Routing Calls
Hi
we have three routing points .service ,marketing and priority…distinguish service and marketing by PRI numbers
e.g last digit number
38 goes to marketing queue
36,37 numbers goes to service queue
but few days back we have problem occur that ..marketing calls goto right
but some service calls goto service point or some are goes to marketing
attached is the TSERVER logs
Usefull would be to post your strategy definition, URS logs and ConnID with exact DNIS to search. You are not expecting to someone read the whole TServer log file and analyze it all, right?
lol direct mode on ;D
F
Conn ID
007101b531d7dd5b
Attached is the URS LOGS
Call from 36 number and routed to Marketing queue instead of service queue
Bob,
There is some issue related to database lookup - URS reports DBServer as “closed” which mean that database is inaccessible. Please check log of DBServer for more information.
16:05:18.687_I_I_007101b531d7dd5b [07:38] HERE IS XDATA
_I_E_007101b531d7dd5b [09:04] error in strategy: 0015 Closed server
_I_I_007101b531d7dd5b [09:04] ASSIGN: __DBReturn(SCRIPT) ← STRING:
16:05:18.687 Int 20003 interaction 007101b531d7dd5b is routed to default
:stuck_out_tongue: the question looked interesting but when realized there was nothing to analyze…well, we are not magicians, right? :slight_smile:
