Running into a weird bug with BYOC Edge SIP Trunk registration failures
Dealing with a very strange bug here with our BYOC Edge deployment in the Paris region. The SIP trunks fail to register with the Genesys Cloud platform after the recent firmware update. The Edge logs show a 403 Forbidden response when attempting to authenticate with the SIP proxy. The configuration matches our other successful edges. Any insights on what might be causing this authentication rejection?
SIP REGISTER failed: 403 Forbidden - Authentication required for realm 'genesys.cloud'
Make sure you verify that the SIP credentials stored in your Edge configuration are not stale or mismatched against the current Genesys Cloud tenant settings. A 403 Forbidden response during SIP REGISTER usually indicates that the authentication credentials (username/password) or the realm configuration are incorrect, rather than a network connectivity issue. Since you mentioned the configuration matches other successful edges, the discrepancy likely lies in how the credentials were injected or refreshed during the firmware update process.
In many BYOC deployments, the Edge service relies on environment variables or a specific JSON configuration file for SIP registration. Check the sip_trunk_credentials section in your Edge deployment manifest. Ensure the username matches the exact SIP user created in Genesys Cloud Administration > Voice > SIP Trunks, and that the password corresponds to the latest generated secret. If you recently rotated secrets in Genesys Cloud, the Edge must be restarted to pick up the new values.
Additionally, verify the realm parameter. The error log explicitly mentions realm 'genesys'. Ensure your SIP client configuration on the Edge explicitly sets the realm to genesys.com or the specific domain provided by your Genesys Cloud tenant. Mismatched realms cause the SIP proxy to reject the authentication challenge immediately.
You can test this manually by generating a new SIP credential in Genesys Cloud and updating the Edge configuration directly. Use the following snippet in your Edge config file:
 "sip_trunk": {
 "username": "your_sip_user",
 "password": "new_generated_secret",
 "realm": "genesys.com",
 "outbound_proxy": "sip.genesys.cloud"
After updating, restart the Edge service to force a new registration attempt. Monitor the logs for a 200 OK response.
Warning: Ensure you are using the correct tenant-specific SIP proxy address. Using a generic or outdated proxy endpoint can also result in authentication failures if the request is routed to the wrong cluster. Always validate the proxy URL in the Genesys Cloud SIP Trunk details.
It’s worth reviewing at the timestamp of your last schedule publish. We’ve seen BYOC auth tokens refresh or invalidate unexpectedly right after weekly schedule deployments in the Chicago region.
Check if the trunk registration retry logic needs a manual kickstart via the admin console.
I’d suggest checking out at the concurrent connection spikes. Even with correct creds, the SIP proxy can reject registrations if the platform API is rate limited by other traffic.
Check your JMeter logs for 429s on the websocket endpoint during the same window. High API throughput often causes collateral auth failures on BYOC edges.
