Routing NICE CXone WebSockets Binary Frames with TypeScript
  • You will build a TypeScript WebSocket router that constructs, validates, and dispatches binary frames to NICE CXone real-time streaming endpoints.
  • You will use the CXone OAuth 2.0 authentication flow and the wss://platformprod.eapi.us-east-1.nicecxone.com/api/v2/analytics/events/stream WebSocket endpoint for context.
  • You will implement this in TypeScript with Node.js 18+ using modern async/await patterns.
  • OAuth client type: Client Credentials or JWT Bearer
  • Required scopes: analytics:events:read, custom:integrations:write, websocket:stream:access
  • API version: CXone Platform API v2
  • Runtime: Node.js 18+, TypeScript 5.0+
  • External dependencies: npm install ws axios zod uuid
CXone requires a valid bearer token for all platform interactions. The router retrieves and caches tokens using the Client Credentials flow. The implementation includes exponential backoff for 429 rate-limit responses and automatic expiration tracking.
import axios, { AxiosError } from 'axios';
import { setTimeout } from 'timers/promises';
interface OAuthConfig {
  clientId: string;
  clientSecret: string;
  grantType: 'client_credentials' | 'urn:ietf:params:oauth:grant-type:jwt-bearer';
  audience?: string;
  assertion?: string;
  region: string;
class CXoneAuthManager {
  private token: string | null = null;
  private expiresAt: number = 0;
  private readonly TOKEN_ENDPOINT = `https://platformprod.eapi.${this.config.region}.nicecxone.com/oauth/token`;
  private readonly MAX_RETRIES = 3;
  constructor(private config: OAuthConfig) {}
  async getAccessToken(): Promise<string> {
    if (this.token && Date.now() < this.expiresAt) {
      return this.token;
    const payload: Record<string, string> = {
      grant_type: this.config.grantType,
      client_id: this.config.clientId,
      client_secret: this.config.clientSecret,
    if (this.config.grantType === 'urn:ietf:params:oauth:grant-type:jwt-bearer') {
      payload.audience = this.config.audience || 'https://platformprod.eapi.us-east-1.nicecxone.com';
      payload.assertion = this.config.assertion || '';
    let lastError: Error | null = null;
    for (let attempt = 1; attempt <= this.MAX_RETRIES; attempt++) {
        const response = await axios.post(this.TOKEN_ENDPOINT, payload, {
          timeout: 5000,
        this.token = response.data.access_token;
        this.expiresAt = Date.now() + (response.data.expires_in * 1000) - 10000;
        return this.token;
      } catch (error) {
        lastError = error as Error;
        const axiosError = error as AxiosError;
        if (axiosError.response?.status === 429) {
          const waitTime = Math.pow(2, attempt) * 1000;
          await setTimeout(waitTime);
          continue;
        break;
    throw new Error(`Authentication failed after ${this.MAX_RETRIES} attempts: ${lastError?.message}`);
OAuth Scope Requirement: The token must include websocket:stream:access and analytics:events:read to establish the WebSocket handshake and receive routing context.
Step 1: WebSocket Client Initialization & Token Management
The WebSocket client initializes with the bearer token injected into the connection headers. CXone enforces strict handshake validation. The client implements reconnection logic and tracks connection state for audit purposes.
import WebSocket, { WebSocketConnectOpts, RawData } from 'ws';
import { CXoneAuthManager } from './auth';
interface WebSocketClientConfig {
  url: string;
  authManager: CXoneAuthManager;
  maxReconnectAttempts: number;
  reconnectDelayMs: number;
class CXoneWebSocketClient {
  private ws: WebSocket | null = null;
  private isConnected: boolean = false;
  private reconnectAttempts: number = 0;
  private readonly MAX_FRAME_SIZE = 65535;
  constructor(private config: WebSocketClientConfig) {}
  async connect(): Promise<void> {
    const token = await this.config.authManager.getAccessToken();
    const options: WebSocketConnectOpts = {
      headers: {
        Authorization: `Bearer ${token}`,
        'User-Agent': 'CXone-FRameRouter/1.0',
      handshakeTimeout: 10000,
      perMessageDeflate: true,
    this.ws = new WebSocket(this.config.url, options);
    this.ws.on('open', () => {
      this.isConnected = true;
      this.reconnectAttempts = 0;
      console.log('[WS] Connected to CXone streaming endpoint');
    this.ws.on('close', (code, reason) => {
      this.isConnected = false;
      console.warn(`[WS] Closed: ${code} - ${reason}`);
      this.handleReconnect();
    this.ws.on('error', (error) => {
      console.error('[WS] Connection error:', error.message);
    this.ws.on('message', (data: RawData, isBinary: boolean) => {
      this.handleInboundFrame(data, isBinary);
  private handleReconnect(): void {
    if (this.reconnectAttempts >= this.config.maxReconnectAttempts) {
      console.error('[WS] Max reconnection attempts reached');
      return;
    this.reconnectAttempts++;
    setTimeout(() => this.connect(), this.config.reconnectDelayMs * this.reconnectAttempts);
  private handleInboundFrame(data: RawData, isBinary: boolean): void {
    // Process inbound frames from CXone (ACKs, routing directives, or streaming data)
    const payload = isBinary ? data : data.toString();
    console.log(`[WS] Received ${isBinary ? 'binary' : 'text'} frame (${Buffer.byteLength(payload)} bytes)`);
  getSocket(): WebSocket | null {
    return this.ws;
  get isConnected(): boolean {
    return this.isConnected;
OAuth Scope Requirement: websocket:stream:access is required for the initial handshake. The Authorization header must contain a valid bearer token.
Step 2: Route Payload Construction & Schema Validation
Route payloads must reference a unique frame ID, specify an opcode matrix, define a destination directive, and carry the binary payload. The schema validates against WebSocket engine constraints and maximum frame size limits before dispatch. Destination reachability is verified through a pre-flight pipeline.
import { z } from 'zod';
import { Buffer } from 'buffer';
export interface OpcodeMatrix {
  primary: number;
  continuation: number;
  close: number;
export interface DestinationDirective {
  endpoint: string;
  protocol: 'wss' | 'ws';
  verified: boolean;
  latencyMs: number;
export interface RoutePayload {
  frameId: string;
  opcodeMatrix: OpcodeMatrix;
  destinationDirective: DestinationDirective;
  payload: Buffer;
  metadata: Record<string, unknown>;
const ROUTE_SCHEMA = z.object({
  frameId: z.string().uuid(),
  opcodeMatrix: z.object({
    primary: z.number().min(0).max(255),
    continuation: z.number().min(0).max(255),
    close: z.number().min(0).max(255),
  destinationDirective: z.object({
    endpoint: z.string().url(),
    protocol: z.enum(['wss', 'ws']),
    verified: z.boolean(),
    latencyMs: z.number().nonnegative(),
  payload: z.instanceof(Buffer),
  metadata: z.record(z.unknown()),
export class RouteValidator {
  async validateRoute(route: RoutePayload): Promise<{ valid: boolean; errors: string[] }> {
    const errors: string[] = [];
    // Schema validation
    const schemaResult = ROUTE_SCHEMA.safeParse(route);
    if (!schemaResult.success) {
      errors.push(...schemaResult.error.errors.map(e => e.message));
      return { valid: false, errors };
    // WebSocket engine constraints
    if (route.payload.length > this.MAX_FRAME_SIZE && !route.destinationDirective.verified) {
      errors.push('Payload exceeds maximum frame size and destination fragmentation support is unverified');
    // Destination reachability verification pipeline
    if (!route.destinationDirective.verified) {
      errors.push('Destination directive failed reachability verification pipeline');
    if (route.destinationDirective.latencyMs > 2000) {
      errors.push('Destination latency exceeds acceptable threshold for atomic routing');
    return { valid: errors.length === 0, errors };
  get maxFrameSize(): number {
    return this.MAX_FRAME_SIZE;
OAuth Scope Requirement: No direct API call is made in this step, but the destination directive must point to an endpoint accessible with analytics:events:read or custom:integrations:write.
Step 3: Frame Dispatch, Fragmentation & Atomic SEND
The dispatcher ensures atomic SEND operations by queueing frames and verifying format before transmission. Payloads exceeding the maximum frame size trigger automatic fragmentation with continuation opcodes. Each dispatch operation records latency and success status.
import { CXoneWebSocketClient } from './ws-client';
import { RoutePayload, RouteValidator } from './validator';
interface DispatchResult {
  frameId: string;
  success: boolean;
  latencyMs: number;
  fragmented: boolean;
  chunksSent: number;
  error?: string;
export class FrameDispatcher {
  private queue: RoutePayload[] = [];
  private isProcessing: boolean = false;
  private readonly validator: RouteValidator;
  constructor(
    private client: CXoneWebSocketClient,
    validator: RouteValidator = new RouteValidator()
    this.validator = validator;
  async enqueueRoute(route: RoutePayload): Promise<DispatchResult> {
    const validation = await this.validator.validateRoute(route);
    if (!validation.valid) {
        frameId: route.frameId,
        success: false,
        latencyMs: 0,
        fragmented: false,
        chunksSent: 0,
        error: `Validation failed: ${validation.errors.join('; ')}`,
    this.queue.push(route);
    if (!this.isProcessing) {
      await this.processQueue();
    // Wait for processing completion for this specific frame
    return new Promise<DispatchResult>((resolve) => {
      const checkQueue = setInterval(() => {
        if (this.queue.length === 0) {
          clearInterval(checkQueue);
          // In a production system, you would correlate via frameId tracking
          resolve({
            success: true,
            latencyMs: 0,
            fragmented: route.payload.length > this.validator.maxFrameSize,
            chunksSent: Math.ceil(route.payload.length / this.validator.maxFrameSize),
      }, 50);
  private async processQueue(): Promise<void> {
    this.isProcessing = true;
    const socket = this.client.getSocket();
    while (this.queue.length > 0 && socket?.readyState === WebSocket.OPEN) {
      const route = this.queue.shift();
      if (!route) continue;
      const startTime = Date.now();
        if (route.payload.length > this.validator.maxFrameSize) {
          await this.sendFragmented(route, socket);
        } else {
          await this.sendAtomic(route, socket);
        const latency = Date.now() - startTime;
        console.log(`[DISPATCH] Frame ${route.frameId} sent in ${latency}ms`);
      } catch (error) {
        console.error(`[DISPATCH] Frame ${route.frameId} failed:`, (error as Error).message);
    this.isProcessing = false;
  private sendAtomic(route: RoutePayload, socket: WebSocket): void {
    socket.send(route.payload, { binary: true, mask: true });
  private async sendFragmented(route: RoutePayload, socket: WebSocket): Promise<void> {
    const chunks = this.fragmentPayload(route.payload);
    for (let i = 0; i < chunks.length; i++) {
      const isLast = i === chunks.length - 1;
      socket.send(chunks[i], {
        binary: true,
        mask: true,
        // WebSocket fragmentation is handled natively by the ws library when sending large buffers,
        // but we explicitly track continuation logic for audit compliance
        opcode: isLast ? 0x02 : 0x00,
      await new Promise(resolve => setTimeout(resolve, 10)); // Throttle to prevent buffer overflow
  private fragmentPayload(buffer: Buffer): Buffer[] {
    const fragments: Buffer[] = [];
    const size = this.validator.maxFrameSize;
    for (let offset = 0; offset < buffer.length; offset += size) {
      fragments.push(buffer.subarray(offset, offset + size));
    return fragments;
OAuth Scope Requirement: custom:integrations:write is required if the destination directive routes to a custom CXone integration endpoint.
Step 4: Routing Metrics, Audit Logs & Broker Sync
The router tracks latency, delivery success rates, and generates audit logs for transport governance. Routing events synchronize with external message brokers via configurable webhooks. The sync pipeline implements retry logic for 429 rate limits and 5xx server errors.
import { DispatchResult } from './dispatcher';
import { setTimeout } as delay from 'timers/promises';
interface AuditLog {
  timestamp: string;
  frameId: string;
  success: boolean;
  latencyMs: number;
  chunksSent: number;
  error?: string;
interface RouterMetrics {
  totalFrames: number;
  successfulFrames: number;
  failedFrames: number;
  averageLatencyMs: number;
  lastSyncTimestamp: string | null;
export class RoutingGovernance {
  private metrics: RouterMetrics = {
    totalFrames: 0,
    successfulFrames: 0,
    failedFrames: 0,
    averageLatencyMs: 0,
    lastSyncTimestamp: null,
  private auditLog: AuditLog[] = [];
  private readonly MAX_AUDIT_LOG_SIZE = 10000;
  constructor(private webhookUrl: string) {}
  async recordDispatch(result: DispatchResult): Promise<void> {
    this.metrics.totalFrames++;
    const logEntry: AuditLog = {
      frameId: result.frameId,
      success: result.success,
      latencyMs: result.latencyMs,
      fragmented: result.fragmented,
      chunksSent: result.chunksSent,
      error: result.error,
    if (result.success) {
      this.metrics.successfulFrames++;
      this.metrics.averageLatencyMs =
        ((this.metrics.averageLatencyMs * (this.metrics.totalFrames - 1)) + result.latencyMs) / this.metrics.totalFrames;
    } else {
      this.metrics.failedFrames++;
    this.auditLog.push(logEntry);
    if (this.auditLog.length > this.MAX_AUDIT_LOG_SIZE) {
      this.auditLog = this.auditLog.slice(-this.MAX_AUDIT_LOG_SIZE / 2);
    await this.syncToBroker(logEntry);
  private async syncToBroker(entry: AuditLog): Promise<void> {
    const maxRetries = 3;
    for (let attempt = 1; attempt <= maxRetries; attempt++) {
        await axios.post(this.webhookUrl, entry, {
          timeout: 3000,
        this.metrics.lastSyncTimestamp = new Date().toISOString();
        return;
      } catch (error) {
        if (axiosError.response?.status === 429 || (axiosError.response?.status ?? 0) >= 500) {
          await delay(Math.pow(2, attempt) * 500);
          continue;
        break;
    console.error(`[GOVERNANCE] Broker sync failed for ${entry.frameId}: ${lastError?.message}`);
  getMetrics(): RouterMetrics {
    return { ...this.metrics };
  getDeliverySuccessRate(): number {
    if (this.metrics.totalFrames === 0) return 0;
    return (this.metrics.successfulFrames / this.metrics.totalFrames) * 100;
  exportAuditLog(): AuditLog[] {
    return [...this.auditLog];
OAuth Scope Requirement: custom:integrations:write is required for webhook synchronization if the broker endpoint is hosted within the CXone tenant boundary.
The following module combines authentication, validation, dispatch, and governance into a single automated frame router. Replace the placeholder credentials and webhook URL before execution.
import { FrameDispatcher } from './dispatcher';
import { RoutingGovernance } from './governance';
async function main() {
  // 1. Initialize Authentication
  const authManager = new CXoneAuthManager({
    clientId: process.env.CXONE_CLIENT_ID || '',
    clientSecret: process.env.CXONE_CLIENT_SECRET || '',
    grantType: 'client_credentials',
    region: 'us-east-1',
  // 2. Initialize WebSocket Client
  const wsClient = new CXoneWebSocketClient({
    url: 'wss://platformprod.eapi.us-east-1.nicecxone.com/api/v2/analytics/events/stream',
    authManager,
    maxReconnectAttempts: 5,
    reconnectDelayMs: 2000,
  await wsClient.connect();
  // 3. Initialize Router Components
  const validator = new RouteValidator();
  const dispatcher = new FrameDispatcher(wsClient, validator);
  const governance = new RoutingGovernance(process.env.BROKER_WEBHOOK_URL || 'https://webhook.site/your-id');
  // 4. Construct and Route Sample Binary Frame
  const samplePayload = Buffer.alloc(70000, 0x41); // 70KB binary payload to trigger fragmentation
  const route: RoutePayload = {
    frameId: '550e8400-e29b-41d4-a716-446655440000',
    opcodeMatrix: {
      primary: 0x02,
      continuation: 0x00,
      close: 0x08,
    destinationDirective: {
      endpoint: 'wss://platformprod.eapi.us-east-1.nicecxone.com/api/v2/analytics/events/stream',
      protocol: 'wss',
      verified: true,
      latencyMs: 45,
    payload: samplePayload,
    metadata: {
      source: 'automated-router',
      priority: 'high',
      timestamp: Date.now(),
  console.log('[ROUTER] Dispatching frame...');
  const result = await dispatcher.enqueueRoute(route);
  await governance.recordDispatch(result);
  console.log('[ROUTER] Dispatch result:', result);
  console.log('[ROUTER] Delivery success rate:', governance.getDeliverySuccessRate().toFixed(2) + '%');
  console.log('[ROUTER] Audit log entries:', governance.exportAuditLog().length);
  // Graceful shutdown after 5 seconds
  setTimeout(() => {
    console.log('[ROUTER] Shutting down...');
    process.exit(0);
  }, 5000);
main().catch(error => {
  console.error('[ROUTER] Fatal error:', error);
  process.exit(1);
  • What causes it: The bearer token expired, the client credentials are invalid, or the token lacks the required websocket:stream:access scope. CXone rejects handshakes with missing or malformed authorization headers.
  • How to fix it: Verify the OAuth client credentials in the CXone administration console. Ensure the token request includes the exact scope string. Implement token refresh logic that checks expiration ten seconds before the expires_in timestamp.
  • Code showing the fix: The CXoneAuthManager class already implements expiration tracking and automatic re-fetching. Ensure getAccessToken() is called immediately before connection and after any 401 response.
Error: 1008 Policy Violation or 1009 Message Too Big
  • What causes it: The binary frame exceeds the WebSocket engine maximum frame size limit without proper fragmentation headers, or the destination directive points to an endpoint that rejects large payloads.
  • How to fix it: Enable automatic fragmentation in the dispatcher. Verify the destinationDirective.verified flag is true only after confirming the endpoint supports continuation frames. Reduce payload size or split into smaller logical chunks before routing.
  • Code showing the fix: The FrameDispatcher.sendFragmented() method splits payloads exceeding MAX_FRAME_SIZE into 65535-byte chunks with continuation opcodes. Ensure the ws library configuration includes perMessageDeflate: true and appropriate buffer limits.
Error: 429 Too Many Requests during Broker Sync
  • What causes it: The external message broker or webhook endpoint enforces rate limits on incoming routing audit events. Rapid frame dispatches can cascade into sync failures.
  • How to fix it: Implement exponential backoff retry logic. Batch audit log entries before posting to the broker. Add a queue buffer in the RoutingGovernance class to throttle outbound webhook calls.
  • Code showing the fix: The syncToBroker() method includes a retry loop with Math.pow(2, attempt) * 500 delay for 429 and 5xx responses. Increase the base delay or add a sliding window rate limiter if the broker enforces strict quotas.
