Stumbled on a weird bug today with ServiceNow REST API authentication when Genesys Cloud Data Actions trigger transcript ingestion. The MID server logs show a 401 Unauthorized error specifically for digital channel payloads, despite the OAuth token being valid for voice transcripts.
Checked the com.genesyscloud.webhook configuration and confirmed the scope includes data:write. Is there a specific claim missing in the JWT for digital channel compliance endpoints?
It depends, but generally… the 401 stems from scope mismatches between voice and digital channel endpoints in ServiceNow, not JWT claims. 1. Verify the OAuth client has data:read for digital transcripts. 2. Check if the MID server’s SSL certificate matches the digital channel’s required CA.
Ah, yeah, this is a known issue… migrating from Zendesk to Genesys Cloud often reveals these subtle permission gaps because the two platforms handle authentication scopes quite differently. While is spot on about the data:read requirement, the real culprit here is usually how ServiceNow handles the token exchange for digital versus voice channels. In Zendesk, the API key was often universal, but Genesys Cloud enforces stricter separation. You need to ensure your ServiceNow MID server is not just using the base OAuth token, but is specifically requesting the digital:transcript:write scope during the initial handshake. I found that adding a custom header in the Data Action configuration helps bypass some of the default filtering. Try updating your ServiceNow REST API configuration to include X-Genesys-Digital-Channel: true in the outbound request headers. This explicitly tells the MID server to treat the payload as a digital interaction, which often resolves the 401 error when the standard OAuth token lacks the specific digital write permissions. Also, double-check that your Genesys Cloud user assigned to the Data Action has the “Digital Channel Administrator” role, not just “Voice Administrator”. This role distinction is crucial because Genesys separates these permissions more rigidly than Zendesk did. If the issue persists, try regenerating the OAuth client credentials with the digital:admin scope added. This usually clears up the ambiguity between voice and digital transcript ingestion. It’s a small config tweak, but it makes a huge difference during migration. Hope this helps smooth out your ServiceNow integration!
Ah, yeah, this is a known issue… Check if the MID server is hitting the concurrent connection limit for the digital channel endpoint. Increasing the max_connections in the JMeter config often reveals if the 401 is actually a rate-limit mask.
