routeing between several agents
hi
I meet a question,when a call enters a route point ,then agent is ringing ,after 15 minutes,another agent does not ring .I donot know why not ring?
In T-Server7.6 ,I set agent-no-answer-action = recall.
here is log ,please help analysising the log.PBX is alcatel
@15:35:20.2960 {tscp.call {destructed} {uuid PB04U5BBU173RE232H2PI5DOCG00EHC7} {connection-id 006b01ba3bd56af7} {call-id 63351}}
CallCleanup: [1 out of 21] calls deleted
09/14/09@15:35:20.546 nasTimer expired for f779:f779:20002@02FE0558
NASData::Apply: current dest = ‘recall’, remaining = ↔
NASData::Apply: actual dest = ‘70069’, remaining = ↔
+++ RqHandler::RequestRedirectCall +++
got message from client <0>
device <20002> is replaced by <12853>
[12853/12853]: check device for ‘RequestRedirectCall’
@15:35:20.5460 [BSYNC] Trace: Send to backup (T-Server_Pri_Backup) [556]:
message EventUserEvent
AttributeServerRole 0
AttributeUserEvent RequestRedirectCall
AttributeOtherDN ‘70069’
AttributeThisDN ‘20002’
AttributeConnID 006b01ba3bd56ae0
AttributeCallState 7
attr_#1005 e6f1ad4a4cf70100
@15:35:20.5460 [BSYNC] Trace: Sent
party [f779:f779:20002@02FE0558] is to be answered and SSXfer to destination [70069]
emuRedir: action executed on <12853>, step = 0
*** Transaction Info:
Type/Oper. : 5 - 2
hostRef : 7ac0
ConnId[0] : (f779-1bee)-<(Unknown)>
SubjDev[0] : 12853 (Private)
LocalDev[0]: 12853 (Unknown)
H->S 23 bytes send, invoke id 31424 (x7ac0), 0[6] requests pending
— RqHandler::RequestRedirectCall —
+++ Resp::AnswerCall +++
Type/Oper. : 2 - 2
hostRef : 7ac0
*** PrivateList has 1 elements:
PData : Global CallID : e6f1ad4a4cf70100
[12853]: event received, for <RequestRedirectCall(RequestAnswerCall):0:0:196119:2>
— Resp::AnswerCall —
link (link-tcp) S->H: (0[6 / 3] requests pending)
09/14/09@15:35:20.750 cstaSwitchingEventDecode: Established event in progress
+++ Evt::Established +++
Type/Oper. : 1 - 6
crossRef : 13bb502
ConnId[1] : (f779-229c)-<(Trunk)>
SubjDev[1] : 12853 (Private)
LocalDev[0]: 20007 (Private)
LocalDev[1]: 70069 (Private)
LocalDev[2]: 70069 (Private)
Cause : 38
LocalInfo : 3
TimeStamp : <090914153532Z>
*** PrivateList has 2 elements:
PData : HybridLinkFlag = true
refDev <12853> (cref = ‘13BB502’)
Agent on <12853> is engaged in business call
PartyDN::Establish: for f779:f779:20002@02FE0558/alerting/Ok with cause (Distributed[38])
PartyDN::Activate: for f779:f779:20002@02FE0558/alerting/Ok with cause (Distributed[38])
emuRedir: action executed on <12853>, step = 1
Type/Oper. : 5 - 7
hostRef : 7ac1
LocalDev[1]: 70069 (Unknown)
H->S 34 bytes send, invoke id 31425 (x7ac1), 0[6] requests pending
— Evt::Established —
link (link-tcp) S->H: (1[6 / 3] requests pending)
cstaSwitchingEventDecode: AgentBusy event in progress
+++ Evt::AgentBusy +++
Type/Oper. : 1 - 207
crossRef : 13bb502
SubjDev[0] : 82800 (Unknown)
LocalDev[0]: 12853 (Private)
LocalDev[1]: 12853 (Unknown)
— Evt::AgentBusy —
cstaSwitchingEventDecode: Held event in progress
+++ Evt::Held +++
Type/Oper. : 1 - 8
crossRef : 13bb502
LocalInfo : 4
PartyDN::Suspend: for f779:f779:20002@02FE0558/established/Ok with cause (Null[0])
— Evt::Held —
Type/Oper. : 1 - 6
crossRef : 12d2800
ConnId[0] : (f77a-225c)-<(Trunk)>
Cause : 46
LocalInfo : 3
PData : Network Time Slot: 0
refDev <20007> (cref = ‘12D2800’)
PartyDN::Establish: for f779:f77a:20007@02C059F8/established/Ok with cause (NetworkSignal[46])
+++ Err::<StateIncompatibility (NoActiveCall)> +++
Type/Oper. : 3 - 516 <Error : <StateIncompatibility (NoActiveCall)>>
hostRef : 7ac1
[12853]: event received, for <RequestRedirectCall(RequestSingleStepTransfer):0:0:196119:2>
reapply failed NAS deflection
NASData::Apply: current dest = ‘release’, remaining = ↔
NASData::Apply: actual dest = ‘release’, remaining = ↔
+++ RqHandler::RequestReleaseCall +++
[12853/12853]: check device for ‘RequestReleaseCall’
Type/Oper. : 5 - 5
hostRef : 7ac2
H->S 23 bytes send, invoke id 31426 (x7ac2), 1[7] requests pending
— RqHandler::RequestReleaseCall —
— Err::<StateIncompatibility (NoActiveCall)> —
link (link-tcp) S->H: (1[7 / 3] requests pending)
+++ Resp::ClearConnection +++
Type/Oper. : 2 - 5
hostRef : 7ac2
[12853]: event received, for RequestReleaseCall:0:1:0:196120
— Resp::ClearConnection —
link (link-tcp) S->H: (0[7 / 4] requests pending)
09/14/09@15:35:20.968 cstaSwitchingEventDecode: Held event in progress
+++ Evt::Held +++
Type/Oper. : 1 - 8
crossRef : 13bb502
Cause : 27
LocalInfo : 4
EventError suppressed (internal client 0)
TmRequest::ResetCtx:RequestReleaseCall:0:12853: context (0:196120) flags ‘400’ reset
— Evt::Held —
what do you mean by after 15 mins agent does not ring..?
dont understand
I dont understand neither. I see some attempts to transfer a call, which is the scenario?
hello
when a call enter a route point , then a free agent (A) is ringing withen 15minutes,after 15 minutes this call will route to another free agent(B).however , B doesn’t ring ,and A is ringring all the time. with the telephone(alcatel-lucent 4038) displying “recall of hold”. I don’t know why ,please help me to analysis the problem. Thank you.
with the T-server version 7.6 and the attrbutes
agent-no-answer-timer 15,
agent-no-answer-overflow recall,
agent-no-answer-action ready.
It should be reroute ao the call goes again to the queue (RSI) and the action = not ready.
hello
the log below shows us that because of the stateIncompatibitity brings out NoActiveCall,so the result is “reapply failed NAS deflection”.I don’t know why the log has this segment ? .
   as you give me addvise that revise the attibute "agent-no-answer-action = notready",I have tried but the call doesn't ring from one agent to another agent while the agent-no-answer-timeout expires.
   Please help me  to analysis this terrible problem.Thank you!
hostRef : 7ac1
Kay,
You posted just snippet of T-Server log showing that overflow destination is ‘70069’. What does this number represents - RSI Routing Point, RSI Processing Group, CCD Pilot etc.?
I’m not able to recall all details but I do remember that action “recall” didn’t work properly on Alcatel switches with RSI as number reported in event’s attribute “ThisQueue” isn’t RSI Routing Point number but some other telephony object.
I have this scenario working:
agent-no-answer-action=notready
agent-no-answer-overflow=recall
agent-no-answer-timeout=20 (seconds) never seen in OXE a phone ringing for 15 minutes…this means you changed some basic timers in OXE that affects administrative and call center extensions, I would never recommend such setting.
OXE R9 and TServer 7.6 by the way
Hi
Thank you for your suggestion, “70069” is the RSI Routing Point which is the distinaction.
In my project , not all agent can’t recall the RSI Routing Point ,but only some agent can’t recall the RSI Routing Point . I don’t understand why the agent rcall the RSI Routing Point successfully.
In what way can bring out “StateIncompatibilty”, Thank you!
And the version of T-Server is 7.6 and PBX is AlcatelA4400.
hostRef : 7ac1
