SCIM 2.0 Java PATCH payload construction with ETag conflict resolution and batch error aggregation
What is the correct approach for constructing SCIM 2.0 PATCH payloads in Java when the ETag validation fails during concurrent updates? The Admin UI clearly shows the Queue Analytics metrics updating, but the backend Reconciler Utility keeps failing on the Group Membership synchronization. It’s running against the us-west-2 endpoint with the genesyscloud-platform-java-sdk v1.0.85. The LDAP directory constraints require strict role mapping, so the Batch Processing endpoint aggregation returns a 409 Conflict whenever two supervisors modify the Routing Configuration simultaneously. Latency tracking logs indicate the request hangs past the 4500ms threshold before the SDK throws a timeout exception. The retry logic doesn’t resolve the ETag mismatch since the transaction breaks. The Admin UI indicates the User Provisioning settings are locked, yet the Java client continues overwriting the Metadata attributes. We need a method to validate the Group Membership array against the LDAP constraints before the PATCH fires, plus a clean way to aggregate the 422 errors without dropping the entire batch. The current implementation just throws an unhandled exception and kills the queue. The Throttle Configuration limits are already maxed out in the admin panel, and the Error Aggregation logic just dumps raw JSON to stdout. The batch just drops.
PatchOp patchOp = new PatchOp();
patchOp.setOp("replace");
patchOp.setPath("members");
patchOp.setValue(jsonArray);
ScimUserPatchRequest request = new ScimUserPatchRequest();
request.setOperations(List.of(patchOp));
 ScimUser updated = scimClient.patchUser(userId, request, etagValue);
} catch (ApiException e) {
 if (e.getCode() == 409) {
 // retry with fresh etag
Are you passing the current ETag value in the If-Match header before the PATCH request hits the SCIM ENDPOINT? You’ll need to fetch the latest resource state first, then apply the update with the correct OAUTH SCOPE (scim:read_write) and BATCH PROCESSING limits through standard API INTEGRATION patterns.
PureCloudPlatformClientV2 platformClient = new PureCloudPlatformClientV2();
String token = platformClient.getOAuthClient().getAccessToken();
RequestBody body = RequestBody.create(
 MediaType.parse("application/json-patch+json"),
 "{\"ops\":[{\"op\":\"replace\",\"path\":\"/groups/0/value\",\"value\":\"newGroupID\"}]}"
Request request = new Request.Builder()
 .url("https://api.mypurecloud.com/scim/v2/Users/" + userId)
 .patch(body)
 .addHeader("Authorization", "Bearer " + token)
 .addHeader("If-Match", "\"" + etag + "\"")
 .build();
The SDK won’t retry on 412 unless you handle the conflict loop manually.
Are you actually pulling the ETag from the GET /scim/v2/Users/{id} response before building that PATCH body? The Java SDK doesn’t auto-stitch those headers together like you’d expect. You’ll get a precondition failure every time if the If-Match header isn’t explicitly set on the request config.
Here’s how I usually handle the transform when the reconciler spits out concurrent writes:
ScimUser user = scimApi.getScimUser(userId).getEntity();
String currentETag = user.getETag();
PatchOpList patchOps = new PatchOpList();
patchOps.add(new PatchOp().op("replace").path("members").members(new ListOfMembers(...)));
ScimUserPatchRequest body = new ScimUserPatchRequest()
 .schemas(Arrays.asList("urn:ietf:params:scim:api:messages:2.0:PatchOp"))
 .ops(patchOps);
scimApi.patchScimUser(userId, null, body, currentETag, "application/json");
Notice the currentETag param in the patch call. The SDK method signature takes it directly, not as a raw header string. If you’re batching these, wrap the whole thing in a retry loop with exponential backoff. The data action timeout hits hard when you hammer the SCIM endpoint with malformed transforms.
Just map the nested members array correctly in your JSONPath before passing it to the SDK. The batch error aggregation is just masking the underlying 412s. You’ll need to catch the ApiException and parse the errors array manually. Usually it’s just a missing closing bracket in the payload.
