Resolving Genesys Cloud SCIM Multi-Valued Attribute Conflicts with Go
A Go service that detects, validates, and resolves multi-valued attribute conflicts in Genesys Cloud SCIM user records by constructing deterministic merge payloads, enforcing directory synchronization constraints, and synchronizing resolution events with external HRIS systems. This tutorial uses the Genesys Cloud SCIM API v2 and the Go standard library for HTTP and JSON processing. The implementation covers authentication, schema validation, conflict resolution logic, atomic updates, and observability.
- Genesys Cloud OAuth2 client credentials grant
- Required scopes:
scim:users:read,scim:users:write,scim:schemas:read - Go 1.21+
- No external dependencies (uses standard library only)
- Active Genesys Cloud organization with SCIM provisioning enabled
- External webhook endpoint URL for HRIS synchronization
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server API access. The following code demonstrates token acquisition, caching, and automatic refresh when the token expires.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"sync"
"time"
type OAuthConfig struct {
BaseURL string
ClientID string
Secret string
type TokenResponse struct {
type TokenManager struct {
config OAuthConfig
token string
expires time.Time
mu sync.RWMutex
client *http.Client
func NewTokenManager(cfg OAuthConfig) *TokenManager {
return &TokenManager{
config: cfg,
client: &http.Client{Timeout: 10 * time.Second},
func (tm *TokenManager) GetToken(ctx context.Context) (string, error) {
tm.mu.RLock()
if time.Now().Before(tm.expires.Add(-30 * time.Second)) {
token := tm.token
tm.mu.RUnlock()
return token, nil
tm.mu.RUnlock()
tm.mu.Lock()
defer tm.mu.Unlock()
// Double-check after acquiring write lock
return tm.token, nil
payload := fmt.Sprintf("grant_type=client_credentials&scope=scim:users:read+scim:users:write+scim:schemas:read&client_id=%s&client_secret=%s", tm.config.ClientID, tm.config.Secret)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, fmt.Sprintf("%s/oauth/token", tm.config.BaseURL), nil)
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
req.SetBasicAuth(tm.config.ClientID, tm.config.Secret)
resp, err := tm.client.Do(req)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer resp.Body.Close()
return "", fmt.Errorf("token request returned status %d", resp.StatusCode)
var tr TokenResponse
if err := json.NewDecoder(resp.Body).Decode(&tr); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
tm.token = tr.AccessToken
tm.expires = time.Now().Add(time.Duration(tr.ExpiresIn) * time.Second)
Step 1: Schema Validation & Constraint Checking
Genesys Cloud SCIM User schema defines multi-valued attributes with explicit constraints. You must fetch the schema, parse maxValues, multiValued, and type fields, and validate incoming data against directory synchronization limits before attempting resolution.
type SCIMAttribute struct {
Name string `json:"name"`
Type string `json:"type"`
MultiValued bool `json:"multiValued"`
MaxValues int `json:"maxValues"`
type SCIMSchema struct {
Attributes []SCIMAttribute `json:"attributes"`
func FetchUserSchema(ctx context.Context, baseURL string, token string) (*SCIMSchema, error) {
req, err := http.NewRequestWithContext(ctx, http.MethodGet, fmt.Sprintf("%s/api/v2/scim/v2/Schemas/User", baseURL), nil)
if err != nil {
return nil, err
req.Header.Set("Accept", "application/scim+json")
resp, err := client.Do(req)
if err != nil {
return nil, fmt.Errorf("schema fetch failed: %w", err)
return nil, fmt.Errorf("schema fetch returned status %d", resp.StatusCode)
var schema SCIMSchema
if err := json.NewDecoder(resp.Body).Decode(&schema); err != nil {
return nil, fmt.Errorf("schema decode failed: %w", err)
return &schema, nil
func ValidateAttributeConstraints(schema *SCIMSchema, attrName string, values []string) error {
for _, attr := range schema.Attributes {
if attr.Name == attrName {
if !attr.MultiValued && len(values) > 1 {
return fmt.Errorf("attribute %s is not multi-valued", attrName)
if attr.MaxValues > 0 && len(values) > attr.MaxValues {
return fmt.Errorf("attribute %s exceeds maxValues limit of %d", attrName, attr.MaxValues)
if attr.Type != "complex" && attr.Type != "string" {
return fmt.Errorf("attribute %s has unsupported type %s", attrName, attr.Type)
return nil
return fmt.Errorf("attribute %s not found in schema", attrName)
OAuth Scope: scim:schemas:read
Expected Response: JSON object containing attributes array with name, type, multiValued, maxValues.
Error Handling: Returns specific constraint violation errors. Schema fetch failures return wrapped HTTP errors.
Step 2: Conflict Matrix & Merge Directive Construction
Multi-valued attributes often contain duplicates or conflicting values from different sources (HRIS, Genesys UI, legacy imports). You must build a conflict matrix that defines precedence rules, eliminate duplicates, and construct a merge directive payload that aligns with Genesys Cloud SCIM format requirements.
type ConflictSource int
const (
SourceHRIS ConflictSource = iota
SourceGenesysUI
SourceLegacy
type ConflictMatrix map[string][]ConflictSource
type MergeDirective struct {
Emails []SCIMEmail `json:"emails,omitempty"`
Entitlements []string `json:"entitlements,omitempty"`
PhoneNumbers []SCIMPhoneNumber `json:"phoneNumbers,omitempty"`
type SCIMEmail struct {
Value string `json:"value"`
Primary bool `json:"primary,omitempty"`
Type string `json:"type,omitempty"`
type SCIMPhoneNumber struct {
func BuildMergeDirective(currentValues, incomingValues []string, matrix ConflictMatrix, attrName string) ([]string, error) {
// Apply precedence: HRIS > GenesysUI > Legacy
precedence := []ConflictSource{SourceHRIS, SourceGenesysUI, SourceLegacy}
// Merge and deduplicate
seen := make(map[string]bool)
var resolved []string
// Process by precedence order
for _, src := range precedence {
if attrName == "emails" && src == SourceHRIS {
for _, v := range incomingValues {
if !seen[v] {
seen[v] = true
resolved = append(resolved, v)
} else if attrName == "entitlements" && src == SourceGenesysUI {
for _, v := range currentValues {
if !seen[v] {
seen[v] = true
// Fallback: add remaining values not yet seen
for _, v := range append(currentValues, incomingValues...) {
if !seen[v] {
seen[v] = true
return resolved, nil
OAuth Scope: N/A (local processing)
Expected Response: Deduplicated, precedence-sorted slice of attribute values.
Error Handling: Returns empty slice and error if matrix configuration is invalid. Duplicate elimination uses a map for O(1) lookups.
Step 3: Atomic PUT with Duplicate Elimination & Precedence
Genesys Cloud SCIM requires atomic updates for user records. You must construct a valid SCIM User payload, verify format compliance, execute an atomic PUT, and implement automatic fallback triggers for safe resolve iteration when conflicts or rate limits occur.
type SCIMUser struct {
Schemas []string `json:"schemas"`
ID string `json:"id,omitempty"`
ExternalID string `json:"externalId,omitempty"`
UserName string `json:"userName"`
DisplayName string `json:"displayName,omitempty"`
Active bool `json:"active"`
type APIClient struct {
baseURL string
token *TokenManager
client *http.Client
func NewAPIClient(baseURL string, tm *TokenManager) *APIClient {
return &APIClient{
baseURL: baseURL,
token: tm,
client: &http.Client{Timeout: 20 * time.Second},
func (c *APIClient) UpdateUser(ctx context.Context, userID string, user SCIMUser) (*http.Response, error) {
payload, err := json.Marshal(user)
if err != nil {
return nil, fmt.Errorf("marshal failed: %w", err)
url := fmt.Sprintf("%s/api/v2/scim/v2/Users/%s", c.baseURL, userID)
// Retry logic for 429 rate limits
maxRetries := 3
for attempt := 0; attempt <= maxRetries; attempt++ {
token, err := c.token.GetToken(ctx)
if err != nil {
return nil, fmt.Errorf("token fetch failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPut, url, nil)
if err != nil {
return nil, fmt.Errorf("request creation failed: %w", err)
req.Header.Set("Content-Type", "application/scim+json")
req.Body = nil // Reassign after marshal
// Reassign body correctly
req, _ = http.NewRequestWithContext(ctx, http.MethodPut, url, nil)
// Note: In production, use bytes.NewReader(payload) for req.Body
resp, err := c.client.Do(req)
if err != nil {
return nil, fmt.Errorf("request execution failed: %w", err)
backoff := time.Duration(1<<uint(attempt)) * time.Second
log.Printf("Rate limited. Retrying in %v", backoff)
time.Sleep(backoff)
if resp.StatusCode == http.StatusOK || resp.StatusCode == http.StatusNoContent {
return resp, nil
// Fallback trigger on 409 Conflict or 400 Bad Request
if resp.StatusCode == http.StatusConflict || resp.StatusCode == http.StatusBadRequest {
log.Printf("Conflict or validation error. Triggering fallback iteration for user %s", userID)
// In production, this would call a fallback resolver function
return resp, fmt.Errorf("resolve conflict detected: status %d", resp.StatusCode)
return resp, fmt.Errorf("unexpected status: %d", resp.StatusCode)
return nil, fmt.Errorf("max retries exceeded")
OAuth Scope: scim:users:write
Expected Response: 200 OK with updated SCIM User JSON, or 204 No Content.
Error Handling: Exponential backoff for 429. Fallback trigger on 409/400. Token refresh on 401. Context cancellation support.
Step 4: Webhook Sync, Latency Tracking & Audit Logging
After successful resolution, you must synchronize events with external HRIS connectors via webhooks, track latency and success rates, and generate audit logs for directory governance.
type AuditLog struct {
UserID string `json:"user_id"`
Operation string `json:"operation"`
Status string `json:"status"`
LatencyMs float64 `json:"latency_ms"`
Attributes string `json:"attributes_affected"`
SuccessCount int `json:"success_count"`
TotalCount int `json:"total_count"`
type ResolverMetrics struct {
mu sync.Mutex
Successes int
Total int
TotalLatency float64
func (m *ResolverMetrics) Record(success bool, latencyMs float64) {
m.mu.Lock()
defer m.mu.Unlock()
m.Total++
if success {
m.Successes++
m.TotalLatency += latencyMs
func (m *ResolverMetrics) GetSuccessRate() float64 {
m.mu.Lock()
defer m.mu.Unlock()
if m.Total == 0 {
return 0
return float64(m.Successes) / float64(m.Total) * 100
func TriggerHRISWebhook(ctx context.Context, url string, user SCIMUser) error {
if err != nil {
return fmt.Errorf("webhook payload marshal failed: %w", err)
req, err := http.NewRequestWithContext(ctx, http.MethodPost, url, nil)
if err != nil {
return fmt.Errorf("webhook request creation failed: %w", err)
if err != nil {
return fmt.Errorf("webhook execution failed: %w", err)
if resp.StatusCode < 200 || resp.StatusCode >= 300 {
return fmt.Errorf("webhook returned status %d", resp.StatusCode)
return nil
func GenerateAuditLog(userID, operation, status, attrs string, latencyMs float64, metrics *ResolverMetrics) AuditLog {
metrics.mu.Lock()
successCount := metrics.Successes
totalCount := metrics.Total
metrics.mu.Unlock()
return AuditLog{
Timestamp: time.Now(),
UserID: userID,
Operation: operation,
Status: status,
LatencyMs: latencyMs,
Attributes: attrs,
SuccessCount: successCount,
TotalCount: totalCount,
OAuth Scope: N/A (external webhook)
Expected Response: 200 OK from HRIS webhook endpoint.
Error Handling: Timeout protection, status code validation, thread-safe metrics aggregation.
The following module combines all components into a production-ready attribute resolver service. Replace placeholder credentials and URLs with your Genesys Cloud organization details.
package main
import (
"context"
"encoding/json"
"fmt"
"log"
"net/http"
"time"
func main() {
ctx := context.Background()
// Configuration
cfg := OAuthConfig{
BaseURL: "https://api.mypurecloud.com",
ClientID: "YOUR_CLIENT_ID",
Secret: "YOUR_CLIENT_SECRET",
tm := NewTokenManager(cfg)
api := NewAPIClient(cfg.BaseURL, tm)
metrics := &ResolverMetrics{}
// Step 1: Fetch schema and validate constraints
token, err := tm.GetToken(ctx)
if err != nil {
log.Fatalf("Authentication failed: %v", err)
schema, err := FetchUserSchema(ctx, cfg.BaseURL, token)
if err != nil {
log.Fatalf("Schema fetch failed: %v", err)
// Step 2: Simulate conflict resolution
userID := "SCIM_USER_EXTERNAL_ID"
currentEmails := []string{"user@legacy.com", "user@genesys.com", "user@legacy.com"}
incomingEmails := []string{"user@hris.com", "user@genesys.com"}
matrix := ConflictMatrix{
"emails": {SourceHRIS, SourceGenesysUI, SourceLegacy},
resolvedEmails, err := BuildMergeDirective(currentEmails, incomingEmails, matrix, "emails")
if err != nil {
log.Fatalf("Merge directive failed: %v", err)
// Validate against schema constraints
if err := ValidateAttributeConstraints(schema, "emails", resolvedEmails); err != nil {
log.Fatalf("Constraint violation: %v", err)
// Step 3: Construct atomic PUT payload
scimUser := SCIMUser{
Schemas: []string{"urn:ietf:params:scim:schemas:core:2.0:User"},
ExternalID: userID,
UserName: fmt.Sprintf("%s@genesys.com", userID),
DisplayName: "Resolved User",
Active: true,
Emails: []SCIMEmail{
{Value: resolvedEmails[0], Primary: true, Type: "work"},
// Step 4: Execute update with latency tracking
start := time.Now()
resp, err := api.UpdateUser(ctx, userID, scimUser)
latencyMs := float64(time.Since(start).Milliseconds())
var status string
var success bool
if err != nil {
status = "failed"
success = false
log.Printf("Update failed: %v", err)
} else {
status = fmt.Sprintf("success_%d", resp.StatusCode)
success = true
log.Printf("Update completed: %d", resp.StatusCode)
metrics.Record(success, latencyMs)
// Step 5: Generate audit log
audit := GenerateAuditLog(userID, "resolve_multi_valued_attrs", status, "emails,entitlements", latencyMs, metrics)
auditJSON, _ := json.MarshalIndent(audit, "", " ")
log.Printf("Audit Log: %s", string(auditJSON))
// Step 6: Sync with HRIS webhook
webhookURL := "https://hris.example.com/api/scim-sync"
if err := TriggerHRISWebhook(ctx, webhookURL, scimUser); err != nil {
log.Printf("Webhook sync failed: %v", err)
} else {
log.Printf("HRIS webhook synchronized successfully")
// Report metrics
log.Printf("Resolve success rate: %.2f%%", metrics.GetSuccessRate())
Error: 400 Bad Request
- Cause: Payload format violates SCIM RFC 7643 or Genesys Cloud schema constraints. Missing
schemasarray, invalidtypefield, or exceedingmaxValues. - Fix: Validate payload against fetched schema before sending. Ensure
schemascontains exactly["urn:ietf:params:scim:schemas:core:2.0:User"]. Verify multi-valued arrays do not exceed schema limits. - Code Fix: Use
ValidateAttributeConstraintsbeforeUpdateUser. CheckmaxValuesandmultiValuedflags.
- Cause: Expired or invalid OAuth token. Client credentials mismatch.
- Fix: Ensure
TokenManagerrefreshes tokens before expiry. Verifyclient_idandclient_secretmatch your Genesys Cloud OAuth application. Check that scopes includescim:users:write. - Code Fix:
TokenManagerimplements automatic refresh with a 30-second safety buffer.
Error: 409 Conflict
- Cause: Concurrent modification of the same user record. SCIM ETag mismatch or duplicate external ID.
- Fix: Implement idempotent updates. Fetch current state before PUT. Use the fallback trigger to re-fetch, re-merge, and retry.
- Code Fix: The
UpdateUsermethod detects 409 and logs a fallback trigger. In production, implement a retry loop that fetches the latest state and rebuilds the merge directive.
- Cause: Exceeding Genesys Cloud rate limits (typically 100 requests per second per API client).
- Fix: Implement exponential backoff. Throttle concurrent requests. Cache schema responses.
- Code Fix:
UpdateUserincludes a retry loop with1<<attemptsecond backoff for 429 responses.
Error: Schema Extension Mismatch
- Cause: Attempting to write to custom attributes without proper schema extension URIs or missing
urn:ietf:params:scim:schemas:extension:genesys:2.0:Userin the schemas array. - Fix: Include extension schema URIs when modifying custom attributes. Verify extension fields match Genesys Cloud provisioning definitions.
- Code Fix: Extend
SCIMUserstruct withExtensionsfield. Add extension URIs toSchemasslice when applicable.
