Scheduling NICE CXone Pure Connect Hunt Group Maintenance via Pure Connect APIs with Python
  • You will build a Python module that schedules hunt group maintenance windows, validates telephony constraints, triggers agent notifications, and synchronizes events with external ITSM systems.
  • This tutorial uses the NICE CXone Pure Connect REST API surface.
  • The implementation covers Python 3.10+ using the httpx library for asynchronous HTTP operations.
  • OAuth 2.0 Client Credentials flow with scopes: pureconnect:huntgroups:write, pureconnect:schedules:manage, pureconnect:agents:notify, webhooks:manage, analytics:read
  • NICE CXone API version: v2
  • Python 3.10 or higher
  • Dependencies: httpx, pydantic, tenacity, python-dotenv
  • Install dependencies: pip install httpx pydantic tenacity python-dotenv
NICE CXone uses the OAuth 2.0 Client Credentials grant type. You must request a token from the authorization server before issuing API calls. The token expires after a fixed duration, so you must implement refresh logic or cache the token until expiration.
import os
import httpx
from typing import Optional
class CXoneAuth:
    def __init__(self, domain: str, client_id: str, client_secret: str):
        self.domain = domain
        self.client_id = client_id
        self.base_url = f"https://{domain}.pure.cloudapps.net"
        if self._token:
            return self._token
        url = f"{self.base_url}/api/v2/oauth/token"
        data = {
            "client_id": self.client_id,
        async with httpx.AsyncClient() as client:
            response = await client.post(url, headers=headers, data=data)
            response.raise_for_status()
            payload = response.json()
            self._token = payload["access_token"]
            return self._token
    def get_headers(self, token: str) -> dict:
            "Accept": "application/json"
OAuth Scopes Required: pureconnect:huntgroups:write, pureconnect:schedules:manage
Step 1: Constructing Scheduling Payloads and Validating Telephony Constraints
You must construct a maintenance schedule payload that includes a maintenance reference, a window matrix, and a plan directive. The payload must pass validation against telephony constraints, such as maximum maintenance duration limits and overlapping window checks. You will use Pydantic to enforce schema compliance before sending the request to the CXone validation endpoint.
from pydantic import BaseModel, Field, field_validator
from typing import List
class MaintenanceWindow(BaseModel):
    start_time: datetime
    end_time: datetime
    timezone: str = "America/New_York"
    recurrence: str = "once"
    @field_validator("end_time")
    @classmethod
    def validate_max_duration(cls, v: datetime, info) -> datetime:
        start = info.data.get("start_time")
        if start and (v - start) > timedelta(hours=24):
            raise ValueError("Maintenance window cannot exceed 24 hours")
        return v
class SchedulePayload(BaseModel):
    maintenance_ref: str = Field(..., description="Unique maintenance ticket identifier")
    plan_directive: str = Field(..., pattern="^(ROLLING|SIMULTANEOUS|STAGGERED)$")
    windows: List[MaintenanceWindow]
    call_diversion_enabled: bool = True
    agent_notification_broadcast: bool = True
    max_concurrent_maintenance: int = Field(default=1, ge=1, le=5)
    def to_api_body(self) -> dict:
            "maintenanceRef": self.maintenance_ref,
            "planDirective": self.plan_directive,
            "windowMatrix": [
                    "startTime": w.start_time.isoformat(),
                    "endTime": w.end_time.isoformat(),
                    "timezone": w.timezone,
                    "recurrence": w.recurrence
                } for w in self.windows
            "callDiversionLogic": {
                "enabled": self.call_diversion_enabled,
                "fallbackQueue": "overflow_queue_id",
                "autoMaintenanceTrigger": True
            "agentNotification": {
                "broadcast": self.agent_notification_broadcast,
                "channels": ["in_app", "email"]
            "constraints": {
                "maxConcurrentMaintenance": self.max_concurrent_maintenance
You must validate the payload against the CXone telephony constraint engine before scheduling. The validation endpoint returns schema compliance and capacity warnings.
async def validate_schedule(auth: CXoneAuth, payload: SchedulePayload) -> dict:
    url = f"{auth.base_url}/api/v2/pureconnect/schedules/validate"
    headers = auth.get_headers(await auth.get_token())
        response = await client.post(url, headers=headers, json=payload.to_api_body())
        if response.status_code == 400:
            raise ValueError(f"Validation failed: {response.json().get('errorDescription')}")
        return response.json()
OAuth Scopes Required: pureconnect:schedules:manage
Step 2: Handling Agent Notifications and Call Diversion via Atomic PUT Operations
After validation, you must submit the schedule using an atomic PUT operation. This operation creates the maintenance window, triggers automatic maintenance mode on the hunt group, and broadcasts agent notifications. The API returns a schedule identifier and a verification hash.
import asyncio
from tenacity import retry, wait_exponential, stop_after_attempt, retry_if_exception_type
@retry(
    wait=wait_exponential(multiplier=1, min=2, max=10),
    stop=stop_after_attempt(3),
    retry=retry_if_exception_type(httpx.HTTPStatusError)
async def schedule_maintenance(auth: CXoneAuth, hunt_group_id: str, payload: SchedulePayload) -> dict:
    url = f"{auth.base_url}/api/v2/pureconnect/huntgroups/{hunt_group_id}/maintenance-schedules"
        response = await client.put(url, headers=headers, json=payload.to_api_body())
        if response.status_code == 409:
            raise ConflictError("Schedule conflicts with an existing maintenance window")
            raise RateLimitError("API rate limit exceeded. Retry with exponential backoff.")
You must implement pagination when listing existing schedules to verify active windows. The CXone API uses cursor-based pagination for schedule queries.
async def list_existing_schedules(auth: CXoneAuth, hunt_group_id: str) -> list:
    all_schedules = []
    cursor = None
        while True:
            params = {"pageSize": 50}
            if cursor:
                params["cursor"] = cursor
            response = await client.get(url, headers=headers, params=params)
            data = response.json()
            all_schedules.extend(data.get("entities", []))
            cursor = data.get("nextPageCursor")
            if not cursor:
                break
    return all_schedules
OAuth Scopes Required: pureconnect:huntgroups:write, pureconnect:agents:notify
Step 3: Peak Hour Checking and Dependency Verification Pipelines
You must prevent scheduling during peak traffic hours and verify dependency chains. The pipeline checks historical conversation volume, validates hunt group routing dependencies, and blocks scheduling if service disruption risk exceeds a threshold.
async def verify_peak_hours_and_dependencies(auth: CXoneAuth, schedule_id: str, payload: SchedulePayload) -> dict:
    url = f"{auth.base_url}/api/v2/analytics/conversations/details/query"
    analytics_payload = {
        "dateRange": {
            "from": (payload.windows[0].start_time - timedelta(days=14)).isoformat(),
            "to": payload.windows[0].start_time.isoformat()
        "groupBy": ["hour"],
        "metrics": ["conversationCount"],
        "filter": {
            "type": "huntGroupId",
            "value": payload.maintenance_ref
        response = await client.post(url, headers=headers, json=analytics_payload)
        analytics_data = response.json()
    peak_threshold = 500
    is_peak = any(r.get("metric", {}).get("conversationCount", 0) > peak_threshold
                  for r in analytics_data.get("data", []))
    dependency_url = f"{auth.base_url}/api/v2/pureconnect/schedules/{schedule_id}/dependencies"
    dep_response = await client.get(dependency_url, headers=headers)
    dep_response.raise_for_status()
    dependencies = dep_response.json().get("dependencies", [])
        "is_peak_hour_risk": is_peak,
        "dependency_count": len(dependencies),
        "disruption_risk": "HIGH" if is_peak else "LOW",
        "validation_passed": not is_peak and len(dependencies) < 3
OAuth Scopes Required: analytics:read, pureconnect:schedules:manage
Step 4: Synchronizing Scheduling Events with External ITSM Tools via Webhooks
You must synchronize maintenance events with external ITSM platforms. CXone supports outbound webhooks that trigger when a schedule is created, modified, or executed. You will register a webhook endpoint and verify the payload format.
async def register_itsm_webhook(auth: CXoneAuth, webhook_url: str) -> dict:
    url = f"{auth.base_url}/api/v2/pureconnect/webhooks"
    webhook_config = {
        "name": "ITSM-Maintenance-Sync",
        "endpoint": webhook_url,
        "events": ["maintenance.scheduled", "maintenance.executed", "maintenance.completed"],
        "headers": {
            "X-ITSM-Source": "CXone-PureConnect",
        "retryPolicy": {
            "maxRetries": 3,
            "backoffMultiplier": 2
        response = await client.post(url, headers=headers, json=webhook_config)
The webhook receiver must verify the payload format and extract maintenance identifiers. You can implement the receiver in JavaScript for external ITSM alignment.
const express = require('express');
const app = express();
app.use(express.json());
app.post('/webhook/cxone-maintenance', (req, res) => {
    const { event, payload, timestamp } = req.body;
    if (!event || !payload) {
        return res.status(400).json({ error: 'Invalid webhook payload structure' });
    const itsmTicket = {
        maintenanceRef: payload.maintenanceRef,
        status: event.split('.')[1],
        scheduledTime: payload.windowMatrix[0].startTime,
        divergenceLogic: payload.callDiversionLogic.enabled
    console.log('ITSM Sync Payload:', JSON.stringify(itsmTicket, null, 2));
    res.status(200).json({ acknowledged: true });
app.listen(3000, () => console.log('ITSM Webhook Listener active on port 3000'));
OAuth Scopes Required: webhooks:manage
Step 5: Tracking Scheduling Latency, Plan Success Rates, and Audit Logging
You must track scheduling latency and plan success rates to measure schedule efficiency. You will also generate scheduling audit logs for telephony governance. The implementation captures request duration, validates plan execution, and writes structured logs.
import logging
logger = logging.getLogger("MaintenanceScheduler")
class SchedulerMetrics:
    def __init__(self):
        self.latencies = []
        self.success_count = 0
        self.failure_count = 0
        self.audit_log = []
    def record_attempt(self, start_time: float, success: bool, schedule_id: str, error: Optional[str] = None) -> None:
        latency = time.time() - start_time
        self.latencies.append(latency)
        if success:
            self.success_count += 1
        else:
            self.failure_count += 1
        log_entry = {
            "timestamp": datetime.utcnow().isoformat(),
            "schedule_id": schedule_id,
            "latency_ms": round(latency * 1000, 2),
            "status": "SUCCESS" if success else "FAILURE",
            "error": error,
            "success_rate": round(self.success_count / (self.success_count + self.failure_count), 2) if (self.success_count + self.failure_count) > 0 else 0
        self.audit_log.append(log_entry)
        logger.info(f"Audit: {log_entry}")
    def get_efficiency_report(self) -> dict:
        avg_latency = sum(self.latencies) / len(self.latencies) if self.latencies else 0
            "average_latency_ms": round(avg_latency * 1000, 2),
            "total_schedules": self.success_count + self.failure_count,
            "success_rate": round(self.success_count / (self.success_count + self.failure_count), 2) if (self.success_count + self.failure_count) > 0 else 0,
            "audit_entries": self.audit_log
The following module combines authentication, payload construction, validation, scheduling, dependency verification, webhook registration, and metrics tracking into a single executable script.
import os
import asyncio
import httpx
import logging
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
logger = logging.getLogger("CXoneMaintenanceScheduler")
class CXoneAuth:
        if self._token:
            return self._token
        data = {
            self._token = response.json()["access_token"]
            return self._token
    end_time: datetime
    @classmethod
        return v
            "windowMatrix": [
            "constraints": {
    def __init__(self):
        self.latencies = []
        self.audit_log = []
        if success:
        else:
        log_entry = {
            "error": error,
async def run_maintenance_scheduler():
    auth = CXoneAuth(
        domain=os.getenv("CXONE_DOMAIN"),
        client_id=os.getenv("CXONE_CLIENT_ID"),
        client_secret=os.getenv("CXONE_CLIENT_SECRET")
    metrics = SchedulerMetrics()
    start_time = time.time()
    payload = SchedulePayload(
        maintenance_ref="MAINT-2024-0892",
        plan_directive="STAGGERED",
        windows=[MaintenanceWindow(
            start_time=datetime.utcnow() + timedelta(hours=2),
            end_time=datetime.utcnow() + timedelta(hours=3)
        logger.info("Validating schedule payload against telephony constraints")
        validation = await asyncio.wait_for(httpx.AsyncClient().post(
            f"{auth.base_url}/api/v2/pureconnect/schedules/validate",
            headers=auth.get_headers(await auth.get_token()),
        ), timeout=10)
        validation.raise_for_status()
        logger.info("Payload validation passed")
        logger.info("Scheduling maintenance via atomic PUT")
        schedule_resp = await asyncio.wait_for(httpx.AsyncClient().put(
            f"{auth.base_url}/api/v2/pureconnect/huntgroups/1234567890/maintenance-schedules",
        ), timeout=15)
        schedule_resp.raise_for_status()
        schedule_id = schedule_resp.json().get("id", "unknown")
        logger.info("Verifying peak hours and dependencies")
        analytics_resp = await asyncio.wait_for(httpx.AsyncClient().post(
            f"{auth.base_url}/api/v2/analytics/conversations/details/query",
            json={
                "dateRange": {"from": (payload.windows[0].start_time - timedelta(days=14)).isoformat(), "to": payload.windows[0].start_time.isoformat()},
        ), timeout=10)
        analytics_resp.raise_for_status()
        logger.info("Registering ITSM synchronization webhook")
        webhook_resp = await asyncio.wait_for(httpx.AsyncClient().post(
            f"{auth.base_url}/api/v2/pureconnect/webhooks",
            json={
                "endpoint": os.getenv("ITSM_WEBHOOK_URL"),
                "events": ["maintenance.scheduled", "maintenance.executed"],
                "headers": {"X-ITSM-Source": "CXone-PureConnect"}
        ), timeout=10)
        webhook_resp.raise_for_status()
        metrics.record_attempt(start_time, True, schedule_id)
        logger.info(f"Maintenance scheduled successfully. Schedule ID: {schedule_id}")
        metrics.record_attempt(start_time, False, "failed", str(e))
        logger.error(f"Scheduling failed: {e}")
    report = metrics.get_efficiency_report()
    logger.info(f"Efficiency Report: {report}")
    asyncio.run(run_maintenance_scheduler())
Error: 400 Bad Request
  • What causes it: The scheduling payload violates telephony constraints, exceeds maximum maintenance duration limits, or contains invalid window matrix formatting.
  • How to fix it: Validate the payload against the Pydantic schema before submission. Ensure the windowMatrix contains ISO 8601 timestamps and that the duration does not exceed 24 hours.
  • Code showing the fix:
    payload = SchedulePayload(maintenance_ref="TEST", plan_directive="INVALID", windows=[])
except ValueError as e:
    logger.error(f"Schema validation failed: {e}")
Error: 409 Conflict
  • What causes it: A maintenance window overlaps with an existing schedule or conflicts with active hunt group routing dependencies.
  • How to fix it: Query existing schedules using pagination to identify overlapping windows. Adjust the start_time or end_time to resolve the conflict.
existing = await list_existing_schedules(auth, "1234567890")
for s in existing:
    if s["status"] == "ACTIVE":
        logger.warning(f"Active schedule found: {s['id']}. Adjusting window.")
  • What causes it: The API rate limit is exceeded due to rapid scheduling attempts or concurrent validation calls.
  • How to fix it: Implement exponential backoff retry logic using the tenacity library. The atomic PUT operation already includes retry configuration.
@retry(wait=wait_exponential(multiplier=1, min=2, max=10), stop=stop_after_attempt(3))
async def schedule_with_retry(auth, hunt_group_id, payload):
        resp = await client.put(f"{auth.base_url}/api/v2/pureconnect/huntgroups/{hunt_group_id}/maintenance-schedules", headers=auth.get_headers(await auth.get_token()), json=payload.to_api_body())
        return resp.json()
Error: 503 Service Unavailable
  • What causes it: The Pure Connect telephony subsystem is undergoing maintenance or experiencing capacity saturation.
  • How to fix it: Wait for the subsystem to recover. Implement circuit breaker logic to prevent cascading failures. Log the event and retry after a fixed delay.
if response.status_code == 503:
    logger.warning("Telephony subsystem unavailable. Entering circuit breaker wait.")
    await asyncio.sleep(30)
    raise httpx.HTTPStatusError("Service temporarily unavailable", request=response.request, response=response)
