Routing Genesys Cloud Client SDK Audio Streams via Java
- You will build a Java module that programmatically routes Client SDK audio streams by constructing device-referenced route payloads, applying volume matrices, and enforcing mute directives.
- The implementation uses the Genesys Cloud Client SDK for Java alongside the REST API for audit logging and metric tracking.
- The code is written in Java 17+ using modern concurrency primitives, HTTP clients, and SDK media classes.
- OAuth 2.0 Client Credentials application registered in Genesys Cloud with
client_credentialsgrant type - Required OAuth scopes:
analytics:read,user:read,routing:read,media:control - Genesys Cloud Client SDK for Java version 2.0.0+ and REST SDK version 2.0.0+
- Java 17 runtime with Maven or Gradle
- Dependencies:
com.genesys.cloud:genesyscloud-client-sdk-java,com.genesys.cloud:genesyscloud-client-sdk-api,com.fasterxml.jackson.core:jackson-databind,org.slf4j:slf4j-api
The Client SDK and REST API share the same OAuth 2.0 token endpoint. You must implement token caching and automatic refresh to prevent 401 interruptions during long-running audio sessions.
import java.net.URI;
import java.time.Instant;
import java.util.Map;
public class OAuthTokenManager {
private final String clientId;
private final String clientSecret;
private final String environment;
private final ObjectMapper mapper = new ObjectMapper();
private final Map<String, Object> tokenCache = new ConcurrentHashMap<>();
private Instant tokenExpiry = Instant.EPOCH;
public OAuthTokenManager(String clientId, String clientSecret, String environment) {
this.clientId = clientId;
this.environment = environment;
public String getAccessToken() throws Exception {
if (Instant.now().isBefore(tokenExpiry.minusSeconds(300))) {
return (String) tokenCache.get("access_token");
refreshTokens();
private void refreshTokens() throws Exception {
String tokenEndpoint = String.format("https://%s/oauth/token", environment);
String body = String.format(
"grant_type=client_credentials&client_id=%s&client_secret=%s",
clientId, clientSecret
.uri(URI.create(tokenEndpoint))
.header("Content-Type", "application/x-www-form-urlencoded")
.POST(HttpRequest.BodyPublishers.ofString(body))
.build();
HttpClient client = HttpClient.newBuilder().build();
HttpResponse<String> response = client.send(request, HttpResponse.BodyHandlers.ofString());
throw new RuntimeException("OAuth token refresh failed with status " + response.statusCode());
JsonNode json = mapper.readTree(response.body());
tokenCache.put("access_token", json.get("access_token").asText());
tokenCache.put("token_type", json.get("token_type").asText());
tokenCache.put("expires_in", json.get("expires_in").asInt());
tokenExpiry = Instant.now().plusSeconds(json.get("expires_in").asInt());
The token manager caches the JWT and refreshes it when expiration approaches. You must pass this token to both the Client SDK initializer and the REST API client to maintain consistent identity.
Step 1: Initialize Audio Router and Validate Device Constraints
The Client SDK exposes an AudioRouter that manages media paths. You must validate device counts and media engine constraints before routing. Genesys Cloud enforces a maximum of 8 concurrent audio devices per client session and requires compatible sample rates.
import com.genesys.cloud.client.sdk.audio.*;
import java.util.List;
import java.util.stream.Collectors;
public class AudioRoutingEngine {
private final AudioRouter audioRouter;
private static final int MAX_DEVICE_COUNT = 8;
private static final List<Integer> SUPPORTED_SAMPLE_RATES = List.of(8000, 16000, 32000, 48000);
public AudioRoutingEngine(AudioRouter router) {
this.audioRouter = router;
public List<AudioDevice> validateAndFilterDevices(List<AudioDevice> candidateDevices) {
if (candidateDevices.size() > MAX_DEVICE_COUNT) {
throw new IllegalArgumentException("Device count exceeds media engine constraint of " + MAX_DEVICE_COUNT);
return candidateDevices.stream()
.filter(device -> {
int sampleRate = device.getFormat().getSampleRate();
return SUPPORTED_SAMPLE_RATES.contains(sampleRate) && device.isAvailable();
.collect(Collectors.toList());
public void enforceMediaEngineConstraints(List<AudioDevice> devices) {
long activeCount = devices.stream().filter(AudioDevice::isActive).count();
if (activeCount > MAX_DEVICE_COUNT) {
throw new IllegalStateException("Active device count violates Genesys Cloud media engine limits");
The validateAndFilterDevices method checks sample rate compatibility and availability. The enforceMediaEngineConstraints method prevents routing failure by rejecting configurations that exceed platform limits.
Step 2: Construct Route Payloads with Volume Matrices and Mute Directives
Route payloads must reference device IDs explicitly. You will construct a volume control matrix and mute state directives before submission. The SDK expects RouteInfo objects that bundle these parameters atomically.
import java.util.*;
public class RoutePayloadBuilder {
public RouteInfo buildRoutePayload(List<AudioDevice> devices, Map<String, Float> volumeMatrix, Map<String, Boolean> muteDirectives) {
List<VolumeControl> volumeControls = new ArrayList<>();
List<MuteState> muteStates = new ArrayList<>();
for (AudioDevice device : devices) {
String deviceId = device.getId();
float volume = volumeMatrix.getOrDefault(deviceId, 1.0f);
boolean muted = muteDirectives.getOrDefault(deviceId, false);
volumeControls.add(new VolumeControl(deviceId, volume));
muteStates.add(new MuteState(deviceId, muted));
List<String> deviceIds = devices.stream().map(AudioDevice::getId).collect(Collectors.toList());
return new RouteInfo(
UUID.randomUUID().toString(),
deviceIds,
volumeControls,
muteStates,
System.currentTimeMillis()
The payload builder maps device IDs to volume levels and mute flags. You must ensure every referenced device ID exists in the validated device list. The SDK rejects payloads with orphaned references.
Step 3: Apply Atomic Configuration Updates with Format Verification
Audio path updates must be atomic. You will verify audio formats, trigger automatic level adjustments, and apply the route in a single transaction. This prevents mid-stream format mismatches and dropped packets.
import java.util.concurrent.atomic.AtomicReference;
public class AtomicRouteUpdater {
private final AudioRouter router;
private final AtomicReference<RouteInfo> activeRoute = new AtomicReference<>(null);
public AtomicRouteUpdater(AudioRouter router) {
this.router = router;
public void applyRouteAtomic(RouteInfo payload) throws Exception {
AudioFormat targetFormat = payload.getDeviceIds().stream()
.map(id -> router.getDeviceById(id))
.findFirst()
.map(AudioDevice::getFormat)
.orElseThrow(() -> new IllegalStateException("No valid audio format found for route"));
if (!isFormatCompatible(targetFormat)) {
throw new IllegalArgumentException("Audio format mismatch prevents atomic update");
triggerAutomaticLevelAdjustment(payload.getVolumeControls());
RouteInfo previous = activeRoute.getAndSet(payload);
router.setRoute(payload);
if (previous != null) {
cleanupPreviousRoute(previous);
private boolean isFormatCompatible(AudioFormat format) {
int channels = format.getChannels();
int bitsPerSample = format.getBitsPerSample();
return channels == 1 && (bitsPerSample == 16 || bitsPerSample == 32);
private void triggerAutomaticLevelAdjustment(List<VolumeControl> controls) {
controls.forEach(vc -> {
if (vc.getVolume() > 1.0f) {
vc.setVolume(1.0f);
} else if (vc.getVolume() < 0.0f) {
vc.setVolume(0.0f);
private void cleanupPreviousRoute(RouteInfo previous) {
previous.getDeviceIds().forEach(router::releaseDevice);
The applyRouteAtomic method locks the format verification, clamps volume levels to safe ranges, and swaps the route atomically. The SDK guarantees that setRoute applies all volume and mute directives simultaneously.
Step 4: Implement Device State Checking and Feedback Loop Prevention
During client scaling, simultaneous device additions can create acoustic feedback. You must verify device states and disable loopback paths before enabling routing.
public class FeedbackLoopPreventer {
public FeedbackLoopPreventer(AudioRouter router) {
public List<AudioDevice> sanitizeDevicesForRouting(List<AudioDevice> devices) {
return devices.stream().filter(device -> {
if (device.getType() == AudioDevice.Type.LOOPBACK) {
device.setEnabled(false);
return false;
if (device.getState() == AudioDevice.State.OVERRIDDEN) {
throw new IllegalStateException("Device " + device.getId() + " is in OVERRIDDEN state. Manual resolution required.");
return device.getState() == AudioDevice.State.READY || device.getState() == AudioDevice.State.ACTIVE;
}).collect(Collectors.toList());
public boolean verifyInputOutputSeparation(List<AudioDevice> devices) {
List<AudioDevice> inputs = devices.stream().filter(d -> d.getDirection() == AudioDevice.Direction.INPUT).toList();
List<AudioDevice> outputs = devices.stream().filter(d -> d.getDirection() == AudioDevice.Direction.OUTPUT).toList();
return !inputs.isEmpty() && !outputs.isEmpty() && inputs.stream().noneMatch(i -> outputs.contains(i));
The preventer removes loopback devices, rejects overridden states, and enforces strict input/output separation. This eliminates acoustic feedback during dynamic device scaling.
Step 5: Synchronize Routing Events via Webhook Callbacks
External audio mixers require real-time alignment. You will push routing state changes to a webhook endpoint with retry logic for 429 responses.
public class WebhookSyncManager {
private final String webhookUrl;
private final HttpClient httpClient;
public WebhookSyncManager(String webhookUrl) {
this.webhookUrl = webhookUrl;
this.httpClient = HttpClient.newBuilder().build();
public void syncRouteEvent(String eventType, Map<String, Object> payload) throws Exception {
String json = mapper.writeValueAsString(Map.of(
"event_type", eventType,
"timestamp", System.currentTimeMillis(),
"data", payload
.uri(URI.create(webhookUrl))
.header("X-Genesys-Event", eventType)
.POST(HttpRequest.BodyPublishers.ofString(json))
.build();
executeWithRetry(request, 3, 1000);
private void executeWithRetry(HttpRequest request, int maxRetries, long backoffMs) throws Exception {
int attempts = 0;
while (attempts < maxRetries) {
if (response.statusCode() == 429) {
long retryAfter = parseRetryAfter(response);
TimeUnit.MILLISECONDS.sleep(Math.max(retryAfter, backoffMs));
attempts++;
continue;
if (response.statusCode() >= 500) {
attempts++;
TimeUnit.MILLISECONDS.sleep(backoffMs);
continue;
if (response.statusCode() < 200 || response.statusCode() >= 300) {
throw new RuntimeException("Webhook sync failed with status " + response.statusCode());
return;
throw new RuntimeException("Max retries exceeded for webhook sync");
private long parseRetryAfter(HttpResponse<String> response) {
String header = response.headers().firstValue("Retry-After").orElse("1");
return Long.parseLong(header) * 1000;
} catch (NumberFormatException e) {
return 1000;
The sync manager implements exponential backoff for 429 rate limits and 5xx server errors. It serializes routing events with timestamps and pushes them to external mixers for alignment.
Step 6: Track Latency, Stability, and Generate Audit Logs
You must measure audio path latency and packet stability. Audit logs require REST API calls to Genesys Cloud with proper scope validation.
import com.genesys.cloud.client.sdk.api.ApiClient;
import com.genesys.cloud.client.sdk.api.ApiException;
import com.genesys.cloud.client.sdk.api.auth.OAuth;
import com.genesys.cloud.client.sdk.api.api.AnalyticsApi;
import com.genesys.cloud.client.sdk.api.model.AuditLogEntry;
public class AudioMetricsAndAudit {
private final AnalyticsApi analyticsApi;
private final Map<String, Double> latencyBuckets = new ConcurrentHashMap<>();
private final Map<String, Long> stabilityCounters = new ConcurrentHashMap<>();
public AudioMetricsAndAudit(ApiClient apiClient) {
this.analyticsApi = new AnalyticsApi(apiClient);
public void recordLatency(String deviceId, double latencyMs) {
latencyBuckets.merge(deviceId, latencyMs, Double::max);
public void recordStabilityEvent(String deviceId, boolean stable) {
stabilityCounters.merge(deviceId, stable ? 1L : 0L, Long::sum);
public void flushAuditLogs(List<Map<String, Object>> routingEvents) throws ApiException {
for (Map<String, Object> event : routingEvents) {
AuditLogEntry logEntry = new AuditLogEntry();
logEntry.setEntityId((String) event.get("deviceId"));
logEntry.setEntityType("audio_device");
logEntry.setAction((String) event.get("action"));
logEntry.setTimestamp(Instant.parse((String) event.get("timestamp")));
logEntry.setDetails(mapper.writeValueAsString(event));
analyticsApi.postAnalyticsConversationsDetailsQuery(
Map.of("view", "default", "timeRange", "lastHour"),
logEntry,
null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null, null
public Map<String, Object> getAudioEfficiencyReport() {
return Map.of(
"max_latency_ms", latencyBuckets,
"stability_rate", stabilityCounters,
"total_devices_tracked", latencyBuckets.size()
The metrics class tracks per-device latency peaks and stability counts. The flushAuditLogs method posts structured events to the Genesys Cloud analytics endpoint. You must include the analytics:read scope for this call.
import java.util.*;
public class GenesysAudioRouterApplication {
public static void main(String[] args) throws Exception {
String environment = "api.mypurecloud.com";
String clientId = System.getenv("GENESYS_CLIENT_ID");
String clientSecret = System.getenv("GENESYS_CLIENT_SECRET");
String webhookEndpoint = System.getenv("AUDIO_MIXER_WEBHOOK");
OAuthTokenManager tokenManager = new OAuthTokenManager(clientId, clientSecret, environment);
String accessToken = tokenManager.getAccessToken();
ApiClient apiClient = ApiClient.init(environment, accessToken);
apiClient.getAuth().setAccessToken(accessToken);
AudioRouter router = AudioRouter.getInstance(apiClient);
AudioRoutingEngine engine = new AudioRoutingEngine(router);
RoutePayloadBuilder builder = new RoutePayloadBuilder();
AtomicRouteUpdater updater = new AtomicRouteUpdater(router);
FeedbackLoopPreventer preventer = new FeedbackLoopPreventer(router);
WebhookSyncManager webhookSync = new WebhookSyncManager(webhookEndpoint);
AudioMetricsAndAudit metrics = new AudioMetricsAndAudit(apiClient);
List<AudioDevice> candidates = router.enumerateDevices();
List<AudioDevice> validated = engine.validateAndFilterDevices(candidates);
List<AudioDevice> sanitized = preventer.sanitizeDevicesForRouting(validated);
if (!preventer.verifyInputOutputSeparation(sanitized)) {
throw new IllegalStateException("Input/output separation verification failed");
Map<String, Float> volumeMatrix = new HashMap<>();
Map<String, Boolean> muteDirectives = new HashMap<>();
for (AudioDevice d : sanitized) {
volumeMatrix.put(d.getId(), 0.8f);
muteDirectives.put(d.getId(), d.getType() == AudioDevice.Type.INPUT);
RouteInfo payload = builder.buildRoutePayload(sanitized, volumeMatrix, muteDirectives);
updater.applyRouteAtomic(payload);
webhookSync.syncRouteEvent("ROUTE_APPLIED", Map.of(
"routeId", payload.getId(),
"devices", sanitized.stream().map(AudioDevice::getId).toList(),
"volumes", volumeMatrix
metrics.recordLatency(sanitized.get(0).getId(), 12.5);
metrics.recordStabilityEvent(sanitized.get(0).getId(), true);
List<Map<String, Object>> auditEvents = List.of(Map.of(
"deviceId", sanitized.get(0).getId(),
"action", "ROUTE_COMMITTED",
"timestamp", Instant.now().toString()
metrics.flushAuditLogs(auditEvents);
System.out.println("Audio routing applied successfully. Report: " + metrics.getAudioEfficiencyReport());
This module initializes authentication, validates devices, constructs payloads, applies atomic updates, prevents feedback, syncs via webhooks, and logs metrics. Replace environment variables with your credentials before execution.
- Cause: OAuth token expired or missing
client_credentialsscope. - Fix: Verify the
OAuthTokenManagerrefresh logic. Ensure the token is attached to both the Client SDKApiClientand REST API calls. - Code Fix: Add explicit token refresh before each API call. Check
tokenExpirytimestamp logic.
- Cause: Webhook sync or analytics flush exceeded rate limits.
- Fix: Implement exponential backoff. Parse the
Retry-Afterheader. TheWebhookSyncManageralready handles this, but verify thebackoffMsbaseline matches your tier limits. - Code Fix: Increase
backoffMsfrom 1000 to 2000 inexecuteWithRetry. Log retry attempts for visibility.
Error: IllegalStateException: Active device count violates media engine limits
- Cause: Attempted to route more than 8 devices simultaneously.
- Fix: Filter candidates before payload construction. Use
validateAndFilterDevicesto enforce the limit. - Code Fix: Add explicit size check before
builder.buildRoutePayload. Remove inactive devices from the candidate list.
Error: Audio format mismatch prevents atomic update
- Cause: Mixed sample rates or channel counts across devices.
- Fix: Enforce uniform format selection during validation. The
isFormatCompatiblemethod rejects non-mono or unsupported bit depths. - Code Fix: Normalize device formats using
router.setDeviceFormat(deviceId, targetFormat)before callingapplyRouteAtomic.
Error: Webhook sync failed with status 500
- Cause: External mixer endpoint rejected the payload structure.
- Fix: Validate JSON schema against the mixer API contract. Ensure
X-Genesys-Eventheader matches expected routing event types. - Code Fix: Add payload schema validation before serialization. Log the raw request body for debugging.
