetToken(ctx context.Context) (string, error) {
if c.token != nil && c.token.FetchedAt.Add(time.Duration(c.token.ExpiresIn)*time.Second).After(time.Now()) {
return c.token.AccessToken, nil
payload := fmt.Sprintf("grant_type=client_credentials&client_id=%s&client_secret=%s", c.ClientID, c.ClientSec)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, c.BaseURL+"/api/v2/oauth/token", nil)
if err != nil {
return "", fmt.Errorf("failed to create oauth request: %w", err)
resp, err := c.httpClient.Do(req)
if err != nil {
return "", fmt.Errorf("oauth request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("oauth failed with status %d", resp.StatusCode)
var tokenResp CxoneToken
return "", fmt.Errorf("failed to decode token response: %w", err)
tokenResp.FetchedAt = time.Now()
c.token = &tokenResp
OAuth Scope Required: messaging:send for sending rich content. The token is cached in memory and refreshed when FetchedAt + ExpiresIn approaches the current time.
Step 1: DOM Vulnerability Scanner and HTML Sanitization
The middleware first parses the incoming HTML payload into a DOM tree. It walks the AST to detect dangerous patterns that standard sanitizers might miss, such as event handler attributes, javascript: URIs, and data: URLs with executable MIME types. After validation, bluemonday strips any remaining unsafe markup.
package security
import (
"bytes"
"fmt"
"strings"
"github.com/microcosm-cc/bluemonday"
"golang.org/x/net/html"
type DOMScanner struct {
policy *bluemonday.Policy
func NewDOMScanner() *DOMScanner {
p := bluemonday.UGCPolicy()
p.AllowElements("div", "p", "span", "a", "img", "strong", "em", "ul", "ol", "li")
p.AllowAttrs("href", "src", "alt", "title", "style").OnElements("a", "img")
p.AllowAttrs("class").Globally()
p.RequireNoFollowOnLinks(true)
p.RequireTargetBlankOnLinks(true)
return &DOMScanner{policy: p}
func (s *DOMScanner) ScanAndSanitize(rawHTML string) (string, error) {
root, err := html.Parse(strings.NewReader(rawHTML))
if err != nil {
return "", fmt.Errorf("failed to parse HTML: %w", err)
if err := s.walkDOM(root); err != nil {
return "", fmt.Errorf("DOM vulnerability detected: %w", err)
return s.policy.Sanitize(rawHTML), nil
func (s *DOMScanner) walkDOM(node *html.Node) error {
for child := node.FirstChild; child != nil; child = child.NextSibling {
if child.Type == html.ElementNode {
for _, attr := range child.Attr {
if strings.HasPrefix(attr.Key, "on") {
return fmt.Errorf("event handler attribute blocked: %s", attr.Key)
if attr.Key == "href" || attr.Key == "src" {
if strings.HasPrefix(strings.ToLower(attr.Val), "javascript:") ||
strings.HasPrefix(strings.ToLower(attr.Val), "data:text/html") {
return fmt.Errorf("dangerous URI scheme blocked in %s", attr.Key)
if err := s.walkDOM(child); err != nil {
return err
return nil
This scanner rejects payloads containing inline event handlers or executable data URIs before passing them to bluemonday for final sanitization.
Step 2: Content Security Policy Enforcement and Signed URL Generation
The middleware attaches a strict CSP header to all responses. It also intercepts <img> and <video> src attributes, replaces them with AWS S3 pre-signed URLs, and serves the assets securely. The signed URL generation uses the AWS SDK v2 with a 1-hour expiration window.
package security
import (
"context"
"fmt"
"net/http"
"regexp"
"time"
"github.com/aws/aws-sdk-go-v2/aws"
"github.com/aws/aws-sdk-go-v2/config"
"github.com/aws/aws-sdk-go-v2/service/s3"
type CSPAndAssetHandler struct {
scanner *DOMScanner
s3Client *s3.Client
bucket string
func NewCSPAndAssetHandler(scanner *DOMScanner, bucket string) (*CSPAndAssetHandler, error) {
cfg, err := config.LoadDefaultConfig(context.Background())
if err != nil {
return nil, fmt.Errorf("failed to load AWS config: %w", err)
return &CSPAndAssetHandler{
scanner: scanner,
s3Client: s3.NewFromConfig(cfg),
bucket: bucket,
}, nil
func (h *CSPAndAssetHandler) Middleware(next http.Handler) http.Handler {
return http.HandlerFunc(func(w http.ResponseWriter, r *http.Request) {
w.Header().Set("Content-Security-Policy", "default-src 'self'; script-src 'none'; style-src 'self'; img-src https://s3.amazonaws.com; font-src 'self'; connect-src https://api.nicecxone.com; frame-ancestors 'none'; base-uri 'self'; form-action 'self';")
w.Header().Set("X-Content-Type-Options", "nosniff")
w.Header().Set("X-Frame-Options", "DENY")
next.ServeHTTP(w, r)
func (h *CSPAndAssetHandler) ReplaceAssetSrcs(ctx context.Context, htmlContent string) (string, error) {
imgRegex := regexp.MustCompile(`<img[^>]+src=["'](https?://[^"']+)["']`)
matches := imgRegex.FindAllStringSubmatch(htmlContent, -1)
for _, match := range matches {
if len(match) < 2 {
originalURL := match[1]
signedURL, err := h.generatePresignedURL(ctx, originalURL)
if err != nil {
return "", fmt.Errorf("failed to sign asset URL: %w", err)
htmlContent = strings.ReplaceAll(htmlContent, originalURL, signedURL)
return htmlContent, nil
func (h *CSPAndAssetHandler) generatePresignedURL(ctx context.Context, assetKey string) (string, error) {
req, _ := h.s3Client.PresignGetObject(ctx, &s3.GetObjectInput{
Bucket: aws.String(h.bucket),
Key: aws.String(assetKey),
}, func(opts *s3.PresignOptions) {
opts.Expires = 1 * time.Hour
return req.URL, nil
The CSP header blocks inline scripts, restricts image sources to AWS S3, and prevents framing. The asset replacer ensures guest-facing interfaces never load unsanitized external media.
Step 3: Forwarding Sanitized Payload to CXone with Retry Logic
The final step constructs the CXone rich content message, signs the assets, and forwards the payload. The implementation includes exponential backoff for HTTP 429 rate limit responses, which is critical during peak messaging volume.
package cxone
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"math"
"net/http"
"time"
"yourmodule/security"
type CxoneMessagingClient struct {
BaseURL string
Auth *auth.CxoneAuthClient
Handler *security.CSPAndAssetHandler
HTTP *http.Client
type RichMessagePayload struct {
Type string `json:"type"`
Content struct {
HTML string `json:"html"`
Title string `json:"title,omitempty"`
} `json:"content"`
func NewCxoneMessagingClient(auth *auth.CxoneAuthClient, handler *security.CSPAndAssetHandler) *CxoneMessagingClient {
return &CxoneMessagingClient{
Auth: auth,
Handler: handler,
HTTP: &http.Client{Timeout: 15 * time.Second},
func (c *CxoneMessagingClient) SendRichContent(ctx context.Context, interactionID string, rawHTML string) error {
sanitizedHTML, err := c.Handler.Scanner.ScanAndSanitize(rawHTML)
if err != nil {
return fmt.Errorf("sanitization failed: %w", err)
signedHTML, err := c.Handler.ReplaceAssetSrcs(ctx, sanitizedHTML)
if err != nil {
return fmt.Errorf("asset signing failed: %w", err)
payload := RichMessagePayload{
Type: "rich",
Content: struct {
HTML: signedHTML,
body, err := json.Marshal(payload)
if err != nil {
return fmt.Errorf("failed to marshal payload: %w", err)
url := fmt.Sprintf("%s/api/v2/messaging/interactions/%s/messages", c.BaseURL, interactionID)
var lastErr error
for attempt := 0; attempt < 5; attempt++ {
req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, bytes.NewReader(body))
if err != nil {
return fmt.Errorf("failed to create request: %w", err)
token, err := c.Auth.GetToken(ctx)
if err != nil {
return fmt.Errorf("auth token retrieval failed: %w", err)
resp, err := c.HTTP.Do(req)
if err != nil {
lastErr = fmt.Errorf("http request failed: %w", err)
respBody, _ := io.ReadAll(resp.Body)
resp.Body.Close()
backoff := time.Duration(math.Pow(2, float64(attempt))) * time.Second
fmt.Printf("Rate limited (429). Retrying in %v. Attempt %d/5\n", backoff, attempt+1)
time.Sleep(backoff)
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
lastErr = fmt.Errorf("CXone API error %d: %s", resp.StatusCode, string(respBody))
if resp.StatusCode == http.StatusUnauthorized || resp.StatusCode == http.StatusForbidden {
return lastErr
time.Sleep(time.Duration(math.Pow(2, float64(attempt))) * time.Second)
return nil
return fmt.Errorf("failed after retries: %w", lastErr)
Expected Request Cycle:
- Method:
POST - Path:
/api/v2/messaging/interactions/{interactionId}/messages - Headers:
Authorization: Bearer <token>,Content-Type: application/json - Body:
"type": "rich",
"content": {
"html": "<div><img src=\"https://s3.amazonaws.com/signed-asset-url?...\" alt=\"product\"/></div>"
- Success Response:
201 Createdwith empty body or message ID object. - Required Scope:
messaging:send
The following script assembles all components into a runnable HTTP server that accepts rich content via a local endpoint and forwards it to CXone after security processing.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"os"
"time"
"yourmodule/auth"
"yourmodule/cxone"
type IncomingRequest struct {
InteractionID string `json:"interactionId"`
RawHTML string `json:"rawHtml"`
func main() {
cxoneClientID := os.Getenv("CXONE_CLIENT_ID")
cxoneClientSecret := os.Getenv("CXONE_CLIENT_SECRET")
s3Bucket := os.Getenv("S3_ASSET_BUCKET")
if cxoneClientID == "" || cxoneClientSecret == "" || s3Bucket == "" {
log.Fatal("Missing required environment variables: CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, S3_ASSET_BUCKET")
authClient := auth.NewCxoneAuthClient(cxoneClientID, cxoneClientSecret)
scanner := security.NewDOMScanner()
handler, err := security.NewCSPAndAssetHandler(scanner, s3Bucket)
if err != nil {
log.Fatalf("Failed to initialize asset handler: %v", err)
cxoneClient := cxone.NewCxoneMessagingClient(authClient, handler)
mux := http.NewServeMux()
mux.Handle("/secure-messaging", handler.Middleware(http.HandlerFunc(func(w http.ResponseWriter, r *http.Request) {
if r.Method != http.MethodPost {
http.Error(w, "Method not allowed", http.StatusMethodNotAllowed)
return
var req IncomingRequest
if err := json.NewDecoder(r.Body).Decode(&req); err != nil {
http.Error(w, "Invalid JSON payload", http.StatusBadRequest)
return
ctx, cancel := context.WithTimeout(r.Context(), 30*time.Second)
defer cancel()
if err := cxoneClient.SendRichContent(ctx, req.InteractionID, req.RawHTML); err != nil {
http.Error(w, fmt.Sprintf("Failed to send rich content: %v", err), http.StatusInternalServerError)
return
w.WriteHeader(http.StatusOK)
json.NewEncoder(w).Encode(map[string]string{"status": "sent", "interactionId": req.InteractionID})
fmt.Println("Secure CXone Messaging Gateway listening on :8080")
if err := http.ListenAndServe(":8080", mux); err != nil {
log.Fatalf("Server failed: %v", err)
Run the server with go run main.go. Send a test payload using curl:
curl -X POST http://localhost:8080/secure-messaging \
-H "Content-Type: application/json" \
-d '{"interactionId": "6f8e12a3-4b5c-6d7e-8f9a-0b1c2d3e4f5a", "rawHtml": "<div><img src=\"assets/product.png\" alt=\"Item\"/><p>Secure content</p></div>"}'
- Cause: OAuth token is expired, invalid, or the client credentials are incorrect.
- Fix: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETin environment variables. Ensure the token cache is not holding a stale token by restarting the service or clearing the in-memory cache. Check that the client is authorized formessaging:send.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scope, or the interaction ID belongs to a different CXone instance.
- Fix: Confirm the OAuth client has
messaging:sendscope assigned in the CXone admin console. Validate that theinteractionIdmatches an active web messaging session in the same CXone instance.
- Cause: CXone rate limits are exceeded. The messaging API enforces per-client and per-instance throttling.
- Fix: The implementation already includes exponential backoff. Increase the initial backoff interval if volume is high. Monitor
Retry-Afterheaders in CXone responses and adjust sleep duration accordingly. Avoid synchronous bulk sends; queue messages and process them with controlled concurrency.
Error: AWS PresignGetObject Failed
- Cause: IAM credentials lack
s3:GetObjectpermission, or the bucket policy blocks public read access. - Fix: Attach the
AmazonS3ReadOnlyAccesspolicy to the IAM role or user. Ensure the S3 bucket policy allowss3:GetObjectfor the signing principal. Verify theS3_ASSET_BUCKETenvironment variable matches the actual bucket name.
