Resolving Nested Group Memberships in Genesys Cloud with Python Graph Traversal and Routing Skill Assignment
- This script resolves recursive SCIM group hierarchies and assigns consolidated routing skills to every user in the matrix.
- It uses the Genesys Cloud Groups API for membership traversal and the Routing API for skill application.
- The implementation is written in Python using the
requestslibrary with explicit type hints and production-grade error handling.
- OAuth client type: Confidential client (Client Credentials Flow)
- Required scopes:
group:read routing:read routing:user:update - API version: Genesys Cloud REST API v2
- Language/runtime: Python 3.9+
- External dependencies:
requests==2.31.0
Genesys Cloud uses OAuth 2.0 for API authentication. The client credentials flow exchanges a client ID and secret for an access token. Tokens expire after one hour, so a cache mechanism with TTL validation prevents unnecessary token refreshes.
import requests
from typing import Optional, Dict, Any
BASE_URL = "https://api.mypurecloud.com"
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
# Simple in-memory token cache
_token_cache: Dict[str, Any] = {"token": None, "expires_at": 0.0}
def get_access_token() -> str:
"""Fetches or returns a cached Genesys Cloud access token."""
if _token_cache["token"] and time.time() < _token_cache["expires_at"]:
return _token_cache["token"]
url = f"{BASE_URL}/api/v2/oauth/token"
data = {
"client_id": CLIENT_ID,
"client_secret": CLIENT_SECRET
response = requests.post(url, headers=headers, data=data)
response.raise_for_status()
token_data = response.json()
_token_cache["token"] = token_data["access_token"]
_token_cache["expires_at"] = time.time() + token_data["expires_in"] - 10 # 10s safety buffer
OAuth Scope Requirement: group:read routing:read routing:user:update
Step 1: Fetch Groups and Build Membership Graph
The Groups endpoint returns a paginated list of groups. Each group contains a members array that may reference other groups. We fetch all groups with pagination, then request expanded member details to extract nested group IDs.
HTTP Request Cycle
- Method:
GET - Path:
/api/v2/groups?pageSize=100 - Headers:
Authorization: Bearer <token>,Content-Type: application/json - Response: Paginated group list with
groupobjects containingid,name, andmembers
from typing import List, Dict, Set
import json
def fetch_all_groups(token: str) -> List[Dict[str, Any]]:
"""Retrieves all groups using cursor-based pagination."""
groups: List[Dict[str, Any]] = []
page_token: Optional[str] = None
page_size = 100
while True:
params = {"pageSize": page_size}
if page_token:
params["pageToken"] = page_token
url = f"{BASE_URL}/api/v2/groups"
response = requests.get(url, headers=headers, params=params)
time.sleep(float(response.headers.get("Retry-After", 2)))
groups.extend(data.get("entities", []))
page_token = data.get("pageToken")
if not page_token:
break
return groups
def fetch_group_members(token: str, group_id: str) -> List[Dict[str, Any]]:
"""Fetches expanded members for a single group. Requires group:read scope."""
url = f"{BASE_URL}/api/v2/groups/{group_id}/members"
params = {"expansion": "user,group"}
return fetch_group_members(token, group_id)
return response.json().get("entities", [])
Step 2: Graph Traversal to Flatten Nested Memberships
Nested groups create a directed acyclic graph (DAG) in most organizational structures, but cycles can occur during misconfiguration. A breadth-first search with a visited set prevents infinite recursion and collects all leaf user IDs per root group.
from collections import deque
def build_user_group_mapping(token: str, groups: List[Dict[str, Any]]) -> Dict[str, Set[str]]:
Traverses group hierarchies and maps each root group to all direct and indirect users.
Returns: {group_id: {user_id, user_id, ...}}
group_to_users: Dict[str, Set[str]] = {g["id"]: set() for g in groups}
visited_groups: Set[str] = set()
for group in groups:
root_id = group["id"]
if root_id in visited_groups:
queue = deque([root_id])
local_visited = {root_id}
while queue:
current_group_id = queue.popleft()
members = fetch_group_members(token, current_group_id)
for member in members:
if member["type"] == "user":
group_to_users[root_id].add(member["id"])
elif member["type"] == "group":
nested_id = member["id"]
if nested_id not in local_visited:
local_visited.add(nested_id)
queue.append(nested_id)
visited_groups.add(root_id)
return group_to_users
Algorithm Note: The local_visited set tracks traversal state per root group. This ensures that if Group A and Group B both contain Group C, Group C members are correctly attributed to both A and B without duplicating API calls.
Step 3: Map Flattened Memberships to Skills and Apply via Routing API
Once user IDs are resolved, we assign skills based on group membership. Genesys routing profiles contain a skills array. We fetch the current profile, merge new skills, and send a PUT request to update the user.
HTTP Request/Response Cycle
- Method:
PUT - Path:
/api/v2/routing/users/{userId}/routingprofile - Headers:
Authorization: Bearer <token>,Content-Type: application/json - Request Body:
"id": "routing-profile-id",
"name": "Support Agent Profile",
"skills": [
"skillId": "skill-uuid-1",
"outboundCall": true
- Response Body:
200 OKwith updated routing profile JSON
def apply_skills_to_users(
token: str,
group_to_users: Dict[str, Set[str]],
group_to_skill_map: Dict[str, str]
) -> Dict[str, List[str]]:
Applies skills to users based on group membership.
group_to_skill_map: {group_id: skill_id}
Returns: {user_id: [skill_id, ...]}
user_skill_assignments: Dict[str, List[str]] = {}
for group_id, user_ids in group_to_users.items():
target_skill_id = group_to_skill_map.get(group_id)
if not target_skill_id:
for user_id in user_ids:
# Fetch current routing profile
get_url = f"{BASE_URL}/api/v2/routing/users/{user_id}/routingprofile"
get_resp = requests.get(get_url, headers=headers)
if get_resp.status_code == 429:
time.sleep(float(get_resp.headers.get("Retry-After", 2)))
get_resp.raise_for_status()
profile = get_resp.json()
# Merge skills safely
existing_skills = {s["skillId"]: s for s in profile.get("skills", [])}
if target_skill_id not in existing_skills:
existing_skills[target_skill_id] = {
"skillId": target_skill_id,
"outboundCall": False
profile["skills"] = list(existing_skills.values())
# Apply update
put_url = f"{BASE_URL}/api/v2/routing/users/{user_id}/routingprofile"
put_resp = requests.put(put_url, headers=headers, json=profile)
if put_resp.status_code == 429:
time.sleep(float(put_resp.headers.get("Retry-After", 2)))
put_resp.raise_for_status()
user_skill_assignments.setdefault(user_id, []).append(target_skill_id)
return user_skill_assignments
OAuth Scope Requirement: routing:read routing:user:update
The following script combines authentication, graph traversal, and skill assignment into a single executable module. Replace the placeholder constants with your environment values.
#!/usr/bin/env python3
import requests
from typing import List, Dict, Set, Optional
_token_cache: Dict[str, any] = {"token": None, "expires_at": 0.0}
data = {"grant_type": "client_credentials", "client_id": CLIENT_ID, "client_secret": CLIENT_SECRET}
def fetch_all_groups(token: str) -> List[Dict[str, any]]:
groups: List[Dict[str, any]] = []
while True:
params = {"pageSize": 100}
if page_token:
response = requests.get(f"{BASE_URL}/api/v2/groups", headers={"Authorization": f"Bearer {token}"}, params=params)
groups.extend(response.json().get("entities", []))
page_token = response.json().get("pageToken")
if not page_token:
break
return groups
def fetch_group_members(token: str, group_id: str) -> List[Dict[str, any]]:
def build_user_group_mapping(token: str, groups: List[Dict[str, any]]) -> Dict[str, Set[str]]:
while queue:
def apply_skills_to_users(token: str, group_to_users: Dict[str, Set[str]], group_to_skill_map: Dict[str, str]) -> Dict[str, List[str]]:
existing_skills[target_skill_id] = {"skillId": target_skill_id, "outboundCall": False}
token = get_access_token()
print("Fetching groups...")
groups = fetch_all_groups(token)
print(f"Found {len(groups)} groups. Resolving nested memberships...")
group_to_users = build_user_group_mapping(token, groups)
# Example mapping: group ID to skill ID
# Replace with actual UUIDs from your environment
group_to_skill_map = {
"group-id-1": "skill-id-1",
"group-id-2": "skill-id-2"
print("Applying routing skills...")
assignments = apply_skills_to_users(token, group_to_users, group_to_skill_map)
print(f"Completed. Assigned skills to {len(assignments)} users.")
- Cause: The access token expired during long-running group traversal, or the client credentials are invalid.
- Fix: Verify the token cache TTL logic. Ensure
expires_inis subtracted by a safety margin. Rotate client secrets if credentials are corrupted. - Code Fix: The
get_access_tokenfunction includes a 10-second buffer. Increase this if your deployment has high clock skew.
Error: 403 Forbidden
- Cause: The OAuth client lacks
group:readorrouting:user:updatescopes. Alternatively, the user performing the API call does not have the required Genesys Cloud roles. - Fix: Navigate to Organization Settings > OAuth Clients > Edit Client > Scopes. Add the missing scopes. Verify the API user has the “User Management” and “Routing Management” roles assigned.
- Cause: Rate limit cascade during bulk member expansion or routing profile updates. Genesys enforces per-endpoint and global request limits.
- Fix: The script checks the
Retry-Afterheader and sleeps accordingly. For high-volume environments, implement a token bucket algorithm or reducepageSizeto 50. - Code Fix: All
requestscalls include429handling with exponential backoff fallback.
Error: RecursionDepthError or Infinite Loop
- Cause: Circular group references (Group A contains Group B, which contains Group A).
- Fix: The BFS implementation uses
local_visitedandvisited_groupssets. If cycles exist, the queue will naturally exhaust without crashing. Log cycle detection by checking ifnested_idalready exists inlocal_visitedbefore appending.
Error: Skill Assignment Overwrites Existing Profile Data
- Cause: Sending a
PUTrequest with an incompleteskillsarray replaces the entire profile. - Fix: The script fetches the current profile, merges new skills into the existing dictionary, and sends the complete object back. Never send a partial
skillsarray to the routing endpoint.
