Resolving Genesys Cloud Web Messaging Guest Identities with Python SDK
A production-grade identity resolver that maps anonymous web messaging sessions to known customer profiles, validates payloads against messaging engine constraints, triggers atomic verification, logs audit trails, and syncs resolved events to external CDP platforms via webhooks. The code uses the Genesys Cloud Python SDK and the POST /api/v2/messaging/resolve endpoint. The tutorial covers Python 3.9+ with type hints, error handling, and latency tracking.
- OAuth2 client credentials flow enabled in Genesys Cloud
- Required scopes:
messaging:resolve,conversation:write,user:read - Genesys Cloud Python SDK version 12.0.0+
- Python 3.9+ runtime
- External dependencies:
httpx,pydantic,genesyscloud
Initialize the Genesys Cloud SDK with client credentials. The SDK handles token caching and automatic refresh. You must configure the environment with your client ID and secret.
import os
from genesyscloud import ApiClient, Configuration
from genesyscloud.messaging.api import messaging_api
def init_genesys_sdk() -> messaging_api.MessagingApi:
"""Initialize the Genesys Cloud SDK with OAuth2 client credentials."""
client_id = os.environ["GENESYS_CLIENT_ID"]
client_secret = os.environ["GENESYS_CLIENT_SECRET"]
environment = os.environ.get("GENESYS_ENVIRONMENT", "my.genesyscloud.com")
config = Configuration(
base_url=f"https://{environment}",
client_id=client_id,
client_secret=client_secret
api_client = ApiClient(configuration=config)
return messaging_api.MessagingApi(api_client)
Step 1: Construct and Validate Resolve Payloads
The messaging engine enforces a maximum identity count of five per resolve request. You must validate the identity matrix against this constraint before submission. The merge directive must be either merge or replace. Use Pydantic to enforce schema compliance.
import hashlib
from typing import Dict, List, Literal
from pydantic import BaseModel, field_validator, ValidationError
class IdentityEntry(BaseModel):
type: str
value: str
class ResolvePayload(BaseModel):
session_key: str
identities: List[IdentityEntry]
merge_directive: Literal["merge", "replace"]
@field_validator("identities")
@classmethod
def validate_identity_count(cls, v: List[IdentityEntry]) -> List[IdentityEntry]:
if len(v) > 5:
raise ValueError("Messaging engine constraint: maximum identity count is 5")
return v
@classmethod
def validate_identity_format(cls, v: List[IdentityEntry]) -> List[IdentityEntry]:
allowed_types = {"email", "phone", "external_id", "user_id"}
for ident in v:
if ident.type not in allowed_types:
raise ValueError(f"Invalid identity type: {ident.type}")
if not ident.value or len(ident.value.strip()) == 0:
raise ValueError("Identity value cannot be empty")
return v
Step 2: Execute Resolve with Atomic GET Verification
Submit the validated payload to POST /api/v2/messaging/resolve. After submission, perform an atomic GET operation against GET /api/v2/messaging/sessions/{sessionKey} to verify the resolution state and trigger automatic deduplication logic. Handle 429 rate limits with exponential backoff.
import logging
import httpx
from typing import Optional
class MessagingResolver:
def __init__(self, messaging_api: messaging_api.MessagingApi):
self.messaging_api = messaging_api
self.http_client = httpx.Client(timeout=30.0)
def resolve_identity(self, payload: ResolvePayload) -> dict:
"""Submit resolve request with retry logic for 429 responses."""
max_retries = 3
request_body = {
"sessionKey": payload.session_key,
"identities": [{"type": i.type, "value": i.value} for i in payload.identities],
"mergeDirective": payload.merge_directive
response = self.messaging_api.post_messaging_resolve(body=request_body)
logger.info("Resolve submitted successfully. Response: %s", response)
return self._verify_resolution(payload.session_key, response)
if "429" in str(e) or (hasattr(e, 'status') and e.status == 429):
wait_time = 2 ** attempt
logger.warning("Rate limited. Retrying in %s seconds...", wait_time)
time.sleep(wait_time)
else:
logger.error("Resolve failed: %s", e)
raise
raise RuntimeError("Max retries exceeded for resolve request")
def _verify_resolution(self, session_key: str, initial_response: dict) -> dict:
"""Atomic GET verification and deduplication trigger."""
time.sleep(0.5) # Allow messaging engine to process
verify_response = self.messaging_api.get_messaging_sessions_session_key(session_key)
if verify_response and verify_response.get("state") == "resolved":
logger.info("Atomic GET verification passed. Session resolved.")
return verify_response
else:
logger.warning("Verification mismatch. Triggering deduplication pipeline.")
return self._trigger_deduplication(session_key, verify_response)
logger.error("Verification GET failed: %s", e)
raise
Step 3: Implement Email Hash Checking and Cookie Persistence
Validate email identities using SHA-256 hashing to ensure format compliance before submission. Verify cookie persistence by checking for a valid session cookie structure. This prevents fragmented records during high-scale web messaging traffic.
import re
class IdentityValidator:
@staticmethod
def validate_email_hash(email: str) -> bool:
"""Verify email format and generate secure hash for audit logging."""
if not re.match(r"^[a-zA-Z0-9_.+-]+@[a-zA-Z0-9-]+\.[a-zA-Z0-9-.]+$", email):
return False
normalized = email.lower().strip()
email_hash = hashlib.sha256(normalized.encode("utf-8")).hexdigest()
logger.info("Email validated. Hash: %s", email_hash)
return True
@staticmethod
def verify_cookie_persistence(cookie_header: str) -> bool:
"""Check for valid Genesys Cloud session cookie persistence."""
if "genesys_cloud_session" not in cookie_header:
return False
cookie_parts = cookie_header.split(";")
for part in cookie_parts:
if "genesys_cloud_session=" in part:
token = part.split("=")[1].strip()
if len(token) >= 32 and re.match(r"^[a-zA-Z0-9_-]+$", token):
return True
return False
Step 4: Synchronize with CDP Webhooks and Track Latency
Sync resolved events to external Customer Data Platforms via webhooks. Track resolve latency and fusion success rates. Generate structured audit logs for identity governance.
import json
class ResolveSyncAndAudit:
def __init__(self, webhook_url: str):
self.http_client = httpx.Client(timeout=15.0)
self.latency_tracker: List[float] = []
self.success_count = 0
self.failure_count = 0
def sync_to_cdp(self, session_key: str, resolved_data: dict) -> None:
"""Push resolved identity to external CDP via webhook."""
payload = {
"event": "identity.resolved",
"session_key": session_key,
"resolved_profile": resolved_data
response = self.http_client.post(
self.webhook_url,
json=payload,
headers={"Content-Type": "application/json", "X-Source": "genesys-resolver"}
response.raise_for_status()
logger.info("CDP sync successful for session: %s", session_key)
except httpx.HTTPError as e:
logger.error("CDP sync failed: %s", e)
def log_audit(self, session_key: str, latency: float, success: bool, details: dict) -> None:
"""Generate structured audit log for identity governance."""
if success:
self.success_count += 1
else:
self.failure_count += 1
self.latency_tracker.append(latency)
audit_entry = {
"audit_id": hashlib.sha256(f"{session_key}-{datetime.now(timezone.utc).isoformat()}".encode()).hexdigest()[:16],
"latency_ms": round(latency * 1000, 2),
"status": "resolved" if success else "failed",
"details": details,
"fusion_success_rate": self._calculate_success_rate()
logger.info("AUDIT LOG: %s", json.dumps(audit_entry, indent=2))
def _calculate_success_rate(self) -> float:
return (self.success_count / total * 100) if total > 0 else 0.0
Combine all components into a single runnable resolver module. Replace environment variables with your credentials before execution.
import os
import logging
import httpx
class WebMessagingIdentityResolver:
def __init__(self):
self.messaging_api = self._init_sdk()
self.resolver = MessagingResolver(self.messaging_api)
self.validator = IdentityValidator()
self.sync_audit = ResolveSyncAndAudit(os.environ["CDP_WEBHOOK_URL"])
def _init_sdk(self) -> messaging_api.MessagingApi:
base_url=f"https://{os.environ['GENESYS_ENVIRONMENT']}",
client_id=os.environ["GENESYS_CLIENT_ID"],
client_secret=os.environ["GENESYS_CLIENT_SECRET"]
return messaging_api.MessagingApi(ApiClient(configuration=config))
def resolve_guest_session(self, session_key: str, identities: List[Dict[str, str]],
merge_directive: str, cookie_header: str) -> dict:
# Validate payload schema
payload = ResolvePayload(
session_key=session_key,
identities=[IdentityEntry(**i) for i in identities],
merge_directive=merge_directive
# Validate email hashes and cookie persistence
for ident in payload.identities:
if ident.type == "email":
if not self.validator.validate_email_hash(ident.value):
raise ValueError(f"Invalid email format: {ident.value}")
if not self.validator.verify_cookie_persistence(cookie_header):
raise ValueError("Invalid or missing session cookie. Persistence check failed.")
# Execute resolve with verification
resolved_data = self.resolver.resolve_identity(payload)
latency = time.perf_counter() - start_time
self.sync_audit.sync_to_cdp(session_key, resolved_data)
self.sync_audit.log_audit(session_key, latency, True, resolved_data)
return resolved_data
self.sync_audit.log_audit(session_key, latency, False, {"error": str(e)})
raise
resolver = WebMessagingIdentityResolver()
result = resolver.resolve_guest_session(
session_key="web-messaging-sess-9876",
identities=[
{"type": "email", "value": "customer@example.com"},
{"type": "phone", "value": "+15550000000"}
merge_directive="merge",
cookie_header="genesys_cloud_session=abc123def456; path=/; secure; samesite=strict"
print("Resolution complete:", result)
logger.error("Resolver execution failed: %s", e)
Error: 400 Bad Request - Schema Validation Failed
- Cause: The identity count exceeds five, the merge directive is invalid, or an identity value is empty.
- Fix: Verify the
ResolvePayloadvalidation logic. EnsuremergeDirectiveis strictlymergeorreplace. Check that all identity values contain non-empty strings. - Code Fix: The Pydantic validators in Step 1 will raise a
ValidationErrorwith explicit field details. CatchValidationErrorand log the exact field failure.
- Cause: The messaging engine rate limit threshold has been exceeded.
- Fix: The retry logic in
resolve_identityimplements exponential backoff. Increasemax_retriesor adjust sleep intervals if your traffic pattern requires longer cooldowns. - Code Fix: Ensure the
except Exceptionblock checks for429status codes and applies the backoff delay before retrying.
Error: 401/403 Unauthorized/Forbidden
- Cause: Missing or incorrect OAuth scopes, or expired client credentials.
- Fix: Verify the OAuth client has
messaging:resolveandconversation:writescopes assigned. Regenerate the client secret if rotated. - Code Fix: The SDK throws
ApiExceptionwith status 401/403. Log the exception message and verify environment variables before initialization.
Error: Atomic GET Verification Mismatch
- Cause: The messaging engine has not yet processed the resolve request, or a duplicate identity conflict occurred.
- Fix: The
_verify_resolutionmethod sleeps 0.5 seconds to allow engine processing. If the state remains unresolved, the deduplication pipeline triggers. Check for conflicting identities in the same session. - Code Fix: Extend the sleep duration or implement a polling loop with a maximum timeout if your deployment experiences high latency.
