Sanitizing NICE CXone Pure Connect Recording Names via API with Python SDK
- A Python service that ingests Pure Connect recording names, applies a strict sanitization pipeline, and updates them via atomic POST operations.
- The implementation uses the official
cxone-pythonSDK andhttpxfor webhook synchronization and audit logging. - The tutorial covers Python 3.9+ with type hints, explicit retry logic, and production-grade error handling.
- OAuth 2.0 Client Credentials flow with
recordings:readandrecordings:writescopes cxone-pythonSDK v2.1+- Python 3.9+ runtime
- External dependencies:
pip install cxone-python httpx
NICE CXone uses OAuth 2.0 Client Credentials for server-to-server API access. The Python SDK handles token acquisition, caching, and automatic refresh, but you must initialize the client with valid credentials and verify the token before executing recording operations.
import os
from cxone import CXoneClient
from cxone.rest import ApiException
from typing import Optional
def initialize_cxone_client(
client_id: str,
client_secret: str,
tenant: str
) -> CXoneClient:
Initialize the CXone SDK client and verify OAuth token validity.
Raises an exception if authentication fails.
client = CXoneClient(client_id, client_secret, tenant)
# Force token acquisition to validate credentials immediately
# The SDK caches tokens automatically. We trigger a silent validation
# by accessing the internal auth module.
auth = client.get_auth()
if not auth.access_token:
auth.get_access_token()
print("OAuth token acquired successfully.")
except ApiException as e:
raise RuntimeError(f"Authentication failed with status {e.status}: {e.reason}") from e
raise RuntimeError(f"SDK initialization error: {str(e)}") from e
return client
The token lifecycle is managed by the SDK. When get_access_token() is called, it posts to POST /oauth/token with grant_type=client_credentials. The returned JWT contains the requested scopes. You must ensure your CXone integration user has the recordings:write scope assigned in the admin console.
Step 1: Configure Sanitization Matrix and Clean Directive
Recording names in CXone often contain timestamps, agent IDs, and call metadata that violate filesystem constraints. You must define a character matrix, a clean directive, and storage constraints before processing.
import re
import unicodedata
import hashlib
from dataclasses import dataclass
from typing import Dict, List, Set
@dataclass
class SanitizationConfig:
"""Configuration for recording name sanitization pipeline."""
max_length: int = 128 # CXone storage constraint for recording names
allowed_chars_pattern: str = r"[^a-zA-Z0-9_\-\.]"
reserved_words: Set[str] = frozenset({
"con", "prn", "aux", "nul", "com1", "com2", "com3", "com4",
"com5", "com6", "com7", "com8", "com9", "lpt1", "lpt2", "lpt3",
"lpt4", "lpt5", "lpt6", "lpt7", "lpt8", "lpt9", "recycle.bin"
path_traversal_patterns: List[str] = [r"\.\./", r"\.\.\\", r"^/"]
suffix_separator: str = "_"
max_suffix_iterations: int = 50
def validate_constraints(self) -> None:
"""Verify configuration against storage limits."""
if self.max_length < 1 or self.max_length > 255:
raise ValueError("max_length must be between 1 and 255 characters.")
if not self.allowed_chars_pattern:
raise ValueError("allowed_chars_pattern cannot be empty.")
The allowed_chars_pattern defines illegal characters. The clean_directive replaces matches with underscores. Path traversal prevention strips sequences that could escape the target directory. Reserved words prevent OS-level naming conflicts.
Step 2: Build the Sanitization Pipeline
This step implements encoding normalization, character matrix filtering, path traversal prevention, reserved word checking, and automatic suffix generation for collision avoidance.
class NameSanitizer:
"""Core sanitization engine for CXone recording names."""
def __init__(self, config: SanitizationConfig):
self.config = config
self.config.validate_constraints()
self.illegal_char_regex = re.compile(self.config.allowed_chars_pattern)
self.traversal_regex = re.compile("|".join(self.config.path_traversal_patterns))
def normalize_encoding(self, raw_name: str) -> str:
"""Apply NFC normalization to prevent duplicate representations."""
return unicodedata.normalize("NFC", raw_name)
def strip_path_traversal(self, name: str) -> str:
"""Remove directory traversal sequences."""
return self.traversal_regex.sub("", name)
def apply_char_matrix(self, name: str) -> str:
"""Replace illegal characters per clean directive."""
return self.illegal_char_regex.sub("_", name)
def check_reserved_words(self, name: str) -> bool:
"""Verify name does not match OS reserved identifiers."""
base_name = name.split(".")[0].lower()
return base_name in self.config.reserved_words
def generate_safe_suffix(self, base_name: str, iteration: int) -> str:
"""Create a deterministic suffix to prevent naming collisions."""
suffix_hash = hashlib.md5(f"{base_name}_{iteration}".encode()).hexdigest()[:8]
return f"{self.config.suffix_separator}{suffix_hash}"
def sanitize(self, original_name: str) -> Dict[str, any]:
Execute full sanitization pipeline.
Returns sanitized name and metadata for audit tracking.
pipeline_start = time.perf_counter()
# 1. Encoding normalization
normalized = self.normalize_encoding(original_name)
# 2. Path traversal prevention
safe_name = self.strip_path_traversal(normalized)
# 3. Character matrix application
clean_name = self.apply_char_matrix(safe_name)
# 4. Trim whitespace and collapse multiple underscores
clean_name = re.sub(r"_{2,}", "_", clean_name.strip())
# 5. Reserved word validation
if self.check_reserved_words(clean_name):
clean_name = f"rec_{clean_name}"
# 6. Length constraint enforcement with suffix generation
final_name = clean_name
iteration = 0
while len(final_name) > self.config.max_length or self._would_collide(final_name):
if iteration >= self.config.max_suffix_iterations:
raise RuntimeError("Sanitization failed: exceeded maximum suffix iterations.")
iteration += 1
suffix = self.generate_safe_suffix(clean_name, iteration)
# Truncate base to accommodate suffix
available = self.config.max_length - len(suffix)
final_name = f"{clean_name[:available]}{suffix}"
latency_ms = (time.perf_counter() - pipeline_start) * 1000
"original": original_name,
"sanitized": final_name,
"suffix_iteration": iteration,
"status": "success"
def _would_collide(self, name: str) -> bool:
"""Placeholder for external collision check. Returns False for demo."""
return False
The pipeline runs sequentially. Encoding normalization prevents é and é from being treated as different names. The character matrix replaces slashes, colons, and asterisks. The suffix generation uses MD5 hashing to produce deterministic, filesystem-safe tags.
Step 3: Execute Atomic POST Operations with Retry Logic
CXone recording updates use POST /api/v2/recording/{recordingId}/rename. You must handle 429 rate limits, verify format constraints, and ensure atomicity.
import httpx
from cxone.api import RecordingApi
from cxone.model import RenameRecordingRequest
class RecordingRenamer:
"""Handles atomic CXone recording rename operations with retry logic."""
def __init__(self, recordings_api: RecordingApi, max_retries: int = 3):
self.api = recordings_api
self.max_retries = max_retries
self.base_delay = 1.0
def rename_recording(
self,
recording_id: str,
new_name: str
Execute atomic rename with exponential backoff for 429 responses.
request = RenameRecordingRequest(name=new_name)
attempt = 0
last_exception = None
while attempt < self.max_retries:
# SDK call translates to:
# POST /api/v2/recording/{recordingId}/rename
# Headers: Authorization: Bearer <token>, Content-Type: application/json
# Body: {"name": "<sanitized_name>"}
response = self.api.rename_recording(recording_id, request)
"status": "updated",
"recording_id": recording_id,
"new_name": new_name,
"attempt": attempt + 1,
"response_code": 200
last_exception = e
if e.status == 429:
# Parse Retry-After header if present
retry_after = float(e.body.get("retry_after", self.base_delay * (2 ** attempt)))
time.sleep(retry_after)
attempt += 1
elif e.status in [401, 403]:
raise RuntimeError(f"Permission denied for recording {recording_id}: {e.reason}") from e
elif e.status == 409:
raise RuntimeError(f"Conflict: recording {recording_id} is locked or being processed.") from e
else:
raise RuntimeError(f"API error {e.status}: {e.reason}") from e
raise RuntimeError(f"Unexpected error during rename: {str(e)}") from e
raise RuntimeError(f"Rename failed after {self.max_retries} attempts. Last error: {last_exception.reason}")
The SDK serializes RenameRecordingRequest into JSON. The 429 handler reads the retry_after field from the response body or falls back to exponential backoff. Atomicity is guaranteed by CXone’s transactional recording service.
Step 4: Webhook Synchronization and Audit Logging
You must synchronize sanitization events with external archiving systems and generate governance logs.
import json
import logging
logger = logging.getLogger("cxone_sanitize")
class SanitizationOrchestrator:
"""Coordinates sanitization, API calls, webhooks, and audit logging."""
def __init__(
self,
sanitizer: NameSanitizer,
renamer: RecordingRenamer,
webhook_url: str,
audit_log_path: str = "sanitize_audit.jsonl"
self.sanitizer = sanitizer
self.renamer = renamer
self.audit_log_path = audit_log_path
self.success_count = 0
self.failure_count = 0
self.total_latency_ms = 0.0
def process_recording(self, recording_id: str, original_name: str) -> Dict[str, any]:
"""End-to-end sanitization workflow."""
audit_record = {
"original_name": original_name,
"sanitized_name": None,
"status": "pending",
"errors": []
# 1. Sanitize
sanitize_result = self.sanitizer.sanitize(original_name)
audit_record["sanitized_name"] = sanitize_result["sanitized"]
audit_record["sanitize_latency_ms"] = sanitize_result["latency_ms"]
# 2. Rename via API
rename_result = self.renamer.rename_recording(recording_id, sanitize_result["sanitized"])
audit_record["status"] = "success"
audit_record["api_response"] = rename_result
# 3. Track metrics
self.success_count += 1
self.total_latency_ms += sanitize_result["latency_ms"]
# 4. Trigger webhook
self._emit_webhook(audit_record)
audit_record["status"] = "failed"
audit_record["errors"].append(str(e))
self.failure_count += 1
finally:
self._write_audit_log(audit_record)
return audit_record
def _emit_webhook(self, payload: Dict[str, any]) -> None:
"""Synchronize sanitization event with external archiving system."""
with httpx.Client(timeout=5.0) as client:
response = client.post(
self.webhook_url,
json={
"event": "recording.name.sanitized",
"data": payload,
"source": "cxone_sanitize_service"
headers={"Content-Type": "application/json"}
if response.status_code not in [200, 202, 204]:
logger.warning("Webhook delivery failed: %s", response.text)
logger.error("Webhook network error: %s", str(e))
def _write_audit_log(self, record: Dict[str, any]) -> None:
"""Append structured audit record for media governance."""
with open(self.audit_log_path, "a", encoding="utf-8") as f:
f.write(json.dumps(record) + "\n")
def get_metrics(self) -> Dict[str, float]:
"""Return sanitization efficiency metrics."""
avg_latency = (self.total_latency_ms / self.success_count) if self.success_count > 0 else 0.0
"success_rate": self.success_count / total if total > 0 else 0.0,
"average_latency_ms": round(avg_latency, 2),
"total_processed": total,
"failures": self.failure_count
The orchestrator tracks latency, calculates success rates, emits JSONL audit logs, and pushes events to an external webhook. The webhook payload includes the sanitized name and status for archiving system alignment.
import os
import logging
def main():
# 1. Load credentials
client_id = os.getenv("CXONE_CLIENT_ID")
client_secret = os.getenv("CXONE_CLIENT_SECRET")
tenant = os.getenv("CXONE_TENANT")
webhook_url = os.getenv("SANITIZE_WEBHOOK_URL", "https://hooks.example.com/cxone-sanitize")
if not all([client_id, client_secret, tenant]):
raise ValueError("Missing required environment variables: CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_TENANT")
# 2. Initialize SDK and API
client = initialize_cxone_client(client_id, client_secret, tenant)
recordings_api = client.get_api("RecordingApi")
# 3. Configure pipeline
config = SanitizationConfig(max_length=120)
sanitizer = NameSanitizer(config)
renamer = RecordingRenamer(recordings_api, max_retries=3)
orchestrator = SanitizationOrchestrator(sanitizer, renamer, webhook_url, "sanitize_audit.jsonl")
# 4. Process target recording
target_id = "rec_8a9b7c6d-5e4f-3a2b-1c0d-9e8f7a6b5c4d"
original_name = "Call/2023-10-25 14:30:00..Agent_Jane..Customer#12345..Duration:00:04:12"
print(f"Processing recording {target_id}...")
result = orchestrator.process_recording(target_id, original_name)
print(f"Result: {result['status']}")
print(f"Sanitized Name: {result.get('sanitized_name', 'N/A')}")
print(f"Metrics: {orchestrator.get_metrics()}")
main()
Run this script with CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, and CXONE_TENANT environment variables set. Replace target_id with a valid recording ID from your CXone tenant. The script outputs the sanitized name, status, and efficiency metrics.
- Cause: Expired OAuth token, invalid client credentials, or missing
recordings:readscope. - Fix: Verify credentials in CXone Admin > Integrations. Ensure the integration user has the required scopes. The SDK will automatically refresh tokens, but initial authentication must succeed.
- Code: The
initialize_cxone_clientfunction raises aRuntimeErroron 401. Catch it and re-authenticate.
Error: 403 Forbidden
- Cause: Integration user lacks
recordings:writepermission or the recording belongs to a restricted partition. - Fix: Assign the
Recordings:Editcapability in CXone Admin. Verify the recording ID exists and is accessible. - Code: The
RecordingRenamerexplicitly raises a permission error on 403.
Error: 409 Conflict
- Cause: Recording is currently being processed, archived, or locked by another API operation.
- Fix: Implement a polling loop with exponential backoff before retrying. CXone releases locks after processing completes.
- Code: The rename handler catches 409 and raises a descriptive error. Wrap the call in a retry loop if transient locking is expected.
- Cause: Rate limit exceeded on the CXone recording endpoint.
- Fix: The orchestrator uses exponential backoff. Adjust
max_retriesandbase_delayif your tenant has stricter limits. Monitor theRetry-Afterheader. - Code: The
rename_recordingmethod parsesretry_afterfrom the response body and sleeps accordingly.
Error: Sanitization Failed - Exceeded Maximum Suffix Iterations
- Cause: Name length constraints combined with suffix generation exceeded the iteration limit.
- Fix: Increase
max_lengthinSanitizationConfigor reduce the suffix length. Ensure original names are not excessively long before pipeline ingestion. - Code: The
sanitizemethod raises aRuntimeErrorwheniteration >= max_suffix_iterations.
