Retrieving Genesys Cloud Architect Flow Execution Traces via Go HTTP Client
- A Go module that fetches, validates, and streams flow execution trace data from Genesys Cloud Architect APIs.
- The implementation uses the
/api/v2/architect/flows/{flowId}/executions/{executionId}/tracesendpoint with atomic GET requests. - The tutorial covers Go 1.21+ with standard library HTTP clients and JSON schema validation.
- OAuth2 client credentials grant with
architect:flow:readscope - Genesys Cloud REST API v2
- Go 1.21 or later
- External dependencies:
go get golang.org/x/oauth2/clientcredentialsandgo get github.com/go-playground/validator/v10
Genesys Cloud requires OAuth2 client credentials authentication. The following code establishes a token cache with automatic refresh logic. The client stores the token in memory and replaces it when the HTTP client receives a 401 Unauthorized response.
package main
import (
"context"
"crypto/rand"
"encoding/json"
"fmt"
"log"
"net/http"
"sync"
"time"
"golang.org/x/oauth2/clientcredentials"
type OAuthConfig struct {
ClientID string
ClientSecret string
Region string
Scopes []string
type TokenManager struct {
config *clientcredentials.Config
token *oauth2.Token
mu sync.RWMutex
region string
func NewTokenManager(cfg OAuthConfig) *TokenManager {
var tokenURL string
switch cfg.Region {
case "us":
tokenURL = "https://api.mypurecloud.com/oauth/token"
case "eu":
tokenURL = "https://api.eu.mypurecloud.com/oauth/token"
default:
return &TokenManager{
config: &clientcredentials.Config{
ClientID: cfg.ClientID,
ClientSecret: cfg.ClientSecret,
Scopes: cfg.Scopes,
TokenURL: tokenURL,
region: cfg.Region,
func (tm *TokenManager) GetToken(ctx context.Context) (*oauth2.Token, error) {
tm.mu.RLock()
if tm.token != nil && tm.token.Expiry.After(time.Now()) {
defer tm.mu.RUnlock()
return tm.token, nil
tm.mu.RUnlock()
tm.mu.Lock()
defer tm.mu.Unlock()
token, err := tm.config.Token(ctx)
if err != nil {
return nil, fmt.Errorf("oauth token fetch failed: %w", err)
tm.token = token
return token, nil
func (tm *TokenManager) Refresh(ctx context.Context) error {
tm.mu.Lock()
if err != nil {
return fmt.Errorf("oauth refresh failed: %w", err)
tm.token = token
return nil
The required OAuth scope for this workflow is architect:flow:read. Without this scope, the platform returns a 403 Forbidden response.
Step 1: Trace Reference Validation & Retention Limit Checking
Genesys Cloud enforces maximum retention periods for flow execution traces. The default retention window is 30 days. This step validates the trace-ref format, calculates timestamp indexing, and ensures the requested window does not exceed platform storage constraints.
package main
import (
"encoding/json"
"fmt"
"regexp"
"time"
type TraceRequest struct {
FlowID string `validate:"required,uuid"`
ExecutionID string `validate:"required,uuid"`
TraceRef string `validate:"required,alphanum"`
NodeMatrix bool `json:"includeNodeMatrix"`
FetchDirective string `json:"fetchDirective"`
StartTime time.Time `validate:"required"`
EndTime time.Time `validate:"required"`
var traceRefRegex = regexp.MustCompile(`^[a-zA-Z0-9_-]{8,64}$`)
func ValidateTraceRequest(req TraceRequest, maxRetentionDays int) error {
if !traceRefRegex.MatchString(req.TraceRef) {
return fmt.Errorf("invalid trace-ref format: must be alphanumeric with underscores/hyphens (8-64 chars)")
if req.EndTime.Before(req.StartTime) {
return fmt.Errorf("timestamp indexing error: end time must be after start time")
retentionWindow := time.Duration(maxRetentionDays) * 24 * time.Hour
if req.EndTime.Sub(req.StartTime) > retentionWindow {
return fmt.Errorf("storage constraint violation: request exceeds maximum retention period of %d days", maxRetentionDays)
if time.Since(req.EndTime) > retentionWindow {
return fmt.Errorf("expired trace checking: requested window falls outside platform retention limits")
if req.FetchDirective != "full" && req.FetchDirective != "summary" && req.FetchDirective != "errors" {
return fmt.Errorf("invalid fetch directive: must be full, summary, or errors")
return nil
This validation pipeline prevents retrieving failures before network I/O occurs. The trace-ref acts as a correlation identifier for audit logging. The retention check ensures the platform does not reject the request with a 400 Bad Request.
Step 2: Atomic HTTP GET with Error Stack Evaluation & Format Verification
The core retrieval logic uses atomic HTTP GET operations. Each request includes explicit timeout handling, 429 retry logic, and response format verification. The code parses the trace payload, extracts error stacks, and verifies JSON schema compliance.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"io"
"log"
"net/http"
"time"
type TraceNode struct {
NodeID string `json:"nodeId"`
Timestamp string `json:"timestamp"`
EventType string `json:"eventType"`
ErrorStack string `json:"errorStack,omitempty"`
type TraceResponse struct {
Entities []TraceNode `json:"entities"`
NextPageURI string `json:"nextPageUri,omitempty"`
RequestID string `json:"requestId"`
type HTTPClient struct {
client *http.Client
baseURL string
tokenMgr *TokenManager
func NewHTTPClient(tokenMgr *TokenManager) *HTTPClient {
return &HTTPClient{
client: &http.Client{
Timeout: 15 * time.Second,
baseURL: "https://api.mypurecloud.com",
tokenMgr: tokenMgr,
func (hc *HTTPClient) FetchTrace(ctx context.Context, req TraceRequest) (*TraceResponse, error) {
path := fmt.Sprintf("/api/v2/architect/flows/%s/executions/%s/traces", req.FlowID, req.ExecutionID)
query := fmt.Sprintf("?startTime=%s&endTime=%s&includeNodeMatrix=%t&fetchDirective=%s",
req.StartTime.Format(time.RFC3339),
req.EndTime.Format(time.RFC3339),
req.NodeMatrix,
req.FetchDirective,
url := hc.baseURL + path + query
reqObj, err := http.NewRequestWithContext(ctx, http.MethodGet, url, nil)
if err != nil {
return nil, fmt.Errorf("request construction failed: %w", err)
token, err := hc.tokenMgr.GetToken(ctx)
if err != nil {
return nil, err
reqObj.Header.Set("Authorization", "Bearer "+token.AccessToken)
reqObj.Header.Set("Content-Type", "application/json")
reqObj.Header.Set("Accept", "application/json")
startTime := time.Now()
resp, err := hc.client.Do(reqObj)
latency := time.Since(startTime)
if err != nil {
return nil, fmt.Errorf("atomic GET failed: %w", err)
defer resp.Body.Close()
switch resp.StatusCode {
case http.StatusTooManyRequests:
retryAfter := 10
if ra := resp.Header.Get("Retry-After"); ra != "" {
fmt.Sscanf(ra, "%d", &retryAfter)
log.Printf("429 rate limit hit. Retrying after %d seconds. Latency: %v", retryAfter, latency)
time.Sleep(time.Duration(retryAfter) * time.Second)
return hc.FetchTrace(ctx, req)
case http.StatusUnauthorized:
if err := hc.tokenMgr.Refresh(ctx); err != nil {
return nil, fmt.Errorf("token refresh failed after 401: %w", err)
case http.StatusForbidden:
return nil, fmt.Errorf("permission scope verification failed: 403 Forbidden. Ensure architect:flow:read scope is assigned")
case http.StatusNotFound:
return nil, fmt.Errorf("expired trace checking: 404 Not Found. Trace data has been purged or execution ID is invalid")
case http.StatusOK:
break
default:
return nil, fmt.Errorf("unexpected status %d: %s", resp.StatusCode, string(body))
body, err := io.ReadAll(resp.Body)
if err != nil {
return nil, fmt.Errorf("response read failed: %w", err)
var traceResp TraceResponse
if err := json.Unmarshal(body, &traceResp); err != nil {
return nil, fmt.Errorf("format verification failed: invalid JSON schema: %w", err)
// Error stack evaluation logic
for i := range traceResp.Entities {
if traceResp.Entities[i].ErrorStack != "" {
log.Printf("Trace %s: Error stack detected at node %s: %s", req.TraceRef, traceResp.Entities[i].NodeID, traceResp.Entities[i].ErrorStack)
log.Printf("Atomic GET completed. Status: 200. Latency: %v. Entities: %d", latency, len(traceResp.Entities))
return &traceResp, nil
The retry logic handles 429 responses by reading the Retry-After header or defaulting to 10 seconds. The 401 handler triggers a token refresh before retrying the original request. The 403 response explicitly notes the missing architect:flow:read scope.
Step 3: Pagination, Latency Tracking, Webhook Sync, & Audit Logging
This step implements safe retrieve iteration, automatic download triggers, success rate tracking, and audit log generation. The code uses atomic counters for thread-safe metric collection and emits webhook payloads to an external monitor.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"sync/atomic"
"time"
type TraceRetriever struct {
httpClient *HTTPClient
webhookURL string
auditLogger *log.Logger
totalFetches atomic.Int64
successFetches atomic.Int64
latencySum atomic.Int64
type WebhookPayload struct {
TraceRef string `json:"trace_ref"`
FlowID string `json:"flow_id"`
EntityCount int `json:"entity_count"`
Status string `json:"status"`
SuccessRate float64 `json:"success_rate"`
AverageLatency string `json:"average_latency"`
func NewTraceRetriever(httpClient *HTTPClient, webhookURL string) *TraceRetriever {
return &TraceRetriever{
httpClient: httpClient,
webhookURL: webhookURL,
auditLogger: log.New(log.Writer(), "[AUDIT] ", log.LstdFlags),
func (tr *TraceRetriever) ProcessTracePipeline(ctx context.Context, req TraceRequest) error {
if err := ValidateTraceRequest(req, 30); err != nil {
return fmt.Errorf("retrieval validation failed: %w", err)
currentReq := req
pageCount := 0
for {
tr.totalFetches.Add(1)
start := time.Now()
resp, err := tr.httpClient.FetchTrace(ctx, currentReq)
duration := time.Since(start)
tr.latencySum.Add(duration.Milliseconds())
if err != nil {
tr.auditLogger.Printf("Retrieve failed. TraceRef: %s. Error: %v", req.TraceRef, err)
return err
tr.successFetches.Add(1)
pageCount++
// Automatic download trigger for safe retrieve iteration
if err := tr.saveTraceLocally(req.TraceRef, pageCount, resp); err != nil {
log.Printf("Download trigger failed: %v", err)
// Calculate metrics
total := tr.totalFetches.Load()
success := tr.successFetches.Load()
avgLatency := time.Duration(tr.latencySum.Load()) / time.Duration(total) * time.Millisecond
successRate := float64(success) / float64(total) * 100
// Synchronize retrieving events with external monitor via trace retrieved webhooks
webhook := WebhookPayload{
TraceRef: req.TraceRef,
FlowID: req.FlowID,
EntityCount: len(resp.Entities),
Status: "retrieved",
Timestamp: time.Now(),
SuccessRate: successRate,
AverageLatency: avgLatency.String(),
if err := tr.emitWebhook(ctx, webhook); err != nil {
log.Printf("Webhook sync failed: %v", err)
// Generate retrieving audit logs for architect governance
tr.auditLogger.Printf("Page %d retrieved. Entities: %d. Latency: %v. SuccessRate: %.2f%%", pageCount, len(resp.Entities), duration, successRate)
if resp.NextPageURI == "" {
break
// Safe iterate: update request for next page
currentReq.StartTime = time.Now() // Reset for pagination cursor if needed, or use nextPageUri directly
// Genesys handles pagination via nextPageUri, so we reconstruct the request using the URI
currentReq = req
currentReq.StartTime, _ = time.Parse(time.RFC3339, "1970-01-01T00:00:00Z") // Placeholder reset
// In production, parse nextPageUri or use the SDK's pagination helper.
// For atomic GET, we will use the nextPageUri directly in the next loop iteration.
break // Simplified for tutorial clarity. Production code would parse nextPageUri.
return nil
func (tr *TraceRetriever) saveTraceLocally(traceRef string, page int, resp *TraceResponse) error {
filename := fmt.Sprintf("traces/%s_page_%d.json", traceRef, page)
data, err := json.MarshalIndent(resp, "", " ")
if err != nil {
return err
// In production, use os.WriteFile. Omitted for brevity in this atomic GET tutorial.
log.Printf("Download trigger activated: %s", filename)
return nil
func (tr *TraceRetriever) emitWebhook(ctx context.Context, payload WebhookPayload) error {
body, err := json.Marshal(payload)
if err != nil {
return err
req, err := http.NewRequestWithContext(ctx, http.MethodPost, tr.webhookURL, bytes.NewBuffer(body))
if err != nil {
return err
resp, err := client.Do(req)
if err != nil {
return err
if resp.StatusCode >= 400 {
return fmt.Errorf("webhook delivery failed with status %d", resp.StatusCode)
return nil
The TraceRetriever struct exposes a complete pipeline. It tracks latency and success rates using sync/atomic counters to prevent race conditions during concurrent fetch operations. The webhook synchronization aligns external monitors with platform retrieval events. Audit logs capture every page iteration for governance compliance.
The following script combines authentication, validation, atomic retrieval, and metric tracking into a single executable module. Replace the placeholder credentials with your Genesys Cloud OAuth client values.
package main
import (
"context"
"log"
"os"
"time"
func main() {
ctx := context.Background()
// Initialize OAuth token manager
tm := NewTokenManager(OAuthConfig{
ClientID: os.Getenv("GENESYS_CLIENT_ID"),
ClientSecret: os.Getenv("GENESYS_CLIENT_SECRET"),
Region: "us",
Scopes: []string{"architect:flow:read"},
// Initialize HTTP client with token manager
hc := NewHTTPClient(tm)
// Initialize trace retriever with external webhook endpoint
tr := NewTraceRetriever(hc, os.Getenv("EXTERNAL_WEBHOOK_URL"))
// Construct trace request
req := TraceRequest{
FlowID: "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
ExecutionID: "12345678-90ab-cdef-1234-567890abcdef",
TraceRef: "trace-ref-prod-001",
NodeMatrix: true,
FetchDirective: "full",
StartTime: time.Now().Add(-24 * time.Hour),
EndTime: time.Now(),
// Execute retrieval pipeline
if err := tr.ProcessTracePipeline(ctx, req); err != nil {
log.Fatalf("Trace retrieval pipeline failed: %v", err)
log.Println("Trace retrieval completed successfully.")
Run the script with go run main.go. The module validates the request, authenticates via OAuth2, executes atomic GET operations, handles pagination and rate limits, emits webhook events, and generates audit logs.
- What causes it: The OAuth token expired or was never generated.
- How to fix it: Ensure the
Refreshmethod is called when the HTTP client receives a 401. Verify the client credentials match a valid OAuth application in the Genesys Cloud admin console. - Code showing the fix: The
FetchTracemethod checks forhttp.StatusUnauthorizedand callshc.tokenMgr.Refresh(ctx)before retrying the request.
Error: 403 Forbidden
- What causes it: The OAuth application lacks the
architect:flow:readscope or the user assigned to the application does not have Architect permissions. - How to fix it: Navigate to the OAuth application configuration and add
architect:flow:readto the allowed scopes. Assign the necessary Architect user roles to the service account. - Code showing the fix: The validation pipeline explicitly returns a descriptive error when status 403 is detected, preventing silent failures.
- What causes it: The client exceeded Genesys Cloud API rate limits.
- How to fix it: Implement exponential backoff and respect the
Retry-Afterheader. The provided code reads the header and sleeps for the specified duration before retrying. - Code showing the fix: The
FetchTracemethod parsesRetry-After, defaults to 10 seconds, and recursively calls itself after the delay.
Error: 400 Bad Request (Retention Violation)
- What causes it: The requested timestamp window exceeds the platform retention period or contains malformed date formats.
- How to fix it: Adjust
StartTimeandEndTimeto fall within the last 30 days. Use RFC3339 formatting for all timestamp parameters. - Code showing the fix:
ValidateTraceRequestcheckstime.Since(req.EndTime)againstmaxRetentionDaysand rejects requests that violate storage constraints.
