Resolving Media Bypass Failures in Codec Negotiation between Genesys Cloud and Cisco UCCE Gateways
This guide configures RFC 3703-compliant media bypass and resolves codec negotiation failures between Genesys Cloud SIP connectors and Cisco UCCE gateways. The end result is a direct RTP path between endpoints and Genesys Cloud media servers, eliminating transcoding overhead while maintaining reliable call setup and renegotiation under production load.
- Genesys Cloud Licensing: CX 2 or higher tier. Media bypass and advanced media policy configuration require at least CX 2.
- Genesys Cloud Permissions:
Telephony:Trunk:EditTelephony:MediaPolicy:EditTrace:ViewTelephony:Media:Edit
- OAuth Scopes:
telephony:trunk:edit,telephony:mediapolicy:edit,trace:read - Cisco UCCE Licensing: SIP/VXML Gateway license per gateway instance. CUCM SIP Trunk license.
- Network Requirements: RFC 1918 NAT traversal configured, SIP Application Layer Gateway (ALG) disabled on all intermediate firewalls and routers, symmetric NAT avoided on edge devices.
- External Dependencies: CUCM SIP Trunk configuration access, Cisco VXML/SIP Gateway administration access, Genesys Cloud Network configuration access.
1. Align SDP Offer/Answer Attributes for RFC 3703 Compliance
Media bypass operates on the principle that the media server intentionally remains out of the RTP path after initial call setup. Genesys Cloud enforces strict SDP attribute validation to prevent routing loops and asymmetric media flows. Cisco UCCE gateways and CUCM SIP trunks frequently modify SDP direction attributes during translation, which breaks the bypass contract.
Configure the Genesys Cloud SIP connector to accept RFC 3703-compliant SDP transitions. In the Genesys Cloud admin console, navigate to Telephony > Trunks, select your SIP connector, and enable Allow Media Bypass. Under advanced settings, set SDP Direction Handling to Strict RFC 3703. This forces Genesys Cloud to expect an initial a=inactive or a=sendrecv from the gateway, followed by a re-INVITE with a=sendrecv pointing directly to the endpoint IP.
On the Cisco UCCE side, modify the SIP Profile assigned to the gateway. Set Allow Direct Media to Yes and Media Termination Point Required to No. Ensure the SIP Trunk Security Profile on CUCM does not enforce Media Termination Point Required. When CUCM forces a Media Termination Point, it intercepts RTP and rewrites the SDP c= line, which directly violates RFC 3703. Genesys Cloud will reject the answer with a 488 Not Acceptable Here because the SDP indicates the media server is still in the path.
The Trap: Enabling Allow Media Bypass in Genesys Cloud without verifying that CUCM’s SIP Trunk Media Termination Point is disabled causes SDP collapse during the first re-INVITE. Genesys Cloud sends a re-INVITE with a=sendrecv and an endpoint IP, but CUCM answers with a=inactive or rewrites the c= line to its own TSP address. The call drops immediately after ringing because Genesys Cloud interprets this as a media server retention request, which conflicts with the bypass flag.
Architectural Reasoning: We enforce strict RFC 3703 alignment because Genesys Cloud’s media stack validates the a=setup and a=connection attributes against its internal routing table. If the gateway modifies these attributes during translation, the media server cannot verify the direct path. This validation prevents NAT hairpinning and ensures RTP flows do not loop back through the gateway under high packet loss conditions.
2. Resolve Codec Priority and Payload Type Mapping Conflicts
Codec negotiation failures occur when Genesys Cloud and Cisco UCCE assign conflicting payload type (PT) numbers or disagree on frame packing parameters. Genesys Cloud dynamically negotiates PT numbers per session, but Cisco UCCE gateways often remap PTs to match internal DSP farm expectations. This remapping breaks media bypass because the RTP stream arrives with a PT number that Genesys Cloud does not associate with the negotiated codec.
Configure explicit payload type mapping on both sides. In Genesys Cloud, navigate to Telephony > Media Policies and create a policy dedicated to the UCCE trunk. Set the preferred codec order to G.711u (PT 0), G.711a (PT 8), G.729 (PT 18), and disable Opus for this specific policy. Enable Lock Payload Types to IETF Standard. This prevents Genesys Cloud from assigning dynamic PTs like 101 or 102 during negotiation.
On Cisco CUCM, edit the SIP Trunk configuration. Under Media Resources, set Prefer Cisco Codec to No and Allow Codec Re-Ordering to No. In the SIP Profile, ensure Payload Type Mapping matches the IETF standard exactly. If you must use G.729, verify that the a=fmtp parameter matches exactly. Genesys Cloud expects a=fmtp:18 annexb=no. Cisco UCCE frequently appends packetization-type=20, which causes Genesys Cloud to reject the SDP during bypass validation.
You can audit the media policy configuration via the Genesys Cloud API. Use the following request to retrieve and validate your policy:
GET /api/v2/telephony/media/policies/{mediaPolicyId}
Authorization: Bearer {access_token}
Accept: application/json
Expected response structure for bypass-compliant configuration:
"id": "12345",
"name": "UCCE_Gateway_Bypass_Policy",
"preferredCodecs": ["G711U", "G711A", "G729"],
"lockPayloadTypes": true,
"allowMediaBypass": true,
"maxPacketSize": 1500,
"rtpKeepAliveEnabled": true,
"rtpKeepAliveIntervalSeconds": 30
The Trap: Allowing dynamic PT assignment while Cisco UCCE remaps PTs during gateway translation causes silent RTP drops. The SIP signaling completes with a 200 OK, but Genesys Cloud discards the RTP stream because the PT number in the RTP header does not match the PT number recorded in the SDP answer. The symptom is one-way audio or complete media timeout despite successful call setup.
Architectural Reasoning: We lock payload types to IETF standards because Cisco UCCE gateways perform PT translation based on internal DSP resource allocation. When Genesys Cloud assigns a dynamic PT, the gateway cannot correlate it to its internal codec table and either drops the stream or falls back to transcoding. Locking PTs ensures the SDP and RTP headers remain synchronized across the gateway boundary, which is mandatory for bypass architecture.
3. Configure NAT Traversal and SIP ALG Neutralization
Media bypass requires direct IP routing between the endpoint and Genesys Cloud media servers. Any intermediate device that rewrites SDP IP addresses or port numbers breaks the direct path. Cisco deployments frequently sit behind firewalls that enable SIP ALG, which modifies the c= and m= lines in the SDP to reflect the firewall’s external IP. Genesys Cloud interprets this as a NAT traversal request and attempts to establish STUN/ICE sessions, which bypass architecture explicitly avoids.
Disable SIP ALG on all Cisco ASA, Firepower, or third-party firewalls handling the trunk traffic. In Genesys Cloud, navigate to Telephony > Trunks > [Your SIP Connector] > Advanced. Set NAT Traversal Mode to Disabled and enable Direct Media Routing. This tells Genesys Cloud to trust the c= line in the SDP without initiating STUN discovery.
On the Cisco side, verify that the VXML/SIP gateway is configured with Public IP matching the actual external IP of the network path. Ensure SIP Normalization Script does not modify SDP attributes. Cisco Unified Communications Manager should be configured with SIP Trunk Security Profile > Media Termination Point Required set to No and Allow Direct Media set to Yes. If you must traverse a NAT boundary, configure Genesys Cloud to use RFC 3581 Symmetric RTP by enabling Expect Symmetric RTP in the SIP connector advanced settings. This forces Genesys Cloud to verify that the source IP of incoming RTP matches the SDP c= line, preventing asymmetric routing.
The Trap: Leaving SIP ALG enabled while enabling Direct Media Routing causes Genesys Cloud to route RTP to an unreachable NAT address. The firewall rewrites the SDP to its external IP, but the firewall does not open the corresponding UDP ports for RTP. Genesys Cloud sends RTP to the external IP, the firewall drops the packets, and the call fails with RTP Timeout in the Genesys Cloud trace.
Architectural Reasoning: We disable NAT traversal and force direct media routing because bypass architecture assumes a flat media path. STUN/ICE adds latency and introduces dependency on UDP hole punching, which conflicts with the deterministic routing required for bypass. Symmetric RTP validation ensures that if NAT exists, it is symmetric and predictable, allowing Genesys Cloud to maintain the direct path without media server intervention.
4. Implement Fallback Transcoding Policies for Negotiation Timeouts
Media bypass negotiation has a strict timeout window. If the gateway fails to respond to the re-INVITE within the configured window, Genesys Cloud drops the call unless a fallback policy exists. Under production load, Cisco UCCE gateways may delay SDP processing due to DSP contention or VXML server queuing. Without fallback, these delays translate to 100% call drops during peak hours.
Configure a graceful degradation path. In Genesys Cloud, navigate to Telephony > Media Policies > [Your Policy]. Enable Fallback to Transcoding on Bypass Failure and set Bypass Negotiation Timeout to 4500ms. Set Fallback Codec to G.711u. This ensures that if the gateway does not complete the bypass handshake within 4.5 seconds, Genesys Cloud routes the media through its transcoding servers instead of dropping the call.
On the Cisco UCCE side, configure the VXML Gateway to Enable Fallback to Transcoding and set SDP Renegotiation Timeout to 5000ms. Ensure the DSP Farm has sufficient resources to handle fallback transcoding. Monitor DSP utilization via RTMT to prevent fallback from consuming all DSP resources, which would block new call setup.
Validate the fallback configuration using the Genesys Cloud Trace API. Capture a failed bypass negotiation and verify the 488 Not Acceptable Here or 503 Service Unavailable response triggers the fallback policy. The trace should show a second INVITE with a=sendrecv pointing to a Genesys Cloud media server IP instead of the endpoint IP.
The Trap: Setting aggressive bypass timeouts without enabling fallback transcoding causes systemic call drops during gateway resource contention. When Cisco UCCE DSPs are saturated, SDP processing delays exceed the timeout, and Genesys Cloud terminates the session. The result is degraded SLA compliance and increased repeat call volume.
Architectural Reasoning: We implement fallback transcoding because bypass is an optimization, not a requirement. Production contact centers prioritize call completion over media path efficiency. Graceful degradation ensures that gateway latency or resource exhaustion does not break the signaling path. Transcoding servers absorb the performance penalty while maintaining call continuity, which aligns with enterprise SLA requirements.
Edge Case 1: SDP Re-INVITE Drops on DTMF/RTP Inspection
- The failure condition: Calls connect successfully, but drop immediately when the agent or customer presses a DTMF key, or when Genesys Cloud initiates a media path update for recording or speech analytics.
- The root cause: Cisco UCCE gateway rejects the re-INVITE due to
a=ptimemismatch or missinga=fmtpparameters for G.729. Genesys Cloud sends a re-INVITE witha=ptime:20, but the gateway answers witha=ptime:30or strips thea=fmtpline entirely. The SDP mismatch triggers a488 Not Acceptable Here. - The solution: Lock
a=ptimeto 20ms across both platforms. In Genesys Cloud Media Policy, set Packet Time to20. On Cisco CUCM, edit the SIP Trunk and set Preferred Packet Size to20. Verify thata=fmtp:18 annexb=nois preserved in the SDP answer by disabling SIP Normalization on the gateway. Use Genesys Cloud Trace to capture the exact SDP exchange and validate attribute parity.
Edge Case 2: RTP Asymmetric Routing Due to Multi-Homed CUCM
- The failure condition: One-way audio or complete media timeout despite successful SIP
200 OKand correct codec negotiation. - The root cause: CUCM publishes multiple SIP endpoints for the same trunk. Genesys Cloud selects the wrong IP address for the SDP
c=line during bypass routing. The endpoint sends RTP to the selected IP, but the network path routes it through a different interface, causing asymmetric routing. - The solution: Force CUCM to use a single primary IP for the SIP trunk. In CUCM, edit the SIP Trunk and disable Multiple IP Addresses or set a strict Preferred Media IP. In Genesys Cloud, configure the SIP connector with Preferred Media IP matching the CUCM primary IP. Verify routing symmetry using Wireshark on both the Genesys Cloud network edge and the Cisco gateway interface.
Edge Case 3: Opus Codec Negotiation Failure on Legacy VXML Gateways
- The failure condition: Negotiation falls back to G.711, but bypass still fails due to packet size mismatch or frame packing errors.
- The root cause: Legacy Cisco VXML gateways do not support Opus frame packing. Genesys Cloud sends Opus with
a=fmtp:101 maxaveragebitrate=26000;stereo=0;useinbandfnc=1. The gateway cannot parse the extendeda=fmtpparameters and rejects the SDP. - The solution: Disable Opus in the Genesys Cloud Media Policy for this specific trunk. Enforce G.729 and G.711 only. Update the Preferred Codec Order to remove
OpusandAMR. Validate the SDP offer using Genesys Cloud Trace to confirm Opus attributes are absent. If Opus is required for other trunks, create a separate media policy scoped to the legacy gateway.
