Retrieving Routing Wrap-Up Codes in Genesys Cloud with the Python SDK: Pagination and Documentation
This guide details how to retrieve all routing wrap-up codes available in a Genesys Cloud organization using the Python SDK. The end result is a Python script that iterates through all pages of wrap-up codes, storing them in a usable data structure. This is critical for dynamic form building, reporting, or integration with other systems requiring up-to-date wrap-up code information.
This implementation requires a Genesys Cloud CX 2.0 or higher licensing tier. The following permissions are required:
  • Reporting > Wrap-up Codes > View
  • OAuth scope: reporting:wrapupcodes:read
  • Python 3.6 or higher installed
  • The genesys-cloud-sdk package installed (pip install genesys-cloud-sdk)
  • A Genesys Cloud API client ID and secret configured for OAuth authentication.
  • Basic familiarity with Python programming and the Genesys Cloud REST API.
1. Authentication and Client Initialization
First, we need to authenticate with the Genesys Cloud API and initialize the SDK client. This involves obtaining an access token using your client ID and secret.
from genesyscloudsdk import GenesysCloudClient
import os
# Replace with your actual credentials
CLIENT_ID = os.environ.get("GENESYS_CLOUD_CLIENT_ID")
CLIENT_SECRET = os.environ.get("GENESYS_CLOUD_CLIENT_SECRET")
REGION = os.environ.get("GENESYS_CLOUD_REGION", "us-east-1")
# Instantiate the client
client = GenesysCloudClient(
    client_id=CLIENT_ID,
    client_secret=CLIENT_SECRET,
    region=REGION
# Authenticate
client.login()
The Trap: Hardcoding your client ID and secret directly into the script is a severe security risk. Always utilize environment variables or a secure configuration management system. Failing to do so could lead to unauthorized access to your Genesys Cloud organization.
2. Wrap-Up Code Retrieval with Pagination
The Genesys Cloud API returns wrap-up codes in paginated results. We must iterate through all pages to retrieve the complete list. The WrapupcodesApi object facilitates this.
from genesyscloudsdk.api.wrapupcodes import WrapupcodesApi
wrapup_codes_api = WrapupcodesApi(client)
all_wrapup_codes = []
page_number = 1
page_size = 100  # Maximum allowed page size
while True:
        response = wrapup_codes_api.get_wrapupcodes(
            page_size=page_size,
            page_number=page_number
        wrapup_codes = response.entities
        if not wrapup_codes:
            break  # No more wrap-up codes
        all_wrapup_codes.extend(wrapup_codes)
        page_number += 1
        print(f"Error retrieving wrap-up codes: {e}")
        break
The Trap: Not handling the pagination correctly will result in only retrieving the first page of wrap-up codes. The API limits the number of records returned per request. The page_size parameter defaults to 25, but can be increased up to 100. Always check for more pages and iterate accordingly. Also, the get_wrapupcodes method can raise exceptions related to API rate limits or authentication failures.
3. Processing and Storage
Now that we have all the wrap-up codes, we can process them as needed. This example simply prints the name and ID of each wrap-up code.
for wrapup_code in all_wrapup_codes:
    print(f"Wrap-up Code ID: {wrapup_code.id}, Name: {wrapup_code.name}")
This data can be stored in a database, used to populate a dropdown list in a UI, or sent to another system via an API. The choice depends on your specific requirements.
4. Error Handling and Logging
Robust error handling is crucial for production environments. The above example includes a basic try...except block, but you should implement more sophisticated logging and error reporting.
import logging
logging.basicConfig(level=logging.ERROR)
# ... (previous code) ...
        logging.error(f"Error retrieving wrap-up codes: {e}")
        print(f"Error retrieving wrap-up codes: {e}")  # For immediate feedback
        break
The Trap: Ignoring errors can lead to silent failures and data inconsistencies. Proper logging allows you to diagnose problems and proactively address issues.
Edge Case 1: Insufficient Permissions
If the authenticated user lacks the Reporting > Wrap-up Codes > View permission, the get_wrapupcodes method will return a 403 Forbidden error. The API response will contain an error message detailing the missing permissions. Verify that the user associated with the OAuth credentials has the necessary permissions in Genesys Cloud.
Edge Case 2: API Rate Limits
The Genesys Cloud API enforces rate limits to prevent abuse. If your script makes too many requests in a short period, the API will return a 429 Too Many Requests error. Implement a retry mechanism with exponential backoff to handle rate limits gracefully.
# ... (inside the while loop) ...
    if "429" in str(e):  # Check for rate limit error
        print("Rate limit exceeded.  Waiting...")
        time.sleep(60)  # Wait 60 seconds before retrying
        continue # Retry the loop
    else:
        break
Edge Case 3: Empty Organization
If the Genesys Cloud organization doesn’t have any wrap-up codes configured, the get_wrapupcodes method will return an empty list on the first page. The loop should terminate correctly in this case, resulting in an empty all_wrapup_codes list.
