SAML SSO enforcement breaking Python OAuth Client Credentials flow
Looking for advice on maintaining programmatic access after enforcing SAML SSO for all human users. Our Python automation scripts using the standard OAuth2 client credentials flow (/oauth/token) started failing with 401 Unauthorized immediately after the SAML requirement went live. The docs imply service accounts are exempt, but our app instance seems tied to a user context.
Is there a specific scope or client configuration I need to adjust to bypass the SAML assertion requirement for headless scripts? Here is the minimal reproducible request failing now:
import requests
requests.post(f'{base_url}/oauth/token', data={'grant_type': 'client_credentials', 'client_id': id, 'client_secret': secret})
How I usually solve this is by ensuring the application is strictly decoupled from any user identity, as SAML enforcement often propagates to legacy integrations if not scoped correctly. Here is how I configure the pipeline in my Glue jobs to maintain stable access:
  1. Verify the application is a “Non-interactive” type in the Genesys Cloud admin console. Interactive apps are forced through SAML.
  2. Ensure your client credentials token request uses the client_credentials grant type exclusively. Do not attempt to refresh a user-derived token.
  3. Implement a custom token refresh callback in the Python SDK to handle expiration silently during the ETL run.
from genesyscloud.platform_client import PureCloudPlatformClientV2
def on_token_refresh(refresh_token, new_token):
 # Persist new_token to your secure storage or environment variable
 pass
platform_client = PureCloudPlatformClientV2(
 client_id='your_client_id',
 client_secret='your_client_secret',
 refresh_token_callback=on_token_refresh
This pattern ensures the service account remains authentic via OAuth2 without triggering the SAML assertion check.
If I remember right, the issue stems from the OAuth client being inadvertently linked to a human user identity rather than a dedicated service account. SAML enforcement applies to interactive sessions, but client_credentials should bypass it if the client is strictly non-interactive.
Check your OAuth client settings in the Admin console. Ensure the “User” field is empty or set to a dedicated service account with admin:api-token:manage scopes. Here is the Python snippet to verify the token request structure:
import requests
token_url = "https://api.mypurecloud.com/oauth/token"
payload = {
 "client_id": "YOUR_CLIENT_ID",
 "client_secret": "YOUR_CLIENT_SECRET",
 "scope": "admin:api-token:manage"
response = requests.post(token_url, data=payload, headers=headers)
print(response.json())
Verify the client type is “Non-interactive” in the UI. See this support article for details on SAML scoping: https://support.genesyscloud.com/articles/saml-oauth-exceptions.
You should probably look at at the specific OAuth client configuration. The suggestion above is correct, but the implementation details matter. If your Python script is still failing, you are likely hitting a scope mismatch or the client is still associated with an interactive user session.
  1. Verify Client Type. Go to Admin > Security > OAuth Clients. Ensure the application is set to Non-interactive. Interactive clients are forced through SAML by design.
  2. Check Associated User. The “User” field must be empty or point to a dedicated service account that has no human login credentials. If it points to a real user, SAML enforcement blocks the token request.
  3. Validate Scopes. Ensure the client has offline_access and the specific resource scopes (e.g., analytics:reports:view). Missing scopes cause 401s that look like SAML failures.
Here is the working Python snippet using requests to bypass the SAML block:
import requests
# Use your Client ID and Secret from the Non-interactive app
client_id = "your_client_id"
client_secret = "your_client_secret"
payload = {
 "client_id": client_id,
 "client_secret": client_secret,
 "scope": "analytics:reports:view offline_access"
response = requests.post(url, data=payload)
if response.status_code == 200:
 token = response.json().get("access_token")
 print("Token acquired successfully.")
else:
 print(f"Failed: {response.status_code} - {response.text}")
Key takeaway: The client_credentials grant type does not send a user assertion. It relies entirely on the client identity. If SAML is blocking it, the client identity is misconfigured. Do not mix user contexts with service accounts.
This is typically caused by the OAuth client still being linked to a human user identity rather than a pure service account.
# Ensure your client is Non-interactive in Admin > Security > OAuth Clients
# No user association allowed for client_credentials grant type
I deploy these via Terraform workspaces to prevent manual drift. If you bind it to a user, SAML enforcement will always block the token request.
