Rotating NICE CXone Pure Connect IVR Prompts via REST APIs with Python
- A Python automation pipeline that validates, uploads, and atomically rotates IVR prompt sets in NICE CXone Pure Connect.
- The solution uses the NICE CXone Platform REST APIs for media management, prompt set rotation, IVR reload triggers, and audit logging.
- Python 3.9+ with
httpx,pydantic,mutagen, andpython-magicfor production-grade execution.
- OAuth 2.0 Client Credentials grant configured in NICE CXone Developer Console
- Required scopes:
prompt:write,media:upload,ivr:manage,webhook:write,audit:read - Python 3.9+ runtime environment
- External dependencies:
pip install httpx pydantic mutagen python-magic aiofiles
NICE CXone uses standard OAuth 2.0 client credentials flow. The following asynchronous client manages token acquisition, caching, and automatic refresh before expiration.
import os
import httpx
from typing import Optional
CXONE_BASE_URL = "https://platform.niceincontact.com"
TOKEN_ENDPOINT = f"{CXONE_BASE_URL}/oauth/token"
class CXoneAuth:
def __init__(self, client_id: str, client_secret: str):
self.client_id = client_id
self.expires_at: float = 0.0
if self.token and time.time() < self.expires_at - 60:
return self.token
response = await client.post(
TOKEN_ENDPOINT,
data={
"scope": "prompt:write media:upload ivr:manage webhook:write audit:read"
auth=(self.client_id, self.client_secret)
response.raise_for_status()
payload = response.json()
self.token = payload["access_token"]
self.expires_at = time.time() + payload["expires_in"]
return self.token
async def get_headers(self) -> dict:
token = await self.get_token()
Step 1: Audio Validation and Storage Quota Pipeline
Telephony constraints require strict MP3 encoding verification, file size limits, and duration boundaries before upload. NICE CXone enforces a maximum prompt size of 15 MB and a playback duration limit of 60 seconds. This pipeline validates files locally, checks storage quota via the platform API, and rejects non-compliant assets before network transmission.
import httpx
import mutagen
import magic
from pathlib import Path
from pydantic import BaseModel, ValidationError
from typing import List
MAX_FILE_SIZE = 15 * 1024 * 1024 # 15 MB
MAX_DURATION = 60.0 # seconds
class PromptValidationResult(BaseModel):
file_path: str
is_valid: bool
mime_type: str
duration_seconds: float
file_size_bytes: int
error: Optional[str] = None
async def validate_prompt_file(file_path: str) -> PromptValidationResult:
path = Path(file_path)
if path.stat().st_size > MAX_FILE_SIZE:
return PromptValidationResult(
file_path=file_path, is_valid=False,
mime_type="", duration_seconds=0.0, file_size_bytes=path.stat().st_size,
error="File exceeds 15 MB telephony constraint"
mime = magic.Magic(mime=True)
detected_mime = mime.from_file(str(path))
if detected_mime != "audio/mpeg":
mime_type=detected_mime, duration_seconds=0.0, file_size_bytes=path.stat().st_size,
error="Invalid encoding. Expected audio/mpeg (MP3)"
audio = mutagen.File(str(path))
duration = audio.info.length if audio and audio.info else 0.0
if duration > MAX_DURATION:
mime_type=detected_mime, duration_seconds=duration, file_size_bytes=path.stat().st_size,
error=f"Duration {duration:.2f}s exceeds 60s telephony limit"
file_path=file_path, is_valid=True,
error=f"MP3 parsing failed: {str(e)}"
async def check_storage_quota(auth: CXoneAuth, headers: dict) -> dict:
"""Queries CXone media quota endpoint to prevent upload rejection."""
response = await client.get(
f"{CXONE_BASE_URL}/api/v1/media/quota",
headers=headers
return response.json()
Step 2: Atomic Prompt Rotation and IVR Reload Trigger
Prompt rotation requires an atomic POST operation that swaps the active audio matrix, applies a swap directive, and triggers an IVR reload to ensure seamless caller experience. The payload contains prompt references, matrix configuration, and a swap directive. The API returns a rotation transaction ID for tracking.
import httpx
from typing import Dict, Any
async def rotate_prompt_set(
auth: CXoneAuth,
prompt_set_id: str,
prompt_references: List[Dict[str, str]],
audio_matrix: Dict[str, Any],
swap_directive: str,
fallback_prompt_id: str
) -> dict:
headers = await auth.get_headers()
rotation_payload = {
"promptSetId": prompt_set_id,
"prompts": prompt_references,
"audioMatrix": audio_matrix,
"swapDirective": swap_directive,
"fallbackPromptId": fallback_prompt_id,
"reloadIvr": True
async with httpx.AsyncClient(timeout=30.0) as client:
f"{CXONE_BASE_URL}/api/v1/prompts/{prompt_set_id}/rotate",
headers=headers,
json=rotation_payload
retry_after = int(response.headers.get("Retry-After", 5))
headers=headers,
Step 3: Webhook Synchronization and Audit Logging
External content libraries must synchronize with prompt rotation events. This step registers a webhook for prompt rotation notifications, tracks latency and swap success rates, and generates audit logs for telephony governance. Audit logs are paginated to handle high-volume environments.
import asyncio
async def register_rotation_webhook(auth: CXoneAuth, webhook_url: str) -> dict:
webhook_config = {
"name": "PromptRotationSync",
"url": webhook_url,
"events": ["prompt.rotated", "prompt.swap.completed"],
"secret": os.getenv("WEBHOOK_SECRET", "default-secret")
f"{CXONE_BASE_URL}/api/v1/webhooks",
headers=headers,
json=webhook_config
async def log_rotation_audit(
auth: CXoneAuth,
prompt_set_id: str,
rotation_id: str,
latency_ms: float,
success: bool,
fallback_triggered: bool
) -> dict:
audit_entry = {
"entity": "prompt_rotation",
"entityId": prompt_set_id,
"transactionId": rotation_id,
"metrics": {
"latency_ms": latency_ms,
"success": success,
"fallback_triggered": fallback_triggered
"governanceTag": "telephony-prompt-rotation"
f"{CXONE_BASE_URL}/api/v1/audit/logs",
headers=headers,
json=audit_entry
async def fetch_audit_logs(auth: CXoneAuth, page: int = 1, page_size: int = 20) -> dict:
headers=headers,
params={"entity": "prompt_rotation", "page": page, "pageSize": page_size}
The following script orchestrates validation, upload, atomic rotation, webhook registration, and audit logging. Replace environment variables with your NICE CXone credentials and prompt set identifier.
import os
import asyncio
import httpx
# Import classes and functions from previous steps
# from auth_module import CXoneAuth
# from validation_module import validate_prompt_file, check_storage_quota
# from rotation_module import rotate_prompt_set, register_rotation_webhook, log_rotation_audit
async def run_prompt_rotator():
client_id = os.getenv("CXONE_CLIENT_ID")
client_secret = os.getenv("CXONE_CLIENT_SECRET")
prompt_set_id = os.getenv("CXONE_PROMPT_SET_ID")
webhook_url = os.getenv("CXONE_WEBHOOK_URL")
prompt_files = os.getenv("PROMPT_FILES", "/tmp/prompts/welcome.mp3,/tmp/prompts/menu.mp3").split(",")
auth = CXoneAuth(client_id, client_secret)
# Step 1: Validate all prompts
valid_prompts = []
for f in prompt_files:
result = await validate_prompt_file(f.strip())
if not result.is_valid:
print(f"Validation failed for {result.file_path}: {result.error}")
return
valid_prompts.append({
"filePath": result.file_path,
"duration": result.duration_seconds,
"size": result.file_size_bytes
# Step 2: Check quota
quota = await check_storage_quota(auth, headers)
if quota.get("availableSpaceBytes", 0) < sum(p["size"] for p in valid_prompts):
print("Insufficient storage quota for prompt rotation")
return
# Step 3: Construct rotation payload
prompt_references = [{"id": f"prompt_{i}", "path": p["filePath"]} for i, p in enumerate(valid_prompts)]
audio_matrix = {
"channels": 2,
"sampleRate": 48000,
"bitrate": 128
swap_directive = "ATOMIC_SWAP_WITH_FALLBACK"
fallback_prompt_id = "prompt_fallback_default"
# Step 4: Execute atomic rotation
start_time = time.time()
rotation_result = await rotate_prompt_set(
auth, prompt_set_id, prompt_references, audio_matrix, swap_directive, fallback_prompt_id
success = True
fallback_triggered = rotation_result.get("fallbackUsed", False)
success = False
fallback_triggered = False
print(f"Rotation failed with status {e.response.status_code}")
rotation_result = {"transactionId": "failed"}
# Step 5: Register webhook and log audit
await register_rotation_webhook(auth, webhook_url)
await log_rotation_audit(
auth, prompt_set_id, rotation_result.get("transactionId", "unknown"),
latency_ms, success, fallback_triggered
print(f"Prompt rotation completed. Latency: {latency_ms:.2f}ms, Success: {success}")
asyncio.run(run_prompt_rotator())
- What causes it: Expired or missing OAuth access token. The client credentials grant may have failed, or the token cache returned a stale credential.
- How to fix it: Verify
CXONE_CLIENT_IDandCXONE_CLIENT_SECRETenvironment variables. Ensure theget_tokenmethod refreshes whentime.time() >= self.expires_at - 60. - Code showing the fix:
# Ensure token refresh logic accounts for network latency
return self.token
# Force refresh
response = await client.post(TOKEN_ENDPOINT, data=..., auth=...)
Error: 403 Forbidden
- What causes it: The OAuth token lacks required scopes for the target endpoint. Prompt rotation requires
prompt:writeandivr:manage. - How to fix it: Update the OAuth client configuration in NICE CXone Developer Console to include all required scopes. Regenerate the token after scope modification.
# Verify scope string matches platform requirements
scope_string = "prompt:write media:upload ivr:manage webhook:write audit:read"
response = await client.post(TOKEN_ENDPOINT, data={"grant_type": "client_credentials", "scope": scope_string}, auth=...)
Error: 400 Bad Request (MP3 Encoding or Schema Validation)
- What causes it: The audio matrix configuration conflicts with telephony constraints, or the MP3 file contains unsupported codec parameters. CXone requires 48kHz sample rate and stereo channels for IVR playback.
- How to fix it: Validate encoding parameters before submission. Use
mutagento verify header compliance and reject files with variable bitrate encoding. - Code showing the fix:
if audio and audio.info:
if audio.info.sample_rate != 48000 or audio.info.channels != 2:
return PromptValidationResult(..., error="IVR requires 48kHz stereo encoding")
Error: 413 Payload Too Large
- What causes it: The combined prompt set exceeds the 15 MB per file limit or the endpoint request body threshold.
- How to fix it: Split large prompt sets into smaller logical groups. Compress audio to 128 kbps constant bitrate before upload.
return PromptValidationResult(..., error="File exceeds 15 MB telephony constraint")
- What causes it: Rate limiting triggered by rapid rotation attempts or concurrent webhook registrations. CXone enforces per-tenant request quotas.
- How to fix it: Implement exponential backoff with jitter. Respect the
Retry-Afterheader returned by the platform. - Code showing the fix:
response = await client.post(url, headers=headers, json=payload)
Error: 503 Service Unavailable (IVR Reload Busy)
- What causes it: The IVR engine is currently processing a configuration update or handling peak call volume. Atomic reloads are blocked until the routing table stabilizes.
- How to fix it: Poll the IVR status endpoint before triggering reloads. Implement a circuit breaker pattern for rotation operations.
async def wait_for_ivr_ready(auth: CXoneAuth, max_retries: int = 5):
for _ in range(max_retries):
async with httpx.AsyncClient(timeout=5.0) as client:
resp = await client.get(f"{CXONE_BASE_URL}/api/v1/ivr/status", headers=headers)
if resp.json().get("status") == "READY":
return True
await asyncio.sleep(2)
return False
