Routing Genesys Cloud EventBridge events to multi-tenant architectures with TypeScript
You will build a TypeScript consumer that ingests Genesys Cloud EventBridge events, extracts tenant identifiers from the event metadata, routes messages through a decision tree engine, and dispatches transformed payloads to tenant-specific AWS SQS queues. The consumer tracks correlation IDs across the message broker pipeline and aggregates delivery latency metrics to identify bottlenecks in high-traffic tenants. This tutorial uses the AWS SDK v3 for SQS, the official Genesys Cloud JavaScript SDK for tenant validation, and modern TypeScript async/await patterns.
- AWS IAM role or credentials with
sqs:SendMessage,sqs:GetQueueUrl, andlogs:*permissions - Genesys Cloud EventBridge integration configured with the
event:readOAuth scope - Node.js 18+ and TypeScript 5+
- Dependencies:
@aws-sdk/client-sqs,@genesyscloud/purecloud-platform-client-v2,uuid,zod - An AWS SQS queue per tenant or a naming convention like
sqs://<region>/<account>/<tenant-id>-events
AWS services authenticate via IAM credentials loaded from environment variables or an EC2/Lambda execution role. The Genesys Cloud SDK requires a client credentials flow. You must configure the following environment variables before running the consumer:
AWS_REGION=us-east-1
AWS_ACCESS_KEY_ID=AKIAIOSFODNN7EXAMPLE
AWS_SECRET_ACCESS_KEY=wJalrXUtnFEMI/K7MDENG/bPxRfiCYEXAMPLEKEY
GENESYS_CLOUD_REGION=us-east-1
GENESYS_CLOUD_CLIENT_ID=your_genesys_client_id
GENESYS_CLOUD_CLIENT_SECRET=your_genesys_client_secret
Initialize the AWS SQS client and the Genesys Cloud SDK:
import { SQSClient } from "@aws-sdk/client-sqs";
import { PlatformClient } from "@genesyscloud/purecloud-platform-client-v2";
const sqsClient = new SQSClient({ region: process.env.AWS_REGION || "us-east-1" });
const platformClient = new PlatformClient();
platformClient.setEnvironment("mygenesys.com");
platformClient.loginClientCredentials(
process.env.GENESYS_CLOUD_CLIENT_ID!,
process.env.GENESYS_CLOUD_CLIENT_SECRET!
).catch((err: Error) => {
console.error("Genesys Cloud authentication failed:", err.message);
process.exit(1);
The Genesys Cloud EventBridge integration requires the event:read scope. The SDK initialization above uses client_credentials grant type, which automatically requests the scopes defined in the OAuth client configuration within the Genesys Cloud admin console.
Step 1: Parse EventBridge metadata and extract tenant identifiers
Genesys Cloud pushes events to EventBridge with a standardized envelope. The tenant identifier resides in the detail.organizationId field. You must validate the payload structure before routing. The following code defines the event schema and extracts the tenant context:
import { z } from "zod";
const GenesysEventDetailSchema = z.object({
organizationId: z.string().uuid(),
eventType: z.string(),
timestamp: z.string().datetime(),
payload: z.record(z.unknown()),
userId: z.string().optional(),
queueId: z.string().optional()
const EventBridgeSchema = z.object({
source: z.string().startsWith("genesys.cloud"),
account: z.string(),
time: z.string().datetime(),
region: z.string(),
resources: z.array(z.string()),
detailType: z.string(),
detail: GenesysEventDetailSchema
interface TenantContext {
tier: "standard" | "premium" | "enterprise";
region: string;
async function extractTenantContext(event: unknown): Promise<TenantContext> {
const parsed = EventBridgeSchema.safeParse(event);
if (!parsed.success) {
throw new Error(`Invalid EventBridge payload: ${parsed.error.message}`);
const orgId = parsed.data.detail.organizationId;
// Validate tenant exists in Genesys Cloud using real API path
// Endpoint: GET /api/v2/organizations/{organizationId}
// Required scope: organization:read
const orgResponse = await platformClient.organizationsApi.getOrganizationById(orgId);
if (orgResponse.status !== 200) {
throw new Error(`Tenant validation failed: ${orgResponse.status}`);
tier: "enterprise", // Derived from org metadata in production
region: parsed.data.region
Step 2: Evaluate routing rules using a decision tree engine
A decision tree evaluates event attributes against business rules to determine the target queue suffix. The engine supports priority-based rule evaluation and fallback routing. Each rule contains a condition function and a target queue identifier:
interface RoutingRule {
priority: number;
condition: (event: unknown, tenant: TenantContext) => boolean;
targetSuffix: string;
class DecisionTreeRouter {
private rules: RoutingRule[] = [];
addRule(rule: RoutingRule): void {
this.rules.push(rule);
this.rules.sort((a, b) => a.priority - b.priority);
evaluate(event: unknown, tenant: TenantContext): string {
for (const rule of this.rules) {
if (rule.condition(event, tenant)) {
return `${tenant.id}-${rule.targetSuffix}`;
} catch (err) {
console.warn(`Rule ${rule.id} evaluation failed:`, (err as Error).message);
return `${tenant.id}-default`;
const router = new DecisionTreeRouter();
router.addRule({
priority: 1,
condition: (evt, _tenant) => {
const parsed = EventBridgeSchema.safeParse(evt);
return parsed.success && parsed.data.detailType === "conversation:created";
targetSuffix: "conversations-high"
router.addRule({
priority: 2,
return parsed.success && parsed.data.detailType === "analytics:summary";
targetSuffix: "analytics-batch"
router.addRule({
priority: 99,
condition: () => true,
targetSuffix: "default"
Step 3: Dispatch transformed payloads to tenant-specific AWS SQS queues
The dispatch function constructs the SQS message, applies exponential backoff for 429 throttling, and returns the broker response. The AWS SDK v3 requires explicit command construction:
import { SendMessageCommand, SQSError } from "@aws-sdk/client-sqs";
interface DispatchConfig {
queueBaseUrl: string;
maxRetries: number;
baseDelayMs: number;
async function dispatchToSqs(
queueSuffix: string,
payload: string,
correlationId: string,
tenantId: string,
config: DispatchConfig
): Promise<string> {
const queueUrl = `${config.queueBaseUrl}/${queueSuffix}`;
let attempt = 0;
while (attempt < config.maxRetries) {
const command = new SendMessageCommand({
QueueUrl: queueUrl,
MessageBody: payload,
MessageAttributes: {
tenantId: { DataType: "String", StringValue: tenantId },
correlationId: { DataType: "String", StringValue: correlationId },
eventType: { DataType: "String", StringValue: "genesys-event" },
processedAt: { DataType: "String", StringValue: new Date().toISOString() }
const response = await sqsClient.send(command);
return response.MessageId || "unknown";
} catch (err) {
const error = err as SQSError;
if (error.name === "ThrottlingException" || error.statusCode === 429) {
const delay = config.baseDelayMs * Math.pow(2, attempt);
console.warn(`SQS 429 throttled. Retrying in ${delay}ms. Attempt ${attempt + 1}`);
await new Promise((resolve) => setTimeout(resolve, delay));
attempt++;
} else {
throw err;
throw new Error("Max retries exceeded for SQS dispatch");
Step 4: Implement correlation ID tracking across message brokers
Correlation IDs enable end-to-end traceability. The consumer generates a UUID v4 at ingestion time, injects it into SQS MessageAttributes, and logs it alongside the event ID. Downstream consumers read the attribute to reconstruct the message lifecycle:
import { v4 as uuidv4 } from "uuid";
interface CorrelationTracker {
track(eventId: string, correlationId: string, queueSuffix: string): void;
class DefaultCorrelationTracker implements CorrelationTracker {
track(eventId: string, correlationId: string, queueSuffix: string): void {
console.log(`[CORRELATION] Event: ${eventId} -> Correlation: ${correlationId} -> Queue: ${queueSuffix}`);
// In production, write to CloudWatch Logs Insights, X-Ray, or OpenTelemetry
const tracker = new DefaultCorrelationTracker();
Step 5: Aggregate delivery latency metrics
Latency aggregation identifies bottlenecks by measuring the delta between event ingestion and SQS acknowledgment. The collector groups metrics by tenant and calculates average processing time:
interface LatencyRecord {
tenantId: string;
correlationId: string;
ingestionTimeMs: number;
dispatchTimeMs: number;
totalLatencyMs: number;
status: "success" | "failed";
class LatencyAggregator {
private records: Map<string, LatencyRecord[]> = new Map();
record(record: LatencyRecord): void {
const tenantRecords = this.records.get(record.tenantId) || [];
tenantRecords.push(record);
this.records.set(record.tenantId, tenantRecords);
getBottleneckTenant(): { tenantId: string; avgLatencyMs: number; sampleCount: number } | null {
let worstTenant = null;
let maxAvgLatency = 0;
for (const [tenantId, records] of this.records) {
if (records.length === 0) continue;
const successRecords = records.filter((r) => r.status === "success");
if (successRecords.length === 0) continue;
const avgLatency = successRecords.reduce((sum, r) => sum + r.totalLatencyMs, 0) / successRecords.length;
if (avgLatency > maxAvgLatency) {
maxAvgLatency = avgLatency;
worstTenant = { tenantId, avgLatencyMs: avgLatency, sampleCount: successRecords.length };
return worstTenant;
const metrics = new LatencyAggregator();
The following script combines all components into a runnable consumer. It accepts a raw EventBridge payload, processes it through the pipeline, and outputs metrics:
import { SQSClient, SendMessageCommand, SQSError } from "@aws-sdk/client-sqs";
// Reuse types and classes from Steps 1-5
// (In production, import from separate modules)
region: z.string(),
region: string;
return { id: orgId, tier: "enterprise", region: parsed.data.region };
priority: number;
if (rule.condition(event, tenant)) return `${tenant.id}-${rule.targetSuffix}`;
} catch (err) {
router.addRule({
priority: 1,
condition: (evt) => {
router.addRule({
priority: 99,
payload: string,
tenantId: string,
queueBaseUrl: string,
maxRetries: number,
baseDelayMs: number
const queueUrl = `${queueBaseUrl}/${queueSuffix}`;
let attempt = 0;
while (attempt < maxRetries) {
QueueUrl: queueUrl,
} catch (err) {
const delay = baseDelayMs * Math.pow(2, attempt);
attempt++;
} else {
throw err;
tenantId: string;
return worstTenant;
async function processGenesysEvent(rawEvent: unknown): Promise<void> {
const ingestionTime = Date.now();
const correlationId = uuidv4();
const tenant = await extractTenantContext(rawEvent);
const queueSuffix = router.evaluate(rawEvent, tenant);
const payload = JSON.stringify({
originalEvent: rawEvent,
correlationId,
routedAt: new Date().toISOString()
const queueBaseUrl = `https://sqs.${process.env.AWS_REGION}.amazonaws.com/${process.env.AWS_ACCOUNT_ID}`;
const messageId = await dispatchToSqs(
queueSuffix,
payload,
correlationId,
tenant.id,
queueBaseUrl,
3,
100
const dispatchTime = Date.now();
metrics.record({
tenantId: tenant.id,
correlationId,
ingestionTimeMs: ingestionTime,
dispatchTimeMs: dispatchTime,
totalLatencyMs: dispatchTime - ingestionTime,
status: "success"
console.log(`Successfully dispatched event ${correlationId} to ${queueSuffix}. MessageId: ${messageId}`);
} catch (err) {
metrics.record({
tenantId: "unknown",
correlationId,
status: "failed"
console.error("Processing failed:", (err as Error).message);
// Mock EventBridge payload for testing
const mockEvent = {
source: "genesys.cloud",
account: "123456789012",
time: "2024-01-15T10:30:00.000Z",
region: "us-east-1",
resources: ["arn:aws:events:us-east-1:123456789012:event-bus/genesys-events"],
detailType: "conversation:created",
detail: {
organizationId: "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
eventType: "conversation.lifecycle",
timestamp: "2024-01-15T10:30:00.000Z",
payload: { conversationId: "conv-98765", mediaType: "voice" },
userId: "user-123",
queueId: "queue-456"
processGenesysEvent(mockEvent).then(() => {
const bottleneck = metrics.getBottleneckTenant();
if (bottleneck) {
console.log(`Bottleneck detected: Tenant ${bottleneck.tenantId} with avg latency ${bottleneck.avgLatencyMs.toFixed(2)}ms (${bottleneck.sampleCount} samples)`);
Error: 403 AccessDeniedException
What causes it: The IAM role lacks sqs:SendMessage permissions for the target queue, or the queue policy denies cross-account access.
How to fix it: Verify the IAM policy attached to the execution role. Ensure the policy explicitly allows sqs:SendMessage on the ARN pattern arn:aws:sqs:<region>:<account>:<tenant-id>-*.
Code showing the fix:
"Version": "2012-10-17",
"Statement": [
"Effect": "Allow",
"Action": [
"sqs:SendMessage",
"sqs:GetQueueUrl"
"Resource": "arn:aws:sqs:us-east-1:123456789012:*"
Error: 429 ThrottlingException
What causes it: SQS enforces per-queue rate limits. Standard queues support 3,000 transactions per second. High-traffic tenants exceed this limit during peak Genesys Cloud event bursts.
How to fix it: The implementation includes exponential backoff. Increase maxRetries or implement client-side jitter. Distribute load across multiple queue suffixes per tenant.
const delay = baseDelayMs * Math.pow(2, attempt) + Math.random() * 100;
Error: Zod validation failure on EventBridge payload
What causes it: Genesys Cloud updates event schemas, or the EventBridge rule filter allows malformed test events.
How to fix it: Use safeParse to catch schema mismatches without crashing the consumer. Log the raw payload and update the Zod schema to match the new detailType structure.
console.warn("Schema mismatch detected. Raw payload:", JSON.stringify(event));
// Route to dead-letter queue or alerting system
return;
Error: Genesys Cloud API 401 Unauthorized
What causes it: The OAuth token expired or the client credentials lack the organization:read scope.
How to fix it: The PlatformClient automatically refreshes tokens, but initial authentication must succeed. Verify the OAuth client in Genesys Cloud has organization:read and event:read scopes enabled. Restart the consumer after scope updates.
