Routing NICE Cognigy AI Fallback Intents to an External LLM Gateway with FastAPI
When working, this system intercepts low-confidence intents from NICE Cognigy AI, retrieves recent conversation context from the CXone API, generates a structured response via an external LLM gateway, validates the output against a strict JSON schema, and returns the result to Cognigy for fulfillment. This tutorial uses the NICE CXone Conversations API, an OpenAI-compatible LLM gateway endpoint, and Python FastAPI. The implementation uses Python 3.10+ with FastAPI, Pydantic, httpx, and Jinja2.
- NICE CXone OAuth2 client with
view:conversationandview:analytics:conversationscopes - External LLM gateway with OpenAI-compatible
/v1/chat/completionsendpoint andchat:writescope - Python 3.10 or later
- Dependencies:
fastapi,uvicorn,httpx,pydantic,jinja2,python-dotenv,hmac,hashlib
NICE CXone requires OAuth2 client credentials flow for API access. The external LLM gateway uses bearer token authentication. The FastAPI service validates inbound Cognigy AI webhooks using HMAC-SHA256 signature verification.
import os
import hmac
import hashlib
import httpx
from typing import Optional
from functools import lru_cache
@lru_cache(maxsize=1)
def get_cxone_client() -> httpx.AsyncClient:
"""Initialize CXone API client with OAuth token management."""
return httpx.AsyncClient(
base_url="https://api.mynicecx.com",
headers={
"Accept": "application/json",
timeout=httpx.Timeout(30.0)
async def fetch_cxone_access_token() -> str:
"""Exchange client credentials for a CXone OAuth2 bearer token."""
async with httpx.AsyncClient() as client:
response = await client.post(
"https://api.mynicecx.com/oauth/token",
data={
"scope": "view:conversation view:analytics:conversation",
"client_id": os.getenv("CXONE_CLIENT_ID"),
"client_secret": os.getenv("CXONE_CLIENT_SECRET"),
auth=(os.getenv("CXONE_CLIENT_ID"), os.getenv("CXONE_CLIENT_SECRET")),
response.raise_for_status()
return response.json()["access_token"]
def verify_webhook_signature(payload: bytes, signature: str, secret: str) -> bool:
"""Verify HMAC-SHA256 signature from Cognigy AI webhook."""
expected = hmac.new(secret.encode(), payload, hashlib.sha256).hexdigest()
return hmac.compare_digest(expected, signature)
Token caching is handled via lru_cache for the client instance. In production, implement token expiration tracking and automatic refresh before the 3600-second TTL expires.
Step 1: Fetch Conversation Context from CXone API
Cognigy AI sends a fallback trigger with a conversationId. You must retrieve recent message history to provide context to the LLM. The CXone API paginates conversation summaries using nextPageToken.
import os
from typing import List, Dict, Any, Optional
async def fetch_conversation_history(conversation_id: str, max_turns: int = 10) -> List[Dict[str, Any]]:
"""Retrieve recent conversation turns from CXone with pagination handling."""
client = get_cxone_client()
token = await fetch_cxone_access_token()
client.headers["Authorization"] = f"Bearer {token}"
history: List[Dict[str, Any]] = []
params = {
"conversationId": conversation_id,
"pageSize": 50,
"sortOrder": "desc",
while len(history) < max_turns:
response = await client.get(
"/api/v2/conversations/summaries",
params=params,
response = await client.get("/api/v2/conversations/summaries", params=params)
data = response.json()
for item in data.get("items", []):
if len(history) >= max_turns:
break
history.append({
"participant": item.get("participantId"),
"text": item.get("text", ""),
"timestamp": item.get("timestamp"),
next_token = data.get("nextPageToken")
if not next_token:
break
params["nextPageToken"] = next_token
return list(reversed(history))
OAuth Scope Required: view:conversation
Expected Response Structure:
"items": [
"conversationId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"participantId": "user-external-9876",
"text": "I need help resetting my password but the link expired",
"timestamp": "2024-01-15T10:23:45.000Z"
"nextPageToken": null
Error Handling: The code implements automatic 401 retry by refreshing the OAuth token. Network timeouts and 5xx errors propagate via httpx.HTTPStatusError for upstream retry or circuit breaker patterns.
Step 2: Build the FastAPI Ingestion Endpoint
Define the webhook receiver with Pydantic validation and HMAC verification.
from fastapi import FastAPI, Request, HTTPException
app = FastAPI(title="Cognigy Fallback Router")
class FallbackTrigger(BaseModel):
conversationId: str
userId: str
lastMessage: str
confidenceScore: float = Field(ge=0.0, le=1.0)
detectedIntent: Optional[str] = None
metadata: Dict[str, Any] = Field(default_factory=dict)
@app.post("/webhook/cognigy/fallback")
async def handle_fallback(request: Request):
signature = request.headers.get("X-Webhook-Signature", "")
secret = os.getenv("COGNIGY_WEBHOOK_SECRET")
body = await request.body()
if not verify_webhook_signature(body, signature, secret or ""):
raise HTTPException(status_code=403, detail="Invalid webhook signature")
trigger = FallbackTrigger.model_validate_json(body)
if trigger.confidenceScore > 0.75:
raise HTTPException(status_code=400, detail="Confidence score exceeds fallback threshold")
return await route_to_llm_gateway(trigger)
This endpoint enforces strict input validation and rejects high-confidence messages that should not trigger the fallback path.
Step 3: Template System Prompts and Call LLM Gateway
Use Jinja2 to construct a deterministic system prompt. Inject conversation history, fallback context, and explicit output constraints. Call the external LLM gateway with exponential backoff for rate limits.
import asyncio
import json
from jinja2 import Template
from typing import Any
SYSTEM_PROMPT_TEMPLATE = """You are a customer support routing assistant.
Analyze the conversation history and the user's last message.
The AI system could not classify the intent with high confidence.
Your goal is to determine the most likely intent and extract required parameters.
Conversation Context:
{% for turn in history %}
[{{ turn.participant }}]: {{ turn.text }}
{% endfor %}
Detected Fallback Intent: {{ detected_intent or "UNKNOWN" }}
Confidence: {{ confidence }}
Output Requirements:
Respond ONLY with valid JSON matching this schema:
"classified_intent": string,
"confidence": number,
"extracted_parameters": object,
"suggested_response": string,
"requires_human_agent": boolean
Do not include markdown formatting or explanatory text.
async def call_llm_gateway(system_prompt: str, user_prompt: str, max_retries: int = 3) -> Dict[str, Any]:
"""Call external LLM gateway with 429 retry logic."""
client = httpx.AsyncClient(
base_url=os.getenv("LLM_GATEWAY_BASE_URL", "https://api.gateway.example.com"),
headers={
"Authorization": f"Bearer {os.getenv('LLM_GATEWAY_API_KEY')}",
timeout=httpx.Timeout(45.0)
payload = {
"model": os.getenv("LLM_MODEL", "gpt-4o-mini"),
"messages": [
{"role": "system", "content": system_prompt},
{"role": "user", "content": user_prompt},
"temperature": 0.2,
"response_format": {"type": "json_object"},
"max_tokens": 500,
response = await client.post("/v1/chat/completions", json=payload)
wait_time = min(2 ** attempt, 16)
raise HTTPException(status_code=401, detail="LLM Gateway authentication failed")
if response.status_code == 500 or response.status_code >= 503:
raise HTTPException(status_code=502, detail="LLM Gateway internal error")
raise HTTPException(status_code=429, detail="LLM Gateway rate limit exceeded after retries")
OAuth Scope Required: chat:write
HTTP Request Cycle:
POST /v1/chat/completions
Authorization: Bearer sk-llm-gateway-key-xxxx
"model": "gpt-4o-mini",
"messages": [
{"role": "system", "content": "You are a customer support routing assistant..."},
{"role": "user", "content": "Analyze the conversation and return structured JSON."}
"temperature": 0.2,
"max_tokens": 500
HTTP Response Cycle:
"id": "chatcmpl-9x8y7z",
"object": "chat.completion",
"created": 1705312825,
"choices": [
"index": 0,
"message": {
"role": "assistant",
"content": "{\"classified_intent\": \"password_reset\", \"confidence\": 0.92, \"extracted_parameters\": {\"account_type\": \"business\"}, \"suggested_response\": \"I can help you reset your password. Would you like a new secure link sent to your registered email?\", \"requires_human_agent\": false}"
"finish_reason": "stop"
"usage": {"prompt_tokens": 340, "completion_tokens": 85, "total_tokens": 425}
The retry logic implements exponential backoff capped at 16 seconds. The 429 response triggers immediate sleep before the next attempt.
Step 4: Enforce JSON Schema Validation
Parse the LLM response and validate against a Pydantic model. Reject malformed outputs and trigger a safe fallback response.
import json
class LLMResponseSchema(BaseModel):
classified_intent: str
confidence: float = Field(ge=0.0, le=1.0)
extracted_parameters: Dict[str, Any] = Field(default_factory=dict)
suggested_response: str
requires_human_agent: bool
async def route_to_llm_gateway(trigger: FallbackTrigger) -> Dict[str, Any]:
history = await fetch_conversation_history(trigger.conversationId)
template = Template(SYSTEM_PROMPT_TEMPLATE)
system_prompt = template.render(
history=history,
detected_intent=trigger.detectedIntent,
confidence=trigger.confidenceScore,
llm_result = await call_llm_gateway(
system_prompt=system_prompt,
user_prompt=f"Last user message: {trigger.lastMessage}",
raw_content = llm_result["choices"][0]["message"]["content"]
parsed_json = json.loads(raw_content)
validated_response = LLMResponseSchema.model_validate(parsed_json)
except (json.JSONDecodeError, ValueError, KeyError) as e:
"status": "schema_validation_failed",
"error": str(e),
"fallback_action": "route_to_human",
"suggested_response": "I am having trouble understanding your request. Connecting you to a specialist.",
"status": "success",
"conversationId": trigger.conversationId,
"routing_decision": validated_response.model_dump(),
Pydantic enforces type constraints and range validation. If the LLM returns free text or invalid JSON, the exception handler returns a deterministic safe response that Cognigy AI can process without crashing.
Combine all components into a single deployable module.
import os
import hmac
import hashlib
import asyncio
import json
import httpx
import uvicorn
# --- Configuration ---
{% endfor %}
# --- Authentication & HTTP Clients ---
headers={"Content-Type": "application/json", "Accept": "application/json"},
data={
# --- Data Models ---
conversationId: str
userId: str
lastMessage: str
# --- Business Logic ---
params = {"conversationId": conversation_id, "pageSize": 50, "sortOrder": "desc"}
for item in response.json().get("items", []):
break
history.append({"participant": item.get("participantId"), "text": item.get("text", ""), "timestamp": item.get("timestamp")})
next_token = response.json().get("nextPageToken")
if not next_token:
break
headers={"Content-Type": "application/json", "Authorization": f"Bearer {os.getenv('LLM_GATEWAY_API_KEY')}", "Accept": "application/json"},
payload = {
"messages": [{"role": "system", "content": system_prompt}, {"role": "user", "content": user_prompt}],
"temperature": 0.2,
"max_tokens": 500,
await asyncio.sleep(min(2 ** attempt, 16))
if response.status_code >= 500:
system_prompt = template.render(history=history, detected_intent=trigger.detectedIntent, confidence=trigger.confidenceScore)
llm_result = await call_llm_gateway(system_prompt=system_prompt, user_prompt=f"Last user message: {trigger.lastMessage}")
return {"status": "schema_validation_failed", "error": str(e), "fallback_action": "route_to_human", "suggested_response": "I am having trouble understanding your request. Connecting you to a specialist."}
return {"status": "success", "conversationId": trigger.conversationId, "routing_decision": validated_response.model_dump()}
# --- Endpoints ---
uvicorn.run(app, host="0.0.0.0", port=8000)
- Cause: The external LLM gateway enforces rate limits on tokens per minute or requests per second. Concurrent fallback triggers from multiple conversations exceed the quota.
- Fix: Implement exponential backoff with jitter. The provided code uses
asyncio.sleep(min(2 ** attempt, 16)). Add request queuing viaasyncio.Queueif concurrency exceeds gateway limits. - Code Fix:
import random
wait_time = min(2 ** attempt + random.uniform(0, 1), 16)
Error: JSON Schema Validation Failure
- Cause: The LLM returns conversational text instead of strict JSON, or omits required fields like
requires_human_agent. - Fix: Lower the
temperatureparameter to 0.1 or 0.2. Explicitly setresponse_format: {"type": "json_object"}in the request payload. Add a retry loop that re-parses the response with a stricter prompt if validation fails. - Code Fix:
if isinstance(e, (json.JSONDecodeError, ValueError)):
system_prompt="Return ONLY valid JSON. No markdown. No extra text.",
user_prompt=f"Previous failed output: {raw_content}",
- Cause: CXone OAuth token expired, LLM gateway API key is invalid, or webhook signature mismatch.
- Fix: Verify environment variables match the exact values from the admin console. Implement token expiration tracking by parsing the
expires_infield from/oauth/token. Refresh tokens 60 seconds before expiration. - Code Fix:
token_expiry = time.time() + int(response.json().get("expires_in", 3600)) - 60
if time.time() > token_expiry:
# Force cache invalidation and refresh
fetch_cxone_access_token.cache_clear()
