Routing Genesys Cloud EventBridge Dead Letter Queue Messages via Node.js
- A Node.js service that consumes dead letter queue messages from AWS EventBridge, validates route payloads against strict schema constraints, and routes them to Genesys Cloud APIs using a configurable retry matrix and escalation depth limit.
- This tutorial uses the Genesys Cloud REST API surface, AWS SDK v3 for SQS, Axios for HTTP operations, and Ajv for JSON schema validation.
- The implementation covers JavaScript (ESM) with Express for management endpoints, explicit OAuth token caching, atomic POST operations, webhook synchronization, metrics tracking, and structured audit logging.
- OAuth2 Client Credentials flow configured in Genesys Cloud with scopes:
analytics:query,routing:queues:write,external:users:write,platform:admin:read - Genesys Cloud REST API v2 (
api.mypurecloud.com) - Node.js 18 or later with
npm - External dependencies:
@aws-sdk/client-sqs,axios,express,ajv,uuid - AWS EventBridge DLQ configured to route failed events to an SQS queue
- Environment variables:
GENESYS_REGION,GENESYS_CLIENT_ID,GENESYS_CLIENT_SECRET,SQS_DLQ_URL,SQS_REGION,INCIDENT_WEBHOOK_URL
Genesys Cloud requires an OAuth2 bearer token for every API call. The following code implements token acquisition, caching, and automatic refresh before expiration.
import axios from 'axios';
import crypto from 'crypto';
const GENESYS_BASE_URL = `https://${process.env.GENESYS_REGION || 'api.mypurecloud.com'}`;
const OAUTH_TOKEN_URL = `${GENESYS_BASE_URL}/api/v2/oauth/token`;
let tokenCache = {
accessToken: null,
expiresAt: 0
export async function getGenesysToken() {
const now = Date.now();
if (tokenCache.accessToken && now < tokenCache.expiresAt - 60000) {
return tokenCache.accessToken;
const authHeader = 'Basic ' + Buffer.from(
`${process.env.GENESYS_CLIENT_ID}:${process.env.GENESYS_CLIENT_SECRET}`,
'utf-8'
).toString('base64');
const response = await axios.post(OAUTH_TOKEN_URL, {
scope: 'analytics:query routing:queues:write external:users:write platform:admin:read'
headers: {
Authorization: authHeader
tokenCache.accessToken = response.data.access_token;
tokenCache.expiresAt = now + (response.data.expires_in * 1000);
} catch (error) {
if (error.response) {
console.error('OAuth 401/403:', error.response.status, error.response.data);
throw new Error('Authentication failed. Verify client credentials and scopes.');
throw error;
The request targets POST /api/v2/oauth/token. The response body contains access_token, token_type, expires_in, and scope. The cache refreshes 60 seconds before expiration to prevent mid-request 401 errors.
Step 1: DLQ Consumer and Message Deserialization
AWS EventBridge routes failed events to an SQS queue. The consumer polls messages, deserializes them, and extracts the original Genesys Cloud payload.
import { SQSClient, ReceiveMessageCommand, DeleteMessageCommand } from '@aws-sdk/client-sqs';
const sqs = new SQSClient({ region: process.env.SQS_REGION || 'us-east-1' });
export async function pollDLQ(dlqUrl) {
const command = new ReceiveMessageCommand({
QueueUrl: dlqUrl,
MaxNumberOfMessages: 10,
VisibilityTimeout: 30,
WaitTimeSeconds: 5
const response = await sqs.send(command);
const messages = response.Messages || [];
for (const msg of messages) {
const body = JSON.parse(msg.Body);
const event = JSON.parse(body.message);
await processDLQMessage(event, msg.ReceiptHandle, dlqUrl);
} catch (error) {
console.error('DLQ deserialization failed:', error.message);
The ReceiveMessageCommand returns an array of messages. Each message contains a message field that holds the original EventBridge payload. The ReceiptHandle is required for atomic deletion after successful processing.
Step 2: Route Payload Construction and Schema Validation
Route payloads must contain a DLQ ID reference, a retry matrix, and an escalation directive. The schema validates against Genesys Cloud error handling constraints and maximum escalation depth limits.
import Ajv from 'ajv';
import addFormats from 'ajv-formats';
const ajv = new Ajv();
addFormats(ajv);
const routeSchema = {
type: 'object',
required: ['dlqId', 'retryMatrix', 'escalateDirective', 'targetEndpoint'],
properties: {
dlqId: { type: 'string', format: 'uuid' },
retryMatrix: {
type: 'object',
required: ['maxRetries', 'backoffMs'],
properties: {
maxRetries: { type: 'integer', minimum: 0, maximum: 5 },
backoffMs: { type: 'integer', minimum: 1000, maximum: 30000 }
escalateDirective: {
type: 'object',
required: ['depth', 'action'],
properties: {
depth: { type: 'integer', minimum: 1, maximum: 3 },
action: { type: 'string', enum: ['reroute', 'alert', 'archive'] }
targetEndpoint: { type: 'string', format: 'uri' }
additionalProperties: false
const validateRoute = ajv.compile(routeSchema);
export function validateRoutePayload(payload) {
const valid = validateRoute(payload);
if (!valid) {
throw new Error(`Schema validation failed: ${JSON.stringify(validateRoute.errors)}`);
if (payload.escalateDirective.depth > 3) {
throw new Error('Maximum escalation depth limit exceeded. Depth must not exceed 3.');
return true;
The Ajv compiler enforces strict typing. The escalateDirective.depth constraint prevents routing failure caused by infinite escalation loops. The retryMatrix defines exponential backoff boundaries.
Step 3: Retry Matrix and Escalation Depth Logic
Recoverable errors require structured retries. The following pipeline tracks attempt counts, applies backoff, and enforces escalation directives when retry exhaustion occurs.
export async function executeRetryPipeline(routePayload, operation) {
const { retryMatrix, escalateDirective, dlqId } = routePayload;
let currentAttempt = 0;
let lastError = null;
while (currentAttempt <= retryMatrix.maxRetries) {
const result = await operation();
console.log(`[AUDIT] Route ${dlqId} succeeded on attempt ${currentAttempt + 1}`);
return { success: true, result, attempts: currentAttempt + 1 };
} catch (error) {
lastError = error;
currentAttempt++;
if (currentAttempt <= retryMatrix.maxRetries) {
const delay = retryMatrix.backoffMs * Math.pow(2, currentAttempt - 1);
console.log(`[AUDIT] Route ${dlqId} retry ${currentAttempt}/${retryMatrix.maxRetries}. Waiting ${delay}ms.`);
if (escalateDirective.action === 'alert') {
await triggerAlert(dlqId, lastError, escalateDirective.depth);
} else if (escalateDirective.action === 'reroute') {
console.log(`[AUDIT] Route ${dlqId} escalated to depth ${escalateDirective.depth} for rerouting.`);
return { success: false, error: lastError, attempts: currentAttempt, escalated: true };
The pipeline multiplies backoff duration exponentially. When maxRetries is exhausted, the escalation directive triggers an alert or reroute path. The function returns a structured result for metrics collection.
Step 4: Atomic POST Operations and Fault Isolation
Genesys Cloud API calls must be atomic. Format verification ensures payload compliance before transmission. Fault isolation prevents cascade failures during EventBridge scaling events.
export async function atomicGenesysPost(endpoint, payload, headers = {}) {
const url = `${GENESYS_BASE_URL}${endpoint}`;
const token = await getGenesysToken();
const requestConfig = {
method: 'POST',
url,
headers: {
'Accept': 'application/json',
...headers
data: payload,
timeout: 10000
const response = await axios(requestConfig);
return response.data;
} catch (error) {
const { status, data } = error.response;
if (status === 429) {
const retryAfter = error.response.headers['retry-after'] || 5;
console.log(`[AUDIT] 429 rate limit hit. Retrying after ${retryAfter}s.`);
await new Promise(resolve => setTimeout(resolve, retryAfter * 1000));
return atomicGenesysPost(endpoint, payload, headers);
if (status === 400 || status === 422) {
throw new Error(`Format verification failed: ${JSON.stringify(data)}`);
throw new Error(`API error ${status}: ${JSON.stringify(data)}`);
throw error;
The function handles 429 responses by reading the Retry-After header and recursively retrying. 400 and 422 errors fail fast to preserve fault isolation. The Authorization header rotates automatically via the token cache.
Step 5: Incident Synchronization, Metrics, and Audit Logging
Routing events must synchronize with external incident management systems. Latency tracking and success rate calculation provide route efficiency metrics. Structured audit logs support reliability governance.
const metrics = {
totalRoutes: 0,
successfulRoutes: 0,
totalLatencyMs: 0
export async function syncIncidentWebhook(dlqId, status, errorDetails) {
const webhookPayload = {
incidentId: uuidv4(),
dlqId,
status,
errorDetails,
source: 'genesys-dlq-router'
await axios.post(process.env.INCIDENT_WEBHOOK_URL, webhookPayload, {
timeout: 5000
} catch (error) {
console.error('[AUDIT] Incident webhook sync failed:', error.message);
export function recordMetrics(dlqId, success, latencyMs) {
metrics.totalRoutes++;
if (success) {
metrics.successfulRoutes++;
metrics.totalLatencyMs += latencyMs;
const successRate = (metrics.successfulRoutes / metrics.totalRoutes) * 100;
const avgLatency = metrics.totalLatencyMs / metrics.totalRoutes;
console.log(`[METRICS] Route ${dlqId} | Success: ${success} | Latency: ${latencyMs}ms | Avg Latency: ${avgLatency.toFixed(2)}ms | Success Rate: ${successRate.toFixed(2)}%`);
export async function triggerAlert(dlqId, error, depth) {
console.log(`[ALERT] DLQ ${dlqId} triggered escalation depth ${depth}. Error: ${error.message}`);
await syncIncidentWebhook(dlqId, 'escalated', { message: error.message, depth });
The metrics collector maintains running totals without external dependencies. The webhook synchronization runs asynchronously to avoid blocking the main routing pipeline. Audit logs follow a consistent prefix format for log aggregation systems.
The following Express application integrates all components into a production-ready DLQ router service.
import express from 'express';
import { pollDLQ } from './dlqConsumer.js';
import { validateRoutePayload } from './validation.js';
import { executeRetryPipeline } from './retryPipeline.js';
import { atomicGenesysPost } from './genesysApi.js';
import { syncIncidentWebhook, recordMetrics, triggerAlert } from './metricsWebhooks.js';
const app = express();
app.use(express.json());
const DLQ_URL = process.env.SQS_DLQ_URL;
let isProcessing = false;
async function processDLQMessage(event, receiptHandle, dlqUrl) {
const routePayload = event.detail || event.body;
validateRoutePayload(routePayload);
} catch (error) {
console.error(`[AUDIT] Validation failed for ${routePayload.dlqId}: ${error.message}`);
await deleteDLQMessage(receiptHandle, dlqUrl);
return;
const startTime = Date.now();
const result = await executeRetryPipeline(routePayload, async () => {
return atomicGenesysPost(routePayload.targetEndpoint, routePayload.data);
const latencyMs = Date.now() - startTime;
recordMetrics(routePayload.dlqId, result.success, latencyMs);
if (!result.success) {
await syncIncidentWebhook(routePayload.dlqId, 'failed', result.error.message);
async function deleteDLQMessage(receiptHandle, dlqUrl) {
await sqs.send(new DeleteMessageCommand({ QueueUrl: dlqUrl, ReceiptHandle: receiptHandle }));
} catch (error) {
console.error('[AUDIT] DLQ message deletion failed:', error.message);
app.get('/api/dlq-router/status', (req, res) => {
res.json({ isProcessing, metrics });
app.post('/api/dlq-router/flush', async (req, res) => {
if (isProcessing) {
return res.status(409).json({ error: 'Router is currently processing messages.' });
isProcessing = true;
await pollDLQ(DLQ_URL);
res.json({ status: 'flush_complete' });
} catch (error) {
res.status(500).json({ error: error.message });
} finally {
const PORT = process.env.PORT || 3000;
app.listen(PORT, () => {
console.log(`DLQ Router listening on port ${PORT}`);
The service exposes GET /api/dlq-router/status for health checks and POST /api/dlq-router/flush for automated management. The isProcessing flag prevents concurrent polling loops. All operations log to structured stdout for containerized deployments.
Error: 401 Unauthorized on Genesys Cloud POST
- Cause: Expired OAuth token or missing
platform:admin:readscope in client credentials. - Fix: Verify the client ID and secret. Ensure the token cache refreshes before expiration. Add
platform:admin:readto the OAuth scope list. - Code Fix: Update the
getGenesysTokenscope parameter to include all required permissions.
- Cause: Exceeding Genesys Cloud API rate limits during high-volume DLQ processing.
- Fix: Implement exponential backoff with
Retry-Afterheader parsing. TheatomicGenesysPostfunction already handles this recursively. - Code Fix: Ensure the
timeoutparameter does not exceed 10 seconds to avoid connection pooling exhaustion.
Error: Schema Validation Failed for escalateDirective.depth
- Cause: Payload defines
depthgreater than 3, violating the maximum escalation depth limit. - Fix: Adjust the retry matrix configuration in the upstream EventBridge rule. Cap
depthat 3 in the payload generator. - Code Fix: The Ajv validator throws immediately. Catch the error and route to a static archive endpoint instead.
Error: SQS Visibility Timeout Exceeded
- Cause: Processing time exceeds the 30-second visibility window, causing duplicate message retrieval.
- Fix: Increase
VisibilityTimeoutinReceiveMessageCommandor implement periodicChangeMessageVisibilitycalls for long-running routes. - Code Fix: Add a visibility extension loop if
latencyMsapproaches 25000.
