We just flipped the switch to enforce SAML SSO for our CXone org. Human users are fine, logging in via IdP as expected. Our backend services are broken though.
We have a dedicated service account that uses the client_credentials grant to fetch tokens for our DFO custom channel integrations. Since the SAML mandate went live, the token endpoint is returning a 401 Unauthorized.
Here’s the request body we’re sending:
"client_id": "my-service-client-id",
"client_secret": "my-secret"
The response is generic:
"error": "unauthorized",
"error_description": "Invalid grant type"
I’ve checked the SAML config in Admin. The service account isn’t assigned to any SAML entity, but it seems the org-level setting is overriding it. Do I need to whitelist the client_id in the SAML settings? Or is there a specific flag in the API call to bypass SAML for machine-to-machine auth? Docs are silent on this edge case.
The documentation states client_credentials flows should be unaffected by SAML SSO enforcement, so a 401 usually indicates an issue with the service account itself - potentially a problem during user provisioning or permission changes. First, verify the service account still possesses the oauth:write permission and hasn’t been disabled within the CXone Admin portal.
Here’s a Node.js snippet using the CXone APIs to troubleshoot the token request, and capture the full error payload. The standard error messages can be a bit vague, so logging the raw response body is crucial.
const cxoneApi = require('cxone-api');
async function checkServiceAccountToken() {
const tokenResponse = await cxoneApi.oauth.getToken({
client_id: process.env.CXONE_CLIENT_ID,
client_secret: process.env.CXONE_CLIENT_SECRET,
scope: 'oauth:write'
console.log('Token acquired successfully:', tokenResponse.access_token.substring(0, 20) + '...');
} catch (error) {
console.error('Token request failed:', error.status, error.data);
checkServiceAccountToken();
If the error indicates invalid_client, the client secret may have been rotated or the client registration corrupted. If it’s unauthorized_client, the service account is likely blocked or lacks the necessary OAuth client permissions in CXone organization settings. Try revoking and regenerating the client secret to rule out credential issues. Also, review the OAuth Client configuration in CXone Admin - confirm the client ID and secret are correct and active. Finally, check the service account’s assigned roles and permissions to ensure it still has the necessary OAuth access.
The 401 error strongly suggests a permission or account status issue, not necessarily a direct conflict with the SAML enforcement. The client_credentials flow is designed to bypass SSO.
We encountered a similar problem with our New Relic integrations during a SAML rollout. The provisioning sync unintentionally disabled the service account. The account existed, but was flagged as inactive in the backend.
To diagnose this, use the CXone APIs to inspect the service account. Specifically, use GET /api/v2/users/{userId} to retrieve the user object. Check the enabled field. If it’s false, re-enable the account. Also, verify the roles array contains the necessary permissions for your DFO channel integration.
Here’s a snippet using the CXone Node SDK to test the token acquisition:
const cxone = require('cxone-node-sdk');
const platformClient = cxone.ApiClient.instance;
platformClient.setAuthMode('client_credentials');
platformClient.setAuthData({
clientId: 'YOUR_SERVICE_ACCOUNT_CLIENT_ID',
clientSecret: 'YOUR_SERVICE_ACCOUNT_CLIENT_SECRET'
platformClient.oauthClient.createOAuthToken({
scope: 'cxone:oauth:write'
}).then(res => {
console.log('Token acquired:', res.body.access_token.substring(0, 20) + '...');
}).catch(err => {
console.error('Auth failed:', err.body.message);
This snippet isolates credential validity. Remember to handle client ID and secret according to GDPR Article 32.
