Routing Genesys Cloud EventBridge Dead Letters via Python SDK
A production-grade Python module that retrieves EventBridge dead letter events, validates them against retention and schema constraints, routes them to reprocessing or archival destinations using atomic POST operations, and synchronizes results with external monitoring via webhook callbacks. The solution uses the official Genesys Cloud Python SDK, implements 429 rate-limit resilience, detects poison pill events, tracks latency and recovery metrics, and generates structured audit logs for governance compliance.
- OAuth 2.0 Service Account with
eventbridge:dlq:readandeventbridge:dlq:writescopes purecloud-platform-client-v2SDK version 128.0.0 or higher- Python 3.9+ runtime
pip install purecloud-platform-client-v2 requests httpx pydantic
Genesys Cloud requires a bearer token for all API calls. The following code retrieves a token using the client credentials grant and caches it for subsequent SDK initialization. The SDK handles automatic refresh, but explicit token acquisition ensures transparent error tracing.
import os
import requests
from typing import Optional
from purecloud_platform_client_v2 import PureCloudPlatformClientV2, Configuration
GENESYS_BASE_URL = os.environ.get("GENESYS_BASE_URL", "https://api.mypurecloud.com")
CLIENT_ID = os.environ["GENESYS_CLIENT_ID"]
CLIENT_SECRET = os.environ["GENESYS_CLIENT_SECRET"]
def acquire_oauth_token() -> str:
"""Fetches a Genesys Cloud OAuth2 token using client credentials."""
token_url = f"{GENESYS_BASE_URL}/v2/oauth/token"
payload = {
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET,
"scope": "eventbridge:dlq:read eventbridge:dlq:write"
response = requests.post(token_url, data=payload, timeout=15)
response.raise_for_status()
token_data = response.json()
return token_data["access_token"]
def initialize_sdk() -> PureCloudPlatformClientV2:
"""Configures and returns the Genesys Cloud SDK client."""
token = acquire_oauth_token()
config = Configuration(
base_url=GENESYS_BASE_URL,
access_token=token,
timeout=30000
client = PureCloudPlatformClientV2(config)
return client
OAuth Scope Requirement: eventbridge:dlq:read for listing DLQ events, eventbridge:dlq:write for routing operations.
Step 1: Initialize SDK and Configure Rate Limit Resilience
The Genesys Cloud API returns HTTP 429 when request quotas are exceeded. The SDK includes a retry policy, but explicit configuration guarantees predictable backoff behavior. The following configuration sets exponential backoff with jitter to prevent thundering herd scenarios during scaling events.
from purecloud_platform_client_v2.rest import ApiException
def configure_retry_policy(client: PureCloudPlatformClientV2) -> None:
"""Applies exponential backoff retry logic for 429 and 5xx responses."""
client.rest_client.retry = True
client.rest_client.retry_backoff_factor = 0.5
client.rest_client.retry_total = 3
client.rest_client.status_forcelist = [429, 500, 502, 503, 504]
Expected Behavior: The SDK automatically retries failed requests up to three times. Each retry doubles the wait time starting at 500 milliseconds. If all retries fail, an ApiException is raised with the final HTTP status code.
Step 2: Construct Route Payloads and Validate Against Event Engine Constraints
EventBridge enforces strict retention limits and batch size caps. Dead letter events older than thirty days are automatically purged. Bulk routing operations are capped at one hundred event identifiers per request. The following validation pipeline ensures payloads conform to engine constraints before submission.
import json
from pydantic import BaseModel, field_validator
from typing import List
class DlrqRoutePayload(BaseModel):
dlq_event_ids: List[str]
action: str # REPROCESS, ARCHIVE, or DELETE
@field_validator("action")
@classmethod
def validate_action(cls, v: str) -> str:
allowed = {"REPROCESS", "ARCHIVE", "DELETE"}
if v not in allowed:
raise ValueError(f"Action must be one of {allowed}")
return v
@field_validator("dlq_event_ids")
@classmethod
def validate_batch_size(cls, v: List[str]) -> List[str]:
if len(v) > 100:
raise ValueError("Batch size exceeds maximum limit of 100 event IDs")
return v
def validate_retention_limit(event_created_at: str) -> bool:
"""Checks if the event is within the 30-day DLQ retention window."""
event_dt = datetime.fromisoformat(event_created_at.replace("Z", "+00:00"))
cutoff = datetime.now(timezone.utc) - timedelta(days=30)
return event_dt >= cutoff
Schema Constraint: The action field must match the EventBridge routing enum. The dlq_event_ids array must not exceed one hundred entries. Events outside the thirty-day retention window will fail with HTTP 400 if submitted.
Step 3: Execute Atomic Routing with Poison Pill Detection
Poison pill events repeatedly fail downstream processing and block pipeline throughput. The following logic inspects retry counts and error codes before routing. Events exceeding the retry exhaustion threshold are diverted to archival destinations instead of reprocessing. Atomic POST operations ensure partial batch failures do not corrupt state.
from purecloud_platform_client_v2 import EventbridgeApi
import logging
logger = logging.getLogger("dlq_router")
def route_dlq_events(
eventbridge_api: EventbridgeApi,
batch_ids: List[str],
action: str,
poison_pill_threshold: int = 3
) -> dict:
"""Routes a validated batch of DLQ events with poison pill handling."""
payload = DlrqRoutePayload(dlq_event_ids=batch_ids, action=action)
response = eventbridge_api.post_eventbridge_dlq_events_route(body=payload)
audit_entry = {
"action": action,
"batch_size": len(batch_ids),
"latency_ms": latency_ms,
"status": "SUCCESS",
"request_id": response.get("requestId")
logger.info(json.dumps(audit_entry))
return {"status": "SUCCESS", "latency_ms": latency_ms, "response": response}
except ApiException as e:
logger.error(f"Routing failed: HTTP {e.status} | {e.reason}")
audit_entry = {
"action": action,
"status": "FAILURE",
"error_code": e.status,
"error_message": str(e.body)
raise
Poison Pill Detection Logic: Before calling route_dlq_events, inspect the retryCount and lastErrorCode fields from the DLQ event list. If retryCount >= poison_pill_threshold, override action to ARCHIVE to prevent pipeline blockage during scaling events.
Step 4: Synchronize Webhooks, Track Latency, and Generate Audit Logs
External monitoring dashboards require real-time alignment with routing operations. The following function dispatches structured metrics to a webhook endpoint, calculates recovery rates, and persists audit trails for governance compliance.
import httpx
from datetime import timedelta
WEBHOOK_URL = os.environ.get("MONITORING_WEBHOOK_URL", "")
def trigger_monitoring_webhook(metrics: dict) -> None:
"""Sends routing metrics to an external monitoring dashboard."""
if not WEBHOOK_URL:
return
payload = {
"source": "genesys_dlrq_router",
"metrics": metrics
with httpx.Client(timeout=10) as client:
response = client.post(WEBHOOK_URL, json=payload)
logger.warning(f"Webhook delivery failed: {e}")
def calculate_recovery_rate(success_count: int, total_count: int) -> float:
"""Computes the percentage of successfully routed events."""
if total_count == 0:
return 0.0
return (success_count / total_count) * 100.0
Metrics Tracking: The router aggregates latency_ms, recovery_rate, poison_pill_diversions, and batch_failures per execution cycle. These values feed directly into the webhook payload for dashboard rendering.
The following script orchestrates the complete DLQ routing lifecycle. It authenticates, paginates through dead letter events, validates constraints, applies poison pill detection, routes batches atomically, and synchronizes results with external monitoring.
#!/usr/bin/env python3
import os
import json
import logging
from datetime import datetime, timezone, timedelta
from typing import List, Dict
import httpx
import requests
from purecloud_platform_client_v2 import PureCloudPlatformClientV2, Configuration, EventbridgeApi, ApiException
# Configuration
POISON_PILL_THRESHOLD = 3
MAX_BATCH_SIZE = 100
RETENTION_DAYS = 30
payload = {
return response.json()["access_token"]
config = Configuration(base_url=GENESYS_BASE_URL, access_token=token, timeout=30000)
return client
def fetch_dlq_events_paginated(api: EventbridgeApi) -> List[Dict]:
events = []
page = 1
while True:
response = api.get_eventbridge_dlq_events(page_size=MAX_BATCH_SIZE, page_number=page)
events.extend(response.entities)
if not response.has_next_page:
break
page += 1
logger.error(f"Pagination failed at page {page}: HTTP {e.status}")
break
return events
def validate_and_partition(events: List[Dict]) -> Dict[str, List[str]]:
cutoff = datetime.now(timezone.utc) - timedelta(days=RETENTION_DAYS)
valid_ids = []
poison_ids = []
for ev in events:
created = datetime.fromisoformat(ev["createdTime"].replace("Z", "+00:00"))
if created < cutoff:
if ev.get("retryCount", 0) >= POISON_PILL_THRESHOLD:
poison_ids.append(ev["id"])
else:
valid_ids.append(ev["id"])
return {"reprocess": valid_ids, "archive": poison_ids}
def route_batch(api: EventbridgeApi, batch_ids: List[str], action: str) -> Dict:
if not batch_ids:
return {"status": "SKIPPED", "latency_ms": 0}
start = time.perf_counter()
body = {"dlqEventIds": batch_ids, "action": action}
response = api.post_eventbridge_dlq_events_route(body=body)
latency = (time.perf_counter() - start) * 1000
audit = {
"action": action,
"latency_ms": latency,
logger.info(json.dumps(audit))
return {"status": "SUCCESS", "latency_ms": latency}
raise
def send_webhook(metrics: Dict) -> None:
if not WEBHOOK_URL:
return
client.post(WEBHOOK_URL, json={
"metrics": metrics
def main() -> None:
client = initialize_sdk()
api = EventbridgeApi(client)
total_events = 0
success_count = 0
failure_count = 0
total_latency = 0.0
events = fetch_dlq_events_paginated(api)
total_events = len(events)
partitions = validate_and_partition(events)
for action, ids in partitions.items():
for i in range(0, len(ids), MAX_BATCH_SIZE):
batch = ids[i:i+MAX_BATCH_SIZE]
result = route_batch(api, batch, action)
if result["status"] == "SUCCESS":
success_count += len(batch)
total_latency += result["latency_ms"]
elif result["status"] == "SKIPPED":
pass
except ApiException:
failure_count += len(batch)
recovery_rate = (success_count / total_events * 100) if total_events > 0 else 0.0
avg_latency = (total_latency / success_count) if success_count > 0 else 0.0
metrics = {
"total_events": total_events,
"success_count": success_count,
"failure_count": failure_count,
"recovery_rate_percent": recovery_rate,
"average_latency_ms": avg_latency
send_webhook(metrics)
logger.info(f"Routing cycle complete. Recovery rate: {recovery_rate:.2f}%")
main()
Error: HTTP 401 Unauthorized
- Cause: Expired access token, invalid client credentials, or missing
eventbridge:dlq:readscope. - Fix: Verify environment variables match the service account configuration. Regenerate the token using the client credentials endpoint. Confirm the scope string contains both read and write permissions.
- Code Verification: The
acquire_oauth_tokenfunction raisesrequests.HTTPErroron failure. Catch and log the response body to identify missing scopes.
Error: HTTP 403 Forbidden
- Cause: Service account lacks administrative permissions for EventBridge DLQ management or organization-level API access is restricted.
- Fix: Assign the
EventBridge Adminrole to the service account via the Genesys Cloud admin console. Ensure the account is not locked or disabled. - Code Verification: The SDK returns a 403 with a JSON body containing
errorCode: "ACCESS_DENIED". Log theresponse.reasonto confirm permission boundaries.
- Cause: Exceeded organizational or endpoint-specific rate limits during pagination or batch routing.
- Fix: The retry policy in
initialize_sdkhandles automatic backoff. If cascading failures occur, reduceMAX_BATCH_SIZEto 50 and add a 1-second sleep between batches. - Code Verification: Monitor
client.rest_client.retry_totalexhaustion. Implement circuit breaker logic if 429 responses persist beyond three retry cycles.
Error: HTTP 400 Bad Request
- Cause: Payload schema mismatch, batch size exceeding 100, or routing events outside the thirty-day retention window.
- Fix: Validate
dlqEventIdslength before submission. Filter events usingvalidate_and_partitionto exclude expired records. EnsureactionmatchesREPROCESS,ARCHIVE, orDELETE. - Code Verification: The API returns
errorCode: "VALIDATION_ERROR"with field-level details. Parsee.bodyto identify the rejected parameter.
Error: HTTP 5xx Server Error
- Cause: Transient EventBridge engine failures or downstream queue saturation.
- Fix: The SDK retry policy covers 500, 502, 503, and 504 responses. If failures persist, pause routing and queue events for deferred processing. Escalate to monitoring dashboards via webhook.
- Code Verification: Log the
requestIdfrom the response header to correlate with Genesys Cloud support case tracking.
