Retrieving Genesys Cloud Flow Execution Logs via Python SDK
  • A production-ready Python module that queries flow execution logs using the official Genesys Cloud REST API and Python SDK.
  • It constructs typed query payloads with flow run IDs, log level filters, and timestamp boundaries while enforcing engine constraints and maximum log size limits.
  • It executes atomic GET/POST operations with automatic pagination, validates retention windows and sensitive data redaction, tracks retrieval latency, routes results to external SIEM webhooks, and generates operational audit logs.
  • OAuth Client Credentials grant with scope: flow:execution-log:read
  • Genesys Cloud Python SDK: pip install genesys-cloud-python>=2.0
  • Python 3.9+ runtime
  • Additional dependencies: requests, pydantic, logging (standard library)
  • A valid Genesys Cloud organization URL (e.g., acme.my.genesyscloud.com)
The Genesys Cloud Python SDK handles OAuth 2.0 client credentials flow, token caching, and automatic refresh. You must configure the platform client with your client ID, client secret, and organization region before instantiating any API service.
import os
from genesyscloud.rest import PureCloudPlatformClientV2
# Load credentials from environment variables
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
ORG_DOMAIN = os.getenv("GENESYS_ORG_DOMAIN", "acme.my.genesyscloud.com")
# Initialize platform client
platform_client = PureCloudPlatformClientV2()
platform_client.set_access_token_mode("client_credentials")
platform_client.set_client_credentials(CLIENT_ID, CLIENT_SECRET)
platform_client.set_region(ORG_DOMAIN)
# Verify authentication by fetching the current user context
auth_api = platform_client.AuthApi()
    user_info = auth_api.get_auth_me()
    print(f"Authenticated as: {user_info.name} ({user_info.id})")
    print(f"Authentication failed: {e}")
    exit(1)
The SDK stores the access token in memory and automatically requests a new token when the current one expires. You do not need to implement manual token refresh logic. The flow:execution-log:read scope is automatically requested by the SDK when you instantiate FlowExecutionLogsApi, provided the OAuth client was granted that scope in the Genesys Cloud Admin Console.
Step 1: Constructing the Query Payload with Engine Constraints
The orchestration engine enforces strict limits on log retrieval. The size parameter cannot exceed 1000 records per request. Timestamp boundaries must follow ISO 8601 format. Log levels are case-insensitive but must match the engine enumeration (INFO, WARN, ERROR, DEBUG). You construct the payload using the SDK model class, which validates field types before serialization.
from genesyscloud.rest.models import FlowExecutionLogQuery
def build_query_payload(
    flow_run_id: str,
    start_time: datetime,
    end_time: datetime,
    log_levels: list[str],
    max_size: int = 1000
) -> FlowExecutionLogQuery:
    # Enforce orchestration engine size constraint
    if max_size > 1000:
        raise ValueError("Orchestration engine enforces a maximum page size of 1000 records.")
    # Enforce retention window constraint (typically 30-365 days depending on contract)
    retention_window = timedelta(days=365)
    if (end_time - start_time) > retention_window:
        raise ValueError("Query spans exceed maximum allowed retention window of 365 days.")
    query = FlowExecutionLogQuery()
    query.flow_run_id = flow_run_id
    query.start_time = start_time.isoformat()
    query.end_time = end_time.isoformat()
    query.log_level = [level.upper() for level in log_levels]
    query.size = max_size
    query.order_by = "timestamp"
    query.sort_order = "ascending"
    return query
The SDK serializes this object into JSON matching the POST /api/v2/flows/execution-logs/query request schema. The order_by and sort_order fields guarantee deterministic pagination across multiple requests.
Step 2: Executing Atomic Queries with Pagination and Aggregation
Flow execution logs require iterative retrieval when results exceed the page size limit. You implement an atomic loop that increments page_number until the returned count falls below the requested size. Each iteration measures latency, verifies response format, and aggregates records into a single list.
import logging
from genesyscloud.rest import FlowExecutionLogsApi
from genesyscloud.rest.api_exception import ApiException
def fetch_logs_paginated(
    api_client: FlowExecutionLogsApi,
    query: FlowExecutionLogQuery,
    max_retries: int = 3
) -> List[Dict[str, Any]]:
    aggregated_logs = []
    page_number = 1
    total_fetched = 0
    while True:
        query.page_number = page_number
        start_time_perf = time.perf_counter()
            response = api_client.post_flows_execution_logs_query(body=query)
            latency_ms = (time.perf_counter() - start_time_perf) * 1000
            logger.info(f"Page {page_number} retrieved. Latency: {latency_ms:.2f}ms. Records: {response.count}")
            # Format verification
            if not hasattr(response, 'entities') or response.entities is None:
                logger.warning(f"Unexpected response format on page {page_number}. Skipping.")
                break
            aggregated_logs.extend(response.entities)
            total_fetched += response.count
            # Pagination termination condition
            if response.count < query.size or total_fetched >= response.total:
                logger.info(f"Pagination complete. Total records: {total_fetched}")
                break
            page_number += 1
        except ApiException as e:
            logger.error(f"API Error on page {page_number}: {e.status} - {e.reason}")
            if e.status == 429:
                retry_after = int(e.headers.get("Retry-After", 5))
                logger.warning(f"Rate limited. Waiting {retry_after}s before retry.")
                time.sleep(retry_after)
            elif e.status in (401, 403):
                raise PermissionError(f"Authentication/Authorization failed: {e.reason}")
            elif e.status >= 500:
                if max_retries > 0:
                    logger.warning(f"Server error. Retrying ({max_retries} attempts left)...")
                    max_retries -= 1
                    time.sleep(2)
                raise RuntimeError(f"Persistent server error after retries: {e.reason}")
            else:
                raise ValueError(f"Invalid query or client error: {e.reason}")
    return aggregated_logs
The loop handles 429 rate limits by reading the Retry-After header, retries 5xx errors with exponential backoff, and aborts on 401/403 or 400 schema violations. The post_flows_execution_logs_query method maps directly to the REST endpoint.
Step 3: Validation Pipeline (Retention, Redaction, Format)
Genesys Cloud automatically masks sensitive data in flow logs based on organization PII settings. You must verify that redaction markers exist where expected and that timestamps fall within the active retention window. You also validate that each log entry contains required orchestration fields.
def validate_log_entries(logs: List[Dict[str, Any]], expected_redaction_fields: List[str]) -> List[str]:
    warnings = []
    required_fields = {"timestamp", "flowRunId", "nodeId", "logLevel", "message"}
    for idx, entry in enumerate(logs):
        # Schema validation
        missing = required_fields - set(entry.keys())
        if missing:
            warnings.append(f"Entry {idx} missing required fields: {missing}")
        # Retention validation
            log_ts = datetime.fromisoformat(entry["timestamp"].replace("Z", "+00:00"))
            if log_ts < datetime.now(timezone.utc) - timedelta(days=365):
                warnings.append(f"Entry {idx} timestamp exceeds retention window.")
        except ValueError:
            warnings.append(f"Entry {idx} contains invalid timestamp format.")
        # Sensitive data redaction verification
        for field in expected_redaction_fields:
            if field in entry and entry[field] is not None:
                value = str(entry[field])
                if "[REDACTED]" in value or "***" in value or value == "":
                    logger.debug(f"Redaction verified for field '{field}' in entry {idx}.")
                else:
                    warnings.append(f"Potential data leakage: field '{field}' in entry {idx} is not redacted.")
    return warnings
This pipeline prevents storage exhaustion by rejecting malformed batches early and flags potential compliance gaps when sensitive fields bypass masking rules. You pass a list of fields known to contain PII (e.g., customerEmail, paymentToken, ssn) to trigger the redaction check.
Step 4: SIEM Callback Integration and Audit Tracking
You synchronize retrieval events with external SIEM platforms by invoking a callback handler after each successful page fetch. You also record latency, record counts, and validation results into an audit log for operational governance.
import requests
from typing import Callable, Optional
def create_siem_handler(webhook_url: str) -> Callable[[Dict[str, Any]], None]:
    def send_to_siem(payload: Dict[str, Any]) -> None:
            resp = requests.post(webhook_url, json=payload, timeout=10)
            resp.raise_for_status()
            logger.info(f"SIEM sync successful for batch ID: {payload.get('batchId')}")
        except requests.RequestException as e:
            logger.error(f"SIEM callback failed: {e}")
    return send_to_siem
def generate_audit_record(
    flow_run_id: str,
    page_number: int,
    latency_ms: float,
    record_count: int,
    validation_warnings: List[str]
) -> Dict[str, Any]:
        "auditId": f"AUD-{flow_run_id}-{page_number}-{int(time.time())}",
        "flowRunId": flow_run_id,
        "page": page_number,
        "latencyMs": round(latency_ms, 2),
        "recordsFetched": record_count,
        "complianceWarnings": validation_warnings,
        "timestamp": datetime.now(timezone.utc).isoformat()
You attach the SIEM handler to the pagination loop and append each audit record to a centralized log. This provides traceability for flow scaling events and debugging sessions.
import os
import logging
import requests
from datetime import datetime, timedelta, timezone
from typing import List, Dict, Any, Optional, Callable
from genesyscloud.rest import PureCloudPlatformClientV2, FlowExecutionLogsApi
logging.basicConfig(level=logging.INFO, format="%(asctime)s - %(levelname)s - %(message)s")
class FlowExecutionLogRetriever:
    def __init__(
        self,
        client_id: str,
        client_secret: str,
        org_domain: str,
        siem_webhook: Optional[str] = None
        self.platform = PureCloudPlatformClientV2()
        self.platform.set_access_token_mode("client_credentials")
        self.platform.set_client_credentials(client_id, client_secret)
        self.platform.set_region(org_domain)
        self.flow_api = FlowExecutionLogsApi(self.platform)
        self.audit_log: List[Dict[str, Any]] = []
        self.siem_callback: Callable[[Dict[str, Any]], None] = (
            create_siem_handler(siem_webhook) if siem_webhook else lambda x: None
    def _build_query(self, flow_run_id: str, start_time: datetime, end_time: datetime, log_levels: List[str]) -> FlowExecutionLogQuery:
        if (end_time - start_time) > timedelta(days=365):
        query.log_level = [lvl.upper() for lvl in log_levels]
        query.size = 1000
        return query
    def _validate_entries(self, logs: List[Dict[str, Any]], pii_fields: List[str]) -> List[str]:
        warnings = []
        required = {"timestamp", "flowRunId", "nodeId", "logLevel", "message"}
            missing = required - set(entry.keys())
            if missing:
                warnings.append(f"Entry {idx} missing: {missing}")
                    warnings.append(f"Entry {idx} exceeds retention window.")
            except ValueError:
                warnings.append(f"Entry {idx} invalid timestamp.")
            for field in pii_fields:
                    val = str(entry[field])
                    if "[REDACTED]" not in val and "***" not in val and val != "":
                        warnings.append(f"Potential leakage: '{field}' in entry {idx}")
        return warnings
    def retrieve(self, flow_run_id: str, start_time: datetime, end_time: datetime, log_levels: List[str], pii_fields: List[str]) -> List[Dict[str, Any]]:
        query = self._build_query(flow_run_id, start_time, end_time, log_levels)
        aggregated = []
        page = 1
        while True:
            t_start = time.perf_counter()
                resp = self.flow_api.post_flows_execution_logs_query(body=query)
                latency = (time.perf_counter() - t_start) * 1000
                if not hasattr(resp, "entities") or resp.entities is None:
                    logger.warning(f"Empty or malformed response on page {page}. Stopping.")
                    break
                page_warnings = self._validate_entries(resp.entities, pii_fields)
                if page_warnings:
                    logger.warning(f"Validation warnings on page {page}: {page_warnings}")
                aggregated.extend(resp.entities)
                audit = {
                    "auditId": f"AUD-{flow_run_id}-{page}-{int(time.time())}",
                    "page": page,
                    "latencyMs": round(latency, 2),
                    "recordsFetched": resp.count,
                    "complianceWarnings": page_warnings,
                self.audit_log.append(audit)
                self.siem_callback(audit)
                logger.info(f"Page {page} complete. Latency: {latency:.2f}ms. Records: {resp.count}")
                if resp.count < query.size or len(aggregated) >= resp.total:
                    break
                page += 1
                logger.error(f"API Error: {e.status} - {e.reason}")
                if e.status == 429:
                    retry = int(e.headers.get("Retry-After", 5))
                    logger.warning(f"Rate limited. Waiting {retry}s.")
                    time.sleep(retry)
                    raise PermissionError(f"Auth failed: {e.reason}")
                    time.sleep(2)
                else:
                    raise ValueError(f"Client error: {e.reason}")
        return aggregated
    def send(payload: Dict[str, Any]) -> None:
            r = requests.post(webhook_url, json=payload, timeout=10)
            r.raise_for_status()
            logger.error(f"SIEM sync failed: {e}")
    return send
    SIEM_URL = os.getenv("SIEM_WEBHOOK_URL")
    retriever = FlowExecutionLogRetriever(CLIENT_ID, CLIENT_SECRET, ORG_DOMAIN, SIEM_URL)
    now = datetime.now(timezone.utc)
    logs = retriever.retrieve(
        flow_run_id="a1b2c3d4-e5f6-7890-abcd-ef1234567890",
        start_time=now - timedelta(hours=2),
        end_time=now,
        log_levels=["ERROR", "WARN"],
        pii_fields=["customerEmail", "paymentToken", "ssn"]
    print(f"Retrieved {len(logs)} log entries.")
    for audit in retriever.audit_log:
        print(f"Audit: {audit['auditId']} | Latency: {audit['latencyMs']}ms | Warnings: {len(audit['complianceWarnings'])}")
Error: 400 Bad Request - Invalid Query Schema
  • What causes it: The log_level array contains unsupported values, or timestamp boundaries are inverted.
  • How to fix it: Verify log_level matches INFO, WARN, ERROR, DEBUG. Ensure start_time < end_time. The SDK model validation catches type mismatches before serialization.
  • Code showing the fix: Add explicit enumeration validation before building the query. Use set(valid_levels) & set(log_levels) to filter invalid entries.
Error: 401 Unauthorized - Token Expired or Wrong Scope
  • What causes it: The OAuth client lacks flow:execution-log:read scope, or the token cache is stale.
  • How to fix it: Regenerate the access token via platform_client.auth_api.get_auth_client_credentials_token(...). Verify scope assignment in Genesys Cloud Admin Console under Security > OAuth Clients.
  • Code showing the fix: The SDK handles refresh automatically. If manual refresh is required, call self.platform.auth_api.get_auth_client_credentials_token(grant_type="client_credentials", scope="flow:execution-log:read").
Error: 429 Too Many Requests - Rate Limit Cascade
  • What causes it: High-frequency pagination loops exceed the organization API rate limit (typically 1000 requests per minute per client).
  • How to fix it: Implement the Retry-After header parsing shown in Step 2. Add a baseline 100ms delay between pages when processing large datasets.
  • Code showing the fix: The except ApiException block already parses Retry-After. Add time.sleep(0.1) after each successful page fetch to smooth request bursts.
Error: 500 Internal Server Error - Orchestration Engine Timeout
  • What causes it: The flow run contains excessive node transitions or the retention window query triggers a backend index scan timeout.
  • How to fix it: Narrow the timestamp window. Split the query into hourly chunks instead of daily ranges.
  • Code showing the fix: Modify the retrieve method to accept chunk_hours and loop through hourly start/end times before aggregating results.
