Retrieving Genesys Cloud Flow Execution Logs with Rust
- A Rust application that queries the Genesys Cloud Architecture API for flow execution logs using structured filter matrices and fetch directives.
- The implementation uses the
POST /api/v2/architect/flowexeclogsendpoint with thereqwestandserdecrates. - The code covers Rust async/await with full error handling, automatic pagination, retry logic, schema validation, metrics tracking, and webhook synchronization.
- OAuth Client Credentials flow with
architect:flowexeclog:readscope - Genesys Cloud API v2
- Rust 1.70+ runtime
- External dependencies:
reqwest = { version = "0.11", features = ["json"] },serde = { version = "1.0", features = ["derive"] },serde_json = "1.0",chrono = { version = "0.4", features = ["serde"] },tokio = { version = "1", features = ["full"] },uuid = { version = "1.0", features = ["v4"] }
Genesys Cloud uses OAuth 2.0 client credentials flow for server-to-server API access. You must cache the access token and refresh it before expiration. The token response includes an expires_in field in seconds.
use chrono::{DateTime, Utc};
use reqwest::Client;
use serde::Deserialize;
#[derive(Deserialize)]
struct TokenResponse {
access_token: String,
expires_in: u64,
struct AuthCache {
token: String,
expires_at: DateTime<Utc>,
impl AuthCache {
fn is_valid(&self) -> bool {
Utc::now() < self.expires_at
async fn fetch(
client: &Client,
client_id: &str,
client_secret: &str,
scope: &str,
) -> reqwest::Result<Self> {
let res = client.post("https://api.mypurecloud.com/oauth/token")
.form(&[
("grant_type", "client_credentials"),
("client_id", client_id),
("client_secret", client_secret),
("scope", scope),
.send()
.await?;
if !res.status().is_success() {
return Err(res.error_for_status().unwrap_err());
let json: TokenResponse = res.json().await?;
Ok(AuthCache {
token: json.access_token,
expires_at: Utc::now() + chrono::Duration::seconds(json.expires_in as i64 - 60),
Step 1: Construct Retrieve Payloads with Filter Matrix and Fetch Directive
The Architecture API accepts a JSON payload containing a filter matrix, sort directives, and a size limit. You must validate the payload against logging engine constraints before transmission. The maximum batch size is 1000 records. The timestamp range must not exceed 30 days to prevent backend timeout failures.
use serde::Serialize;
#[derive(Serialize)]
struct FlowExecLogQuery {
filter: Filter,
sort: Vec<SortDirective>,
#[serde(skip_serializing_if = "Option::is_none")]
page_token: Option<String>,
struct Filter {
conditions: Vec<Condition>,
struct Condition {
attribute: String,
#[serde(rename = "operator")]
op: String,
value: String,
struct SortDirective {
attribute: String,
order: String,
fn build_query(
start_time: DateTime<Utc>,
end_time: DateTime<Utc>,
flow_id: &str,
severity_filter: Option<&str>,
batch_size: u32,
) -> Result<FlowExecLogQuery, String> {
if batch_size > 1000 {
return Err("Batch size exceeds maximum retrieval limit of 1000.".to_string());
let duration = end_time.signed_duration_since(start_time);
if duration.num_days() > 30 {
return Err("Timestamp range exceeds 30-day logging engine constraint.".to_string());
let mut conditions = vec![
Condition {
attribute: "timestamp".to_string(),
op: ">=".to_string(),
value: start_time.to_rfc3339_opts(chrono::SecondsFormat::Secs, true),
Condition {
op: "<".to_string(),
value: end_time.to_rfc3339_opts(chrono::SecondsFormat::Secs, true),
Condition {
attribute: "flowId".to_string(),
op: "=".to_string(),
value: flow_id.to_string(),
if let Some(sev) = severity_filter {
conditions.push(Condition {
attribute: "errorSeverity".to_string(),
value: sev.to_string(),
Ok(FlowExecLogQuery {
filter: Filter { conditions },
sort: vec![SortDirective {
order: "desc".to_string(),
page_token,
Step 2: Execute Atomic GET Operations with Pagination and Retry Logic
The endpoint returns a paginated response. You must extract the pageToken from the response metadata to trigger automatic pagination. The logging engine enforces strict rate limits. You must implement exponential backoff for 429 responses to prevent cascading failures during scaling events.
use reqwest::StatusCode;
use std::time::Instant;
struct FlowExecLogResponse {
entities: Vec<FlowExecLogEntry>,
total: u64,
division_id: String,
struct FlowExecLogEntry {
flow_id: String,
timestamp: String,
step_id: String,
result: String,
error: Option<serde_json::Value>,
async fn fetch_page_with_retry(
client: &Client,
token: &str,
query: &FlowExecLogQuery,
max_retries: u32,
) -> Result<FlowExecLogResponse, reqwest::Error> {
let mut attempts = 0;
let mut delay = std::time::Duration::from_secs(1);
loop {
let start = Instant::now();
let res = client.post("https://api.mypurecloud.com/api/v2/architect/flowexeclogs")
.bearer_auth(token)
.json(query)
.send()
.await;
let latency_ms = start.elapsed().as_millis();
match res {
Ok(response) => {
if response.status() == StatusCode::OK {
let json: FlowExecLogResponse = response.json().await?;
println!(
"Audit: Batch retrieved in {} ms. Records: {}",
latency_ms,
json.entities.len()
return Ok(json);
} else if response.status() == StatusCode::TOO_MANY_REQUESTS && attempts < max_retries {
attempts += 1;
println!("Audit: Rate limited. Retrying in {} seconds...", delay.as_secs());
tokio::time::sleep(delay).await;
delay *= 2;
continue;
} else {
return Err(response.error_for_status().unwrap_err());
Err(e) => {
if attempts < max_retries {
attempts += 1;
println!("Audit: Network error. Retrying in {} seconds...", delay.as_secs());
delay *= 2;
continue;
return Err(e);
Step 3: Implement Validation Pipelines and Metrics Tracking
You must verify the response format matches the expected schema. You must track fetch success rates and latency percentiles for observability governance. The pipeline filters entries by error severity and timestamps to prevent log flooding during peak scaling periods.
struct MetricsTracker {
total_fetched: u64,
successful_batches: u64,
failed_batches: u64,
latencies_ms: Vec<u128>,
impl MetricsTracker {
fn new() -> Self {
Self {
total_fetched: 0,
successful_batches: 0,
failed_batches: 0,
latencies_ms: Vec::new(),
fn record_success(&mut self, count: u64, latency: u128) {
self.total_fetched += count;
self.successful_batches += 1;
self.latencies_ms.push(latency);
fn record_failure(&mut self) {
self.failed_batches += 1;
fn report(&self) {
let avg_latency = if self.latencies_ms.is_empty() {
0.0
} else {
self.latencies_ms.iter().sum::<u128>() as f64 / self.latencies_ms.len() as f64
let success_rate = if self.successful_batches + self.failed_batches > 0 {
(self.successful_batches as f64 / (self.successful_batches + self.failed_batches) as f64) * 100.0
} else {
0.0
println!(
"Audit Report: Total records: {}, Success rate: {:.2}%, Avg latency: {:.2} ms",
self.total_fetched, success_rate, avg_latency
fn validate_and_filter_entries(entries: Vec<FlowExecLogEntry>) -> Vec<FlowExecLogEntry> {
entries.into_iter().filter(|entry| {
let valid_timestamp = entry.timestamp.parse::<DateTime<Utc>>().is_ok();
let valid_format = !entry.id.is_empty() && !entry.flow_id.is_empty();
valid_timestamp && valid_format
}).collect()
Step 4: Synchronize Retrieved Events with External Monitoring Webhooks
You must dispatch retrieved log batches to external dashboards for alignment. The webhook payload contains the batch metadata, record count, and validation status. You must handle webhook transmission failures gracefully to prevent log retrieval pipeline blockage.
struct WebhookPayload {
event_type: String,
batch_id: String,
record_count: u64,
validation_status: String,
timestamp: String,
async fn sync_webhook(client: &Client, webhook_url: &str, payload: &WebhookPayload) {
let res = client.post(webhook_url)
.json(payload)
.send()
.await;
match res {
Ok(resp) if resp.status().is_success() => {
println!("Audit: Webhook synchronized successfully for batch {}", payload.batch_id);
Ok(resp) => {
println!("Audit: Webhook failed with status {}", resp.status());
Err(e) => {
println!("Audit: Webhook network error: {}", e);
The following module integrates authentication, payload construction, pagination, retry logic, validation, metrics tracking, and webhook synchronization. Replace the environment variables with your Genesys Cloud credentials.
use std::env;
#[tokio::main]
async fn main() {
let client_id = env::var("GENESYS_CLIENT_ID").expect("GENESYS_CLIENT_ID required");
let client_secret = env::var("GENESYS_CLIENT_SECRET").expect("GENESYS_CLIENT_SECRET required");
let flow_id = env::var("TARGET_FLOW_ID").unwrap_or_else(|_| "default-flow-id".to_string());
let webhook_url = env::var("WEBHOOK_URL").unwrap_or_else(|_| "https://hooks.example.com/logs".to_string());
let http_client = Client::new();
let auth = AuthCache::fetch(&http_client, &client_id, &client_secret, "architect:flowexeclog:read")
.await
.expect("Authentication failed");
let start_time = Utc::now() - chrono::Duration::days(1);
let end_time = Utc::now();
let mut metrics = MetricsTracker::new();
let mut current_token: Option<String> = None;
let mut batch_count = 0;
loop {
batch_count += 1;
let query = build_query(
start_time,
end_time,
&flow_id,
Some("ERROR"),
500,
current_token.clone(),
).expect("Query construction failed");
match fetch_page_with_retry(&http_client, &auth.token, &query, 3).await {
Ok(response) => {
let valid_entries = validate_and_filter_entries(response.entities);
let latency = Instant::now().elapsed().as_millis();
metrics.record_success(valid_entries.len() as u64, latency);
let batch_id = uuid::Uuid::new_v4().to_string();
let webhook_payload = WebhookPayload {
event_type: "flow_exec_log_batch".to_string(),
batch_id: batch_id.clone(),
record_count: valid_entries.len() as u64,
validation_status: "passed".to_string(),
timestamp: Utc::now().to_rfc3339(),
sync_webhook(&http_client, &webhook_url, &webhook_payload).await;
if response.page_token.is_none() {
println!("Audit: Pagination complete. Total batches: {}", batch_count);
break;
current_token = response.page_token;
Err(e) => {
metrics.record_failure();
println!("Audit: Batch retrieval failed: {}", e);
break;
metrics.report();
Common Errors and Debugging
- Cause: The OAuth token is expired, malformed, or missing the required scope.
- Fix: Verify the
client_idandclient_secretmatch your Genesys Cloud integration. Ensure the scope string containsarchitect:flowexeclog:read. Implement token refresh logic before theexpires_inthreshold. - Code adjustment: Add a scope validation check before token generation. Log the raw OAuth response for debugging.
Error: 400 Bad Request
- Cause: The filter matrix contains invalid operators, unsupported attributes, or a timestamp range exceeding 30 days.
- Fix: Validate the
start_timeandend_timedifference before construction. Ensure alloperatorvalues match the API specification (=,!=,>,<,>=,<=,contains). - Code adjustment: The
build_queryfunction already enforces the 30-day constraint. Add explicit operator whitelisting if extending the filter matrix.
Error: 403 Forbidden
- Cause: The OAuth client lacks permission to read flow execution logs, or the target flow belongs to a division the client cannot access.
- Fix: Verify integration permissions in the Genesys Cloud admin console. Assign the
Architect: Flow execution logread permission. Ensure thedivision_idmatches your scope. - Code adjustment: Check the
division_idfield in the response. If it differs from your expected division, adjust the query to target the correct organizational unit.
- Cause: The logging engine rate limit is exceeded. This occurs during bulk historical analysis or concurrent retrievals.
- Fix: The
fetch_page_with_retryfunction implements exponential backoff. Increase the initial delay or reduce thesizeparameter to lower request frequency. - Code adjustment: Monitor the
Retry-Afterheader in 429 responses and adjust the backoff calculation dynamically.
