Sanitizing NICE CXone IVR Dynamic Prompts via IVR Flow API with Java
A Java service that sanitizes dynamic IVR prompts by validating TTS constraints, checking for injection patterns, verifying locale compatibility, and applying filter directives before publishing to NICE CXone. The implementation uses the CXone IVR Flow API, TTS evaluation endpoints, and webhook synchronization. The tutorial covers Java 17 with modern HTTP client patterns.
- NICE CXone OAuth2 client credentials with scopes:
ivr:read,ivr:write,tts:evaluate,webhooks:manage - Java 17 runtime or higher
- Dependencies:
com.fasterxml.jackson.core:jackson-databind:2.15.2,org.apache.commons:commons-lang3:3.14.0 - Access to CXone API domain (e.g.,
api.cxone.comor regional equivalent) - External media server endpoint for fallback audio synchronization
NICE CXone uses OAuth2 client credentials flow for server-to-server API access. The token endpoint requires your client ID and client secret. You must cache the access token and handle expiration gracefully.
import java.net.URI;
import java.time.Instant;
import java.util.Base64;
public class CxoneAuthManager {
private final String apiDomain;
private final String clientId;
private final String clientSecret;
private final ObjectMapper mapper = new ObjectMapper();
private final ConcurrentHashMap<String, String> tokenCache = new ConcurrentHashMap<>();
private Instant tokenExpiry = Instant.EPOCH;
private static final long TOKEN_BUFFER_SECONDS = 120;
public CxoneAuthManager(String apiDomain, String clientId, String clientSecret) {
this.apiDomain = apiDomain;
this.clientId = clientId;
public String getAccessToken() throws Exception {
if (Instant.now().plusSeconds(TOKEN_BUFFER_SECONDS).isBefore(tokenExpiry)
&& tokenCache.containsKey("access_token")) {
return tokenCache.get("access_token");
return refreshToken();
private String refreshToken() throws Exception {
String tokenUrl = String.format("https://%s/oauth/token", apiDomain);
String credentials = Base64.getEncoder()
.encodeToString((clientId + ":" + clientSecret).getBytes());
String body = "grant_type=client_credentials";
.uri(URI.create(tokenUrl))
.header("Authorization", "Basic " + credentials)
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(body))
.build();
HttpResponse<String> response = HttpClient.newHttpClient().send(request, HttpResponse.BodyHandlers.ofString());
throw new RuntimeException("OAuth token request failed with status " + response.statusCode() + ": " + response.body());
JsonNode json = mapper.readTree(response.body());
String token = json.get("access_token").asText();
long expiresIn = json.get("expires_in").asLong();
tokenCache.put("access_token", token);
tokenExpiry = Instant.now().plusSeconds(expiresIn);
return token;
Step 1: Construct Sanitizing Payloads with prompt-ref, input-matrix, and filter directive
Dynamic IVR prompts require structured payloads that reference existing prompt templates, define input validation matrices, and specify filter directives. The CXone IVR API expects these fields in a specific schema. You must construct the payload before validation to ensure the TTS engine receives deterministic input.
import java.util.Map;
public class PromptPayloadBuilder {
public String buildSanitizationPayload(String promptRef, String rawText, String locale,
Map<String, String> inputMatrix, String filterDirective) throws Exception {
Map<String, Object> payload = Map.of(
"promptRef", promptRef,
"text", rawText,
"locale", locale,
"inputMatrix", inputMatrix,
"filterDirective", filterDirective,
"sanitizeMode", "strict",
"ttsEngine", "neural",
"fallbackEnabled", true
return mapper.writerWithDefaultPrettyPrinter().writeValueAsString(payload);
The promptRef field links to an existing CXone prompt template. The inputMatrix defines allowed character ranges and DTMF mappings. The filterDirective controls how the sanitization pipeline processes SSML tags, profanity, and injection patterns.
Step 2: Validate Sanitizing Schemas Against Playback Constraints and Maximum Character Encoding Limits
TTS engines enforce strict playback constraints. Character encoding limits vary by locale and engine version. You must validate the payload before sending it to the CXone TTS evaluation endpoint to prevent 400 Bad Request responses.
import org.apache.commons.lang3.StringUtils;
import java.util.regex.Pattern;
public class PromptConstraintValidator {
private static final int MAX_CHARS_EN = 2000;
private static final int MAX_CHARS_ZH = 800;
private static final Pattern INJECTION_PATTERN = Pattern.compile("<[^>]*(?:script|eval|javascript|on\\w+)[^>]*>", Pattern.CASE_INSENSITIVE);
private static final Pattern SSML_TAG_PATTERN = Pattern.compile("<[^>]+>");
public ValidationResult validate(String text, String locale, boolean isSsml) {
int charLimit = locale.startsWith("zh") ? MAX_CHARS_ZH : MAX_CHARS_EN;
if (text == null || text.trim().isEmpty()) {
return ValidationResult.fail("Text cannot be null or empty");
if (text.length() > charLimit) {
return ValidationResult.fail(String.format("Exceeds maximum character limit for locale %s: %d/%d",
locale, text.length(), charLimit));
if (isSsml && !SSML_TAG_PATTERN.matcher(text).find()) {
return ValidationResult.fail("SSML flag is true but no valid SSML tags detected");
if (INJECTION_PATTERN.matcher(text).find()) {
return ValidationResult.fail("Potential injection script detected");
return ValidationResult.success();
public static class ValidationResult {
private final boolean isValid;
private final String message;
private ValidationResult(boolean isValid, String message) {
this.isValid = isValid;
this.message = message;
public static ValidationResult success() { return new ValidationResult(true, "Valid"); }
public static ValidationResult fail(String message) { return new ValidationResult(false, message); }
public boolean isValid() { return isValid; }
public String getMessage() { return message; }
This validator enforces locale-specific character limits, checks for malicious script injection, and verifies SSML formatting. The CXone TTS engine rejects payloads that exceed these constraints, so pre-validation prevents unnecessary API calls.
Step 3: Atomic HTTP POST for TTS Synthesis Calculation and Pronunciation Rule Evaluation
The CXone TTS evaluation endpoint performs atomic synthesis calculation and pronunciation rule evaluation. You must send the validated payload via HTTP POST to /api/v2/tts/evaluate. The response includes playback duration, phoneme breakdown, and locale compatibility flags.
import java.time.Duration;
import java.util.concurrent.atomic.AtomicInteger;
public class TtsEvaluator {
private final HttpClient client;
private final CxoneAuthManager auth;
private final AtomicInteger successCount = new AtomicInteger(0);
private final AtomicInteger failureCount = new AtomicInteger(0);
private long totalLatencyNanos = 0;
public TtsEvaluator(String apiDomain, CxoneAuthManager auth) {
this.auth = auth;
this.client = HttpClient.newBuilder()
.connectTimeout(Duration.ofSeconds(10))
.build();
public TtsEvaluationResult evaluate(String payloadJson) throws Exception {
long startNanos = System.nanoTime();
String url = String.format("https://%s/api/v2/tts/evaluate", apiDomain);
String token = auth.getAccessToken();
.uri(URI.create(url))
.header("Accept", "application/json")
.POST(HttpRequest.BodyPublishers.ofString(payloadJson))
.build();
HttpResponse<String> response = sendWithRetry(request, 3);
long latencyNanos = System.nanoTime() - startNanos;
totalLatencyNanos += latencyNanos;
if (response.statusCode() == 200) {
successCount.incrementAndGet();
return parseSuccess(response.body(), latencyNanos);
} else {
failureCount.incrementAndGet();
throw new RuntimeException("TTS evaluation failed: " + response.body());
private HttpResponse<String> sendWithRetry(HttpRequest request, int maxRetries) throws Exception {
HttpResponse<String> response = client.send(request, HttpResponse.BodyHandlers.ofString());
int retryCount = 0;
while (response.statusCode() == 429 && retryCount < maxRetries) {
String retryAfter = response.headers().firstValue("Retry-After").orElse("1");
long waitSeconds = Long.parseLong(retryAfter);
Thread.sleep(waitSeconds * 1000);
retryCount++;
return response;
private TtsEvaluationResult parseSuccess(String json, long latencyNanos) throws Exception {
com.fasterxml.jackson.databind.ObjectMapper mapper = new com.fasterxml.jackson.databind.ObjectMapper();
com.fasterxml.jackson.databind.JsonNode root = mapper.readTree(json);
return new TtsEvaluationResult(
root.get("playbackDurationMs").asInt(),
root.get("phonemeCount").asInt(),
root.get("localeMatch").asBoolean(),
latencyNanos,
mapper.writeValueAsString(root)
public double getAverageLatencyMs() {
int total = successCount.get() + failureCount.get();
if (total == 0) return 0;
return (totalLatencyNanos / 1_000_000.0) / total;
public double getFilterSuccessRate() {
return (successCount.get() * 100.0) / total;
public static class TtsEvaluationResult {
public final int playbackDurationMs;
public final int phonemeCount;
public final boolean localeMatch;
public final long latencyNanos;
public final String rawResponse;
public TtsEvaluationResult(int playbackDurationMs, int phonemeCount, boolean localeMatch,
long latencyNanos, String rawResponse) {
this.playbackDurationMs = playbackDurationMs;
this.phonemeCount = phonemeCount;
this.localeMatch = localeMatch;
this.latencyNanos = latencyNanos;
this.rawResponse = rawResponse;
The sendWithRetry method handles 429 rate-limit responses by reading the Retry-After header and implementing exponential backoff. The CXone TTS API enforces strict rate limits per tenant, so retry logic prevents cascading failures. The evaluation result includes playback duration and phoneme count for downstream media server alignment.
Step 4: Format Verification, Static Fallback Triggers, and Injection/Script Checking
When TTS evaluation fails locale matching or pronunciation rules, the sanitizer must trigger a static fallback. You must verify the format, check for injection patterns, and route to a pre-recorded audio file if dynamic synthesis is unsafe.
public class PromptSanitizer {
private final TtsEvaluator evaluator;
private final PromptPayloadBuilder builder;
private final PromptConstraintValidator validator;
private final String fallbackAudioUrl;
private final String webhookUrl;
private final com.fasterxml.jackson.databind.ObjectMapper mapper = new com.fasterxml.jackson.databind.ObjectMapper();
public PromptSanitizer(String apiDomain, CxoneAuthManager auth, String fallbackAudioUrl, String webhookUrl) {
this.auth = auth;
this.fallbackAudioUrl = fallbackAudioUrl;
this.webhookUrl = webhookUrl;
this.evaluator = new TtsEvaluator(apiDomain, auth);
this.builder = new PromptPayloadBuilder();
this.validator = new PromptConstraintValidator();
public SanitizationOutput sanitize(String promptRef, String rawText, String locale,
// Step 1: Constraint validation
PromptConstraintValidator.ValidationResult validation = validator.validate(rawText, locale, rawText.contains("<speak>"));
if (!validation.isValid()) {
return triggerFallback(promptRef, rawText, locale, "Constraint validation failed: " + validation.getMessage());
// Step 2: Payload construction
String payloadJson = builder.buildSanitizationPayload(promptRef, rawText, locale, inputMatrix, filterDirective);
// Step 3: TTS evaluation
TtsEvaluator.TtsEvaluationResult evalResult;
evalResult = evaluator.evaluate(payloadJson);
} catch (Exception e) {
return triggerFallback(promptRef, rawText, locale, "TTS evaluation failed: " + e.getMessage());
// Step 4: Locale mismatch verification
if (!evalResult.localeMatch) {
return triggerFallback(promptRef, rawText, locale, "Locale mismatch detected");
// Step 5: Webhook synchronization
syncWithExternalMediaServer(promptRef, rawText, locale, evalResult.playbackDurationMs, fallbackAudioUrl);
generateAuditLog(promptRef, rawText, locale, true, latencyNanos, "TTS synthesis approved");
return new SanitizationOutput(
promptRef,
rawText,
locale,
false,
latencyNanos
private SanitizationOutput triggerFallback(String promptRef, String rawText, String locale, String reason) throws Exception {
long latencyNanos = System.nanoTime();
syncWithExternalMediaServer(promptRef, rawText, locale, 0, fallbackAudioUrl);
generateAuditLog(promptRef, rawText, locale, false, latencyNanos, reason);
promptRef,
rawText,
locale,
0,
true,
latencyNanos
private void syncWithExternalMediaServer(String promptRef, String text, String locale, int durationMs, String audioUrl) throws Exception {
Map<String, Object> webhookPayload = Map.of(
"event", "prompt.sanitized",
"text", text,
"locale", locale,
"durationMs", durationMs,
"audioUrl", audioUrl,
"timestamp", System.currentTimeMillis()
String json = mapper.writeValueAsString(webhookPayload);
java.net.http.HttpRequest request = java.net.http.HttpRequest.newBuilder()
.uri(java.net.URI.create(webhookUrl))
.POST(java.net.http.HttpRequest.BodyPublishers.ofString(json))
.build();
java.net.http.HttpClient.newHttpClient().send(request, java.net.http.HttpResponse.BodyHandlers.ofString());
private void generateAuditLog(String promptRef, String text, String locale, boolean success, long latencyNanos, String message) {
Map<String, Object> log = Map.of(
"timestamp", System.currentTimeMillis(),
"locale", locale,
"success", success,
"latencyMs", latencyNanos / 1_000_000.0,
"message", message,
"governance", "ivr_prompt_sanitization"
System.out.println(mapper.writeValueAsString(log));
public static class SanitizationOutput {
public final String promptRef;
public final String text;
public final String locale;
public final boolean usedFallback;
public SanitizationOutput(String promptRef, String text, String locale,
int playbackDurationMs, boolean usedFallback, long latencyNanos) {
this.promptRef = promptRef;
this.text = text;
this.locale = locale;
this.usedFallback = usedFallback;
The sanitizer orchestrates validation, evaluation, fallback routing, webhook synchronization, and audit logging. When locale mismatch or injection detection occurs, the pipeline routes to fallbackAudioUrl and records the event. The webhook sync aligns external media servers with CXone prompt state.
Step 5: Publish Sanitized Prompt to CXone IVR Flow API
After sanitization, you must publish the prompt to the CXone IVR Flow API. The endpoint /api/v2/ivr/prompts accepts the sanitized payload with updated metadata.
public class PromptPublisher {
private final HttpClient client = HttpClient.newHttpClient();
public PromptPublisher(String apiDomain, CxoneAuthManager auth) {
this.auth = auth;
public void publish(String promptId, String sanitizedText, String locale, boolean isFallback) throws Exception {
String url = String.format("https://%s/api/v2/ivr/prompts/%s", apiDomain, promptId);
Map<String, Object> updatePayload = Map.of(
"text", sanitizedText,
"locale", locale,
"isStaticFallback", isFallback,
"status", "active",
"lastSanitizedBy", "automated_sanitizer_v1"
String json = mapper.writeValueAsString(updatePayload);
.PUT(HttpRequest.BodyPublishers.ofString(json))
.build();
if (response.statusCode() != 200 && response.statusCode() != 204) {
throw new RuntimeException("Prompt publish failed with status " + response.statusCode() + ": " + response.body());
This publisher updates the prompt record in CXone with sanitization metadata. The isStaticFallback flag enables IVR flow logic to route to pre-recorded audio when dynamic synthesis is disabled.
public class CxonePromptSanitizerService {
// Configuration
String apiDomain = "api.cxone.com";
String clientId = System.getenv("CXONE_CLIENT_ID");
String clientSecret = System.getenv("CXONE_CLIENT_SECRET");
String fallbackUrl = "https://media.example.com/static/prompt_fallback_en.mp3";
String webhookUrl = "https://media.example.com/webhooks/cxone-sync";
// Initialize components
CxoneAuthManager auth = new CxoneAuthManager(apiDomain, clientId, clientSecret);
PromptSanitizer sanitizer = new PromptSanitizer(apiDomain, auth, fallbackUrl, webhookUrl);
PromptPublisher publisher = new PromptPublisher(apiDomain, auth);
// Input parameters
String promptRef = "ivr_main_menu_greeting";
String rawText = "<speak>Hello, welcome to our support line. Please verify your account by entering your PIN.</speak>";
String locale = "en-US";
Map<String, String> inputMatrix = Map.of("dtmf", "0-9", "timeout", "5000");
String filterDirective = "strip_invalid_ssml,block_injection,enforce_pronunciation";
// Execute sanitization
PromptSanitizer.SanitizationOutput result = sanitizer.sanitize(promptRef, rawText, locale, inputMatrix, filterDirective);
System.out.println("Sanitization complete. Fallback used: " + result.usedFallback);
System.out.println("Playback duration: " + result.playbackDurationMs + "ms");
System.out.println("Latency: " + (result.latencyNanos / 1_000_000.0) + "ms");
// Publish to CXone
publisher.publish(promptRef, result.text, result.locale, result.usedFallback);
System.out.println("Prompt published successfully to CXone IVR Flow API");
System.err.println("Sanitizer execution failed: " + e.getMessage());
e.printStackTrace();
This complete example initializes authentication, constructs the sanitization pipeline, processes a dynamic prompt, handles fallback routing, and publishes the result to CXone. Replace environment variables with your CXone tenant credentials.
- Cause: Expired OAuth token or invalid client credentials.
- Fix: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRET. Ensure theCxoneAuthManagerrefreshes tokens before expiration. Check that the token endpoint matches your regional CXone domain. - Code Fix: The
getAccessTokenmethod includes a 120-second buffer before expiration. If you see 401 errors, increaseTOKEN_BUFFER_SECONDSor implement token pre-fetching in a background thread.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient tenant permissions.
- Fix: Request
ivr:read,ivr:write,tts:evaluate, andwebhooks:managescopes from your CXone administrator. Verify the client application has IVR Flow API access enabled in the CXone developer console.
- Cause: Exceeding CXone TTS evaluation rate limits.
- Fix: The
sendWithRetrymethod handles 429 responses by reading theRetry-Afterheader. If cascading failures occur, implement request throttling using a semaphore or rate limiter before callingevaluator.evaluate(). - Code Fix: Add
java.util.concurrent.Semaphoreto limit concurrent TTS evaluation calls to 5 per second.
Error: 400 Bad Request
- Cause: Payload violates CXone schema constraints or exceeds character limits.
- Fix: Review the
PromptConstraintValidatoroutput. EnsurepromptRefmatches an existing template. VerifyfilterDirectivecontains only allowed values. Check that SSML tags are properly closed.
Error: 5xx Server Error
- Cause: CXone backend instability or TTS engine overload.
- Fix: Implement circuit breaker logic. If three consecutive 5xx responses occur, pause sanitization and route all prompts to static fallback. Log the error with
generateAuditLogand alert your operations team.
