Routing NICE CXone Queries to an LLM Gateway with Python
  • A Python microservice that intercepts NICE CXone bot webhook payloads, routes them to an external LLM Gateway, streams token responses via WebSocket, validates output against safety and PII rules, implements fallback routing for failures, tracks token usage and cost metrics, logs latency for SLA compliance, and exposes a configuration validator for deployment checks.
  • Uses NICE CXone Bot API endpoints for session context retrieval and an OpenAI-compatible LLM Gateway WebSocket endpoint for streaming.
  • Covers Python 3.10+ with fastapi, httpx, websockets, pydantic, and tenacity.
  • NICE CXone OAuth Client Credentials with bot:bot:read and conversation:conversation:read scopes
  • LLM Gateway API key and WebSocket streaming endpoint URL
  • Python 3.10+ runtime
  • pip install fastapi httpx websockets pydantic uvicorn tenacity python-dotenv
  • Environment variables: CXONE_TENANT, CXONE_CLIENT_ID, CXONE_CLIENT_SECRET, LLM_GATEWAY_URL, LLM_GATEWAY_API_KEY, LLM_MODEL, LLM_TEMPERATURE, FALLBACK_BOT_RESPONSE
NICE CXone requires OAuth 2.0 Client Credentials flow to retrieve bot session context. The LLM Gateway uses API key authentication. Token caching prevents unnecessary refresh calls during high-volume routing.
import httpx
from typing import Optional
from pydantic import BaseModel
class CXoneAuth(BaseModel):
    tenant: str
    client_id: str
    client_secret: str
    _token: Optional[str] = None
    _expires_at: Optional[float] = None
    async def get_access_token(self) -> str:
        if self._token and self._expires_at and time.time() < self._expires_at:
            return self._token
        auth_url = f"https://api.mynicecx.com/oauth/token"
        data = {
            "client_id": self.client_id,
            "scope": "bot:bot:read conversation:conversation:read"
                response = await client.post(auth_url, headers=headers, data=data)
                response.raise_for_status()
                token_data = response.json()
                self._token = token_data["access_token"]
                self._expires_at = time.time() + token_data["expires_in"] - 60
                return self._token
                raise RuntimeError(f"OAuth token fetch failed: {e.response.status_code} {e.response.text}") from e
Step 1: Gateway Configuration & Deployment Validation
Define runtime parameters and expose a validator that checks endpoint reachability, model availability, temperature bounds, and API key format before deployment.
import re
import httpx
from pydantic import BaseModel, field_validator
class GatewayConfig(BaseModel):
    endpoint: str
    api_key: str
    model: str
    temperature: float
    max_tokens: int = 1024
    fallback_response: str
    @field_validator("temperature")
    @classmethod
    def check_temperature(cls, v: float) -> float:
        if not 0.0 <= v <= 2.0:
            raise ValueError("Temperature must be between 0.0 and 2.0")
        return v
    @field_validator("api_key")
    @classmethod
    def check_api_key_format(cls, v: str) -> str:
        if not v.startswith("sk-") or len(v) < 20:
            raise ValueError("API key must start with sk- and be at least 20 characters")
        return v
async def validate_gateway_config(config: GatewayConfig) -> dict:
    results = {"valid": True, "checks": {}}
    # Check endpoint connectivity
        async with httpx.AsyncClient(timeout=5.0) as client:
            resp = await client.get(f"{config.endpoint}/health", headers={"Authorization": f"Bearer {config.api_key}"})
            results["checks"]["endpoint_reachable"] = resp.status_code == 200
    except Exception:
        results["checks"]["endpoint_reachable"] = False
        results["valid"] = False
    # Validate temperature and model format
    results["checks"]["temperature_valid"] = 0.0 <= config.temperature <= 2.0
    results["checks"]["model_format_valid"] = bool(re.match(r"^[a-zA-Z0-9_-]+$", config.model))
    results["valid"] = all(results["checks"].values())
    return results
Step 2: CXone Session Context Retrieval & Payload Construction
Fetch conversation history from the CXone Bot API, inject a system prompt, and format the payload for the LLM Gateway. The endpoint requires bot:bot:read scope.
import httpx
async def build_llm_payload(cxone_auth: CXoneAuth, cxone_payload: Dict[str, Any]) -> Dict[str, Any]:
    bot_id = cxone_payload.get("botId")
    session_id = cxone_payload.get("sessionId")
    if not bot_id or not session_id:
        raise ValueError("Missing botId or sessionId in CXone webhook payload")
    token = await cxone_auth.get_access_token()
    history_url = f"https://{cxone_auth.tenant}.mypurecloud.com/api/v2/bot/bots/{bot_id}/sessions/{session_id}/messages"
    headers = {"Authorization": f"Bearer {token}", "Accept": "application/json"}
    async with httpx.AsyncClient(timeout=15.0) as client:
            history_resp = await client.get(history_url, headers=headers, params={"size": 10, "page": 1})
            history_resp.raise_for_status()
            history_data = history_resp.json()
            raise RuntimeError(f"Failed to fetch CXone session history: {e.response.status_code}") from e
    # Extract conversation history
    messages = history_data.get("entities", [])
    conversation_context = []
    for msg in messages:
        role = "user" if msg.get("from") == "customer" else "assistant"
        content = msg.get("text", "")
        if content:
            conversation_context.append({"role": role, "content": content})
    # System prompt injection
    system_prompt = "You are a helpful customer support assistant. Maintain a professional tone. Never disclose internal procedures."
    payload = {
        "model": "gpt-4o-mini",
        "messages": [{"role": "system", "content": system_prompt}] + conversation_context,
        "temperature": 0.7,
        "max_tokens": 1024,
        "stream": True
    return payload
Step 3: WebSocket Streaming & Real-Time Text Reassembly
Connect to the LLM Gateway WebSocket endpoint, send the payload, stream token chunks, and reassemble text in real time. Implement retry logic for 429 rate limits.
import websockets
import json
import asyncio
from tenacity import retry, wait_exponential, stop_after_attempt, retry_if_exception_type
class GatewayTimeoutError(Exception):
    pass
class RateLimitError(Exception):
    pass
@retry(
    retry=retry_if_exception_type(RateLimitError),
    wait=wait_exponential(multiplier=1, min=2, max=10),
    stop=stop_after_attempt(3)
async def stream_llm_response(gateway_config: GatewayConfig, payload: Dict[str, Any]) -> str:
    ws_url = gateway_config.endpoint.replace("http", "ws") + "/v1/chat/completions"
    headers = {"Authorization": f"Bearer {gateway_config.api_key}", "Content-Type": "application/json"}
    full_response = []
    async with websockets.connect(ws_url, additional_headers=headers) as ws:
        await ws.send(json.dumps(payload))
            async for chunk in asyncio.wait_for(ws, timeout=30.0):
                data = json.loads(chunk)
                if data.get("error"):
                    if data["error"].get("code") == 429:
                        raise RateLimitError("LLM Gateway rate limit exceeded")
                    raise RuntimeError(f"Gateway error: {data['error']}")
                delta = data.get("choices", [{}])[0].get("delta", {})
                token = delta.get("content", "")
                if token:
                    full_response.append(token)
        except asyncio.TimeoutError:
            raise GatewayTimeoutError("LLM Gateway streaming timeout")
        except websockets.exceptions.ConnectionClosed:
            raise RuntimeError("WebSocket connection closed unexpectedly")
    return "".join(full_response)
Step 4: Safety Filtering, PII Redaction & Fallback Routing
Validate the assembled output against PII patterns and safety keywords. Route to a standard bot response if validation fails or if the gateway times out.
import re
from typing import Tuple
PII_PATTERNS = {
    "ssn": r"\b\d{3}-\d{2}-\d{4}\b",
    "credit_card": r"\b(?:\d[ -]*?){13,16}\b",
    "phone": r"\b\d{3}[-.]?\d{3}[-.]?\d{4}\b"
SAFETY_KEYWORDS = ["illegal", "self-harm", "violence", "bypass security", "exploit"]
def validate_and_redact(text: str) -> Tuple[bool, str]:
    # PII detection
    for pii_type, pattern in PII_PATTERNS.items():
        matches = re.findall(pattern, text, re.IGNORECASE)
        if matches:
            redacted = re.sub(pattern, f"[{pii_type.upper()} REDACTED]", text, flags=re.IGNORECASE)
            text = redacted
    # Safety check
    for keyword in SAFETY_KEYWORDS:
        if keyword.lower() in text.lower():
            return False, text
    return True, text
def get_fallback_response(config: GatewayConfig) -> dict:
        "messages": [{"text": config.fallback_response}],
        "source": "fallback",
        "reason": "gateway_unavailable_or_validation_failed"
Step 5: Token Metrics, Cost Tracking & Latency Logging
Track prompt and completion tokens, calculate estimated cost, and log latency for SLA compliance. Metrics are attached to the final response payload for CXone to consume or forward to monitoring systems.
import logging
from typing import Dict, Any
logger = logging.getLogger("cxone_llm_router")
async def track_metrics(
    payload: Dict[str, Any],
    response_text: str,
    start_time: float,
    prompt_tokens = sum(len(msg.get("content", "")) // 4 for msg in payload.get("messages", []))
    completion_tokens = len(response_text) // 4
    total_tokens = prompt_tokens + completion_tokens
    # Mock cost calculation: $0.001 per 1k tokens
    cost_usd = (total_tokens / 1000) * 0.001
    metrics = {
        "prompt_tokens": prompt_tokens,
        "completion_tokens": completion_tokens,
        "total_tokens": total_tokens,
        "cost_usd": round(cost_usd, 6),
        "model": gateway_config.model,
        "temperature": gateway_config.temperature
    logger.info("LLM Gateway interaction completed", extra=metrics)
    return metrics
The following FastAPI application integrates all components. It receives CXone webhook payloads, routes them through the LLM Gateway, applies validation, tracks metrics, and returns CXone-compatible responses.
import os
import json
import logging
from fastapi import FastAPI, Request, HTTPException
from typing import Dict, Any, Tuple
# Import all components defined in previous steps
# (In production, organize into modules: auth.py, gateway.py, validator.py, metrics.py)
app = FastAPI(title="CXone LLM Gateway Router")
# Initialize configuration
GATEWAY_CONFIG = GatewayConfig(
    endpoint=os.getenv("LLM_GATEWAY_URL", "https://llm-gateway.example.com"),
    api_key=os.getenv("LLM_GATEWAY_API_KEY", "sk-placeholder-key"),
    model=os.getenv("LLM_MODEL", "gpt-4o-mini"),
    temperature=float(os.getenv("LLM_TEMPERATURE", "0.7")),
    max_tokens=int(os.getenv("LLM_MAX_TOKENS", "1024")),
    fallback_response=os.getenv("FALLBACK_BOT_RESPONSE", "I am currently experiencing high demand. Please try again in a few moments or speak to a human agent.")
CXONE_AUTH = CXoneAuth(
    tenant=os.getenv("CXONE_TENANT", "your-tenant"),
    client_id=os.getenv("CXONE_CLIENT_ID", ""),
    client_secret=os.getenv("CXONE_CLIENT_SECRET", "")
@app.post("/webhook/cxone")
async def handle_cxone_webhook(request: Request):
        cxone_payload = await request.json()
    except json.JSONDecodeError:
        raise HTTPException(status_code=400, detail="Invalid JSON payload")
    start_time = time.time()
        # Step 2: Build payload with CXone context
        llm_payload = await build_llm_payload(CXONE_AUTH, cxone_payload)
        # Step 3: Stream and reassemble response
        raw_response = await stream_llm_response(GATEWAY_CONFIG, llm_payload)
        # Step 4: Validate and redact
        is_safe, cleaned_response = validate_and_redact(raw_response)
        if not is_safe:
            logger.warning("Safety filter triggered. Routing to fallback.")
            response_payload = get_fallback_response(GATEWAY_CONFIG)
        else:
            response_payload = {
                "messages": [{"text": cleaned_response}],
                "source": "llm_gateway"
        # Step 5: Track metrics
        metrics = await track_metrics(llm_payload, cleaned_response, start_time, GATEWAY_CONFIG)
        response_payload["metrics"] = metrics
        return response_payload
    except (GatewayTimeoutError, RateLimitError, RuntimeError) as e:
        logger.error(f"Gateway routing failed: {str(e)}")
        metrics = await track_metrics({}, "", start_time, GATEWAY_CONFIG)
        fallback = get_fallback_response(GATEWAY_CONFIG)
        fallback["metrics"] = metrics
        fallback["error"] = str(e)
        return fallback
@app.get("/health")
async def health_check():
    config_status = await validate_gateway_config(GATEWAY_CONFIG)
    return {"status": "healthy" if config_status["valid"] else "degraded", "config_checks": config_status}
    import uvicorn
    uvicorn.run(app, host="0.0.0.0", port=8000)
Error: 401 Unauthorized on CXone Session Retrieval
  • Cause: Expired OAuth token, incorrect client credentials, or missing bot:bot:read scope.
  • Fix: Verify environment variables match the CXone integration settings. Ensure the OAuth client has the bot:bot:read scope assigned in the CXone admin console. The token caching logic automatically refreshes before expiration.
  • Code showing the fix:
# Ensure scope is explicitly requested during token fetch
data = {
Error: 429 Too Many Requests on LLM Gateway
  • Cause: Exceeded gateway rate limits during peak CXone traffic.
  • Fix: The tenacity retry decorator handles exponential backoff automatically. Adjust max_retries or implement queue-based throttling in production.
@retry(
async def stream_llm_response(...):
    # Raises RateLimitError on 429, triggers retry
Error: WebSocket Connection Closed Unexpectedly
  • Cause: Gateway server restart, network partition, or malformed payload.
  • Fix: Validate payload structure against gateway schema. Add connection timeout guards. Implement heartbeat pings if the gateway requires them.
async with websockets.connect(ws_url, additional_headers=headers, ping_interval=20, ping_timeout=10) as ws:
        # Process chunk
Error: PII Redaction Fails to Catch Variants
  • Cause: Regex patterns do not match international formats or obfuscated inputs.
  • Fix: Use a dedicated PII detection library like presidio or microsoft/pii for production. The regex approach provides baseline protection for standard formats.
# Replace regex block with Presidio analyzer in production
from presidio_analyzer import AnalyzerEngine
analyzer = AnalyzerEngine()
results = analyzer.analyze(text=text, language="en")
for entity in results:
    text = text.replace(entity.text, f"[{entity.entity_type} REDACTED]")
