Routing Genesys Cloud EventBridge Interaction Lifecycle Events to Multiple Microservices Using a Go Fan-Out Processor
A Go service that consumes interaction lifecycle events from Genesys Cloud EventBridge, fans them out to multiple downstream microservices over HTTP, and manages independent retry queues with dead-letter tracking for each target. This tutorial uses the Genesys Cloud Platform Client SDK for Go and the Confluent Kafka Go client. The implementation is written in Go.
  • OAuth Client Credentials grant with eventbridge:read scope
  • Genesys Cloud Platform Client SDK for Go v14+
  • Go 1.21+ runtime
  • External dependencies: github.com/mypurecloud/platform-client-sdk-go/v14, github.com/confluentinc/confluent-kafka-go/kafka, github.com/google/uuid
Genesys Cloud EventBridge configuration retrieval requires a valid OAuth 2.0 access token. The Client Credentials flow is the standard pattern for server-to-server integrations. You must cache the token and implement refresh logic before expiration to avoid unnecessary re-authentication cycles.
The OAuth endpoint is https://api.mypurecloud.com/api/v2/oauth/token. The request requires a Basic authorization header containing the base64-encoded client ID and secret, along with a form-urlencoded body specifying the grant type and scopes.
package auth
import (
	"bytes"
	"encoding/base64"
	"encoding/json"
	"fmt"
	"net/http"
	"sync"
	"time"
type TokenResponse struct {
	ExpiresIn   int    `json:"expires_in"`
	TokenType   string `json:"token_type"`
type OAuthManager struct {
	clientID      string
	clientSecret  string
	accessToken   string
	expiresAt     time.Time
	mu            sync.RWMutex
	baseURL       string
	httpClient    *http.Client
func NewOAuthManager(clientID, clientSecret string) *OAuthManager {
	return &OAuthManager{
		clientID:     clientID,
		clientSecret: clientSecret,
		baseURL:      "https://api.mypurecloud.com/api/v2/oauth/token",
		httpClient:   &http.Client{Timeout: 10 * time.Second},
func (o *OAuthManager) GetToken() (string, error) {
	o.mu.RLock()
	if time.Now().Before(o.expiresAt.Add(-5 * time.Minute)) {
		token := o.accessToken
		o.mu.RUnlock()
		return token, nil
	o.mu.RUnlock()
	return o.refreshToken()
func (o *OAuthManager) refreshToken() (string, error) {
	o.mu.Lock()
	defer o.mu.Unlock()
	// Check again under write lock
		return o.accessToken, nil
	auth := base64.StdEncoding.EncodeToString([]byte(o.clientID + ":" + o.clientSecret))
	payload := []byte("grant_type=client_credentials&scope=eventbridge:read")
	req, err := http.NewRequest("POST", o.baseURL, bytes.NewBuffer(payload))
	if err != nil {
		return "", fmt.Errorf("failed to create oauth request: %w", err)
	req.Header.Set("Authorization", "Basic "+auth)
	resp, err := o.httpClient.Do(req)
	if err != nil {
		return "", fmt.Errorf("oauth request failed: %w", err)
	defer resp.Body.Close()
		return "", fmt.Errorf("oauth returned status %d", resp.StatusCode)
	var tokenResp TokenResponse
		return "", fmt.Errorf("failed to decode oauth response: %w", err)
	o.accessToken = tokenResp.AccessToken
	o.expiresAt = time.Now().Add(time.Duration(tokenResp.ExpiresIn) * time.Second)
The token manager uses a read-write mutex to allow concurrent reads while blocking only during refresh. The five-minute buffer prevents edge-case expiration during high-throughput periods. The eventbridge:read scope grants permission to query EventBridge connection details without modifying streaming configurations.
Step 1: Initialize SDK and Retrieve EventBridge Configuration
The Genesys Cloud Go SDK abstracts REST serialization and provides type-safe access to EventBridge metadata. You must configure the SDK with the base path and inject the cached OAuth token before invoking API methods.
package main
import (
	"context"
	"fmt"
	"log"
	"github.com/mypurecloud/platform-client-sdk-go/v14/configuration"
	"github.com/mypurecloud/platform-client-sdk-go/v14/platformclientv2"
func fetchEventBridgeConfig(token string) (*platformclientv2.Eventbridge, error) {
	cfg := configuration.NewConfiguration()
	cfg.BasePath = "https://api.mypurecloud.com/api/v2"
	cfg.AccessToken = token
	// Create the API client with context for cancellation support
	ctx := context.Background()
	eventbridgeAPI := platformclientv2.NewEventbridgeAPI(cfg)
	// Retrieve the primary EventBridge instance
	resp, _, err := eventbridgeAPI.GetEventbridge(ctx)
	if err != nil {
		return nil, fmt.Errorf("failed to fetch eventbridge config: %w", err)
	if resp == nil {
		return nil, fmt.Errorf("eventbridge response is nil")
	return resp, nil
The GetEventbridge method maps to GET /api/v2/eventbridge. The response contains the Kafka bootstrap servers, SASL mechanism, and topic naming conventions. The SDK automatically handles pagination for list endpoints, but this specific call returns a single configuration object. You must pass a context to enable request cancellation during shutdown sequences.
Step 2: Connect to Kafka and Deserialize Interaction Events
EventBridge publishes interaction lifecycle events to Kafka topics using JSON serialization. You will use the Confluent Kafka Go client to establish a consumer connection, subscribe to the interaction topic, and deserialize payloads into a structured type.
package main
import (
	"encoding/json"
	"fmt"
	"log"
	"github.com/confluentinc/confluent-kafka-go/kafka"
type InteractionEvent struct {
	EventID     string `json:"event_id"`
	EventType   string `json:"event_type"`
	Timestamp   string `json:"timestamp"`
	Interaction struct {
		ID          string `json:"id"`
		ChannelType string `json:"channel_type"`
		Status      string `json:"status"`
	} `json:"interaction"`
func startKafkaConsumer(bootstrapServers string, saslUsername, saslPassword string) (*kafka.Consumer, error) {
	consumerConfig := &kafka.ConfigMap{
		"bootstrap.servers": bootstrapServers,
		"group.id":          "genesys-fanout-processor",
		"auto.offset.reset": "latest",
		"enable.auto.commit": false,
		"security.protocol": "SASL_SSL",
		"sasl.mechanisms":   "SCRAM-SHA-512",
		"sasl.username":     saslUsername,
		"sasl.password":     saslPassword,
	consumer, err := kafka.NewConsumer(consumerConfig)
	if err != nil {
		return nil, fmt.Errorf("failed to create kafka consumer: %w", err)
	// Subscribe to the interaction lifecycle topic
	topic := "genesys-cloud-interaction-events"
	err = consumer.Subscribe(topic, nil)
	if err != nil {
		return nil, fmt.Errorf("failed to subscribe to topic %s: %w", topic, err)
	return consumer, nil
func deserializeEvent(value []byte) (*InteractionEvent, error) {
	var evt InteractionEvent
	if err := json.Unmarshal(value, &evt); err != nil {
		return nil, fmt.Errorf("failed to deserialize event: %w", err)
	return &evt, nil
The consumer configuration disables automatic offset commits to ensure exactly-once processing semantics at the application layer. The SCRAM-SHA-512 mechanism matches Genesys Cloud EventBridge default authentication requirements. The InteractionEvent struct maps directly to the JSON schema published by EventBridge. You must commit offsets only after successful fan-out completion to prevent duplicate processing.
Step 3: Implement the Fan-Out Router with Independent Retry Queues
Each downstream microservice requires an isolated retry queue to prevent a slow or failing service from blocking other targets. You will implement a router that dispatches events concurrently, tracks retry attempts per service, and applies exponential backoff with 429 rate-limit handling.
package main
import (
	"bytes"
	"context"
	"encoding/json"
	"fmt"
	"io"
	"log"
	"math"
	"net/http"
	"sync"
	"time"
type MicroserviceTarget struct {
	Name           string
	URL            string
	MaxRetries     int
	RetryQueue     chan *PendingRequest
	DeadLetterChan chan *DeadLetterEvent
type PendingRequest struct {
	Event      *InteractionEvent
	Attempt    int
	TargetURL  string
	TargetName string
type DeadLetterEvent struct {
	EventID    string
	TargetName string
	Error      string
	Payload    []byte
	Timestamp  time.Time
type FanOutRouter struct {
	targets []*MicroserviceTarget
	wg      sync.WaitGroup
func NewFanOutRouter(targets []MicroserviceTarget) *FanOutRouter {
	r := &FanOutRouter{}
	for i := range targets {
		targets[i].RetryQueue = make(chan *PendingRequest, 100)
		targets[i].DeadLetterChan = make(chan *DeadLetterEvent, 50)
		r.targets = append(r.targets, &targets[i])
	return r
func (r *FanOutRouter) Start(ctx context.Context) {
	for _, t := range r.targets {
		r.wg.Add(1)
		go r.retryWorker(ctx, t)
		r.wg.Add(1)
		go r.deadLetterWorker(ctx, t)
func (r *FanOutRouter) Dispatch(event *InteractionEvent) {
	payload, _ := json.Marshal(event)
		req := &PendingRequest{
			Event:      event,
			Attempt:    0,
			TargetURL:  t.URL,
			TargetName: t.Name,
		select {
		case t.RetryQueue <- req:
		default:
			log.Printf("Retry queue full for %s, dropping event %s", t.Name, event.EventID)
func (r *FanOutRouter) retryWorker(ctx context.Context, target *MicroserviceTarget) {
	defer r.wg.Done()
	for {
		select {
		case <-ctx.Done():
			return
		case req := <-target.RetryQueue:
			err := r.sendWithRetry(ctx, req, target)
			if err != nil {
				select {
				case target.DeadLetterChan <- &DeadLetterEvent{
					EventID:    req.Event.EventID,
					TargetName: req.TargetName,
					Error:      err.Error(),
					Payload:    []byte(fmt.Sprintf("%v", req.Event)),
					Timestamp:  time.Now(),
				default:
					log.Printf("Dead letter queue full for %s", target.Name)
func (r *FanOutRouter) sendWithRetry(ctx context.Context, req *PendingRequest, target *MicroserviceTarget) error {
	for req.Attempt < target.MaxRetries {
		delay := time.Duration(math.Pow(2, float64(req.Attempt))) * time.Second
		if req.Attempt > 0 {
			select {
			case <-time.After(delay):
			case <-ctx.Done():
				return ctx.Err()
		payload, _ := json.Marshal(req.Event)
		httpReq, err := http.NewRequestWithContext(ctx, "POST", req.TargetURL, bytes.NewBuffer(payload))
		if err != nil {
			return fmt.Errorf("failed to create request: %w", err)
		httpReq.Header.Set("Content-Type", "application/json")
		httpReq.Header.Set("X-Genesys-Event-ID", req.Event.EventID)
		resp, err := client.Do(httpReq)
		if err != nil {
			req.Attempt++
		resp.Body.Close()
		if resp.StatusCode == http.StatusOK || resp.StatusCode == http.StatusCreated {
			return nil
			// Extract Retry-After header if present
			retryAfter := 2 * time.Second
			if val := resp.Header.Get("Retry-After"); val != "" {
				if seconds, parseErr := time.ParseDuration(val + "s"); parseErr == nil {
					retryAfter = seconds
			select {
			case <-time.After(retryAfter):
			case <-ctx.Done():
				return ctx.Err()
			req.Attempt++
		// Non-retryable error
		return fmt.Errorf("target %s returned status %d: %s", req.TargetName, resp.StatusCode, string(body))
	return fmt.Errorf("max retries exceeded for %s", req.TargetName)
func (r *FanOutRouter) deadLetterWorker(ctx context.Context, target *MicroserviceTarget) {
	defer r.wg.Done()
	for {
		select {
		case <-ctx.Done():
			return
		case dl := <-target.DeadLetterChan:
			log.Printf("Dead letter: event=%s target=%s error=%s", dl.EventID, dl.TargetName, dl.Error)
			// In production, persist to database, file, or separate Kafka topic
The retry worker processes each queue independently. The exponential backoff calculation prevents thundering herd scenarios when downstream services experience transient failures. The 429 handling respects the Retry-After header when present, falling back to a two-second default. Non-retryable status codes (4xx excluding 429, 5xx) immediately route the event to the dead-letter channel. The dead-letter worker logs failures and provides a hook for persistence.
Step 4: Dead-Letter Tracking and Persistence
Dead-letter events require durable storage for auditing and replay. You will implement a simple file-based tracker that serializes failed events with timestamps and error contexts. This pattern ensures no event is silently dropped during processing failures.
package main
import (
	"encoding/json"
	"fmt"
	"os"
	"path/filepath"
	"time"
type DeadLetterTracker struct {
	basePath string
func NewDeadLetterTracker(basePath string) (*DeadLetterTracker, error) {
	err := os.MkdirAll(basePath, 0755)
	if err != nil {
		return nil, fmt.Errorf("failed to create dead letter directory: %w", err)
	return &DeadLetterTracker{basePath: basePath}, nil
func (d *DeadLetterTracker) Persist(event *DeadLetterEvent) error {
	filename := fmt.Sprintf("%s/%s_%s.json", d.basePath, event.TargetName, event.EventID)
	payload, err := json.MarshalIndent(event, "", "  ")
	if err != nil {
		return fmt.Errorf("failed to marshal dead letter event: %w", err)
	f, err := os.Create(filename)
	if err != nil {
		return fmt.Errorf("failed to create dead letter file: %w", err)
	defer f.Close()
	_, err = f.Write(payload)
	if err != nil {
		return fmt.Errorf("failed to write dead letter file: %w", err)
	return nil
The tracker creates a JSON file per failed event, named by target service and event ID. This structure enables quick lookup and replay operations. In production, you would replace file I/O with a message queue or database write to support distributed replay workers.
The following script combines all components into a runnable Go application. Replace the placeholder credentials and target URLs before execution.
package main
import (
	"context"
	"log"
	"os"
	"os/signal"
	"syscall"
	"time"
func main() {
	ctx, cancel := signal.NotifyContext(context.Background(), os.Interrupt, syscall.SIGTERM)
	defer cancel()
	// 1. Initialize OAuth
	oauth := NewOAuthManager(os.Getenv("GENESYS_CLIENT_ID"), os.Getenv("GENESYS_CLIENT_SECRET"))
	token, err := oauth.GetToken()
	if err != nil {
		log.Fatalf("OAuth initialization failed: %v", err)
	// 2. Fetch EventBridge config
	cfg, err := fetchEventBridgeConfig(token)
	if err != nil {
		log.Fatalf("EventBridge config fetch failed: %v", err)
	// 3. Start Kafka consumer
	consumer, err := startKafkaConsumer(cfg.ConnectionDetails.BootstrapServers, cfg.ConnectionDetails.SaslUsername, cfg.ConnectionDetails.SaslPassword)
	if err != nil {
		log.Fatalf("Kafka consumer failed: %v", err)
	defer consumer.Close()
	// 4. Initialize fan-out router
	targets := []MicroserviceTarget{
		{Name: "analytics-service", URL: "https://analytics.internal/api/events", MaxRetries: 3},
		{Name: "notification-service", URL: "https://notifications.internal/api/interactions", MaxRetries: 3},
		{Name: "compliance-service", URL: "https://compliance.internal/api/audit", MaxRetries: 5},
	router := NewFanOutRouter(targets)
	router.Start(ctx)
	// 5. Initialize dead letter tracker
	tracker, err := NewDeadLetterTracker("./dead-letters")
	if err != nil {
		log.Fatalf("Dead letter tracker failed: %v", err)
	// 6. Event loop
	log.Println("EventBridge fan-out processor running...")
	for {
		select {
		case <-ctx.Done():
			log.Println("Shutting down processor...")
			router.wg.Wait()
			return
		default:
			msg, err := consumer.ReadMessage(-1)
			if err != nil {
				if err == kafka.ErrAssignmentLost {
					log.Println("Consumer assignment lost, rejoining group...")
				log.Printf("Kafka read error: %v", err)
				time.Sleep(1 * time.Second)
			event, err := deserializeEvent(msg.Value)
			if err != nil {
				log.Printf("Deserialization failed: %v", err)
				consumer.CommitMessage(msg)
			router.Dispatch(event)
			// Commit offset after successful routing initiation
			err = consumer.CommitMessage(msg)
			if err != nil {
				log.Printf("Offset commit failed: %v", err)
The main function establishes the processing pipeline, handles graceful shutdown via signal context, and maintains the event loop. The consumer commits offsets only after the fan-out router accepts the event into its retry queues. This approach balances throughput with failure safety.
The OAuth token has expired or the client credentials are invalid. Verify that the GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET environment variables match a registered client in the Genesys Cloud admin console. Ensure the client has the eventbridge:read scope assigned. The token manager automatically refreshes tokens before expiration, but initial startup failures require valid credentials.
Error: 403 Forbidden
The OAuth client lacks permission to access EventBridge configuration. Navigate to the Genesys Cloud admin console, locate the OAuth client, and verify that the eventbridge:read scope is enabled. Additionally, confirm that the service account associated with the client has read access to the EventBridge resource.
Downstream microservices or the Genesys Cloud API are rate-limiting requests. The fan-out router implements exponential backoff and respects the Retry-After header for 429 responses. If the error persists, increase the MaxRetries value for the affected target or implement request throttling using a token bucket algorithm. Monitor the X-RateLimit-Remaining header in responses to adjust concurrency dynamically.
Error: SASL authentication failed
The Kafka consumer cannot authenticate with EventBridge. Verify that the sasl.username and sasl.password match the credentials provided in the EventBridge connection details. Ensure that security.protocol is set to SASL_SSL and sasl.mechanisms is set to SCRAM-SHA-512. Network firewalls must allow outbound traffic on port 9094.
Error: JSON unmarshal error
The event payload does not match the InteractionEvent struct definition. Genesys Cloud occasionally updates event schemas. Add the omitempty tag to optional fields and implement a fallback deserializer that captures unknown fields as map[string]interface{}. Log the raw payload for schema analysis when unmarshal failures occur.
