Salesforce Classic Integration Using Gplus adapter Login Issue
Hi All,
We are facing issues during the integration of Genesys and Salesforce using Gplus adapter for salesforce.
Genesys Websevices version : 8.5.2
Salesforce version : Classic
Genesys Webeservices is deployed and the adapter opening in Browser using the URL : http://xx.xxx.xxx.xxx:xxxx/ui/crm-adapter/index.html?crm=salesforce
Similarly the Adapter is loaded successfully into Salesforce Classic version.
When the Agent login credentilas are entered to login , we are facing issue in Jetty Cloud log,
01/12/2017 05:53:25.812 WARN [TestAgent] [DIMJoQ0oryXRoD6V0G60oQhi2abp5cqd6u142ra70mdeilx] [9e126b00-d3d2-462e-a65d-0f902a83e5a2] [qtp944905881-25] /api/v2/me subresources=features,devices,channels c.g.c.v.a.s.e.WebApiExceptionHandlerV2 http://10.255.144.152:8090/ui/crm-adapter/index.html?sfdcIFrameOrigin=https%3A%2F%2Fc.cs24.visual.force.com&nonce=63e0a4fc77bf60c91a7da7aa7ab6ce3843ddae41aad7968897cb463b0cd97e72& Operation forbidden
com.genesyslab.cloud.v2.exceptions.OperationForbiddenException: Unsupported feature
at com.genesyslab.cloud.v2.api.springintegration.interceptors.FeatureSupportInterceptorV2.preHandle(FeatureSupportInterceptorV2.java:56) ~[gws.jar!/:8.5.2]
at com.genesyslab.cloud.v2.api.springintegration.interceptors.FeatureSupportInterceptorV2$$FastClassBySpringCGLIB$$d2738970.invoke() ~[gws.jar!/:8.5.2]
Need Suggestion
Do you need to use GPlus adapter? Is it for popup only or do you also do co-browsing / chat as well?
We found it much easier and cheaper to use a third-party OpenCTI adapter. At least for popup.
