Running the Genesys tech tutorials on winxp....
Hey,
Ive just installed a fresh windows xp machine and am trying to run the tech tutes downloaded from the support site. I have java installed, but the presentation sticks with “waiting on media stream” in the mini player window.
Any ideas how to get these working?
Windows media player updated and codecs?
Yes, I can navigate to the audio file and plays fine so Im thinking the media player part of it is fine. Possibly a javascript error, but Ive set the security to lowest and enabled all script running etc
Maybe a IE version issue? What happens if you enable Java error console?
Just built a windows XP original with no service pack and ie6 and its working now. Must be a version issue with later IE…
Thanks for the help C
Where on the support site are they?
ill check it on my end for you
