Scaling Genesys Cloud EventBridge Integrations with SQS Dead Letter Queues and Lambda Concurrency Management
  • You will build a serverless architecture that decouples high-volume Genesys Cloud interaction events from AWS Lambda execution using Amazon SQS.
  • You will implement a Python Lambda function that consumes events from SQS with controlled concurrency and robust error handling.
  • You will use Terraform (HCL) to provision the infrastructure and Python (boto3, requests) to handle the business logic.
  • Genesys Cloud: An organization with an active API Client (Public or Private) and the analytics:conversation:view scope.
  • AWS Account: Permissions to create SQS queues, Lambda functions, IAM roles, and EventBridge rules.
  • Python 3.9+: For the Lambda runtime.
  • Dependencies: requests for HTTP calls, boto3 for AWS interactions.
  • Terraform: Version 1.0+ for infrastructure definition.
Genesys Cloud APIs require OAuth 2.0 authentication. In a serverless environment, you must manage token lifecycle carefully to avoid cold-start latency and token expiration errors. The following Python class handles the acquisition and caching of access tokens.
import requests
import json
import os
class GenesysAuthManager:
    def __init__(self, environment: str, client_id: str, client_secret: str):
        self.environment = environment
        self.client_id = client_id
        self.access_token = None
        self.token_expiry = 0
        self.base_url = f"https://api.{environment}.mygenesys.com"
    def get_token(self) -> str:
        Retrieves an access token if not cached or expired.
        Implements basic retry logic for 429 errors.
        now = time.time()
        # Return cached token if valid
        if self.access_token and now < self.token_expiry:
            return self.access_token
        # If expired or missing, fetch new one
        url = f"{self.base_url}/oauth/token"
        headers = {
        data = {
            "client_id": self.client_id,
        max_retries = 3
                response = requests.post(url, headers=headers, data=data, timeout=10)
                if response.status_code == 200:
                    token_data = response.json()
                    # Set expiry slightly before actual expiry to prevent edge cases
                    self.token_expiry = now + (token_data["expires_in"] - 30)
                elif response.status_code == 429:
                    # Rate limited, wait and retry
                    wait_time = 2 ** attempt
                    time.sleep(wait_time)
                else:
                    raise Exception(f"Failed to get token: {response.status_code} - {response.text}")
                if attempt == max_retries - 1:
                    raise Exception(f"Max retries exceeded for token fetch: {str(e)}")
                time.sleep(2 ** attempt)
        raise Exception("Failed to acquire Genesys Cloud token")
Step 1: Infrastructure Provisioning with Terraform
To prevent Lambda concurrency limits, you must decouple the event source (EventBridge) from the compute resource (Lambda). Amazon SQS acts as the buffer. When Genesys Cloud fires events via EventBridge, they land in SQS. Lambda then polls SQS with a controlled batch size and concurrency limit.
Create a file named main.tf. This configuration sets up:
  1. An SQS Queue with visibility timeout tuned for Lambda processing time.
  2. An IAM Role for Lambda with permissions to read from SQS and write to CloudWatch Logs.
  3. A Lambda Function with reserved concurrency to prevent it from consuming all available account limits.
  4. An EventBridge Rule targeting the SQS Queue.
provider "aws" {
  region = "us-east-1"
# 1. SQS Queue
resource "aws_sqs_queue" "genesys_events_queue" {
  name                       = "genesys-interaction-events-queue"
  visibility_timeout_seconds = 300 # 5 minutes, sufficient for complex API calls
  receive_wait_time_seconds  = 10  # Long polling enabled
  message_retention_seconds  = 1209600 # 14 days
  redrive_policy = jsonencode({
    deadLetterTargetArn = aws_sqs_queue.dead_letter_queue.arn
    maxReceiveCount     = 3
  tags = {
    Environment = "production"
    Source      = "GenesysCloud"
# Dead Letter Queue for failed messages
resource "aws_sqs_queue" "dead_letter_queue" {
  name = "genesys-interaction-events-dlq"
# 2. IAM Role for Lambda
resource "aws_iam_role" "lambda_exec_role" {
  name = "genesys-lambda-exec-role"
  assume_role_policy = jsonencode({
    Version = "2012-10-17"
    Statement = [
        Action = "sts:AssumeRole"
        Effect = "Allow"
        Principal = {
          Service = "lambda.amazonaws.com"
resource "aws_iam_role_policy_attachment" "lambda_basic" {
  role       = aws_iam_role.lambda_exec_role.name
  policy_arn = "arn:aws:iam::aws:policy/service-role/AWSLambdaBasicExecutionRole"
# Policy to allow Lambda to delete messages from SQS
resource "aws_iam_role_policy" "sqs_permissions" {
  name = "sqs-permissions"
  role = aws_iam_role.lambda_exec_role.id
    Statement = [
        Effect = "Allow"
        Action = [
          "sqs:ReceiveMessage",
          "sqs:DeleteMessage",
          "sqs:GetQueueAttributes"
        Resource = aws_sqs_queue.genesys_events_queue.arn
# 3. Lambda Function
resource "aws_lambda_function" "genesys_processor" {
  filename         = "lambda_function.zip"
  function_name    = "genesys-event-processor"
  role             = aws_iam_role.lambda_exec_role.arn
  handler          = "lambda_function.handler"
  runtime          = "python3.9"
  timeout          = 290 # Near max timeout for complex processing
  reserved_concurrent_executions = 10 # Critical: Limits concurrency to prevent oversubscription
  environment {
    variables = {
      GENESYS_ENV      = "mypurecloud"
      GENESYS_CLIENT_ID = var.genesys_client_id
      GENESYS_CLIENT_SECRET = var.genesys_client_secret
      QUEUE_URL       = aws_sqs_queue.genesys_events_queue.id
  source_code_hash = filebase64sha256("lambda_function.zip")
# 4. EventBridge Rule
resource "aws_cloudwatch_event_rule" "genesys_event_rule" {
  name        = "genesys-interaction-rule"
  description = "Route Genesys Cloud events to SQS"
  event_pattern = jsonencode({
    source      = ["com.genesys.cloud"]
    detail-type = ["Genesys Cloud Interaction Event"]
resource "aws_cloudwatch_event_target" "sqs_target" {
  rule      = aws_cloudwatch_event_rule.genesys_event_rule.name
  target_id = "SendToSQS"
  arn       = aws_sqs_queue.genesys_events_queue.arn
# Allow EventBridge to send to SQS
resource "aws_sqs_queue_policy" "eventbridge_policy" {
  queue_url = aws_sqs_queue.genesys_events_queue.id
    Id      = "EventBridgePolicy"
    Statement = [
        Sid       = "AllowEventBridge"
        Effect    = "Allow"
        Principal = { Service = "events.amazonaws.com" }
        Action    = "sqs:SendMessage"
Step 2: The Lambda Handler with Batch Processing
The Lambda function receives a batch of events from SQS. It must process each event independently. If one event fails, it should not cause the entire batch to fail, nor should it block the processing of subsequent events.
Key considerations:
  • Partial Batch Responses: If processing fails for some messages, return a batchItemFailures list. SQS will retry only the failed messages after the visibility timeout.
  • Idempotency: Ensure your logic can handle duplicate events safely.
  • Error Isolation: Wrap individual event processing in try-except blocks.
import json
import os
import logging
# Import the auth manager from the previous step
from auth_manager import GenesysAuthManager
logger = logging.getLogger()
logger.setLevel(logging.INFO)
# Initialize Auth Manager once per cold start
auth_manager = GenesysAuthManager(
    environment=os.environ["GENESYS_ENV"],
    client_id=os.environ["GENESYS_CLIENT_ID"],
    client_secret=os.environ["GENESYS_CLIENT_SECRET"]
def process_single_event(event_detail: Dict[str, Any]) -> bool:
    Processes a single Genesys Cloud event.
    Returns True if successful, False otherwise.
        interaction_id = event_detail.get("interactionId")
        if not interaction_id:
            logger.warning("Missing interactionId in event")
            return False
        # Example: Fetch conversation details to enrich data
        token = auth_manager.get_token()
        url = f"https://api.{os.environ['GENESYS_ENV']}.mygenesys.com/api/v2/analytics/conversations/details/query"
        # Construct a query for the specific interaction
        query_body = {
            "dateFrom": "now-1h",
            "dateTo": "now",
            "view": "summary",
            "filterBy": [
                    "type": "field",
                    "filterType": "equals",
                    "path": "interaction.id",
                    "value": interaction_id
        headers = {
        response = requests.post(url, json=query_body, headers=headers, timeout=5)
            # Process data here (e.g., send to Data Lake, update CRM)
            logger.info(f"Successfully processed interaction {interaction_id}")
            return True
        else:
            logger.error(f"API Error for interaction {interaction_id}: {response.status_code}")
            return False
        logger.error(f"Exception processing event: {str(e)}")
        return False
def handler(event: Dict[str, Any], context: Any) -> Dict[str, Any]:
    AWS Lambda handler for SQS trigger.
    batch_item_failures = []
    # SQS sends a batch of records
    records = event.get("Records", [])
    if not records:
        logger.info("No records in event")
        return {}
    logger.info(f"Processing batch of {len(records)} records")
    for record in records:
        receipt_handle = record["receiptHandle"]
            # Parse the body (which is the EventBridge event)
            body = json.loads(record["body"])
            # Extract the actual Genesys event detail
            event_detail = body.get("detail", {})
            success = process_single_event(event_detail)
            if not success:
                # Mark this item for retry
                batch_item_failures.append({"itemIdentifier": receipt_handle})
            logger.error(f"Failed to process record {receipt_handle}: {str(e)}")
    # Return partial batch response if any items failed
    if batch_item_failures:
        logger.warning(f"Batch processing completed with {len(batch_item_failures)} failures")
            "batchItemFailures": batch_item_failures
    logger.info("Batch processing completed successfully")
    return {}
Step 3: Handling High Volume and Backpressure
When Genesys Cloud sends a spike of events (e.g., during a campaign launch), the SQS queue depth increases. Lambda scales up automatically, but you must respect your reserved_concurrent_executions limit.
If the queue grows faster than Lambda can process, the messages remain in the queue, hidden from other consumers for the visibility_timeout_seconds duration. This is desirable behavior. It prevents duplicate processing and ensures order within the visibility window.
To monitor this, you should set up CloudWatch Alarms on the ApproximateNumberOfMessagesVisible metric.
# CloudWatch Alarm for Queue Depth
resource "aws_cloudwatch_metric_alarm" "queue_depth_alarm" {
  alarm_name          = "GenesysQueueHighDepth"
  comparison_operator = "GreaterThanThreshold"
  evaluation_periods  = "2"
  metric_name         = "ApproximateNumberOfMessagesVisible"
  namespace           = "AWS/SQS"
  period              = "60"
  statistic           = "Average"
  threshold           = 1000
  alarm_description   = "Queue depth is high, consider increasing Lambda concurrency"
  alarm_actions       = [] # Add SNS topic ARN here for notifications
  dimensions = {
    QueueName = "genesys-interaction-events-queue"
Combine the main.tf and lambda_function.py (including the auth_manager class) into your project structure.
Directory Structure:
/terraform
  main.tf
  variables.tf
/lambda
  lambda_function.py
  auth_manager.py
  requirements.txt
requirements.txt:
requests==2.31.0
boto3==1.28.0
Deployment Steps:
  1. Package Lambda:
    cd lambda
    pip install -r requirements.txt -t .
    zip -r ../terraform/lambda_function.zip .
  2. Initialize Terraform:
    cd ../terraform
    terraform init
  3. Apply Infrastructure:
    terraform apply -auto-approve
  4. Test with Sample Event:
    Use the AWS CLI to send a test message to the SQS queue.
    aws sqs send-message \
      --queue-url https://sqs.us-east-1.amazonaws.com/123456789012/genesys-interaction-events-queue \
      --message-body '{"detail":{"interactionId":"12345678-1234-1234-1234-123456789012","type":"interaction.created"}}'
Error: 429 Too Many Requests from Genesys API
Cause: The Lambda function is making API calls faster than Genesys allows.
Fix: Implement exponential backoff in the GenesysAuthManager and add rate limiting to the process_single_event function.
    # ... existing code ...
    for attempt in range(3):
            # API Call
                logger.warning(f"Rate limited. Waiting {wait_time}s")
            # ... rest of logic ...
        except:
            pass
Error: Lambda Concurrency Limit Exceeded
Cause: Too many concurrent invocations requested.
Fix: Increase the reserved_concurrent_executions in aws_lambda_function or optimize the processing time per event.
Error: Message Visibility Timeout Expired
Cause: The Lambda function took longer than the SQS visibility timeout to process a batch.
Fix: Increase visibility_timeout_seconds in aws_sqs_queue or reduce the batch size in the Lambda trigger configuration.
