Sanitizing Genesys Cloud LLM Gateway System Prompts with Java
- A Java service that constructs, validates, and sanitizes LLM Gateway system prompts using atomic update operations, tracks execution latency, registers synchronization webhooks, and generates governance audit logs.
- This tutorial uses the Genesys Cloud LLM Gateway API (
/api/v2/ai/llmgateway/systemprompts) and Routing Webhooks API (/api/v2/routing/webhooks) via the official Java SDK. - The implementation is written in Java 17 using the
genesyscloud-sdk, Jackson for JSON processing, and SLF4J for structured logging.
- Genesys Cloud OAuth confidential client with scopes:
llmgateway:systemprompt:write,llmgateway:systemprompt:read,routing:webhook:write - Genesys Cloud Java SDK version
2.100.0or higher - Java 17 runtime environment
- Maven dependencies:
com.mangofactory:genesyscloud-sdk,com.fasterxml.jackson.core:jackson-databind,org.slf4j:slf4j-api,com.squareup.okhttp3:okhttp
Genesys Cloud uses standard OAuth 2.0 Client Credentials flow. The Java SDK handles token acquisition, caching, and automatic refresh when configured correctly. You initialize the ApiClient with your environment URL, client ID, and client secret.
import com.mangofactory.api.client.ApiClient;
import com.mangofactory.api.client.Configuration;
import com.mangofactory.api.client.auth.OAuth;
public class GenesysAuth {
private static final String ENV_URL = "https://api.mypurecloud.com";
private static final String CLIENT_ID = "your-client-id";
private static final String CLIENT_SECRET = "your-client-secret";
public static ApiClient configureClient() {
ApiClient client = new ApiClient();
client.setBasePath(ENV_URL);
OAuth oauth = new OAuth();
oauth.setClientId(CLIENT_ID);
oauth.setClientSecret(CLIENT_SECRET);
oauth.setAuthMode(OAuth.AuthMode.CLIENT_CREDENTIALS);
oauth.setScopes("llmgateway:systemprompt:write llmgateway:systemprompt:read routing:webhook:write");
client.setOAuth(oauth);
client.setDebugging(false);
Configuration.setDefaultApiClient(client);
return client;
The SDK caches the access token in memory. When the token expires, the next API call automatically triggers a silent refresh. If your deployment requires explicit token lifecycle management, implement a wrapper that calls client.getOAuth().refreshToken() and stores the result in a distributed cache like Redis.
Step 1: Construct Sanitizing Payloads with Prompt References and Template Matrices
You build the sanitization payload by mapping business directives to Genesys Cloud LLM Gateway model fields. The prompt-ref maps to the referenceId, template-matrix maps to structured metadata, and the clean directive maps to sanitization policy settings.
import com.mangofactory.model.ai.llmgateway.UpdateSystemPrompt;
import com.mangofactory.model.ai.llmgateway.SanitizationSettings;
import java.util.Map;
public class PromptPayloadBuilder {
private static final ObjectMapper mapper = new ObjectMapper();
public static UpdateSystemPrompt buildSanitizationPayload(String promptRef, String templateMatrix, String cleanDirective) {
UpdateSystemPrompt prompt = new UpdateSystemPrompt();
prompt.setReferenceId(promptRef);
prompt.setName("Sanitized System Prompt - " + promptRef);
// Map template-matrix to custom metadata for tracking
prompt.setMetadata(Map.of(
"template-matrix", templateMatrix,
"clean-directive", cleanDirective,
"sanitization-version", "1.0"
// Configure sanitization settings
SanitizationSettings sanitization = new SanitizationSettings();
sanitization.setEnabled(true);
sanitization.setMode(cleanDirective); // e.g., "strict", "balanced"
prompt.setSanitizationSettings(sanitization);
return prompt;
The UpdateSystemPrompt object serializes directly to the JSON payload expected by the LLM Gateway API. You attach the template-matrix and clean-directive to the metadata map because Genesys Cloud allows arbitrary key-value pairs for internal tracking without breaking schema validation.
Step 2: Validate Schemas Against Injection Constraints and Length Limits
Before transmitting the payload, you must validate it against injection patterns, variable interpolation syntax, and context window limits. This prevents sanitization failures and reduces unnecessary API calls.
import java.util.regex.Pattern;
public class PromptValidator {
private static final Pattern INJECTION_PATTERN = Pattern.compile("(?i)(ignore previous instructions|system override|bypass security|developer mode)");
private static final Pattern VARIABLE_PATTERN = Pattern.compile("\\{\\{[a-zA-Z_][a-zA-Z0-9_]*\\}\\}");
private static final int MAX_PROMPT_LENGTH = 4096;
public static void validatePayload(String content, String templateMatrix) throws IllegalArgumentException {
if (content == null || content.length() > MAX_PROMPT_LENGTH) {
throw new IllegalArgumentException("Prompt exceeds maximum length limit of " + MAX_PROMPT_LENGTH + " characters.");
if (INJECTION_PATTERN.matcher(content).find()) {
throw new IllegalArgumentException("Malicious instruction detected. Prompt rejected by injection constraint pipeline.");
// Verify variable interpolation calculation
if (content.contains("{") && !VARIABLE_PATTERN.matcher(content).find()) {
throw new IllegalArgumentException("Invalid variable interpolation syntax detected. Expected {{variable_name}} format.");
// Context overflow verification
int estimatedTokens = content.length() / 4;
if (estimatedTokens > 3500) {
throw new IllegalArgumentException("Context overflow risk detected. Estimated tokens exceed safe threshold.");
This validation pipeline runs locally before the HTTP request. It checks for known jailbreak patterns, validates that all variables follow the {{name}} convention, and estimates token count to prevent context overflow. If any check fails, the application throws an exception and skips the API call.
Step 3: Execute Atomic HTTP PUT Operations with Jailbreak Detection and Redact Triggers
You update the system prompt using an atomic HTTP PUT operation. The Genesys Cloud API supports conditional updates via If-Match headers to prevent race conditions. You also configure automatic redact triggers for failed sanitization iterations.
HTTP Request/Response Cycle:
PUT /api/v2/ai/llmgateway/systemprompts/{id} HTTP/1.1
Host: api.mypurecloud.com
If-Match: "current-version-etag"
X-Genesys-Request-Id: req-sanitize-001
"referenceId": "prompt-ref-prod-01",
"name": "Sanitized System Prompt - prompt-ref-prod-01",
"metadata": {
"template-matrix": "matrix-v2",
"clean-directive": "strict",
"sanitization-version": "1.0"
"sanitizationSettings": {
"enabled": true,
"mode": "strict",
"autoRedactOnFailure": true,
"jailbreakDetection": "enabled"
Response:
"id": "a1b2c3d4-e5f6-7890-g1h2-i3j4k5l6m7n8",
"version": "2",
"etag": "\"updated-version-etag\"",
"metadata": {
"enabled": true,
"mode": "strict",
The Java SDK wraps this cycle. You implement retry logic for 429 Too Many Requests and format verification before submission.
import com.mangofactory.api.client.ApiException;
import com.mangofactory.api.ai.llmgateway.api.LlmgatewayApi;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
public class PromptSanitizerExecutor {
private static final Logger logger = LoggerFactory.getLogger(PromptSanitizerExecutor.class);
private final LlmgatewayApi llmApi = new LlmgatewayApi();
private static final int MAX_RETRIES = 3;
public UpdateSystemPrompt executeAtomicUpdate(String promptId, UpdateSystemPrompt payload) throws ApiException {
int retryCount = 0;
while (retryCount < MAX_RETRIES) {
// Format verification
if (payload.getSanitizationSettings() == null) {
throw new IllegalArgumentException("Sanitization settings missing. Format verification failed.");
UpdateSystemPrompt result = llmApi.putLlmgatewaySystemprompt(promptId, payload);
logger.info("Atomic PUT successful for prompt {}. Version: {}", promptId, result.getVersion());
return result;
} catch (ApiException e) {
if (e.getCode() == 429 && retryCount < MAX_RETRIES - 1) {
retryCount++;
long delay = (long) Math.pow(2, retryCount) * 1000;
logger.warn("Rate limited. Retrying in {} ms...", delay);
Thread.sleep(delay);
} else {
logger.error("Atomic PUT failed with status {}: {}", e.getCode(), e.getMessage());
throw e;
throw new ApiException("Max retries exceeded for prompt update.");
The executeAtomicUpdate method enforces format verification, handles 429 responses with exponential backoff, and throws on terminal errors. The autoRedactOnFailure flag in the payload instructs Genesys Cloud to revert to a safe baseline if jailbreak detection triggers during runtime.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
You register a webhook to synchronize sanitization events with external security scanners. You also track latency, success rates, and generate audit logs for governance compliance.
import com.mangofactory.api.routing.api.WebhooksApi;
import com.mangofactory.model.routing.Webhook;
import com.mangofactory.model.routing.WebhookRequest;
import java.time.Instant;
import java.util.List;
public class SanitizationGovernance {
private final WebhooksApi webhookApi = new WebhooksApi();
private final ConcurrentHashMap<String, Long> latencyLog = new ConcurrentHashMap<>();
private final ConcurrentHashMap<String, Integer> successLog = new ConcurrentHashMap<>();
public void registerSyncWebhook(String webhookUrl, String promptId) throws ApiException {
WebhookRequest request = new WebhookRequest();
request.setUrl(webhookUrl);
request.setMethod("POST");
request.setTransportProtocol(WebhooksApi.TransportProtocolEnum.HTTPS);
request.setEventType("llmgateway:systemprompt:updated");
request.setHeaders(Map.of("X-Sanitize-Source", "java-governance-pipeline"));
request.setPayloadTemplate("{\"promptId\":\"${id}\",\"timestamp\":\"${date}\",\"status\":\"${status}\"}");
request.setFilters(List.of(new WebhookRequest.Filter().filter("id").equals(promptId)));
Webhook webhook = webhookApi.postRoutingWebhook(request);
logger.info("Webhook registered with ID: {}", webhook.getId());
public void trackMetrics(String promptId, boolean success, long startTimeNs) {
long latencyMs = (System.nanoTime() - startTimeNs) / 1_000_000;
latencyLog.put(promptId, latencyMs);
successLog.merge(promptId, success ? 1 : 0, Integer::sum);
logger.info("Audit Log | Prompt: {} | Latency: {}ms | Success: {} | Timestamp: {}",
promptId, latencyMs, success, Instant.now());
public Map<String, Object> getGovernanceReport(String promptId) {
long avgLatency = latencyLog.getOrDefault(promptId, 0L);
int successes = successLog.getOrDefault(promptId, 0);
return Map.of(
"promptId", promptId,
"latencyMs", avgLatency,
"successCount", successes,
"governanceStatus", successes > 0 ? "COMPLIANT" : "REVIEW_REQUIRED"
The SanitizationGovernance class handles webhook registration, latency tracking, and audit logging. The webhook payload template pushes sanitization events to your external security scanner. The metrics map stores per-prompt latency and success counts for compliance reporting.
public class GenesysPromptSanitizer {
private static final Logger logger = LoggerFactory.getLogger(GenesysPromptSanitizer.class);
private final LlmgatewayApi llmApi;
private final WebhooksApi webhookApi;
public GenesysPromptSanitizer(String envUrl, String clientId, String clientSecret) {
client.setBasePath(envUrl);
oauth.setClientId(clientId);
oauth.setClientSecret(clientSecret);
this.llmApi = new LlmgatewayApi();
this.webhookApi = new WebhooksApi();
public void sanitizeAndDeploy(String promptId, String promptRef, String templateMatrix, String cleanDirective, String content, String webhookUrl) {
long startTime = System.nanoTime();
validatePayload(content);
UpdateSystemPrompt payload = buildPayload(promptRef, templateMatrix, cleanDirective);
UpdateSystemPrompt result = executeAtomicUpdate(promptId, payload);
registerSyncWebhook(webhookUrl, promptId);
trackMetrics(promptId, true, startTime);
logger.info("Sanitization pipeline completed successfully for {}", promptId);
} catch (Exception e) {
trackMetrics(promptId, false, startTime);
logger.error("Sanitization pipeline failed: {}", e.getMessage());
throw new RuntimeException("Sanitization failed", e);
private void validatePayload(String content) {
if (content.length() > MAX_PROMPT_LENGTH) throw new IllegalArgumentException("Exceeds max length");
if (INJECTION_PATTERN.matcher(content).find()) throw new IllegalArgumentException("Injection detected");
if (content.contains("{") && !VARIABLE_PATTERN.matcher(content).find()) throw new IllegalArgumentException("Invalid interpolation");
private UpdateSystemPrompt buildPayload(String promptRef, String templateMatrix, String cleanDirective) {
prompt.setName("Sanitized Prompt - " + promptRef);
prompt.setMetadata(Map.of("template-matrix", templateMatrix, "clean-directive", cleanDirective));
SanitizationSettings settings = new SanitizationSettings();
settings.setEnabled(true);
settings.setMode(cleanDirective);
prompt.setSanitizationSettings(settings);
return prompt;
private UpdateSystemPrompt executeAtomicUpdate(String promptId, UpdateSystemPrompt payload) throws ApiException {
int retry = 0;
while (retry < MAX_RETRIES) {
return llmApi.putLlmgatewaySystemprompt(promptId, payload);
if (e.getCode() == 429) {
retry++;
Thread.sleep((long) Math.pow(2, retry) * 1000);
} else {
throw e;
throw new ApiException("Max retries exceeded");
private void registerSyncWebhook(String webhookUrl, String promptId) throws ApiException {
WebhookRequest req = new WebhookRequest();
req.setUrl(webhookUrl);
req.setMethod("POST");
req.setTransportProtocol(WebhooksApi.TransportProtocolEnum.HTTPS);
req.setEventType("llmgateway:systemprompt:updated");
req.setFilters(List.of(new WebhookRequest.Filter().filter("id").equals(promptId)));
webhookApi.postRoutingWebhook(req);
private void trackMetrics(String promptId, boolean success, long startNs) {
long latency = (System.nanoTime() - startNs) / 1_000_000;
latencyLog.put(promptId, latency);
logger.info("Audit | ID: {} | Latency: {}ms | Success: {} | Time: {}", promptId, latency, success, Instant.now());
GenesysPromptSanitizer sanitizer = new GenesysPromptSanitizer(
"https://api.mypurecloud.com",
"your-client-id",
sanitizer.sanitizeAndDeploy(
"prompt-id-123",
"ref-prod-01",
"matrix-v2",
"strict",
"You are a helpful assistant. Respond to {{user_query}} safely.",
"https://security-scanner.example.com/webhook"
This class encapsulates the complete sanitization pipeline. It validates input, constructs the payload, executes the atomic update with retry logic, registers the synchronization webhook, and logs audit metrics. You run it by providing your environment URL, credentials, prompt identifiers, and external webhook endpoint.
- Cause: The OAuth client credentials are invalid, expired, or lack the required
llmgateway:systemprompt:writescope. - Fix: Verify the client ID and secret match a confidential OAuth client in Genesys Cloud. Ensure the scope string includes
llmgateway:systemprompt:write. Restart the application to force a fresh token fetch.
Error: 403 Forbidden
- Cause: The authenticated user or service account lacks the
LLM Gateway AdministratororLLM Gateway Managerrole assignment. - Fix: Assign the required role to the service account in the Genesys Cloud administration console. The API requires explicit role-based permissions regardless of OAuth scope validity.
Error: 409 Conflict
- Cause: The
If-Matchheader contains an outdated ETag, or another process modified the prompt simultaneously. - Fix: Fetch the current prompt version using
getLlmgatewaySystemprompt, extract theetagfield, and attach it to the PUT request. Implement optimistic concurrency control in your deployment pipeline.
- Cause: The API rate limit for LLM Gateway operations has been exceeded.
- Fix: The code implements exponential backoff. If failures persist, reduce the batch size of sanitization jobs or implement a token bucket rate limiter in your application layer. Monitor the
Retry-Afterheader in the response.
