Sanitize NICE CXone LLM Gateway Responses with Python
  • The code intercepts LLM Gateway outputs, applies PII redaction and toxicity filtering, and returns a compliance verified response.
  • This implementation uses the NICE CXone REST API v2 LLM Gateway endpoints and the httpx library.
  • The tutorial covers Python 3.9+ with strict type hints, schema validation, and production grade error handling.
  • OAuth 2.0 Client Credentials grant with scopes: ai:gateway:write, ai:gateway:read, webhook:write
  • CXone API v2 base URL: https://api-us-1.cxone.com (or your region specific host)
  • Python 3.9+ runtime
  • External dependencies: pip install httpx jsonschema
  • Environment variables: CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, CXONE_BASE_URL, CXONE_WEBHOOK_URL
NICE CXone uses OAuth 2.0 Client Credentials flow. The token expires after one hour, so the implementation caches the token and refreshes it automatically when the expiration window approaches.
import httpx
import os
import logging
import jsonschema
from typing import Dict, Any, Optional, List
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
logger = logging.getLogger("cxone_sanitizer")
@dataclass
class OAuthToken:
    access_token: str
    expires_in: int
    issued_at: float = field(default_factory=time.time)
    @property
    def is_expired(self) -> bool:
        return time.time() >= self.issued_at + self.expires_in - 60
class CXoneAuthManager:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client_id = client_id
        self._token: Optional[OAuthToken] = None
        self._client = httpx.Client(timeout=10.0)
        if self._token and not self._token.is_expired:
            return self._token.access_token
        token_url = f"{self.base_url}/api/v2/oauth/token"
        payload = {
            "client_id": self.client_id,
            "scope": "ai:gateway:write ai:gateway:read webhook:write"
        response = self._client.post(token_url, data=payload)
        response.raise_for_status()
        data = response.json()
        self._token = OAuthToken(
            access_token=data["access_token"],
            expires_in=data["expires_in"]
        logger.info("OAuth token acquired successfully.")
Step 1: Construct Sanitizing Payloads and Validate Gateway Constraints
The LLM Gateway sanitization endpoint requires a structured payload containing a response reference, generation matrix, and filter directive. CXone enforces maximum regex pattern limits to prevent gateway overload. The schema validation step catches malformed payloads before they hit the API.
SANITIZATION_SCHEMA = {
    "type": "object",
    "required": ["responseReference", "generationMatrix", "filterDirective", "content"],
    "properties": {
        "responseReference": {"type": "string", "pattern": "^conv-[a-zA-Z0-9-]+$"},
        "generationMatrix": {
            "type": "object",
            "properties": {
                "model": {"type": "string"},
                "temperature": {"type": "number", "minimum": 0.0, "maximum": 2.0},
                "maxTokens": {"type": "integer", "minimum": 1, "maximum": 4096}
        "filterDirective": {
            "type": "object",
            "properties": {
                "piiPatterns": {"type": "array", "items": {"type": "string"}},
                "toxicityThreshold": {"type": "number", "minimum": 0.0, "maximum": 1.0},
                "maxRegexPatterns": {"type": "integer", "minimum": 1, "maximum": 50}
        "content": {"type": "string", "maxLength": 8000}
class PayloadValidator:
    MAX_REGEX_LIMIT = 50
    @staticmethod
    def validate_and_construct(
        response_ref: str,
        model: str,
        content: str,
        pii_patterns: List[str],
        toxicity_threshold: float
    ) -> Dict[str, Any]:
        if len(pii_patterns) > PayloadValidator.MAX_REGEX_LIMIT:
            raise ValueError(f"PII pattern count {len(pii_patterns)} exceeds gateway limit of {PayloadValidator.MAX_REGEX_LIMIT}")
        payload = {
            "responseReference": response_ref,
                "model": model,
                "temperature": 0.7,
                "maxTokens": 1024
                "piiPatterns": pii_patterns,
                "toxicityThreshold": toxicity_threshold,
                "maxRegexPatterns": PayloadValidator.MAX_REGEX_LIMIT
            "content": content
            jsonschema.validate(instance=payload, schema=SANITIZATION_SCHEMA)
        except jsonschema.exceptions.ValidationError as err:
            raise ValueError(f"Payload failed schema validation: {err.message}")
        logger.info("Payload constructed and validated against gateway constraints.")
        return payload
Step 2: Execute Atomic Sanitization POST with Retry Logic
The sanitization request is an atomic POST operation. The gateway returns toxicity scores, PII matches, and redaction markers. The implementation handles HTTP 429 rate limits with exponential backoff and logs the full request/response cycle for debugging.
class SanitizationExecutor:
    def __init__(self, base_url: str, auth_manager: CXoneAuthManager):
        self.auth = auth_manager
        self._client = httpx.Client(timeout=15.0, follow_redirects=True)
    def submit_sanitization(self, payload: Dict[str, Any], max_retries: int = 3) -> Dict[str, Any]:
        endpoint = f"{self.base_url}/api/v2/ai/gateway/sanitize"
        headers = {
            "Authorization": f"Bearer {self.auth.get_access_token()}",
        attempt = 0
        while attempt < max_retries:
            start_time = time.time()
            response = self._client.post(endpoint, json=payload, headers=headers)
            logger.info(f"POST {endpoint} | Status: {response.status_code} | Latency: {latency_ms:.2f}ms")
            logger.debug(f"Request Payload: {json.dumps(payload, indent=2)}")
            logger.debug(f"Response Body: {response.text}")
            if response.status_code == 200:
                return response.json()
            elif response.status_code == 429:
                retry_after = float(response.headers.get("Retry-After", 2 ** attempt))
                logger.warning(f"Rate limited (429). Retrying in {retry_after}s...")
                time.sleep(retry_after)
                attempt += 1
            else:
        raise RuntimeError("Max retries exceeded for sanitization request.")
Step 3: Process Toxicity Scores, PII Redaction, and Compliance Rules
The gateway response contains a toxicityScore, piiMatches, and redactedContent. The processing step applies automatic redaction triggers when toxicity exceeds the threshold, verifies output formatting, and runs compliance rule checks before exposing the sanitized text.
class ComplianceProcessor:
    REQUIRED_FIELDS = ["sanitizedContent", "toxicityScore", "piiMatches", "complianceStatus"]
    @staticmethod
    def process_gateway_response(response_data: Dict[str, Any]) -> Dict[str, Any]:
        missing = [f for f in ComplianceProcessor.REQUIRED_FIELDS if f not in response_data]
        if missing:
            raise KeyError(f"Gateway response missing required fields: {missing}")
        toxicity_score = response_data["toxicityScore"]
        compliance_status = response_data.get("complianceStatus", "UNKNOWN")
        redacted_content = response_data["sanitizedContent"]
        if toxicity_score >= 0.7:
            logger.warning(f"High toxicity detected: {toxicity_score}. Applying strict redaction override.")
            redacted_content = "[FILTERED: HIGH TOXICITY SCORE]"
            compliance_status = "REJECTED_HIGH_TOXICITY"
        pii_count = len(response_data.get("piiMatches", []))
        if pii_count > 0:
            logger.info(f"PII redaction triggered for {pii_count} matches.")
        output = {
            "originalReference": response_data.get("responseReference", "unknown"),
            "sanitizedContent": redacted_content,
            "toxicityScore": toxicity_score,
            "piiCount": pii_count,
            "complianceStatus": compliance_status,
            "formatValid": ComplianceProcessor._verify_format(redacted_content)
        return output
    @staticmethod
    def _verify_format(content: str) -> bool:
        return isinstance(content, str) and len(content.strip()) > 0 and content != "[FILTERED: HIGH TOXICITY SCORE]"
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
Sanitization events must synchronize with external content moderation APIs via webhooks. The implementation tracks filter success rates, calculates latency, and writes structured audit logs for content governance. Pagination is demonstrated when fetching historical sanitization metrics.
class SanitizationManager:
        self.executor = SanitizationExecutor(base_url, auth_manager)
        self.processer = ComplianceProcessor()
        self._metrics = {"total_requests": 0, "successful_filters": 0, "total_latency_ms": 0.0}
    def sanitize_response(
        self,
        response_ref: str,
        model: str,
        content: str,
        toxicity_threshold: float,
        webhook_url: str
        payload = PayloadValidator.validate_and_construct(
            response_ref, model, content, pii_patterns, toxicity_threshold
        gateway_response = self.executor.submit_sanitization(payload)
        processed = self.processer.process_gateway_response(gateway_response)
        self._metrics["total_requests"] += 1
        self._metrics["total_latency_ms"] += latency_ms
        if processed["complianceStatus"].startswith("APPROVED"):
            self._metrics["successful_filters"] += 1
        self._sync_webhook(webhook_url, processed, latency_ms)
        self._write_audit_log(processed, latency_ms)
        return processed
    def _sync_webhook(self, webhook_url: str, data: Dict[str, Any], latency_ms: float) -> None:
        payload = {
            "eventType": "llm.response.sanitized",
            "timestamp": time.time(),
            "latencyMs": latency_ms,
            "data": data
            resp = self._client.post(webhook_url, json=payload, headers={"Content-Type": "application/json"})
            if resp.status_code >= 400:
                logger.error(f"Webhook sync failed: {resp.status_code} {resp.text}")
            logger.error(f"Webhook sync network error: {e}")
    def _write_audit_log(self, data: Dict[str, Any], latency_ms: float) -> None:
        log_entry = {
            "auditTimestamp": time.strftime("%Y-%m-%dT%H:%M:%SZ", time.gmtime()),
            "reference": data["originalReference"],
            "complianceStatus": data["complianceStatus"],
            "toxicityScore": data["toxicityScore"],
            "piiCount": data["piiCount"],
            "formatValid": data["formatValid"]
        logger.info(f"AUDIT_LOG: {json.dumps(log_entry)}")
    def get_sanitization_metrics(self, page_size: int = 100, page_number: int = 1) -> Dict[str, Any]:
        endpoint = f"{self.executor.base_url}/api/v2/ai/gateway/metrics/sanitization"
        headers = {"Authorization": f"Bearer {self.auth.get_access_token()}"}
        params = {"pageSize": page_size, "pageNumber": page_number}
        response = self._client.get(endpoint, headers=headers, params=params)
The following script combines all components into a runnable module. Replace the environment variables with your CXone tenant credentials before execution.
import os
import json
def main():
    base_url = os.getenv("CXONE_BASE_URL", "https://api-us-1.cxone.com")
    client_id = os.getenv("CXONE_CLIENT_ID")
    client_secret = os.getenv("CXONE_CLIENT_SECRET")
    webhook_url = os.getenv("CXONE_WEBHOOK_URL", "https://webhook.site/test-endpoint")
    if not all([client_id, client_secret]):
        raise EnvironmentError("Missing required CXone credentials in environment variables.")
    auth_manager = CXoneAuthManager(base_url, client_id, client_secret)
    sanitizer = SanitizationManager(base_url, auth_manager)
    test_content = "My SSN is 123-45-6789 and I am very frustrated with this service."
    pii_patterns = [r"\b\d{3}-\d{2}-\d{4}\b", r"\b\d{16}\b"]
    logger.info("Starting LLM Gateway sanitization workflow...")
    result = sanitizer.sanitize_response(
        response_ref="conv-test-001-llm-out",
        model="gpt-4-turbo",
        content=test_content,
        pii_patterns=pii_patterns,
        toxicity_threshold=0.6,
        webhook_url=webhook_url
    logger.info(f"Sanitization complete. Status: {result['complianceStatus']}")
    logger.info(f"Sanitized Output: {result['sanitizedContent']}")
    metrics = sanitizer.get_sanitization_metrics()
    logger.info(f"Gateway Metrics: {json.dumps(metrics, indent=2)}")
    main()
  • Cause: The OAuth token is expired, malformed, or missing required scopes.
  • Fix: Verify CXONE_CLIENT_ID and CXONE_CLIENT_SECRET are correct. Ensure the token request includes ai:gateway:write and ai:gateway:read. The CXoneAuthManager automatically refreshes tokens, but network timeouts during token acquisition will trigger this error. Check the is_expired property logic and ensure system clocks are synchronized.
Error: 400 Bad Request (Schema or Regex Limit Violation)
  • Cause: The payload exceeds maxRegexPatterns (50), contains invalid temperature values, or fails JSON schema validation.
  • Fix: Review the PayloadValidator.validate_and_construct method. The gateway rejects payloads with more than 50 regex patterns to prevent CPU exhaustion. Reduce the pii_patterns list or group patterns using alternation syntax (pattern1|pattern2).
  • Cause: The LLM Gateway enforces rate limits per tenant or per OAuth client.
  • Fix: The SanitizationExecutor.submit_sanitization method implements exponential backoff with Retry-After header parsing. If cascading 429s occur, implement a token bucket rate limiter in your calling service. Do not disable the retry logic.
Error: 500 Internal Server Error or 503 Service Unavailable
  • Cause: Gateway backend overload, model routing failure, or transient CXone infrastructure maintenance.
  • Fix: Verify CXone status page. Implement circuit breaker patterns in production. The atomic POST operation will raise httpx.HTTPError. Wrap the call in a retry loop with jitter if the error persists beyond 30 seconds.
