Scoping OAuth Clients to Specific Divisions for Multi-Tenant BPO Access
- One sentence: You will build a Python script that authenticates via OAuth and retrieves user data scoped strictly to a specific division ID.
- One sentence: This uses the Genesys Cloud Pure Cloud Platform Client V2 SDK and the
/api/v2/usersendpoint with thedivisionIdquery parameter. - One sentence: The code is written in Python 3.9+ using the
genesys-cloud-purecloud-platform-clientlibrary.
- OAuth Client Type: Confidential Client (Client Credentials Grant).
- Required Scopes:
user:read(for reading user data),division:read(if querying division metadata). - SDK Version:
genesys-cloud-purecloud-platform-client>= 135.0.0. - Runtime Requirements: Python 3.9 or higher.
- External Dependencies:
genesys-cloud-purecloud-platform-clientpython-dotenv(for secure credential management)
In a multi-tenant BPO environment, the OAuth client itself does not enforce division scoping. The OAuth token represents the identity of the application. The scoping happens at the API call level by explicitly passing the divisionId in the request headers or query parameters. However, the client must have the necessary permissions to access the target division.
First, install the required packages:
pip install genesys-cloud-purecloud-platform-client python-dotenv
Create a .env file in your project root with your client credentials and the target division ID.
GENESYS_CLIENT_ID=your_client_id
GENESYS_CLIENT_SECRET=your_client_secret
GENESYS_REGION=us-east-1
TARGET_DIVISION_ID=your_target_division_uuid
The authentication logic uses the OAuthApi to obtain a bearer token. The genesys-cloud-purecloud-platform-client handles token refresh automatically when using the PlatformClient singleton, but understanding the flow is critical for debugging multi-tenant isolation issues.
import os
from purecloud_platform_client import (
PlatformClient,
Configuration,
OAuthApi,
ApiClient,
ApiException
load_dotenv()
def get_platform_client() -> PlatformClient:
Initializes and configures the Genesys Cloud Platform Client.
# Load credentials from environment variables
region = os.getenv("GENESYS_REGION", "us-east-1")
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set in environment.")
# Configure the client with the correct region
config = Configuration(
host=f"https://{region}.pure.cloudapi.net",
client_id=client_id,
client_secret=client_secret
# Create the platform client instance
# The SDK handles OAuth token acquisition and refresh automatically
# when API calls are made via the generated API classes.
return PlatformClient(configuration=config)
# Initialize the client
pc = get_platform_client()
Step 1: Validate Division Access and Retrieve Division ID
Before querying users, it is prudent to verify that the OAuth client has access to the specific division. In Genesys Cloud, if a client attempts to access a division it does not have permission for, it will receive a 403 Forbidden or an empty result set depending on the endpoint.
We will use the DivisionsApi to fetch the division details. This confirms the division exists and is accessible to the current OAuth context.
from purecloud_platform_client import DivisionsApi
def validate_division_access(division_id: str) -> dict:
Validates that the OAuth client can access the specified division.
Args:
division_id (str): The UUID of the target division.
Returns:
dict: The division object if accessible.
Raises:
ApiException: If the division is not found or access is denied.
divisions_api = DivisionsApi(pc)
# Endpoint: GET /api/v2/divisions/{divisionId}
# Scope: division:read
response = divisions_api.get_divisions_division_id(division_id)
if response.body is None:
raise ValueError(f"Division {division_id} returned a null body.")
print(f"Access confirmed for division: {response.body.name} ({division_id})")
return response.body.to_dict()
except ApiException as e:
if e.status == 404:
print(f"Error: Division {division_id} not found.")
elif e.status == 403:
print(f"Error: Access forbidden for division {division_id}. Check OAuth client permissions.")
else:
print(f"Unexpected error: {e.status} - {e.body}")
raise
Step 2: Query Users Scoped to the Division
This is the core of the multi-tenant isolation. When calling the UsersApi, you must explicitly pass the division_id parameter. If you omit this, the API may return users from the default division or all accessible divisions, breaking tenant isolation.
The Genesys Cloud API uses pagination. To ensure you retrieve all users for a tenant, you must implement a loop that continues fetching until the nextPageUri is null.
from purecloud_platform_client import UsersApi
def get_users_in_division(division_id: str) -> List[Dict[str, Any]]:
Retrieves all users belonging to a specific division.
Args:
Returns:
List[Dict[str, Any]]: A list of user objects.
users_api = UsersApi(pc)
all_users = []
# Initial query parameters
# Endpoint: GET /api/v2/users
# Query Params: divisionId, pageSize
# Scope: user:read
page_size = 100
next_page_uri = None
while True:
# Fetch the current page of users
# The division_id parameter scopes the result set strictly to this tenant
response = users_api.get_users(
division_id=division_id,
page_size=page_size,
page_token=next_page_uri
if response.body is None or response.body.entities is None:
print(f"No users found in division {division_id}.")
break
# Append users to the list
all_users.extend(response.body.entities)
# Check for pagination
next_page_uri = response.body.next_page_uri
if not next_page_uri:
break
print(f"Successfully retrieved {len(all_users)} users from division {division_id}.")
return all_users
print(f"Error retrieving users: {e.status} - {e.body}")
raise
Step 3: Process and Isolate Results
In a multi-tenant BPO scenario, you must never mix data from different divisions. After retrieval, validate that every user object contains the expected division_id. This acts as a secondary safety check to ensure the API response adhered to the scoping request.
def process_tenant_users(users: List[Dict[str, Any]], expected_division_id: str) -> None:
Processes the list of users and validates division isolation.
Args:
users (List[Dict[str, Any]]): The list of user objects.
expected_division_id (str): The division ID that all users must belong to.
if not users:
print("No users to process.")
return
print(f"\n--- Processing {len(users)} users for Division {expected_division_id} ---")
for user in users:
user_division = user.get('division', {}).get('id')
# Safety Check: Ensure no cross-tenant data leakage
if user_division != expected_division_id:
print(f"WARNING: User {user.get('name')} ({user.get('id')}) belongs to division {user_division}, not {expected_division_id}.")
# Example processing: Print user details
print(f"User: {user.get('name')} | Email: {user.get('email')} | ID: {user.get('id')}")
# Example usage flow
target_div = os.getenv("TARGET_DIVISION_ID")
if not target_div:
raise ValueError("TARGET_DIVISION_ID is not set in environment.")
# Step 1: Validate Access
validate_division_access(target_div)
# Step 2: Get Users
users = get_users_in_division(target_div)
# Step 3: Process
process_tenant_users(users, target_div)
print(f"Application failed: {e}")
Below is the full, copy-pasteable script. Save this as tenant_user_scoper.py. Ensure your .env file is in the same directory.
import os
import sys
PlatformClient,
Configuration,
DivisionsApi,
UsersApi,
ApiException
load_dotenv()
"""Initializes the Genesys Cloud Platform Client."""
def validate_division_access(pc: PlatformClient, division_id: str) -> dict:
"""Validates that the OAuth client can access the specified division."""
print(f"[OK] Access confirmed for division: {response.body.name} ({division_id})")
if e.status == 404:
print(f"[FAIL] Division {division_id} not found.")
print(f"[FAIL] Access forbidden for division {division_id}. Check OAuth client permissions.")
else:
print(f"[FAIL] Unexpected error: {e.status} - {e.body}")
raise
def get_users_in_division(pc: PlatformClient, division_id: str) -> List[Dict[str, Any]]:
"""Retrieves all users belonging to a specific division with pagination."""
all_users = []
page_size = 100
while True:
print(f"[INFO] No users found in division {division_id}.")
break
break
print(f"[OK] Successfully retrieved {len(all_users)} users from division {division_id}.")
return all_users
print(f"[FAIL] Error retrieving users: {e.status} - {e.body}")
raise
"""Processes the list of users and validates division isolation."""
if not users:
print("[INFO] No users to process.")
return
for user in users:
print(f"[WARN] User {user.get('name')} ({user.get('id')}) belongs to division {user_division}, not {expected_division_id}.")
if not target_div:
print("[ERROR] TARGET_DIVISION_ID is not set in environment.")
sys.exit(1)
validate_division_access(pc, target_div)
# Step 2: Get Users
users = get_users_in_division(pc, target_div)
# Step 3: Process
print(f"[CRITICAL] Application failed: {e}")
sys.exit(1)
Error: 403 Forbidden
What causes it: The OAuth client does not have the user:read scope, or the client is not associated with the target division in the Genesys Cloud admin console.
How to fix it:
- Go to the Genesys Cloud Admin Console.
- Navigate to Admin > Platform > OAuth.
- Select your client.
- Ensure the scope
user:readis checked. - Ensure the client is assigned to the correct Division(s) in the “Divisions” tab of the client settings.
Code showing the fix:
Verify the scope in your local configuration if you are managing scopes manually, but primarily this is an admin console fix. In code, you can catch this specifically:
if e.status == 403:
print("Check OAuth Client Permissions: Does the client have 'user:read' and is it assigned to the target division?")
What causes it: You have exceeded the rate limit for the /api/v2/users endpoint. This is common when iterating over many divisions or large user bases.
How to fix it: Implement exponential backoff. The SDK does not automatically retry 429s for all operations, so you must handle it.
def get_users_with_retry(pc: PlatformClient, division_id: str, max_retries: int = 3) -> List[Dict[str, Any]]:
all_users = []
page_size = 100
attempt = 0
while True:
break
break
attempt = 0 # Reset attempt on successful page fetch
if e.status == 429:
if attempt < max_retries:
wait_time = 2 ** attempt
print(f"Rate limit hit. Waiting {wait_time} seconds before retry...")
time.sleep(wait_time)
attempt += 1
else:
print("Max retries exceeded for rate limit.")
raise
else:
raise
return all_users
Error: 404 Not Found
What causes it: The TARGET_DIVISION_ID provided in the .env file is invalid or the division has been deleted.
How to fix it: Verify the Division ID in the Genesys Cloud Admin Console under Admin > Organization > Divisions. Copy the UUID from the URL or the “Copy ID” button.
