Resolving Zoom Contact Center Call Recording Failures Caused by Insufficient Storage Permissions on Associated AWS S3 Buckets
This guide provides the technical process for diagnosing and remediating call recording failures in Zoom Contact Center (Zoom CX) caused by incorrect IAM policies or ACLs on the AWS S3 buckets used for external archival. You will learn how to identify the permission gap and apply the precise S3 bucket policy required to restore recording availability.
  • Zoom Licensing: Zoom Contact Center license with External Storage/Archival enabled.
  • AWS Permissions: Full Administrator access to the AWS account hosting the S3 bucket (specifically s3:PutBucketPolicy, s3:GetBucketPolicy, and iam:PassRole).
  • Zoom Roles: Zoom Admin role with permissions to manage Contact Center storage settings.
  • External Dependencies: A provisioned AWS S3 bucket in the same region as the Zoom CX deployment to minimize latency and egress costs.
1. Identifying the Failure Mode
Call recording failures due to S3 permissions do not typically trigger a “hard fail” that drops the call. Instead, the call proceeds, but the recording file is either never created or remains in a “pending” state indefinitely.
To confirm the issue is permission-based rather than a configuration error in the Zoom Admin Portal:
  1. Navigate to the Zoom Admin Portal > Contact Center > Recording.
  2. Attempt to playback a recording from the time window where failures are reported.
  3. If the playback fails with a “File not found” or “Access Denied” error, but the recording entry exists in the metadata, the issue is likely the handshake between Zoom’s recording service and your S3 bucket.
The Trap: Many engineers assume that because they can manually upload a file to the bucket using the AWS Console, the permissions are correct. The AWS Console uses your User IAM credentials, whereas Zoom CX uses a specific Service Principal or IAM Role. If the bucket policy does not explicitly grant s3:PutObject and s3:PutObjectAcl to the Zoom Service Principal, the recording upload will fail silently in the background.
2. Auditing the S3 Bucket Policy
Zoom requires a specific trust relationship to write media files to your bucket. You must ensure the Bucket Policy allows the Zoom AWS Account ID to perform write operations.
Architectural Reasoning: Zoom utilizes a “Push” model for external archival. The Zoom recording service acts as the writer. If the bucket is private (which it should be for PCI/HIPAA compliance), the bucket policy is the only mechanism that can authorize the external Zoom service without requiring static AWS Access Keys, which are a security risk.
Navigate to the S3 Console > Permissions > Bucket Policy and verify the existence of the following block (replace placeholders with your actual values):
    "Version": "2012-10-17",
    "Statement": [
            "Sid": "AllowZoomRecordingUploads",
            "Effect": "Allow",
            "Principal": {
                "AWS": "arn:aws:iam::ZOOM_AWS_ACCOUNT_ID:root"
            "Action": [
                "s3:PutObject",
                "s3:PutObjectAcl",
                "s3:GetBucketLocation"
            "Resource": [
                "arn:aws:s3:::YOUR_BUCKET_NAME",
                "arn:aws:s3:::YOUR_BUCKET_NAME/*"
The Trap: Omitting s3:PutObjectAcl is the most common cause of failure. Zoom often applies an ACL to the uploaded object to ensure it can verify the write was successful. If only s3:PutObject is granted, the upload may initiate, but the final confirmation step fails, causing Zoom to flag the recording as “Failed” or “Missing.”
3. Validating the IAM Role and Trust Relationship
If you are using an IAM Role for the integration rather than a direct bucket policy, you must verify the Trust Relationship tab of the role.
The role must allow the sts:AssumeRole action for the Zoom service principal. If this trust relationship is broken or the role has been deleted/recreated with a new ARN, the Zoom CX integration will lose access immediately.
Configuration Steps:
  1. Go to IAM > Roles > [Your Zoom Recording Role].
  2. Select the Trust relationships tab.
  3. Ensure the following is present:
  "Statement": [
      "Effect": "Allow",
      "Principal": {
      "Action": "sts:AssumeRole"
4. Re-synchronizing Zoom CX Storage Settings
Once the AWS permissions are corrected, you must force Zoom to re-validate the connection.
  1. In the Zoom Admin Portal, navigate to Contact Center > Storage Settings.
  2. Update the S3 bucket name or region (even a minor change) and click Save.
  3. Re-enter the correct bucket details and save again.
Architectural Reasoning: This “toggle” forces the Zoom backend to re-authenticate the connection and refresh the cached token for the S3 bucket. It ensures that the changes made in the AWS Console are recognized by the Zoom application layer.
Edge Case 1: S3 Block Public Access (BPA)
The Failure Condition: The bucket policy is correct, but recordings still fail to upload.
The Root Cause: The “Block Public Access” settings at the AWS Account level or Bucket level are overriding the bucket policy. Specifically, if “Block public access to buckets and objects granted through new access control lists (ACLs)” is enabled, the s3:PutObjectAcl call from Zoom will be rejected.
The Solution: Disable the specific BPA setting that blocks ACLs. While BPA is generally recommended, Zoom’s archival mechanism relies on object-level ACLs to verify ownership of the uploaded recording.
Edge Case 2: KMS Encryption Mismatch
The Failure Condition: Recordings are uploaded to S3, but the files are corrupted or cannot be played back by Zoom.
The Root Cause: The S3 bucket is configured to use AWS KMS (SSE-KMS) for encryption, but the Zoom Service Principal has not been granted kms:GenerateDataKey and kms:Decrypt permissions for the specific KMS key.
The Solution: Either switch the bucket encryption to SSE-S3 (Amazon S3 managed keys) or add a key policy to the KMS key that allows the Zoom AWS Account ID to use the key for encryption/decryption.
Edge Case 3: Regional Latency and Timeout
The Failure Condition: Intermittent recording failures (e.g., 5% of calls fail) despite correct permissions.
The Root Cause: The S3 bucket is located in a different AWS region than the Zoom CX instance (e.g., Zoom is in us-east-1 but the bucket is in eu-west-1). Large recordings may timeout during the upload phase.
The Solution: Migrate the archival bucket to the same region as the Zoom CX deployment to ensure the lowest possible latency and avoid cross-region data transfer timeouts.
