Running GAD on local machine
I am wanting to do some GAD customization development on my local machine (Windows XP SP2). I’ve imported the GAD war file into Eclipse to set up a new project and I am running Tomcat 6.0. When I deploy the app into tomcat and start it up, I get the following error:
ConfigServiceException (Config is Already Running)
at com.genesyslab.ail.core.AilModule.start(AilModule.java:679)
at com.genesyslab.ail.core.AilFactoryImpl.init(AilFactoryImpl.java:261)
at com.genesyslab.ail.core.AilModule.start(AilModule.java:1124)
at com.genesyslab.ail.AilLoader.getAilFactory(AilLoader.java:310)
at com.genesyslab.uadthin.InitBusinessLogic.run(InitBusinessLogic.java:96)
Connection failed : Another AIL application is already running.
04 01 12:41:53:562 [ Init Ail Logic] WARN GD.Init AIL is not initialized: Already Running
The thing is, I don’t have any other Genesys applications running or anything, so I don’t know why it says the Config is already running. I have seen this error on server machines before too. If anyone has any ideas, please let me know.
OK, I think I figured this one out on my own. I was connecting to an existing environment that happened to have another instance of the same GAD application running on a different machine. When I shutdown the existing GAD, I was able to start mine up from my machine.
