Resolving NICE CXone Outbound Campaign Callback Scheduling Conflicts via Python SDK
  • A Python service that detects callback scheduling conflicts in a CXone outbound campaign, constructs a resolution payload with conflict references, callback matrices, and defer directives, and executes an atomic PATCH operation to resolve the conflict.
  • The implementation uses the CXone Outbound Campaign REST API surface with Python requests, wrapped in a production-grade service class.
  • The tutorial covers Python 3.9+ with explicit OAuth2 token handling, constraint validation, timezone conversion, DNC compliance checking, webhook synchronization, metrics tracking, and audit logging.
  • CXone API key and secret with campaigns:read, campaigns:write, dnc:read, and webhooks:write scopes
  • CXone REST API v2 endpoints (Outbound Campaigns, DNC Lists, Webhooks)
  • Python 3.9 or newer
  • External dependencies: pip install requests pytz python-dateutil
CXone uses a JWT-based OAuth 2.0 client credentials flow. You must exchange your API key and secret for a bearer token before making any campaign or DNC API calls. The token expires after one hour and must be cached or refreshed programmatically.
import requests
from typing import Optional
class CxoneAuth:
    def __init__(self, api_key: str, api_secret: str, base_url: str = "https://api.us-2.cxone.com"):
        self.api_key = api_key
        self.api_secret = api_secret
    def get_token(self) -> str:
        if self.token and time.time() < self.token_expiry:
            return self.token
        url = f"{self.base_url}/api/v2/oauth/token"
        payload = {
            "client_id": self.api_key,
            "client_secret": self.api_secret
        headers = {"Content-Type": "application/json"}
        response = requests.post(url, json=payload, headers=headers, timeout=10)
        response.raise_for_status()
        data = response.json()
        self.token = data["access_token"]
        self.token_expiry = time.time() + data["expires_in"] - 60  # 60s buffer
        return self.token
Step 1: Fetch Campaign State and Detect Scheduling Conflicts
The first step retrieves the current campaign configuration and identifies conflicts where callback windows overlap with agent availability schedules or exceed maximum rescheduling limits. CXone stores campaign dialer constraints and callback rules in the campaign payload.
import logging
from typing import Dict, Any
logger = logging.getLogger("cxone_conflict_resolver")
class CxoneConflictResolver:
    def __init__(self, auth: CxoneAuth):
        self.auth = auth
        self.session = requests.Session()
        self.session.headers.update({"Accept": "application/json", "Content-Type": "application/json"})
    def _request(self, method: str, path: str, **kwargs) -> Dict[str, Any]:
        token = self.auth.get_token()
        self.session.headers["Authorization"] = f"Bearer {token}"
        url = f"{self.auth.base_url}{path}"
        # Retry logic for 429 Too Many Requests
        max_retries = 3
            response = self.session.request(method, url, **kwargs, timeout=15)
                retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
                logger.warning(f"Rate limited (429). Retrying in {retry_after}s (attempt {attempt+1}/{max_retries})")
                time.sleep(retry_after)
            return response.json() if response.text else {}
        raise Exception("Max retries exceeded for 429 response")
    def get_campaign(self, campaign_id: str) -> Dict[str, Any]:
        return self._request("GET", f"/api/v2/campaigns/{campaign_id}")
Step 2: Validate Constraints and Construct Resolution Payload
You must validate the resolve schema against outbound constraints before submission. The validation pipeline checks maximum rescheduling window limits, do-not-call compliance, and customer contact preferences. The payload includes a conflict reference, callback matrix, and defer directive.
from zoneinfo import ZoneInfo
import json
class ConflictValidator:
    def __init__(self, campaign: Dict[str, Any]):
        self.max_reschedule_window_hours = campaign.get("dialer", {}).get("maxRescheduleWindowHours", 24)
        self.agent_timezone = campaign.get("schedule", {}).get("timezone", "America/Chicago")
        self.agent_available = campaign.get("schedule", {}).get("availableHours", [])
    def check_dnc_and_preferences(self, number: str, dnc_client: "CxoneDncChecker") -> bool:
        is_blocked = dnc_client.is_on_dnc(number)
        preference = dnc_client.get_contact_preference(number)
        if is_blocked:
            logger.warning(f"Number {number} is on DNC list. Resolution aborted.")
            return False
        if preference and preference.get("status") == "OPT_OUT":
            logger.warning(f"Number {number} has opted out. Resolution aborted.")
            return False
        return True
    def validate_window(self, defer_timestamp: str, callback_matrix: Dict[str, Any]) -> bool:
        defer_dt = datetime.fromisoformat(defer_timestamp.replace("Z", "+00:00"))
        now_utc = datetime.now(ZoneInfo("UTC"))
        window_limit = now_utc + timedelta(hours=self.max_reschedule_window_hours)
        if defer_dt > window_limit:
            logger.error(f"Defer timestamp exceeds maximum rescheduling window of {self.max_reschedule_window_hours} hours.")
            return False
        for attempt in callback_matrix.get("attempts", []):
            attempt_dt = datetime.fromisoformat(attempt["scheduledAt"].replace("Z", "+00:00"))
            if attempt_dt > window_limit:
                logger.error(f"Callback attempt {attempt['id']} exceeds rescheduling window.")
                return False
        return True
    def check_agent_overlap(self, scheduled_timestamps: list[str]) -> bool:
        tz = ZoneInfo(self.agent_timezone)
        for ts in scheduled_timestamps:
            dt = datetime.fromisoformat(ts.replace("Z", "+00:00")).astimezone(tz)
            hour = dt.hour
            day = dt.weekday()
            # Simple overlap check against campaign schedule
            if not self._is_within_schedule(hour, day):
                logger.warning(f"Timestamp {ts} falls outside agent availability window.")
                return False
        return True
    def _is_within_schedule(self, hour: int, day: int) -> bool:
        for slot in self.agent_available:
            if slot.get("dayOfWeek") == day:
                if slot.get("startHour", 0) <= hour < slot.get("endHour", 24):
                    return True
        return False
Step 3: Execute Atomic PATCH with Queue Rebalance Trigger
CXone supports conditional updates using ETags to prevent race conditions during high-volume campaign modifications. The PATCH operation must include an If-Match header with the campaign ETag. You also set a queue rebalance flag to trigger automatic distribution adjustment after the conflict resolves.
    # ... previous methods ...
    def resolve_conflict(self, campaign_id: str, conflict_ref: str,
                         defer_timestamp: str, callback_matrix: Dict[str, Any],
                         etag: str) -> Dict[str, Any]:
        payload = {
            "conflictReference": conflict_ref,
            "deferDirective": {
                "deferUntil": defer_timestamp,
                "reason": "callback_scheduling_conflict_resolution"
            "callbackMatrix": callback_matrix,
            "queueRebalanceTrigger": True,
            "formatVersion": "2.0"
        headers = {"If-Match": etag}
        logger.info(f"Executing atomic PATCH for campaign {campaign_id} with ETag {etag}")
        return self._request("PATCH", f"/api/v2/campaigns/{campaign_id}", json=payload, headers=headers)
Step 4: Webhook Synchronization, Metrics Tracking, and Audit Logging
After a successful resolve, you must synchronize the event with external calendar systems via webhooks, track latency and defer success rates, and generate structured audit logs for campaign governance.
    def trigger_calendar_webhook(self, webhook_url: str, event_data: Dict[str, Any]) -> None:
            response = requests.post(webhook_url, json=event_data, timeout=5)
            logger.info(f"Calendar sync webhook delivered successfully.")
            logger.error(f"Webhook delivery failed: {e}")
    def log_audit(self, campaign_id: str, conflict_ref: str, status: str, latency_ms: float) -> Dict[str, Any]:
        audit_entry = {
            "timestamp": datetime.now(ZoneInfo("UTC")).isoformat(),
            "campaignId": campaign_id,
            "resolutionStatus": status,
            "latencyMilliseconds": latency_ms,
            "resolvedBy": "automated_conflict_resolver",
            "complianceChecked": True,
            "queueRebalanced": True
        logger.info(f"Audit log: {json.dumps(audit_entry)}")
        return audit_entry
import requests
import logging
import json
class CxoneAuth:
            return self.token
        payload = {"grant_type": "client_credentials", "client_id": self.api_key, "client_secret": self.api_secret}
        response = requests.post(url, json=payload, headers={"Content-Type": "application/json"}, timeout=10)
        return self.token
class CxoneDncChecker:
        self.auth = auth
        self.session.headers.update({"Authorization": f"Bearer {self.auth.get_token()}"})
        response = self.session.request(method, url, **kwargs, timeout=10)
    def is_on_dnc(self, number: str) -> bool:
            data = self._request("GET", f"/api/v2/dnc/lists/default/entries?phoneNumbers={number}")
            return len(data.get("entries", [])) > 0
            if e.response.status_code == 404:
                return False
            raise
    def get_contact_preference(self, number: str) -> Dict[str, Any]:
            return self._request("GET", f"/api/v2/preferences/{number}")
        except requests.exceptions.HTTPError:
            return {}
    def __init__(self, auth: CxoneAuth, dnc_checker: CxoneDncChecker):
        self.auth = auth
        self.dnc_checker = dnc_checker
        self.metrics = {"total_resolves": 0, "successful_defers": 0, "total_latency_ms": 0.0}
        self.session.headers["Authorization"] = f"Bearer {self.auth.get_token()}"
        max_retries = 3
                logger.warning(f"Rate limited (429). Retrying in {retry_after}s")
                         etag: str, webhook_url: str) -> Dict[str, Any]:
        start_time = time.time()
        campaign = self.get_campaign(campaign_id)
        validator = ConflictValidator(campaign)
        target_number = callback_matrix.get("targetNumber", "")
        if not validator.check_dnc_and_preferences(target_number, self.dnc_checker):
            raise ValueError("DNC or preference compliance check failed")
        if not validator.validate_window(defer_timestamp, callback_matrix):
            raise ValueError("Rescheduling window constraint violated")
        scheduled_times = [att["scheduledAt"] for att in callback_matrix.get("attempts", [])]
        if not validator.check_agent_overlap(scheduled_times):
            raise ValueError("Agent availability overlap conflict detected")
        payload = {
            "deferDirective": {"deferUntil": defer_timestamp, "reason": "callback_scheduling_conflict_resolution"},
        logger.info(f"Executing atomic PATCH for campaign {campaign_id}")
        result = self._request("PATCH", f"/api/v2/campaigns/{campaign_id}", json=payload, headers=headers)
        self.metrics["total_resolves"] += 1
        self.metrics["successful_defers"] += 1
        self.metrics["total_latency_ms"] += latency_ms
        event_data = {
            "eventType": "CONFLICT_RESOLVED",
            "resolvedAt": datetime.now(ZoneInfo("UTC")).isoformat(),
            "latencyMs": latency_ms
        self.trigger_calendar_webhook(webhook_url, event_data)
        self.log_audit(campaign_id, conflict_ref, "SUCCESS", latency_ms)
        return result
            logger.info("Calendar sync webhook delivered successfully.")
        audit_entry = {
        return audit_entry
    def check_dnc_and_preferences(self, number: str, dnc_client: CxoneDncChecker) -> bool:
        if is_blocked:
            return False
            return False
        return True
            return False
                logger.error(f"Callback attempt exceeds rescheduling window.")
                return False
        return True
            if not self._is_within_schedule(dt.hour, dt.weekday()):
                return False
        return True
                    return True
        return False
    auth = CxoneAuth(api_key="YOUR_API_KEY", api_secret="YOUR_API_SECRET")
    dnc = CxoneDncChecker(auth)
    resolver = CxoneConflictResolver(auth, dnc)
    campaign_id = "a1b2c3d4-e5f6-7890-abcd-ef1234567890"
    conflict_ref = "CONFLICT-CB-98765"
    etag = '"v1-campaign-abc123"'
    webhook_url = "https://your-calendar-system.com/api/cxone-sync"
    defer_ts = (datetime.now(ZoneInfo("UTC")) + timedelta(hours=2)).isoformat() + "Z"
    callback_matrix = {
        "targetNumber": "+15551234567",
        "attempts": [
            {"id": "ATT-001", "scheduledAt": defer_ts, "priority": 1},
            {"id": "ATT-002", "scheduledAt": (datetime.now(ZoneInfo("UTC")) + timedelta(hours=3)).isoformat() + "Z", "priority": 2}
        result = resolver.resolve_conflict(campaign_id, conflict_ref, defer_ts, callback_matrix, etag, webhook_url)
        print("Conflict resolved successfully.")
        print(f"Metrics: {resolver.metrics}")
        print(f"Resolution failed: {e}")
Error: 400 Bad Request
  • Cause: The payload schema violates CXone outbound constraints, such as missing required fields in the callback matrix or an invalid defer timestamp format.
  • Fix: Verify that deferUntil and all scheduledAt values use ISO 8601 format with timezone designators. Ensure the callback matrix contains valid attempt IDs and priority integers.
  • Code Fix: Add explicit schema validation before the PATCH call:
from dateutil import parser
def validate_iso_timestamp(ts: str) -> bool:
        parser.isoparse(ts)
        return True
    except ValueError:
        return False
Error: 409 Conflict
  • Cause: The If-Match ETag header does not match the current campaign version. Another process modified the campaign between your GET and PATCH requests.
  • Fix: Implement optimistic locking. Re-fetch the campaign, extract the new ETag from the response headers, and retry the PATCH operation.
  • Code Fix:
response = self.session.patch(url, json=payload, headers=headers, timeout=15)
if response.status_code == 409:
    fresh_campaign = self._request("GET", path)
    new_etag = response.headers.get("ETag", etag)
    return self._request("PATCH", path, json=payload, headers={"If-Match": new_etag})
  • Cause: CXone rate limits are enforced per tenant and per endpoint. High-frequency conflict resolution loops trigger exponential backoff requirements.
  • Fix: The provided _request method implements automatic retry with Retry-After header parsing. Ensure your resolution pipeline respects the Retry-After value and caps concurrent requests.
  • Code Fix: Already implemented in the _request method with exponential backoff and header parsing.
Error: 5xx Internal Server Error
  • Cause: CXone backend processing failure, often related to queue rebalance triggers or DNC list synchronization delays.
  • Fix: Implement circuit breaker logic. If 5xx errors exceed a threshold within 60 seconds, pause resolution attempts and log a governance alert.
  • Code Fix:
if response.status_code >= 500:
    logger.error(f"Server error {response.status_code}. Pausing resolution pipeline.")
    time.sleep(30)
    raise Exception("Circuit breaker triggered for 5xx cascade")
