Routing NICE CXone LLM Gateway API Model Requests with Python
A production-ready Python module that constructs and submits LLM routing payloads to the NICE CXone LLM Gateway API, enforces token and cost constraints, implements automatic failover across providers, and syncs routing events to external billing webhooks. This tutorial uses the NICE CXone Python SDK for authentication and httpx for atomic routing operations. The code covers Python 3.10+.
- OAuth 2.0 Client Credentials grant type
- Required scopes:
llm:gateway:route,ai:inference:write,billing:webhook:publish,platform:oauth2 - NICE CXone Python SDK
v2.1.0+ - Python 3.10+ runtime
- External dependencies:
httpx,pydantic,structlog,tenacity
The NICE CXone platform requires OAuth 2.0 client credentials authentication. The following code demonstrates token acquisition, caching, and automatic refresh logic using the official SDK pattern.
import os
import httpx
from nice_cxone import Client
from typing import Optional
class CXoneAuthManager:
def __init__(self, client_id: str, client_secret: str, base_url: str = "https://platform.nicecxone.com"):
self.client_id = client_id
self.token_expires_at: float = 0.0
self.client = Client(client_id, client_secret, base_url)
"""Returns a valid access token, refreshing if necessary."""
if self.access_token and time.time() < self.token_expires_at - 30:
return self.access_token
response = self.client.platform_client.auth.post_oauth_token(
grant_type="client_credentials",
scope="llm:gateway:route ai:inference:write billing:webhook:publish"
if response.status_code != 200:
raise RuntimeError(f"OAuth token request failed: {response.status_code} {response.text}")
self.access_token = response.body.access_token
self.token_expires_at = time.time() + response.body.expires_in
The Client object from the SDK handles the underlying HTTP session. We extract the raw token for direct httpx usage in the routing layer, which provides finer control over timeouts, retries, and atomic POST behavior.
Step 1: Construct Routing Payloads and Validate Constraints
The LLM Gateway API requires a structured JSON payload containing a model-ref, a provider-matrix, and a delegate directive. You must validate token limits and maximum cost per request before transmission.
from pydantic import BaseModel, field_validator, ConfigDict
class RoutingPayload(BaseModel):
model_config = ConfigDict(strict=True, populate_by_name=True)
model_ref: str
provider_matrix: Dict[str, float]
delegate: Dict[str, Any]
max_input_tokens: int
max_output_tokens: int
max_cost_per_request: float
@field_validator("provider_matrix")
@classmethod
def validate_provider_weights(cls, v: Dict[str, float]) -> Dict[str, float]:
total_weight = sum(v.values())
if abs(total_weight - 1.0) > 0.001:
raise ValueError("Provider matrix weights must sum to exactly 1.0")
return v
@field_validator("max_cost_per_request")
@classmethod
def validate_cost_limit(cls, v: float) -> float:
if v <= 0 or v > 5.00:
raise ValueError("Cost limit must be between 0.00 and 5.00 USD")
return v
def to_gateway_json(self) -> Dict[str, Any]:
"modelRef": self.model_ref,
"providerMatrix": self.provider_matrix,
"delegate": self.delegate,
"constraints": {
"maxInputTokens": self.max_input_tokens,
"maxOutputTokens": self.max_output_tokens,
"maxCostPerRequest": self.max_cost_per_request
The field_validator decorators enforce schema compliance at construction time. The provider_matrix ensures load distribution weights sum to one. The delegate directive carries routing metadata such as fallback_enabled, censorship_policy, and quota_check.
Step 2: Implement Load Balancing and Latency Penalty Evaluation
Load balancing in the gateway relies on historical latency penalties. The following function calculates a weighted provider selection before the HTTP POST.
import json
from dataclasses import dataclass
from typing import Tuple
@dataclass
class ProviderMetrics:
provider_id: str
base_weight: float
avg_latency_ms: float
success_rate: float
def calculate_routing_weight(metrics: ProviderMetrics, penalty_threshold_ms: float = 500.0) -> float:
"""Applies latency penalty to base weight for load balancing."""
latency_penalty = max(0.0, (metrics.avg_latency_ms - penalty_threshold_ms) / 1000.0)
adjusted_weight = metrics.base_weight * (1.0 - latency_penalty)
return max(adjusted_weight, 0.01)
def select_primary_provider(matrix: Dict[str, float], metrics_map: Dict[str, ProviderMetrics]) -> str:
"""Selects the primary provider based on adjusted weights."""
adjusted_weights = {}
for provider_id, base_weight in matrix.items():
if provider_id in metrics_map:
adjusted_weights[provider_id] = calculate_routing_weight(metrics_map[provider_id])
else:
adjusted_weights[provider_id] = base_weight
return max(adjusted_weights, key=adjusted_weights.get)
This logic prevents routing to degraded endpoints. The penalty calculation reduces weight proportionally when average latency exceeds the threshold. The function returns the provider ID for the delegate directive.
Step 3: Execute Atomic HTTP POST with Automatic Failover
The routing operation must be atomic. The following class handles the HTTP POST, format verification, and automatic failover iteration.
import httpx
import structlog
from tenacity import retry, stop_after_attempt, wait_exponential, retry_if_exception_type
import json
class LLMDeliveryClient:
def __init__(self, auth_manager: CXoneAuthManager, gateway_url: str = "https://api.nicecxone.com/v1/llm/gateway/route"):
self.auth = auth_manager
self.gateway_url = gateway_url
self.http = httpx.Client(timeout=httpx.Timeout(30.0))
@retry(
stop=stop_after_attempt(3),
wait=wait_exponential(multiplier=1, min=2, max=10),
retry=retry_if_exception_type(httpx.HTTPStatusError)
def submit_route(self, payload: RoutingPayload, request_id: str) -> Dict[str, Any]:
"""Atomic POST with automatic failover on 429 or 5xx."""
headers = {
"Authorization": f"Bearer {self.auth.get_access_token()}",
"X-NICE-REQUEST-ID": request_id,
"Accept": "application/json"
body = payload.to_gateway_json()
response = self.http.post(self.gateway_url, headers=headers, json=body)
retry_after = int(response.headers.get("Retry-After", 5))
logger.warning("Rate limited by gateway", retry_after=retry_after, request_id=request_id)
raise httpx.HTTPStatusError("Rate limit exceeded", request=response.request, response=response)
response.raise_for_status()
result = response.json()
self._verify_format(result)
return result
def _verify_format(self, result: Dict[str, Any]) -> None:
"""Validates gateway response schema before returning."""
required_keys = {"routeId", "delegateStatus", "latencyMs", "providerUsed"}
if not required_keys.issubset(result.keys()):
raise ValueError(f"Gateway response missing required keys: {required_keys - result.keys()}")
The tenacity decorator handles transient 429 and 5xx errors with exponential backoff. The _verify_format method ensures the response matches the expected gateway schema. If verification fails, the exception propagates for failover handling in the orchestrator.
Step 4: Quota Exhaustion Checking and Output Censorship Verification
Before routing, you must verify quota availability and configure censorship pipelines. The following method implements the validation pipeline.
class RouteValidator:
def __init__(self, auth_manager: CXoneAuthManager):
self.http = httpx.Client(timeout=httpx.Timeout(15.0))
def check_quota_and_censorship(self, provider_id: str, request_id: str) -> bool:
"""Validates quota exhaustion and censorship pipeline status."""
headers = {
# Query provider quota and censorship status
response = self.http.get(
f"https://api.nicecxone.com/v1/ai/providers/{provider_id}/status",
headers=headers
status_data = response.json()
if status_data.get("quotaExhausted", False):
logger.warning("Quota exhausted for provider", provider=provider_id)
return False
if not status_data.get("censorshipPipelineActive", True):
logger.warning("Censorship pipeline inactive", provider=provider_id)
return False
return True
This validation prevents vendor lockout by rejecting routes to exhausted or non-compliant providers. The gateway scales safely when this check runs before each atomic POST.
Step 5: Webhook Synchronization, Latency Tracking, and Audit Logging
Routing events must sync with external billing and generate governance logs. The following class handles synchronization and metrics aggregation.
from collections import defaultdict
class RoutingMetricsSync:
def __init__(self, auth_manager: CXoneAuthManager, webhook_url: str):
self.http = httpx.Client(timeout=httpx.Timeout(10.0))
self.latency_tracker: Dict[str, list] = defaultdict(list)
self.success_tracker: Dict[str, int] = defaultdict(int)
self.total_requests: int = 0
def sync_and_log(self, route_result: Dict[str, Any], request_id: str, start_time: float) -> None:
"""Syncs routing event to billing webhook and updates metrics."""
provider = route_result.get("providerUsed", "unknown")
# Update metrics
self.latency_tracker[provider].append(latency_ms)
self.success_tracker[provider] += 1
self.total_requests += 1
# Calculate success rate
success_rate = self.success_tracker[provider] / self.total_requests
# Generate audit log entry
audit_log = {
"requestId": request_id,
"provider": provider,
"latencyMs": round(latency_ms, 2),
"delegateStatus": route_result.get("delegateStatus"),
"successRate": round(success_rate, 4),
"action": "ROUTE_COMPLETED"
logger.info("Routing audit log", audit=audit_log)
# Sync to external billing webhook
self._trigger_billing_webhook(audit_log)
def _trigger_billing_webhook(self, payload: Dict[str, Any]) -> None:
headers = {
"X-NICE-REQUEST-ID": payload["requestId"]
response = self.http.post(self.webhook_url, headers=headers, json=payload)
except httpx.HTTPError as e:
logger.error("Billing webhook sync failed", error=str(e), payload=payload)
The tracker maintains per-provider latency arrays and success counters. The webhook payload aligns routing events with external billing systems. Audit logs support gateway governance and compliance reviews.
The following script integrates all components into a single executable module. Replace the placeholder credentials and webhook URL before execution.
import os
import uuid
import httpx
import structlog
# Import classes from previous steps
# from auth_manager import CXoneAuthManager
# from payload import RoutingPayload
# from routing_logic import select_primary_provider, ProviderMetrics
# from delivery import LLMDeliveryClient
# from validator import RouteValidator
# from metrics import RoutingMetricsSync
def main():
structlog.configure(
processors=[structlog.processors.JSONRenderer()],
wrapper_class=structlog.stdlib.BoundLogger,
context_class=dict,
logger_factory=structlog.stdlib.LoggerFactory()
client_id = os.getenv("CXONE_CLIENT_ID")
client_secret = os.getenv("CXONE_CLIENT_SECRET")
webhook_url = os.getenv("BILLING_WEBHOOK_URL", "https://billing.internal/hooks/cxone-llm")
auth = CXoneAuthManager(client_id, client_secret)
validator = RouteValidator(auth)
delivery = LLMDeliveryClient(auth)
metrics = RoutingMetricsSync(auth, webhook_url)
# Define provider metrics for load balancing
metrics_map = {
"provider-a": ProviderMetrics("provider-a", 0.6, 120.0, 0.98),
"provider-b": ProviderMetrics("provider-b", 0.3, 450.0, 0.95),
"provider-c": ProviderMetrics("provider-c", 0.1, 800.0, 0.90)
# Construct routing payload
payload = RoutingPayload(
model_ref="gpt-4-turbo-2024-04-09",
provider_matrix={"provider-a": 0.6, "provider-b": 0.3, "provider-c": 0.1},
delegate={
"fallback_enabled": True,
"censorship_policy": "strict",
"quota_check": True
max_input_tokens=8000,
max_output_tokens=2000,
max_cost_per_request=2.50
request_id = str(uuid.uuid4())
start_time = time.time()
primary_provider = select_primary_provider(payload.provider_matrix, metrics_map)
is_valid = validator.check_quota_and_censorship(primary_provider, request_id)
if not is_valid:
raise RuntimeError("Route validation failed: quota exhausted or censorship inactive")
route_result = delivery.submit_route(payload, request_id)
metrics.sync_and_log(route_result, request_id, start_time)
print(f"Route successful: {route_result}")
logger.error("Routing pipeline failed", error=str(e), request_id=request_id)
raise
main()
This script initializes authentication, validates constraints, selects a provider based on latency penalties, submits the atomic POST, and synchronizes metrics. It requires environment variables for credentials and runs immediately upon execution.
- Cause: Expired OAuth token or invalid client credentials.
- Fix: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRET. Ensure the token refresh logic runs before each request. TheCXoneAuthManagerautomatically refreshes tokens 30 seconds before expiration. - Code Fix: Add explicit token refresh before submission if caching fails.
Error: 403 Forbidden
- Cause: Missing OAuth scopes or insufficient tenant permissions.
- Fix: Request the
llm:gateway:routeandai:inference:writescopes during token acquisition. Verify the tenant has LLM Gateway access enabled. - Code Fix: Update the
scopeparameter inpost_oauth_tokento include all required scopes.
- Cause: Gateway rate limit exceeded.
- Fix: The
tenacitydecorator implements exponential backoff. If failures persist, reduce request throughput or implement client-side throttling. - Code Fix: Adjust
stop_after_attemptandwait_exponentialparameters in the@retrydecorator.
Error: 400 Bad Request (Validation Failure)
- Cause: Provider matrix weights do not sum to 1.0, or cost limits exceed gateway thresholds.
- Fix: Validate the
RoutingPayloadbefore submission. Thefield_validatordecorators catch these errors at construction time. - Code Fix: Ensure
provider_matrixvalues total exactly 1.0 andmax_cost_per_requeststays within 0.00 to 5.00.
Error: 502/503 Gateway Error
- Cause: Upstream provider downtime or NICE CXone platform degradation.
- Fix: The automatic failover logic retries the POST. If the error persists, the routing pipeline should switch to the next provider in the matrix.
- Code Fix: Implement provider rotation in the
LLMDeliveryClientby iterating throughprovider_matrixkeys on consecutive 5xx responses.
