Hello again,
I have a strange problem. I have installed framework on a machine and everything works great but then I had to have a dedicated machine for databases so I installed the Log dbserver on that machine. Now SCI doesn’t want to connect to the dbserver anymore. Anything special I have to do if it’s cross multiple server installation? I have connections to the SCS and the DAP which is tested so it’s good.
Thank you!
Is LCA installed as well?
LCA is installed and working
BTW here is what I get in the DBServerLog log:
************************************ LCALayer: REventRegistered on LCA... ************************************ GServer: new_client: fd=300, found server=292 14:23:21.914 Trc 04521 New client 3268 connected from '10.99.162.11' 14:23:36.399 Std 04523 Connection to client 'Unknown' closed, reason ''client disconnected'' Client Unknown is being closed. Current numofclients=1
You have:
Server 1:
CfgServer installed on
Server 2:
LCA
DBServer_LOG
On CME:
LOG_DAP pointing to DBServer_LOG with new configuration
Right? What does MessageServer logs say?
Which database server are you using? MS-SQL or Oracle?
In order for Genesys DBServer to work, you also need to install the Oracle client or MS-SQL Native client on the same box as DBServer.
For some reason the port I was using for DBServer_Log (2220) was closed or something but once I changed it everything works fine.
Thank you!
I’m back with this problem. After a while I noticed that the connection is not as it is upposed to be.
In fact in SCI if I select ‘Centralized Log’, Alarm History’ or ‘Audit’ in the title bar it sais that it is connected to DB server. If I select any other options like Applications or Hosts… it sais not connected to DB server. I have looked in the logs and all seems OK, there are no errors.
Any ideeas?
Thank you,
Mihai
I downgraded SCI from 802 to 801 and I don’t get the “not connected to DB server” message anymore. Still no alarms are raised. I shut down a server and in hots it sais it’s down but no alarms. I shut down some applications from services still no alarms even if it sais the app is down.
What else should I do? SCI is connected to SCS, LOG_Dap and Configuration Server.
solved it ![]()
SCS is starting as SYSTEM account and SYSTEM didn’t had rights on alarms.
Thank you!
