Rotating OAuth Client Secrets Without Downtime: A Step-by-Step Implementation Guide
  • You will build a secure credential rotation mechanism that updates your Genesys Cloud OAuth client secret in the Admin console while maintaining active token generation for your application.
  • This tutorial utilizes the Genesys Cloud Platform APIs, specifically the Organization and OAuth management endpoints, alongside standard HTTP client libraries.
  • The implementation is demonstrated in Python using the requests library, but the logic applies directly to JavaScript, Java, C#, and Go implementations.
Before executing the code in this tutorial, you must have the following resources and permissions:
  • Genesys Cloud Account: An organization with administrative privileges.
  • OAuth Client: An existing OAuth client created in the Genesys Cloud Admin console. You need the Client ID.
  • Admin Credentials: A user account with the Organization Administrator role or custom permissions that include oauth:client:write and organization:read.
  • Current Secret: The active client secret for the OAuth client you intend to rotate.
  • Python Environment: Python 3.8+ with the requests and pyjwt libraries installed.
    • Install dependencies: pip install requests pyjwt
Rotating a secret requires authenticated access to the Genesys Cloud API. Since you are modifying security credentials, you must authenticate as a user with sufficient permissions. We will use the Resource Owner Password Credentials (ROPC) flow for this administrative task. This flow exchanges a username and password for an access token.
Important: Do not use the OAuth client whose secret you are rotating to authenticate this process. Use a dedicated admin service account or a human administrator’s credentials.
The following Python function establishes the initial authenticated session. It retrieves an access token using the admin credentials.
import requests
import json
# Configuration
GENESYS_BASE_URL = "https://api.mypurecloud.com"
ADMIN_USERNAME = "admin@yourcompany.com"
ADMIN_PASSWORD = "YourStrongAdminPassword"
def get_admin_access_token(username: str, password: str) -> str:
    Authenticates as an admin user to obtain an access token for API operations.
    Uses the Resource Owner Password Credentials grant type.
    url = f"{GENESYS_BASE_URL}/oauth/token"
    headers = {
        "Content-Type": "application/x-www-form-urlencoded",
        "Accept": "application/json"
    data = {
        "grant_type": "password",
        "username": username,
        "password": password
        response = requests.post(url, headers=headers, data=data)
        response.raise_for_status()
        token_data = response.json()
        return token_data.get("access_token")
        print(f"Authentication failed: {e.response.status_code} - {e.response.text}")
        raise
        print(f"An error occurred during authentication: {e}")
        raise
# Execute authentication
admin_token = get_admin_admin_access_token(ADMIN_USERNAME, ADMIN_PASSWORD)
print(f"Admin Access Token obtained: {admin_token[:10]}...")
Step 1: Retrieve the Current OAuth Client Configuration
Before generating a new secret, you must identify the specific OAuth client you intend to update. Genesys Cloud allows multiple OAuth clients per organization. You need the id of the specific client.
We will query the list of OAuth clients. The endpoint /api/v2/oauth/clients returns a paginated list of clients associated with the authenticated user’s organization.
Required Scope: oauth:client:read
def get_oauth_client_by_id(client_id: str, access_token: str) -> dict:
    Retrieves the configuration of a specific OAuth client by its ID.
    url = f"{GENESYS_BASE_URL}/api/v2/oauth/clients/{client_id}"
    headers = {
        "Authorization": f"Bearer {access_token}",
        response = requests.get(url, headers=headers)
        return response.json()
        if e.response.status_code == 404:
            print(f"OAuth Client with ID {client_id} not found.")
        elif e.response.status_code == 403:
            print("Forbidden: Check if your admin account has 'oauth:client:read' permissions.")
        else:
            print(f"HTTP Error: {e.response.status_code} - {e.response.text}")
        raise
        print(f"Error retrieving client: {e}")
        raise
# Replace with your actual OAuth Client ID
TARGET_CLIENT_ID = "your-oauth-client-id-here"
    current_client_config = get_oauth_client_by_id(TARGET_CLIENT_ID, admin_token)
    print(f"Client Name: {current_client_config.get('name')}")
    print(f"Client ID: {current_client_config.get('id')}")
    print(f"Current Secret Status: {'Active' if current_client_config.get('secret') else 'Unknown'}")
    print(f"Failed to retrieve client configuration: {e}")
Step 2: Generate the New Client Secret
Genesys Cloud provides a dedicated endpoint to rotate the client secret. This endpoint replaces the existing secret with a newly generated one. The old secret becomes invalid immediately after this call.
Critical Logic: To avoid downtime, your application must be capable of using the new secret immediately. However, the API call itself is atomic. You cannot have two active secrets simultaneously for the same grant type in a way that allows seamless fallback without application-level logic. The standard pattern for “zero downtime” in this context is:
  1. Generate the new secret via API.
  2. Update your application’s configuration store (e.g., HashiCorp Vault, AWS Secrets Manager, or environment variables) with the new secret.
  3. Restart the application or reload its configuration to pick up the new secret.
  4. (Optional) If your application supports multiple secrets or has a grace period, you might handle the transition differently, but Genesys Cloud replaces the secret atomically.
The endpoint to rotate the secret is PUT /api/v2/oauth/clients/{id}/secret.
Required Scope: oauth:client:write
def rotate_client_secret(client_id: str, access_token: str) -> str:
    Rotates the client secret for the specified OAuth client.
    Returns the new client secret.
    url = f"{GENESYS_BASE_URL}/api/v2/oauth/clients/{client_id}/secret"
    headers = {
        "Accept": "application/json",
    # The body is empty for this endpoint; the API generates the secret.
    body = {}
        response = requests.put(url, headers=headers, json=body)
        new_secret_data = response.json()
        new_secret = new_secret_data.get("secret")
        if not new_secret:
            raise ValueError("API response did not contain a new secret.")
        print(f"Secret rotated successfully. New secret: {new_secret}")
        return new_secret
        if e.response.status_code == 401:
            print("Unauthorized: Check your admin access token.")
            print("Forbidden: Check if your admin account has 'oauth:client:write' permissions.")
        else:
        raise
        print(f"Error rotating secret: {e}")
        raise
# Execute the rotation
    new_secret = rotate_client_secret(TARGET_CLIENT_ID, admin_token)
    # In a production environment, you would now store 'new_secret' securely
    # and trigger a configuration reload for your application.
    print(f"Secret rotation failed: {e}")
Step 3: Validate the New Secret
After rotating the secret, you must verify that the new secret works correctly. This step ensures that your application can successfully authenticate using the new credentials. We will use the Client Credentials grant type to test the new secret.
Required Scope: oauth:client:write (for the admin user) and the new client must have the appropriate grant types enabled.
def validate_new_secret(client_id: str, new_secret: str) -> bool:
    Validates the new client secret by attempting to obtain an access token.
    Uses the Client Credentials grant type.
    headers = {
    data = {
        "client_id": client_id,
        "client_secret": new_secret
        if "access_token" in token_data:
            print("Validation successful: New secret is valid.")
            return True
        else:
            print("Validation failed: Response did not contain an access token.")
            return False
        print(f"Validation failed: {e.response.status_code} - {e.response.text}")
        return False
        print(f"Error validating secret: {e}")
        return False
# Validate the newly generated secret
is_valid = validate_new_secret(TARGET_CLIENT_ID, new_secret)
if is_valid:
    print("System is ready for production use with the new secret.")
else:
    print("Warning: New secret validation failed. Do not deploy yet.")
The following script combines all steps into a single executable module. It handles the authentication, rotation, and validation process. It includes basic error handling and logging.
import requests
import sys
import os
# Configuration
ADMIN_USERNAME = os.getenv("GENESYS_ADMIN_USERNAME", "admin@yourcompany.com")
ADMIN_PASSWORD = os.getenv("GENESYS_ADMIN_PASSWORD", "YourStrongAdminPassword")
TARGET_CLIENT_ID = os.getenv("GENESYS_TARGET_CLIENT_ID", "your-oauth-client-id-here")
    headers = {
    data = {
        return response.json().get("access_token")
        sys.exit(1)
        sys.exit(1)
    headers = {
        response = requests.put(url, headers=headers, json={})
        new_secret = response.json().get("secret")
        if not new_secret:
        return new_secret
        print(f"Rotation failed: {e.response.status_code} - {e.response.text}")
        sys.exit(1)
        sys.exit(1)
    Validates the new client secret.
    headers = {
    data = {
        return "access_token" in response.json()
        return False
        return False
def main():
    print("Starting OAuth Client Secret Rotation Process...")
    # Step 1: Authenticate as Admin
    print("1. Authenticating as Admin...")
    admin_token = get_admin_access_token(ADMIN_USERNAME, ADMIN_PASSWORD)
    # Step 2: Rotate Secret
    print("2. Rotating Client Secret...")
    print(f"   New Secret Generated: {new_secret[:10]}...")
    # Step 3: Validate New Secret
    print("3. Validating New Secret...")
    if is_valid:
        print("SUCCESS: Secret rotation and validation completed.")
        print(f"IMPORTANT: Update your application configuration with the new secret: {new_secret}")
    else:
        print("FAILURE: New secret validation failed. Please investigate.")
        sys.exit(1)
    main()
  • Cause: The admin access token is invalid, expired, or missing.
  • Fix: Ensure the ADMIN_USERNAME and ADMIN_PASSWORD are correct. Verify that the user account is not locked or disabled. Check that the ROPC grant type is enabled for the admin user’s OAuth client (if using a service account) or that the user has direct login permissions.
Error: 403 Forbidden
  • Cause: The admin user lacks the required permissions to modify OAuth clients.
  • Fix: Verify that the user has the Organization Administrator role or a custom role with oauth:client:write permissions. In Genesys Cloud, permissions are hierarchical. Ensure the user is assigned to the correct organization if you are using a multi-org setup.
Error: 404 Not Found
  • Cause: The TARGET_CLIENT_ID does not exist in the current organization.
  • Fix: Double-check the Client ID. You can list all clients using GET /api/v2/oauth/clients to verify the ID exists. Ensure you are targeting the correct organization if your admin account has access to multiple organizations.
  • Cause: You have exceeded the rate limit for the OAuth client or the admin user.
  • Fix: Implement exponential backoff in your requests. Genesys Cloud enforces rate limits to protect the platform. If you are rotating secrets frequently, consider spacing out the operations.
Error: Validation Failed (New Secret Invalid)
  • Cause: The new secret was generated but failed to authenticate.
  • Fix: This is rare but can occur if the OAuth client is disabled or if the grant types are misconfigured. Check the OAuth client settings in the Admin console to ensure the Client Credentials grant type is enabled if you are using it for validation.
