Routing Genesys Cloud EventBridge Interaction Lifecycle Events to AWS SQS with Node.js Lambda
A Node.js AWS Lambda function that ingests Genesys Cloud interaction lifecycle events from EventBridge, filters payloads by interaction type and priority, routes matched events to a primary SQS queue, and sends unhandled or failed events to a dead-letter queue. This tutorial uses the Genesys Cloud Node.js SDK to configure the EventBridge integration and AWS SDK v3 for Lambda and SQS operations. The programming language covered is JavaScript (Node.js 18+).
- Genesys Cloud OAuth 2.0 client credentials with
eventbridge:write,integration:write, andinteraction:readscopes - AWS account with IAM permissions for
lambda:InvokeFunction,sqs:SendMessage,sqs:GetQueueUrl, andlogs:CreateLogGroup - Node.js 18 runtime environment
@genesyscloud/purecloud-api-client-nodejsversion 8.0.0 or higher@aws-sdk/client-sqsversion 3.400.0 or higher@aws-sdk/client-lambdaversion 3.400.0 or higher (optional, for deployment)
The Genesys Cloud Node.js SDK handles OAuth 2.0 client credentials flow automatically. You must initialize the PlatformClient outside the Lambda handler to reuse the authenticated session across invocations. The SDK caches the access token and refreshes it transparently when it expires.
import { PlatformClient } from '@genesyscloud/purecloud-api-client-nodejs';
const GENESYS_ENV = process.env.GENESYS_ENV || 'mypurecloud.com';
const GENESYS_CLIENT_ID = process.env.GENESYS_CLIENT_ID;
const GENESYS_CLIENT_SECRET = process.env.GENESYS_CLIENT_SECRET;
let platformClient;
export async function getPlatformClient() {
if (!platformClient) {
platformClient = PlatformClient.authClientCredentials({
clientId: GENESYS_CLIENT_ID,
clientSecret: GENESYS_CLIENT_SECRET,
environment: GENESYS_ENV
return platformClient;
The client credentials flow exchanges GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET for a bearer token. The SDK stores the token in memory and attaches it to subsequent API calls. If the token expires, the SDK triggers a silent refresh before the next request. You must ensure the OAuth client has the eventbridge:write scope for configuration operations and interaction:read if you query interaction metadata later.
Step 1: Configure Genesys Cloud EventBridge Integration via SDK
You must register an EventBridge configuration in Genesys Cloud before events stream to AWS. The configuration defines the target ARN, event filters, and retry policy. The API endpoint is POST /api/v2/eventbridge/configurations.
Required OAuth Scope: eventbridge:write
HTTP Request:
POST /api/v2/eventbridge/configurations HTTP/1.1
Host: api.mypurecloud.com
"name": "InteractionLifecycleToSQS",
"description": "Streams voice and email interactions to AWS SQS",
"targetArn": "arn:aws:lambda:us-east-1:123456789012:function:GenesysEventRouter",
"eventFilters": [
"eventType": "interaction.lifecycle",
"filterCriteria": {
"type": ["voice", "email"],
"state": ["connected", "queued", "ended"]
"retryPolicy": {
"maxRetries": 3,
"backoffStrategy": "exponential"
SDK Implementation:
import { EventBridgeApi } from '@genesyscloud/purecloud-api-client-nodejs';
export async function configureEventBridgeIntegration(platformClient) {
const eventBridgeApi = new EventBridgeApi(platformClient);
const configurationBody = {
description: 'Streams voice and email interactions to AWS SQS',
targetArn: process.env.AWS_LAMBDA_TARGET_ARN,
eventFilters: [
eventType: 'interaction.lifecycle',
filterCriteria: {
type: ['voice', 'email'],
state: ['connected', 'queued', 'ended']
retryPolicy: {
maxRetries: 3,
backoffStrategy: 'exponential'
const response = await eventBridgeApi.postEventbridgeConfigurations(configurationBody);
console.log('EventBridge configuration created:', response.body);
return response.body;
} catch (error) {
if (error.status === 409) {
console.warn('Configuration already exists. Skipping creation.');
return null;
if (error.status === 401 || error.status === 403) {
console.error('Authentication or authorization failed. Verify OAuth scopes.');
throw new Error('GENESYS_AUTH_ERROR');
console.error('Failed to create EventBridge configuration:', error.message);
throw error;
Expected Response:
"id": "e7b9c2d1-4f5a-6b7c-8d9e-0f1a2b3c4d5e",
"status": "active",
"createdTime": "2023-11-15T14:30:00.000Z",
"eventFilters": [
"filterCriteria": {
Step 2: Build the Lambda Handler with EventBridge Input Parsing
AWS EventBridge delivers events to Lambda as a JSON payload. The detail object contains the Genesys Cloud interaction data. You must parse the payload safely and validate required fields before processing.
import { SQSClient, SendMessageCommand, GetQueueUrlCommand } from '@aws-sdk/client-sqs';
const sqsClient = new SQSClient({ region: process.env.AWS_REGION || 'us-east-1' });
const PRIMARY_QUEUE_URL = process.env.PRIMARY_SQS_QUEUE_URL;
const DLQ_QUEUE_URL = process.env.DLQ_SQS_QUEUE_URL;
export async function handler(event, context) {
const records = event.detail || [event]; // Handle single or batch EventBridge payloads
const results = [];
for (const record of records) {
const processed = await processEventBridgeRecord(record);
results.push(processed);
} catch (error) {
console.error('Event processing failed:', error);
await sendToDeadLetterQueue(JSON.stringify(record), error.message);
results.push({ status: 'failed', reason: error.message });
statusCode: 200,
body: JSON.stringify({ processed: results.length })
The handler accepts the EventBridge detail object. If Genesys Cloud batches events, the payload may contain an array. The code normalizes the input into an iterable array. Each record is processed independently to prevent a single malformed event from blocking the entire batch.
Step 3: Implement Payload Filtering Logic
You must filter events based on business rules before routing to the primary queue. This example filters by interaction type and priority. Unmatched events route directly to the dead-letter queue to prevent queue pollution.
const ALLOWED_TYPES = (process.env.ALLOWED_INTERACTION_TYPES || 'voice,email').split(',');
const MIN_PRIORITY = parseInt(process.env.MIN_PRIORITY || '5', 10);
async function processEventBridgeRecord(record) {
const detail = record.detail || record;
const interactionType = detail.type;
const priority = detail.priority || 1;
if (!ALLOWED_TYPES.includes(interactionType)) {
console.log(`Filtered: Unsupported interaction type ${interactionType}`);
await sendToDeadLetterQueue(JSON.stringify(record), 'FILTERED_TYPE');
return { status: 'filtered', reason: 'type_mismatch' };
if (priority < MIN_PRIORITY) {
console.log(`Filtered: Priority ${priority} below threshold ${MIN_PRIORITY}`);
await sendToDeadLetterQueue(JSON.stringify(record), 'FILTERED_PRIORITY');
return { status: 'filtered', reason: 'priority_below_threshold' };
const payload = {
interactionId: detail.interactionId,
type: interactionType,
state: detail.state,
priority: priority,
timestamp: detail.timestamp || new Date().toISOString(),
source: 'genesys.cloud'
await sendToPrimaryQueue(JSON.stringify(payload));
return { status: 'routed', interactionId: detail.interactionId };
The filtering logic uses environment variables for configuration. You adjust ALLOWED_INTERACTION_TYPES and MIN_PRIORITY without redeploying code. The function checks conditions sequentially and routes rejected events to the DLQ with explicit rejection reasons.
Step 4: Route to SQS with DLQ Fallback and Retry Logic
AWS SQS may return throttling errors during high-throughput scenarios. You must implement exponential backoff retry logic for transient failures. Successful messages route to the primary queue. Permanent failures route to the DLQ.
async function sendToPrimaryQueue(messageBody) {
await retryWithBackoff(async () => {
const command = new SendMessageCommand({
QueueUrl: PRIMARY_QUEUE_URL,
MessageBody: messageBody,
MessageGroupId: 'gen-interactions', // Required for FIFO queues
MessageDeduplicationId: crypto.randomUUID() // Required for FIFO queues
await sqsClient.send(command);
async function sendToDeadLetterQueue(messageBody, errorReason) {
const dlqPayload = {
originalMessage: JSON.parse(messageBody),
errorReason: errorReason,
failedAt: new Date().toISOString()
QueueUrl: DLQ_QUEUE_URL,
MessageBody: JSON.stringify(dlqPayload)
async function retryWithBackoff(fn, maxRetries = 3) {
for (let attempt = 1; attempt <= maxRetries; attempt++) {
return await fn();
} catch (error) {
const isRetryable =
error.name === 'ThrottlingException' ||
error.name === 'TooManyRequestsException' ||
error.statusCode === 429 ||
error.statusCode === 503;
if (!isRetryable || attempt === maxRetries) {
console.error(`Retry exhausted after ${attempt} attempts.`, error);
throw error;
const delay = Math.pow(2, attempt) * 100 + Math.random() * 100;
console.warn(`Retry ${attempt}/${maxRetries} in ${Math.round(delay)}ms`);
The retryWithBackoff function catches ThrottlingException and HTTP 429/503 status codes. It applies exponential backoff with jitter to avoid thundering herd problems. The function retries up to three times before propagating the error. FIFO queues require MessageGroupId and MessageDeduplicationId. Standard queues do not require these fields, but the code includes them for compatibility.
The following script combines authentication, configuration, and the Lambda handler into a single deployable module. You must set environment variables before execution.
import crypto from 'crypto';
import { SQSClient, SendMessageCommand } from '@aws-sdk/client-sqs';
// Configuration
const AWS_REGION = process.env.AWS_REGION || 'us-east-1';
// SDK Clients
const sqsClient = new SQSClient({ region: AWS_REGION });
let platformClient;
async function configureEventBridgeIntegration() {
const client = await getPlatformClient();
const eventBridgeApi = new EventBridgeApi(client);
eventFilters: [
filterCriteria: {
retryPolicy: { maxRetries: 3, backoffStrategy: 'exponential' }
console.log('EventBridge configuration created:', response.body.id);
} catch (error) {
console.warn('Configuration already exists.');
return null;
throw error;
return await fn();
} catch (error) {
const isRetryable =
throw error;
async function sendToQueue(queueUrl, messageBody, metadata = {}) {
QueueUrl: queueUrl,
MessageBody: JSON.stringify({ ...metadata, message: JSON.parse(messageBody) })
const results = [];
await sendToQueue(DLQ_QUEUE_URL, JSON.stringify(record), { reason: 'FILTERED_TYPE' });
results.push({ status: 'filtered', reason: 'type_mismatch' });
continue;
await sendToQueue(DLQ_QUEUE_URL, JSON.stringify(record), { reason: 'FILTERED_PRIORITY' });
results.push({ status: 'filtered', reason: 'priority_below_threshold' });
continue;
const payload = {
priority: priority,
await sendToQueue(PRIMARY_QUEUE_URL, JSON.stringify(payload), { routed: true });
results.push({ status: 'routed', interactionId: detail.interactionId });
} catch (error) {
console.error('Processing failed:', error);
await sendToQueue(DLQ_QUEUE_URL, JSON.stringify(record), { reason: error.message });
return { statusCode: 200, body: JSON.stringify({ processed: results.length })};
Deploy this module as a Node.js 18 Lambda function. Configure environment variables for Genesys credentials, AWS region, queue URLs, and filtering thresholds. Invoke the setup script once to register the EventBridge configuration. Subsequent invocations process streaming events.
What causes it: The OAuth client lacks the required eventbridge:write scope, or the client credentials are invalid.
How to fix it: Regenerate the client secret in the Genesys Cloud admin console. Verify the OAuth client has eventbridge:write and integration:write scopes. Ensure the GENESYS_ENV matches your deployment region.
Code showing the fix:
} catch (error) {
console.error('Check OAuth scopes: eventbridge:write, integration:write');
throw new Error('GENESYS_SCOPE_MISMATCH');
What causes it: Genesys Cloud API rate limits are exceeded during configuration polling, or AWS SQS throttles high-throughput Lambda invocations.
How to fix it: Implement exponential backoff with jitter. The retryWithBackoff function in the complete example handles this automatically. For Genesys API calls, respect the Retry-After header if present.
const delay = (error.headers?.['retry-after'] || Math.pow(2, attempt)) * 1000;
Error: SQSThrottlingException
What causes it: The primary queue receives messages faster than the provisioned throughput allows, or the Lambda concurrency exceeds AWS account limits.
How to fix it: Increase queue throughput, switch to a FIFO queue with higher per-group limits, or add a SQS standard queue as a buffer before the primary queue. The retry wrapper catches ThrottlingException and backs off automatically.
if (error.name === 'ThrottlingException') {
console.warn('SQS throttled. Backing off.');
// retryWithBackoff handles the delay automatically
Error: Malformed EventBridge Detail Object
What causes it: Genesys Cloud updates the event schema, or a test event lacks the detail.type or detail.interactionId fields.
How to fix it: Add defensive parsing and validation before filtering. Route malformed events to the DLQ for manual inspection.
if (!detail.type || !detail.interactionId) {
await sendToQueue(DLQ_QUEUE_URL, JSON.stringify(record), { reason: 'MISSING_FIELDS' });
continue;
