Hi i am facing the below issue, Strategy is not executing in the RP 1260955. It is present in Avaya Switch.Any thoughts what is the root cause?
received from 65531(tserv_a)xxenp001:3000(fd=) message EventError
(Invalid origination or destination address)
AttributeErrorMessage ‘Invalid origination or destination address’
AttributeReferenceID 23958993
AttributeThisDN ‘1260955’
AttributeConnID 0079028b99a62661
AttributeCallID 11013
AttributeErrorCode 600
AttributeTimeinSecs 1475101094 (15:18:14)
AttributeTimeinuSecs 650136
AttributeCustomerID ‘Resources’
AttributeEventSequenceNumber 0000000002fa5b60
Show the TRoute request and full log
2016-09-28T15:18:14.648 Trace xxenp001 tserv_a GCTI-00-04541 RequestRouteCall received from [15] (00000002 urs_a 10.193.x.1:39886)
message RequestRouteCall
AttributeOtherDN ‘’
AttributeExtensions [44] 00 02 00 00..
‘CUSTOMER_ID’ ‘Resources’
‘SWITCH’ ‘RB8800’
AttributeRouteType 1 (RouteTypeDefault)
AttributeReason [14] 00 01 01 00..
‘RTR’ 365
2016-09-28T15:18:14.648 Interaction xxenp001 tserv_a GCTI-00-04543 Interaction message “RequestRouteCall” received from 15 (“urs_a”)
TDN:1260955
IID:0079028B99A62661
ODN:
OPER:36
@15 :18:14.6489 [gctmi] Distributing request RequestRouteCall
@15 :18:14.6489 [asai] Party [0079028b99a62661:1260955,s809,tRP,rDST,lINT] (reqRouteCall)
TP_AsaiData
FACILITY CRV:9ca0
Facility: INVOKE
InvokeId: 2
Operation: RouteSelect
CalledNum: (unknown),‘’
@15 :18:14.6490 [>>] 08 00 00 16 08 02 9C A0 62 96 1C 0E 91 A1 0B 02 01 02 02 01 B7 40 03 70 01 80
@15 :18:14.6500 [<<] 08 00 00 17 08 02 1C A0 5A 96 1C 0F 91 A1 0C 02 01 02 02 01 B9 40 04 08 02 81 9C
TP_AsaiData
RELEASE_COMPLETE CRV:1ca0
Facility: INVOKE
InvokeId: 2
Operation: RouteEnd
Cause: C_INVLDNUM
@15 :18:14.6501 [asai] (processOperRouteEnd)
@15 :18:14.6501 [gctmi] TMsg [EventError()] distributing to model
@15 :18:14.6501 [gctmi] Party [0079028b99a62661:1260955,s809,tRP,rDST,lINT] processError
@15 :18:14.6501 [gctmi] request RequestRouteCall ctiRefId 40096 removed from reqMgr
@15 :18:14.6501 [0] 8.1.001.55 send_to_client: message EventError
2016-09-28T15:18:14.650 Interaction xxenp001 tserv_a GCTI-00-04545 Interaction message “EventError” sent to 15 (“urs_a”)
TDN:1260955
OPER:52
2016-09-28T15:18:14.650 Trace xxenp001 tserv_a GCTI-00-04542 EventError sent to [15] (00000002 urs_a 10.193.x.1:39886)
Kubig
September 29, 2016, 7:07am
4
From my point of view, the OtherDN parameter is missing, respectively has empty value, which means you wanted to route to “null” destination and the PBX declined it. Check your strategy.
Agree with Kubig
We use the same strategy for other Transfer Numbers it all works. Only for one number it is not working so
So…check your strategy or configuration
Tambo
September 30, 2016, 10:24am
8
delete RP and re-create from working one maybe ?!?
Tambo
September 30, 2016, 10:51am
10
can be corrupt during creation, had it before with route points
RP corrupt? Hummmm could be not monitored and then you force the register again but not corrupt… It is just a DB object which is sent to TServer to ask for a Monitor request to the PBX :S
Tambo
September 30, 2016, 12:44pm
12
seriously it didn’t show as being registered in logs, honestly ;D
n3vek7
September 30, 2016, 2:18pm
13
Corrupt, isn’t it a generic answer when you don’t know what was the problem and you just restarted a service? ;D
Agree with cavagnaro/Kubig, RP is probably not monitored by TServer and it just doesn’t exist. Make sure it is registered.
