Retrieving connection to database for pulse failed. Using Gax 8.5.220
Hi everyone, I am getting error after installing pulse plugin with GAX. Gax works fine but i cannot see the pulse plugin, Can anyone help me please,
here is my GAX log,
Extension Log File
Version: 8.5.220.20
Hostname: MU1-VM-DBS-02
JVM vendor: Java HotSpot™ 64-Bit Server VM version:Java HotSpot™ 64-Bit Server VM
2016-03-30 10:45:52,442 WARN : com.genesyslab.gax.core.audit.AuditDatabaseBeanManager [main] - [49] Auditing data source is not configured, auditing is disabled!
2016-03-30 10:45:58,042 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:58,045 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [180] GAX - MS configuration.
2016-03-30 10:45:58,077 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [201] Timeout in seconds between attempts = 60
2016-03-30 10:45:58,077 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [218] Maximum number of connection attempts = 1
2016-03-30 10:45:58,077 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [221] Maximum number of configured switchovers trials = unlimited
2016-03-30 10:45:58,090 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [235] Starting Warmstandby Service
2016-03-30 10:45:58,090 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [237] Warmstandby Service started.
2016-03-30 10:45:58,175 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:58,175 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] GAX - SCS configuration.
2016-03-30 10:45:58,200 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [201] Timeout in seconds between attempts = 60
2016-03-30 10:45:58,202 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [218] Maximum number of connection attempts = 1
2016-03-30 10:45:58,202 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [221] Maximum number of configured switchovers trials = unlimited
2016-03-30 10:45:58,210 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [235] Starting Warmstandby Service
2016-03-30 10:45:58,212 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [237] Warmstandby Service started.
2016-03-30 10:45:58,222 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [154] Opening connection to SCS Server …
2016-03-30 10:45:58,340 INFO : com.genesyslab.gax.core.configuration.messageserver.MessageServerAdapter [main] - [154] Opening connection to MS Server …
2016-03-30 10:45:58,755 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:58,862 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [180] GAX - LCA configuration.
2016-03-30 10:45:58,880 INFO : com.genesyslab.gax.core.configuration.messageserver.MSChannelListener [Thread-11] - [22] Event:Channel tcp://MS@172.31.182.50:4044 is opened.
2016-03-30 10:45:58,880 INFO : com.genesyslab.gax.core.configuration.scs.SCSConnectorChannelListener [Thread-10] - [22] Event:Channel tcp://SCS@172.31.182.50:4046 is opened.
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [201] Timeout in seconds between attempts = 60
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [206] Timeout for LCA = 1000
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [218] Maximum number of connection attempts = 1
2016-03-30 10:45:58,902 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [221] Maximum number of configured switchovers trials = unlimited
2016-03-30 10:45:58,917 ERROR: com.genesyslab.gax.core.configuration.warmstandby.utils.WarmStandbyImpl [main] - [71] Wrong port configuration for Configuration object: type = CfgApplication, properties = {
DBID : 253
password : [output suppressed]
type : CFGGenesysAdministratorServer
version : 8.5.2
appServerDBIDs : StructList(CfgConnectionInfo)[6] = {
Configuration object: type = CfgConnInfo, properties = {
appServerDBID : 99
connProtocol : addp
timoutLocal : 20
timoutRemote : 20
mode : CFGTMBoth
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 103
timoutLocal : 0
timoutRemote : 0
mode : CFGTMNoTraceMode
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 104
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 254
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 255
timoutLocal : 0
timoutRemote : 0
mode : CFGTMNone
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 261
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
tenantDBIDs : ConfIntegerCollection[1 item(s)] = {
[1-1]: 101
isServer : CFGTrue
serverInfo : Configuration object: type = CfgServer, properties = {
hostDBID : 106
backupServerDBID : 0
timeout : 10
attempts : 1
options : KVList:
‘arm’ [lst] = KVList:
‘delete_from_db_after_processing’ [str] = “false”
‘local_announcement_folder’ [str] = “announcement”
‘local_music_folder’ [str] = “music”
‘local_path’ [str] = “/opt/gax/arm”
‘local_sox_path’ [str] = “/usr/bin/sox”
‘max_upload_audio_file_size’ [str] = “20”
‘target_announcement_folder’ [str] = “announcement”
‘target_music_folder’ [str] = “music”
‘target_path’ [str] = “/mnt/arm/target”
‘asd’ [lst] = KVList:
‘local_ip_cache_dir’ [str] = “./plugin.data/asd/gaxLocalCache”
‘silent_ini_path’ [str] = “./plugin.data/asd/installation/genesys_silent_ini.xml”
‘clog’ [lst] = KVList:
‘maxlogs’ [str] = “5000”
‘minlogs’ [str] = “100”
‘ga’ [lst] = KVList:
‘ga_appName’ [str] = “default”
‘ga_host’ [str] = “”
‘ga_port’ [str] = “80”
‘ga_protocol’ [str] = “http”
‘general’ [lst] = KVList:
‘auditing’ [str] = “true”
‘client_app_name’ [str] = “default”
‘default_account_dbid’ [str] = “100”
‘inactivity_timeout’ [str] = “600”
‘msgsrv_attempts’ [str] = “1”
‘msgsrv_timeout’ [str] = “10”
‘msgsrv_warmstandby_timeout’ [str] = “60”
‘scs_attempts’ [str] = “1”
‘scs_timeout’ [str] = “10”
‘scs_warmstandby_timeout’ [str] = “60”
‘session_timeout’ [str] = “900”
‘log’ [lst] = KVList:
‘all’ [str] = “”
‘standard’ [str] = “stdout,./logs/gax.log”
‘trace’ [str] = “”
‘verbose’ [str] = “standard”
‘opm’ [lst] = KVList:
‘write_json’ [str] = “false”
‘pulse’ [lst] = KVList:
‘cache_expire_timeout’ [str] = “1200”
‘editable_templates’ [str] = “false”
‘health_expire_timeout’ [str] = “30”
‘install_templates’ [str] = “true”
‘max_widgets_per_user’ [str] = “0”
‘snapshot_expire_timeout’ [str] = “24”
‘security’ [lst] = KVList:
‘host_whitelist’ [str] = “172.31.182.55”
‘host_whitelist_enabled’ [str] = “true”
state : CFGEnabled
userProperties : KVList:
appPrototypeDBID : 151
flexibleProperties : KVList:
workDirectory : .
commandLine : .
autoRestart : CFGFalse
startupTimeout : 90
shutdownTimeout : 90
redundancyType : CFGHTColdStanby
isPrimary : CFGTrue
startupType : CFGSUTAutomatic
portInfos : StructList(CfgPortInfo)[0] = {
resources : StructList(CfgObjectResource)[0] = {
componentType : CFGAppComponentUnknown
2016-03-30 10:45:58,922 ERROR: com.genesyslab.gax.core.configuration.warmstandby.utils.WarmStandbyImpl [main] - [74] Wrong port configuration for Configuration object: type = CfgApplication, properties = {
DBID : 253
version : 8.5.2
appServerDBID : 99
connProtocol : addp
timoutLocal : 20
timoutRemote : 20
mode : CFGTMBoth
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 103
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 104
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 254
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 255
timoutLocal : 0
timoutRemote : 0
mode : CFGTMNone
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
appServerDBID : 261
timoutLocal : 0
timoutRemote : 0
longField1 : 0
longField2 : 0
longField3 : 0
longField4 : 0
[1-1]: 101
isServer : CFGTrue
hostDBID : 106
timeout : 10
attempts : 1
options : KVList:
‘all’ [str] = “”
‘trace’ [str] = “”
state : CFGEnabled
workDirectory : .
commandLine : .
startupTimeout : 90
isPrimary : CFGTrue
2016-03-30 10:45:58,930 INFO : com.genesyslab.gax.core.configuration.lca.LcaAdapter [main] - [154] Opening connection to LCA Server …
2016-03-30 10:45:58,977 WARN : com.genesyslab.gax.core.system.SystemConfigurationImpl [main] - [145]
GAX starts with following command line:
null
GAX (application dbid: 253) is configured with the following options:
arm/delete_from_db_after_processing: ‘false’
arm/local_announcement_folder: ‘announcement’
arm/local_music_folder: ‘music’
arm/local_path: ‘/opt/gax/arm’
arm/local_sox_path: ‘/usr/bin/sox’
arm/max_upload_audio_file_size: ‘20’
arm/target_announcement_folder: ‘announcement’
arm/target_music_folder: ‘music’
arm/target_path: ‘/mnt/arm/target’
asd/local_ip_cache_dir: ‘./plugin.data/asd/gaxLocalCache’
asd/silent_ini_path: ‘./plugin.data/asd/installation/genesys_silent_ini.xml’
clog/maxlogs: ‘5000’
clog/minlogs: ‘100’
ga/ga_appname: ‘default’
ga/ga_host: ‘’
ga/ga_port: ‘80’
ga/ga_protocol: ‘http’
general/auditing: ‘true’
general/client_app_name: ‘default’
general/default_account_dbid: ‘100’
general/inactivity_timeout: ‘600’
general/msgsrv_attempts: ‘1’
general/msgsrv_timeout: ‘10’
general/msgsrv_warmstandby_timeout: ‘60’
general/scs_attempts: ‘1’
general/scs_timeout: ‘10’
general/scs_warmstandby_timeout: ‘60’
general/session_timeout: ‘900’
log/all: ‘’
log/standard: ‘stdout,./logs/gax.log’
log/trace: ‘’
log/verbose: ‘standard’
opm/write_json: ‘false’
pulse/cache_expire_timeout: ‘1200’
pulse/editable_templates: ‘false’
pulse/health_expire_timeout: ‘30’
pulse/install_templates: ‘true’
pulse/max_widgets_per_user: ‘0’
pulse/snapshot_expire_timeout: ‘24’
security/host_whitelist: ‘172.31.182.55’
security/host_whitelist_enabled: ‘true’
2016-03-30 10:45:59,200 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [179] ------------------------------------------------------------
2016-03-30 10:45:59,215 INFO : com.genesyslab.gax.core.configuration.scs.SolutionControlServerAdapter [main] - [180] GAX - SCS configuration.
2016-03-30 10:45:58,977 INFO : com.genesyslab.gax.core.configuration.lca.LcaMessageHandler [com.genesyslab.PCT.invoker.default] - [14] message received: ‘EventHostUnderControl’ (41) attributes:
attr_scs_socket [long] = 552
attr_scs_app_name [str] = “P_SolutionControlServer”
attr_scs_host_name [str] = “”
2016-03-30 10:45:59,212 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-13] - [23] Event:Channel tcp://LCA@localhost:4999 is opened.
2016-03-30 10:45:59,217 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-13] - [28] Event:updateStatus app name: gax
2016-03-30 10:45:59,220 INFO : com.genesyslab.gax.core.configuration.lca.LcaChannelListener [Thread-13] - [29] Event:updateStatus status: Running
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-22] - [161] Plugin gax-core is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-14] - [161] Plugin gax-clog is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-15] - [163] Plugin gax-fim is running as a backend service
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-16] - [161] Plugin gax-webservice is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-17] - [161] Plugin gax-opm-arm is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-18] - [161] Plugin gax-ga is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-19] - [161] Plugin pulse is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-20] - [161] Plugin gax-com is enabled
2016-03-30 10:46:00,962 INFO : com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-21] - [161] Plugin gax-asd is enabled
2016-03-30 10:46:01,140 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [89] ---------- opm-arm Database Schema Version ----------
2016-03-30 10:46:01,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [90] 8.1.301.01
2016-03-30 10:46:01,205 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [91] -------------------------------------------------
2016-03-30 10:46:01,205 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [41] Db Schema Version for plugin gax-opm-arm 8.1.301.01 is matching.
2016-03-30 10:46:01,207 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-17] - [43] ------------------------------------------------------------------------
2016-03-30 10:46:01,112 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [89] ---------- core Database Schema Version ----------
2016-03-30 10:46:01,220 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [90] 8.1.301.01
2016-03-30 10:46:01,220 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [91] -------------------------------------------------
2016-03-30 10:46:01,222 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [41] Db Schema Version for plugin gax-core 8.1.301.01 is matching.
2016-03-30 10:46:01,230 INFO : com.genesyslab.gax.core.util.CoreDatabaseInspectorImpl [Thread-22] - [43] ------------------------------------------------------------------------
2016-03-30 10:46:01,200 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [89] ---------- asd Database Schema Version ----------
2016-03-30 10:46:01,232 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [90] 8.5.000.01
2016-03-30 10:46:01,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [91] -------------------------------------------------
2016-03-30 10:46:01,237 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [41] Db Schema Version for plugin gax-asd 8.5.000.01 is matching.
2016-03-30 10:46:01,260 INFO : com.genesyslab.gax.api.database.DefaultDatabaseInspectorImpl [Thread-21] - [43] ------------------------------------------------------------------------
2016-03-30 10:46:02,573 ERROR: com.genesyslab.gax.core.database.GAXBasicDataSource [Thread-19] - [29] ---------------------------------------------------------------------
2016-03-30 10:46:03,075 ERROR: com.genesyslab.gax.core.database.GAXBasicDataSource [Thread-19] - [30] Retrieving connection to database for pulse failed.
2016-03-30 10:46:03,425 ERROR: com.genesyslab.gax.core.database.GAXBasicDataSource [Thread-19] - [32] ---------------------------------------------------------------------
2016-03-30 10:46:05,130 WARN : com.genesyslab.gax.wbrt.dao.LayoutDaoImpl [Thread-19] - [405] Database check schema failed due to exception: Could not get JDBC Connection; nested exception is org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Network error IOException: Connection refused: connect)
2016-03-30 10:46:07,660 WARN : com.genesyslab.gax.wbrt.main.EZPulsePlugin [Thread-19] - [93] Db Schema Version for plugin pulse is not matching: expected version 8.5.001.02 but current is null
2016-03-30 10:46:07,660 ERROR: com.genesyslab.gax.core.plugin.DefaultPluginManagerImpl [Thread-19] - [190] Plugin pulse database schema version mismatch
2016-03-30 10:46:13,000 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-21] - [83] SPD setup: loaded default scripts
2016-03-30 10:46:13,495 INFO : com.genesyslab.gax.asd.main.ASDPlugin [Thread-21] - [102] ASD initialized
2016-03-30 10:46:26,848 INFO : com.genesyslab.gax.webservice.UserController [qtp1323468230-42] - [118] Client:172.31.182.43 try to login.
2016-03-30 10:46:27,028 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [256] Warmstandby.getstate: Idle
2016-03-30 10:46:27,028 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.warmstandby] - [318] Config Server warmstandby state changed to Idle
2016-03-30 10:46:27,033 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [257] Warmstandby service started
2016-03-30 10:46:27,033 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [366] Opening connection to endpoint 2mjlpp9cecmp1de4mfcburxoda - tcp://172.31.182.50:2020
2016-03-30 10:46:27,033 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [367] Trusted storage location: null
2016-03-30 10:46:27,036 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [368] TLS service properly initialized: false
2016-03-30 10:46:27,038 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [qtp1323468230-42] - [369] TLS Authentication mandatory: false
2016-03-30 10:46:27,213 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.default] - [338] Config server (tcp://2mjlpp9cecmp1de4mfcburxoda@172.31.182.50:2020) channel opened event. Endpoint: 2mjlpp9cecmp1de4mfcburxoda - tcp://172.31.182.50:2020
2016-03-30 10:46:27,604 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.default] - [359] Notifying waiting thread…
2016-03-30 10:46:31,261 INFO : com.genesyslab.gax.core.scs.AlarmService [coreExecutor-1] - [59] Registered to ActiveAlarms
2016-03-30 10:46:46,007 INFO : com.genesyslab.gax.core.connection.ConnectorInternal [com.genesyslab.PCT.invoker.warmstandby] - [318] Config Server warmstandby state changed to Off
2016-03-30 10:46:46,009 INFO : com.genesyslab.gax.core.connection.ConfServiceProxyHandler [qtp1323468230-55] - [92] Connection to config server closed (User:default, Session:2mjlpp9cecmp1de4mfcburxod)
2016-03-30 10:46:46,012 INFO : com.genesyslab.gax.webservice.UserController [qtp1323468230-55] - [268] User default logged out
Is the Pulse database on same DBMS server as the GAX databases? Did you check the DAP’s configuration if all matches against suggested approach? Is this fresh install or any upgrade/migration?
Thank you for your response, this is a fresh installation. gax database is in the same dbms as pulse database, i checked all configurations on dap.
I see the Connection refused: connect, i don`t know why it cannot connect to db. My pulse collector dap connection to the db is fine. it is just the pulse jdbc that is not working.
Which DB are you using?
