Resolving State Locks and Drift in Genesys Cloud Routing Queues with Terraform
- A diagnostic and remediation script that identifies Terraform state lock contention for
genesyscloud_routing_queueresources. - A Python utility using the Genesys Cloud Python SDK to fetch live queue configuration and compare it against Terraform state to isolate true drift from transient lock errors.
- A Go-based CLI helper to force-unlock stale state locks when safe to do so.
- OAuth Client: Service Account or Client Credentials with scopes
routing:queue:read,routing:queue:write, andanalytics:report:read. - Terraform Version: 1.5+ with the
myntra/genesyscloudprovider (v1.10+). - Language/Runtime: Python 3.9+ (for SDK comparison) and Go 1.21+ (for state management).
- Dependencies:
- Python:
pip install genesys-cloud-python requests - Go:
go get github.com/hashicorp/terraform-plugin-sdk/v2/helper/schema(for understanding state structure) or direct JSON manipulation. - Terraform: Installed and configured with remote state (S3, Azure Blob, or Genesys Cloud backend).
- Python:
Genesys Cloud uses OAuth 2.0 Client Credentials flow for service accounts. You must obtain a valid access token before making any API calls or interacting with the Terraform state via the SDK.
Python Authentication Helper
import os
import requests
from typing import Dict, Optional
class GenesysAuth:
def __init__(self, org_id: str, client_id: str, client_secret: str, env: str = "us"):
self.org_id = org_id
self.client_id = client_id
self.base_url = f"https://{env}.mypurecloud.com"
self.token_url = f"{self.base_url}/oauth/token"
if self.access_token:
return self.access_token
payload = {
"client_id": self.client_id,
headers = {
response = requests.post(self.token_url, data=payload, headers=headers)
response.raise_for_status()
data = response.json()
self.access_token = data.get("access_token")
raise Exception("Invalid client credentials or organization ID.") from e
elif response.status_code == 403:
raise Exception("Client does not have permission to authenticate.") from e
else:
raise Exception(f"Authentication failed: {e}") from e
def get_headers(self) -> Dict[str, str]:
token = self.get_access_token()
"Accept": "application/json"
Step 1: Diagnosing the State Lock
When terraform plan fails with Error acquiring the state lock, it is often due to a previous failed apply, a concurrent CI/CD pipeline run, or a backend timeout. Before assuming drift, you must determine if the lock is active or stale.
Go: Check and Force Unlock Stale State
This Go snippet demonstrates how to interact with the Terraform state lock mechanism if you are managing the backend directly (e.g., S3 with DynamoDB). Note: This is a diagnostic step. Only force unlock if you are certain no other process is writing.
package main
import (
"fmt"
"os"
"time"
"github.com/aws/aws-sdk-go/aws"
"github.com/aws/aws-sdk-go/aws/session"
"github.com/aws/aws-sdk-go/service/dynamodb"
// Assumes DynamoDB lock table is used for S3 backend
func checkStateLock(tableName string, lockId string) error {
svc := dynamodb.New(session.New(), &aws.Config{Region: aws.String("us-east-1")})
input := &dynamodb.GetItemInput{
Key: map[string]*dynamodb.AttributeValue{
"LockID": {
S: aws.String(lockId),
TableName: aws.String(tableName),
result, err := svc.GetItem(input)
if err != nil {
return fmt.Errorf("failed to get lock item: %w", err)
if result.Item == nil {
fmt.Println("No active lock found. The lock may have expired.")
return nil
// Check if the lock is stale (older than 10 minutes)
lockTime := result.Item["LockTime"].N
var lockTimestamp int64
fmt.Sscanf(*lockTime, "%d", &lockTimestamp)
now := time.Now().Unix()
if now - lockTimestamp > 600 { // 10 minutes
fmt.Println("Stale lock detected. Consider force-unlocking if safe.")
} else {
fmt.Println("Active lock detected. Another process is running.")
return nil
func main() {
if len(os.Args) < 3 {
fmt.Println("Usage: go run main.go <table-name> <lock-id>")
os.Exit(1)
tableName := os.Args[1]
lockId := os.Args[2]
err := checkStateLock(tableName, lockId)
if err != nil {
fmt.Printf("Error: %v\n", err)
os.Exit(1)
If the lock is stale, use terraform force-unlock <LOCK_ID> in your terminal. If the lock is active, wait for the other process to complete.
Step 2: Fetching Live Queue Data via SDK
Once the lock is resolved, terraform plan may still show drift. This drift often occurs because Genesys Cloud API returns default values for fields not explicitly set in the UI, while Terraform state may store null or different defaults.
We will use the Python SDK to fetch the actual state of a queue to compare against Terraform’s expectation.
Python: Fetch Queue Details
from genesyscloud import routing
from genesyscloud.platform_client import PlatformClient
def get_queue_by_name(auth: GenesysAuth, queue_name: str) -> dict:
Fetches a Genesys Cloud routing queue by name.
Requires scope: routing:queue:read
# Initialize PlatformClient
config = routing.Configuration()
config.host = auth.base_url
config.access_token = auth.get_access_token()
# Create API instance
api_instance = routing.QueueApi(routing.ApiClient(config))
# Search for queue by name
# Note: The SDK method is list_routing_queue
response, status_code, _ = api_instance.list_routing_queue(
page_size=25,
name=queue_name,
expand=['wrapupprompt', 'outboundemail', 'acdskills', 'members']
if status_code != 200:
raise Exception(f"API Error: {status_code} - {response}")
queues = response.entities
if not queues:
return None
# Return the first match
return queues[0]
raise Exception(f"Failed to fetch queue: {e}") from e
Step 3: Comparing State and Live Data
The core of the drift issue lies in specific fields: wrapupprompt, outbound_email, and skills. Genesys Cloud API often returns empty arrays or default objects for these, while Terraform may expect specific structures.
Python: Drift Analysis Utility
This function compares the live API response against a sample Terraform state representation.
import json
def analyze_queue_drift(live_queue: dict, tf_state_attrs: dict) -> list:
Compares live Genesys Cloud queue data against Terraform state attributes.
Returns a list of drift descriptions.
drifts = []
# 1. Check Wrap-up Prompt
# Genesys API returns an object or null. Terraform may store null if not set.
live_wrapup = live_queue.get('wrapupprompt')
tf_wrapup = tf_state_attrs.get('wrapup_prompt')
if live_wrapup is not None and tf_wrapup is None:
drifts.append(f"Drift: wrapup_prompt. Live has ID '{live_wrapup.get('id')}', State has None.")
elif live_wrapup is None and tf_wrapup is not None:
drifts.append(f"Drift: wrapup_prompt. Live is None, State has ID '{tf_wrapup}'.")
elif live_wrapup and tf_wrapup:
if live_wrapup.get('id') != tf_wrapup:
drifts.append(f"Drift: wrapup_prompt ID mismatch. Live: {live_wrapup.get('id')}, State: {tf_wrapup}")
# 2. Check Outbound Email
# API returns an object with 'id' and 'email'. State may be a string.
live_email = live_queue.get('outboundemail')
tf_email = tf_state_attrs.get('outbound_email')
if live_email is not None and tf_email is None:
drifts.append(f"Drift: outbound_email. Live has config, State has None.")
elif live_email is None and tf_email is not None:
drifts.append(f"Drift: outbound_email. Live is None, State has '{tf_email}'.")
elif live_email and tf_email:
if live_email.get('id') != tf_email:
drifts.append(f"Drift: outbound_email ID mismatch. Live: {live_email.get('id')}, State: {tf_email}")
# 3. Check Skills
# API returns a list of objects. State is a list of strings.
live_skills = [s.get('id') for s in live_queue.get('acdskills', [])]
tf_skills = tf_state_attrs.get('skills', [])
# Normalize for comparison
live_skills_set = set(live_skills)
tf_skills_set = set(tf_skills)
missing_in_state = live_skills_set - tf_skills_set
extra_in_state = tf_skills_set - live_skills_set
if missing_in_state:
drifts.append(f"Drift: skills. Missing in State: {missing_in_state}")
if extra_in_state:
drifts.append(f"Drift: skills. Extra in State: {extra_in_state}")
return drifts
Step 4: Resolving Drift via API
If drift is confirmed, you can either update the Terraform state to match the live system (terraform import or refresh) or update the live system to match Terraform (terraform apply). To avoid further drift, ensure your Terraform configuration explicitly sets all mutable fields.
Python: Update Queue to Match Terraform State
This example shows how to patch a queue to align with Terraform’s desired state, specifically handling the wrapup_prompt and outbound_email.
def update_queue_to_match_state(auth: GenesysAuth, queue_id: str, tf_state_attrs: dict) -> dict:
Updates a Genesys Cloud queue to match Terraform state.
Requires scope: routing:queue:write
# Prepare patch body
body = {}
# Handle Wrap-up Prompt
if tf_wrapup is not None:
body['wrapupprompt'] = {'id': tf_wrapup}
else:
body['wrapupprompt'] = None # Explicitly nullify if needed
# Handle Outbound Email
if tf_email is not None:
body['outboundemail'] = {'id': tf_email}
else:
body['outboundemail'] = None
# Handle Skills
if tf_skills:
body['acdskills'] = [{'id': skill_id} for skill_id in tf_skills]
else:
body['acdskills'] = []
# Use patch_routing_queue
response, status_code, _ = api_instance.patch_routing_queue(
queue_id=queue_id,
body=body
if status_code not in [200, 204]:
raise Exception(f"Update failed: {status_code} - {response}")
return response
raise Exception(f"Failed to update queue: {e}") from e
This complete Python script authenticates, fetches a queue, analyzes drift against a provided Terraform state dictionary, and optionally applies fixes.
import os
import sys
import json
import requests
# Import classes from previous steps
# Note: In a real script, these would be in the same file or imported from modules
class GenesysAuth:
self.access_token = None
payload = {
def get_queue_by_name(auth: GenesysAuth, queue_name: str):
page_size=25,
name=queue_name,
expand=['wrapupprompt', 'outboundemail', 'acdskills']
if status_code != 200 or not response.entities:
return None
return response.entities[0]
drifts = []
if extra_in_state:
return drifts
def main():
# Configuration
ORG_ID = os.getenv("GENESYS_ORG_ID")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
QUEUE_NAME = os.getenv("QUEUE_NAME", "Support-Queue")
if not all([ORG_ID, CLIENT_ID, CLIENT_SECRET]):
print("Error: Missing environment variables.")
sys.exit(1)
auth = GenesysAuth(ORG_ID, CLIENT_ID, CLIENT_SECRET)
# Sample Terraform State Attributes (Replace with actual state parsing if needed)
tf_state = {
"wrapup_prompt": "abc123-wrappid",
"outbound_email": "def456-emailid",
"skills": ["skill1-id", "skill2-id"]
print(f"Fetching queue: {QUEUE_NAME}")
live_queue = get_queue_by_name(auth, QUEUE_NAME)
if not live_queue:
print(f"Queue '{QUEUE_NAME}' not found.")
sys.exit(1)
print(f"Found Queue ID: {live_queue['id']}")
drifts = analyze_queue_drift(live_queue, tf_state)
if drifts:
print("\nDetected Drifts:")
for d in drifts:
print(f" - {d}")
else:
print("\nNo drift detected between live queue and provided Terraform state.")
main()
- Cause: Invalid OAuth token, expired credentials, or missing
routing:queue:readscope. - Fix: Verify the client ID and secret. Check the scope in the Genesys Cloud Admin Console under Organization Settings > OAuth. Ensure the client is authorized for the required scopes.
- Code Check: Ensure
auth.get_access_token()is called before every API interaction.
Error: 403 Forbidden
- Cause: The OAuth client lacks permissions to access the specific queue or organization.
- Fix: Assign the OAuth client to a user group with appropriate routing permissions. Ensure the service account has access to the organization.
- Code Check: Validate the
org_idmatches the target environment.
- Cause: Rate limiting due to excessive API calls.
- Fix: Implement exponential backoff retry logic. Genesys Cloud returns a
Retry-Afterheader in 429 responses. - Code Example:
def api_call_with_retry(func, max_retries=3):
for i in range(max_retries):
return func()
if e.response.status_code == 429:
retry_after = int(e.response.headers.get('Retry-After', 2 ** i))
print(f"Rate limited. Waiting {retry_after} seconds...")
time.sleep(retry_after)
else:
raise
raise Exception("Max retries exceeded")
Error: State Lock Timeout
- Cause: Another Terraform process is running.
- Fix: Wait for the other process to complete. If the process is stuck, use
terraform force-unlockwith the lock ID from the error message. Only do this if you are certain no other write operations are in progress.
