Rotating Genesys Cloud Recording Policies via Java SDK with Validation and Webhook Sync
- A Java service that constructs, validates, and atomically updates Genesys Cloud recording policies to enforce retention cycles and storage limits.
- This tutorial uses the Genesys Cloud
/api/v2/recording/policiesendpoint and the officialgenesyscloud-java-sdk. - The implementation is written in Java 17 with explicit lifecycle calculation, 429 retry logic, webhook synchronization, and audit logging.
- OAuth 2.0 Client Credentials flow with scopes:
recording:policy:write,recording:policy:read - Genesys Cloud Java SDK version 23.10.0 or newer
- Java Development Kit 17 or newer
- Maven dependency:
com.genesiscloud.sdk:genesyscloud-java-sdk:23.10.0 - External dependencies:
com.google.code.gson:gson:2.10.1for JSON serialization,java.net.http(built into Java 11+) for webhook dispatch
The Genesys Cloud Java SDK manages token acquisition and refresh automatically when initialized with client credentials. You must configure the environment with your OAuth client ID, client secret, and login center URL. The SDK caches the access token and handles refresh tokens transparently.
import com.genesiscloud.sdk.auth.AuthApi;
import com.genesiscloud.sdk.client.PlatformClient;
import com.genesiscloud.sdk.auth.AuthClient;
public class GenesysAuth {
public static PlatformClient initializePlatformClient() {
PlatformClient platformClient = PlatformClient.create();
AuthApi authApi = AuthApi.create(platformClient);
AuthClient authClient = AuthClient.builder()
.clientId(System.getenv("GENESYS_CLIENT_ID"))
.clientSecret(System.getenv("GENESYS_CLIENT_SECRET"))
.loginCenter(System.getenv("GENESYS_LOGIN_CENTER"))
.build();
authApi.setAuthClient(authClient);
return platformClient;
The AuthClient builder stores credentials securely. The SDK throws an ApiException with HTTP 401 if the client credentials are invalid or the login center URL is malformed. Always validate environment variables before initialization.
Step 1: Initialize SDK and Validate Policy Schema
Before modifying any recording policy, you must verify that the incoming rotation parameters comply with Genesys Cloud storage constraints and maximum retention limits. Genesys Cloud enforces a maximum retention period (typically 730 days) and storage quotas per environment. This step constructs a validation pipeline that rejects invalid inputs early.
import java.time.LocalDate;
import java.time.temporal.ChronoUnit;
public class PolicyValidator {
private static final int MAX_RETENTION_DAYS = 730;
private static final long MAX_STORAGE_BYTES = 50L * 1024 * 1024 * 1024 * 1024; // 50 TB
public static void validateRotationParameters(int retentionDays, long estimatedSizePerDayBytes, String policyId) {
if (retentionDays <= 0 || retentionDays > MAX_RETENTION_DAYS) {
throw new IllegalArgumentException(
String.format("Retention period %d days exceeds maximum limit of %d days.", retentionDays, MAX_RETENTION_DAYS)
long projectedStorageBytes = retentionDays * estimatedSizePerDayBytes;
if (projectedStorageBytes > MAX_STORAGE_BYTES) {
String.format("Projected storage %d bytes exceeds environment limit of %d bytes.",
projectedStorageBytes, MAX_STORAGE_BYTES)
if (policyId == null || policyId.isBlank()) {
throw new IllegalArgumentException("Policy reference identifier cannot be null or empty.");
The validation method checks the retention matrix against hard limits. It calculates the lifecycle storage projection by multiplying daily ingestion estimates by the retention window. If the projection exceeds the configured cap, the method throws an exception before any API call occurs. This prevents 400 Bad Request responses from the platform and avoids partial state mutations.
Step 2: Construct Rotation Payload and Calculate Lifecycle Metrics
Genesys Cloud recording policies use a structured JSON schema for updates. You must construct the payload using the official SDK models to ensure type safety and format verification. The rotation directive maps to the retention and archive objects within the RecordingPolicy model.
import com.genesiscloud.sdk.model.RecordingPolicy;
import com.genesiscloud.sdk.model.RecordingPolicyRetention;
import com.genesiscloud.sdk.model.RecordingPolicyArchive;
import com.genesiscloud.sdk.model.RecordingPolicyStorage;
public class RotationPayloadBuilder {
public static RecordingPolicy buildRotationPayload(String policyId, int retentionDays, String archiveLocation) {
RecordingPolicy policy = new RecordingPolicy();
policy.setId(policyId);
RecordingPolicyRetention retention = new RecordingPolicyRetention();
retention.setDays(retentionDays);
retention.setArchiveRetentionDays(retentionDays / 2); // Archive half the retention window
policy.setRetention(retention);
RecordingPolicyArchive archive = new RecordingPolicyArchive();
archive.setEnable(true);
archive.setArchiveLocation(archiveLocation);
policy.setArchive(archive);
RecordingPolicyStorage storage = new RecordingPolicyStorage();
storage.setEnable(true);
policy.setStorage(storage);
return policy;
The RecordingPolicy model enforces the correct schema structure. The retention object defines the active cycle duration. The archive object configures automatic archive triggers when the cycle reaches its threshold. The SDK serializes this model into the exact JSON structure expected by /api/v2/recording/policies/{id}. You must set the id field to ensure the PUT operation targets the correct resource.
Step 3: Execute Atomic PUT with Retry and Webhook Sync
The core rotation logic performs an atomic HTTP PUT operation. Genesys Cloud returns HTTP 429 when rate limits are exceeded. This step implements exponential backoff retry logic and dispatches a synchronization webhook to an external storage manager upon success.
import com.genesiscloud.sdk.api.RecordingApi;
import com.genesiscloud.sdk.client.ApiException;
import java.net.URI;
import java.util.logging.Logger;
import java.util.logging.Level;
public class PolicyRotator {
private static final Logger logger = Logger.getLogger(PolicyRotator.class.getName());
private static final int MAX_RETRIES = 3;
private static final long INITIAL_BACKOFF_MS = 1000;
public static void executeRotation(RecordingApi recordingApi, RecordingPolicy policy, String webhookUrl) throws Exception {
long startTime = System.nanoTime();
int attempt = 0;
boolean success = false;
while (attempt < MAX_RETRIES) {
recordingApi.putRecordingPolicy(policy.getId(), policy);
success = true;
break;
} catch (ApiException e) {
if (e.getCode() == 429 && attempt < MAX_RETRIES - 1) {
long backoff = INITIAL_BACKOFF_MS * (long) Math.pow(2, attempt);
logger.warning(String.format("Rate limited (429). Retrying in %d ms...", backoff));
TimeUnit.MILLISECONDS.sleep(backoff);
attempt++;
} else {
throw e;
long latencyMs = TimeUnit.NANOSECONDS.toMillis(System.nanoTime() - startTime);
if (success) {
dispatchWebhook(webhookUrl, policy.getId(), retentionDays, latencyMs);
logger.info(String.format("Policy %s rotated successfully. Latency: %d ms.", policy.getId(), latencyMs));
private static void dispatchWebhook(String webhookUrl, String policyId, int retentionDays, long latencyMs) {
String payload = String.format(
"{\"policyId\":\"%s\",\"retentionDays\":%d,\"latencyMs\":%d,\"timestamp\":\"%s\"}",
policyId, retentionDays, latencyMs, java.time.Instant.now().toString()
HttpClient client = HttpClient.newHttpClient();
.uri(URI.create(webhookUrl))
.POST(HttpRequest.BodyPublishers.ofString(payload))
.timeout(java.time.Duration.ofSeconds(10))
.build();
HttpResponse<String> response = client.send(request, HttpResponse.BodyHandlers.ofString());
if (response.statusCode() >= 200 && response.statusCode() < 300) {
logger.info("Webhook synchronized successfully for policy " + policyId);
} else {
logger.warning("Webhook returned status " + response.statusCode());
} catch (Exception e) {
logger.log(Level.SEVERE, "Failed to dispatch webhook for policy " + policyId, e);
The retry loop catches ApiException with status code 429 and applies exponential backoff. The PUT operation is atomic. If the request succeeds, the method calculates the request latency and triggers a webhook to an external storage manager. The webhook payload contains the policy reference, retention duration, and latency metrics for alignment tracking.
Step 4: Track Metrics and Generate Audit Logs
Governance requires persistent audit trails and efficiency tracking. This step implements a metrics collector that records cycle success rates, latency distributions, and rotation events.
import java.util.concurrent.atomic.AtomicInteger;
import java.util.logging.FileHandler;
import java.util.logging.SimpleFormatter;
public class RotationMetrics {
private static final AtomicInteger successfulRotations = new AtomicInteger(0);
private static final AtomicInteger failedRotations = new AtomicInteger(0);
private static final ConcurrentHashMap<String, Long> latencyLog = new ConcurrentHashMap<>();
public static void recordSuccess(String policyId, long latencyMs) {
successfulRotations.incrementAndGet();
latencyLog.put(policyId, latencyMs);
writeAuditLog(String.format("ROTATION_SUCCESS|%s|%d ms", policyId, latencyMs));
public static void recordFailure(String policyId, int httpStatus) {
failedRotations.incrementAndGet();
writeAuditLog(String.format("ROTATION_FAILURE|%s|%d", policyId, httpStatus));
public static double getSuccessRate() {
int total = successfulRotations.get() + failedRotations.get();
return total == 0 ? 0.0 : (double) successfulRotations.get() / total * 100.0;
private static void writeAuditLog(String message) {
java.util.logging.Logger auditLogger = java.util.logging.Logger.getLogger("RotationAudit");
auditLogger.info(message);
e.printStackTrace();
The metrics collector uses AtomicInteger for thread-safe counters and ConcurrentHashMap for latency tracking. The writeAuditLog method appends structured entries to a dedicated audit logger. You can configure the logger to output to a file handler for compliance reporting. The success rate calculation provides a real-time efficiency metric for rotation pipelines.
The following Java module combines authentication, validation, payload construction, atomic PUT execution, webhook synchronization, and metrics tracking into a single executable service. Replace the placeholder environment variables with your Genesys Cloud credentials.
public class RecordingPolicyRotatorService {
private static final String WEBHOOK_URL = System.getenv("EXTERNAL_STORAGE_WEBHOOK_URL");
private static final long ESTIMATED_DAILY_BYTES = 10L * 1024 * 1024 * 1024; // 10 GB/day
if (args.length < 2) {
System.err.println("Usage: java RecordingPolicyRotatorService <policyId> <retentionDays>");
System.exit(1);
String policyId = args[0];
int retentionDays = Integer.parseInt(args[1]);
// Step 1: Initialize Platform Client
authApi.setAuthClient(AuthClient.builder()
.build());
// Step 2: Validate Schema and Constraints
PolicyValidator.validateRotationParameters(retentionDays, ESTIMATED_DAILY_BYTES, policyId);
// Step 3: Construct Rotation Payload
RecordingPolicy policy = RotationPayloadBuilder.buildRotationPayload(
policyId, retentionDays, "s3://company-archive/recordings"
// Step 4: Execute Atomic PUT with Retry and Webhook Sync
RecordingApi recordingApi = RecordingApi.create(platformClient);
PolicyRotator.executeRotation(recordingApi, policy, WEBHOOK_URL);
// Step 5: Track Metrics and Audit
RotationMetrics.recordSuccess(policyId, PolicyRotator.getLatency(policyId));
System.out.printf("Rotation complete. Success rate: %.2f%%%n", RotationMetrics.getSuccessRate());
} catch (IllegalArgumentException e) {
System.err.println("Validation failed: " + e.getMessage());
RotationMetrics.recordFailure(policyId, 400);
System.err.printf("API Error %d: %s%n", e.getCode(), e.getMessage());
RotationMetrics.recordFailure(policyId, e.getCode());
System.err.println("Unexpected error: " + e.getMessage());
This service validates inputs, constructs the policy update, executes the atomic PUT with 429 retry logic, synchronizes with an external storage manager via webhook, and records audit logs. It runs as a standalone Java application or integrates into a larger orchestration pipeline.
Error: HTTP 401 Unauthorized
- What causes it: Invalid OAuth client credentials, expired refresh token, or incorrect login center URL.
- How to fix it: Verify
GENESYS_CLIENT_IDandGENESYS_CLIENT_SECRETmatch the Genesys Cloud admin console. Ensure the login center URL follows the formathttps://{{login_center}}.mypurecloud.com. - Code showing the fix: The
AuthClient.builder()configuration must match the exact environment. Add a credential validation step before SDK initialization.
Error: HTTP 403 Forbidden
- What causes it: The OAuth token lacks the
recording:policy:writescope. - How to fix it: Update the OAuth client configuration in the Genesys Cloud admin console to include
recording:policy:writeandrecording:policy:read. Regenerate the access token after scope changes. - Code showing the fix: The SDK automatically requests configured scopes. If using custom token flows, append the required scopes to the
scopeparameter in the token request.
Error: HTTP 400 Bad Request
- What causes it: Invalid retention matrix values, malformed archive location, or schema violations.
- How to fix it: Run the
PolicyValidatorchecks before API calls. EnsureretentionDaysfalls within1to730. Verify the archive location URI is accessible to Genesys Cloud. - Code showing the fix: The validation step throws
IllegalArgumentExceptionwith explicit constraint details. Log the exception message to identify the exact field violation.
- What causes it: Exceeding Genesys Cloud rate limits for recording policy updates.
- How to fix it: Implement exponential backoff retry logic. The
PolicyRotator.executeRotationmethod handles this automatically with a maximum of three attempts. - Code showing the fix: The retry loop in Step 3 catches
ApiExceptionwith code 429 and applies backoff. Monitor the retry counter to detect sustained rate limiting.
Error: HTTP 5xx Server Error
- What causes it: Temporary platform degradation or internal service failure.
- How to fix it: Implement circuit breaker patterns for production deployments. Retry with longer backoff intervals. Contact Genesys Cloud support if errors persist beyond five minutes.
- Code showing the fix: Wrap the PUT call in a try-catch block that distinguishes between client errors (4xx) and server errors (5xx). Log 5xx responses separately for incident tracking.
