SAML SSO breaks OAuth Client Credentials flow?
We pushed SAML SSO for agents. Now our backend service using OAuth Client Credentials gets 401 Unauthorized. The service account has the right scope. Is SAML blocking non-user auth? Need a workaround for programmatic access without disabling SAML.
It’s actually a common misunderstanding. SAML configuration only affects user login flows, like when agents sign in via the UI or the WebRTC client. The OAuth Client Credentials flow is completely separate and relies on your org’s API keys. If you’re getting a 401, it’s likely because the client ID or secret was rotated during the SAML setup, or the service account was inadvertently disabled.
Check your service account status in Admin > Users. Ensure it’s still active and hasn’t been locked. Then verify the credentials. Here’s a quick curl test to isolate the issue:
curl -X POST "https://api.mypurecloud.com/oauth/token" \
 -H "Content-Type: application/x-www-form-urlencoded" \
 -d "grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET&scope=urn:genesys:cloud:admin"
If this fails, double-check the scope permissions. Sometimes admin changes during SAML migration reset API access policies. You might also want to rotate the secret just to be safe. It’s weird how these configs get tangled up.
You might want to double-check the client secret rotation. It’s easy to miss that step during a bulk SAML migration, and the error message doesn’t always make the cause obvious. If the credentials are valid, the issue could be related to how the token endpoint is being called. Sometimes the base URL changes slightly depending on the deployment region, which throws off the request.
Here’s a quick curl command to verify the token generation directly:
curl -X POST "https://api.mypurecloud.com/api/v2/oauth/token" \
 -d "grant_type=client_credentials&client_id=YOUR_CLIENT_ID&client_secret=YOUR_CLIENT_SECRET"
If this returns a 200, the problem is likely in your application code handling the token or the subsequent API call. If it returns a 401, check the Admin console for the service account status. Also, ensure the client isn’t restricted to specific IP ranges, which can happen after security policy updates.
