why in the world would sce -d NOT work on my cute and shiny DELL running Windows XP and CME 7.6?
I want to be able to tell DBID of every object, but -d does not seem to do it anymore? Did I get a counterfeat version of Genesys made in China?
Have you tried does this …go to Program->Genesys Solutions ->Framework → Configuration Manager ->Start configuration Manager …there right click and click on create shortcut …once the short cut is created change the Target as “C:\Program Files\GCTI\Configuration Manager\sce.exe” -d … ( i mean the full installation path followed by -d )
I think I may have come across this, more recently… Unfortunately…
We have a ticket raised with Genesys because some of the switches on CCP+ do not appear to work, either. Bascially, you can try to apply the -port and -host switches but the Application in itself is set to read those particular parameters from the Registry. So - the workaround is to update the Registry settings, to reflect the values you want on the switches.
Apparently, this is “cosmetic” and Genesys are looking at it as an FR, rather than an SR…
It’s not the exact same scenario as here but it does indicate that perhaps the running parameters and switches do need to be looked at closer by the Genesys Developers…
