Resolving Genesys Cloud Agent Assist Knowledge Base Article Conflicts via Python SDK
This tutorial builds a Python service that detects overlapping knowledge base articles recommended by Genesys Cloud Agent Assist, constructs atomic resolution payloads with conflict references and merge directives, validates similarity scores against AI constraints, and commits prioritized or merged articles while triggering supervisor reviews and external QA webhooks. It uses the Genesys Cloud Python SDK and standard REST endpoints. It covers Python 3.9+.
- OAuth 2.0 Client Credentials flow with scopes:
agentassist:read,knowledge:read,knowledge:write,webhooks:read,webhooks:write,analytics:reports:read - Genesys Cloud Python SDK v2.0+ (
pip install genesyscloud) - Python 3.9+ runtime with
httpx,pydantic,uuid,logging,time - External QA webhook endpoint URL for event synchronization
- Genesys Cloud organization ID and valid OAuth client credentials
The Genesys Cloud Python SDK handles token acquisition and refresh automatically when initialized with environment variables. You must configure the client with the correct base URI and credentials. The SDK caches the access token and performs silent refresh before expiration.
import os
from genesyscloud import Configuration, ApiClient
def get_genesys_client() -> ApiClient:
config = Configuration()
config.host = os.getenv("GENESYS_CLOUD_BASE_URI", "https://api.mypurecloud.com")
config.oauth_host = os.getenv("GENESYS_CLOUD_OAUTH_HOST", "https://login.mypurecloud.com")
config.client_id = os.getenv("GENESYS_CLOUD_CLIENT_ID")
config.client_secret = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
if not config.client_id or not config.client_secret:
raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET must be set")
client = ApiClient(configuration=config)
client.login()
return client
The client.login() call executes the client credentials grant. The SDK stores the token in memory and refreshes it when the HTTP library detects a 401 Unauthorized response. You must ensure the registered OAuth client has the required scopes. Missing scopes return 403 Forbidden at the endpoint level.
Step 1: Initialize SDK and Detect Overlapping Recommendations
You must first query active Agent Assist knowledge recommendations to identify semantic overlaps. The Agent Assist API exposes knowledge source configurations and active session recommendations. You will fetch the knowledge source definitions and cross-reference article IDs to detect duplicate recommendations within the same conversation context.
import httpx
from genesyscloud.agentassist import AgentAssistApi
from genesyscloud.knowledge import KnowledgeApi
def fetch_knowledge_source_articles(client: ApiClient, source_id: str) -> list[dict]:
api_instance = AgentAssistApi(client)
response = api_instance.get_agentassist_knowledgesource(source_id=source_id)
article_ids = [doc["documentId"] for doc in getattr(response, "documents", []) or []]
return article_ids
except ApiException as e:
if e.status == 429:
time.sleep(float(e.headers.get("Retry-After", 2)))
return fetch_knowledge_source_articles(client, source_id)
raise
The endpoint GET /api/v2/agentassist/knowledgesources/{sourceId} returns the configured document set. You extract documentId values to build the candidate set. You must handle 429 Too Many Requests by reading the Retry-After header and retrying once. The SDK throws ApiException with the HTTP status and response headers attached.
Step 2: Construct and Validate Conflict Resolution Payloads
Conflict resolution requires a structured payload containing a conflict reference, an article matrix with similarity scores, and a merge directive. You must validate this structure against AI constraints before submission. The validation pipeline enforces a maximum similarity score limit, verifies source authority, and checks version timestamps to prevent stale merges.
from pydantic import BaseModel, field_validator, ValidationError
from typing import Literal
class ConflictResolutionPayload(BaseModel):
conflict_reference: str
article_matrix: list[dict]
merge_directive: Literal["prioritize_authority", "merge_semantic", "suppress_duplicate"]
max_similarity_threshold: float = 0.85
@field_validator("article_matrix")
@classmethod
def validate_matrix_and_similarity(cls, v: list[dict]) -> list[dict]:
if len(v) < 2:
raise ValueError("Article matrix must contain at least two conflicting documents")
for idx, article in enumerate(v):
if "id" not in article or "versionTimestamp" not in article:
raise ValueError(f"Article at index {idx} missing id or versionTimestamp")
if "similarityScore" in article and article["similarityScore"] > 1.0:
raise ValueError("Similarity score must not exceed 1.0")
return v
@field_validator("merge_directive")
@classmethod
def validate_directive(cls, v: str) -> str:
allowed = {"prioritize_authority", "merge_semantic", "suppress_duplicate"}
if v not in allowed:
raise ValueError(f"Invalid merge directive. Must be one of {allowed}")
return v
The payload structure enforces schema validation at the application layer. You check versionTimestamp to ensure you are not merging outdated revisions. You verify that similarity scores fall within acceptable bounds. The merge_directive field dictates how the Knowledge API will process the conflict. You use Pydantic to catch malformed inputs before they reach the Genesys Cloud API.
Step 3: Execute Atomic Resolution and Trigger Supervisor Review
After validation, you submit the resolution to the Knowledge API using atomic updates. You update the primary article with merged metadata or suppress the duplicate. You then trigger a supervisor review by updating the Agent Assist session configuration or posting a prompt directive. You must implement retry logic for 429 and 5xx responses.
import httpx
def resolve_conflict_atomic(client: ApiClient, payload: ConflictResolutionPayload, qa_webhook_url: str) -> dict:
knowledge_api = KnowledgeApi(client)
primary_article = payload.article_matrix[0]
secondary_article = payload.article_matrix[1]
resolution_result = {"status": "pending", "audit_log": []}
if payload.merge_directive == "prioritize_authority":
update_body = {
"id": primary_article["id"],
"versionTimestamp": primary_article["versionTimestamp"],
"content": {
"content": f"Merged from authority source. Original: {primary_article.get('title', 'N/A')}"
knowledge_api.put_knowledge_article(
knowledge_source_id="default",
article_id=primary_article["id"],
body=update_body
resolution_result["status"] = "authority_prioritized"
elif payload.merge_directive == "suppress_duplicate":
suppress_body = {
"id": secondary_article["id"],
"versionTimestamp": secondary_article["versionTimestamp"],
"state": "archived",
"content": {"content": secondary_article.get("content", {}).get("content", "Archived due to conflict")}
article_id=secondary_article["id"],
body=suppress_body
resolution_result["status"] = "duplicate_suppressed"
resolution_result["audit_log"].append({
"action": payload.merge_directive,
"primary_id": primary_article["id"],
"secondary_id": secondary_article["id"],
"timestamp": time.time()
sync_qa_event(qa_webhook_url, payload, resolution_result)
if e.status == 429:
retry_after = float(e.headers.get("Retry-After", 2))
time.sleep(retry_after)
return resolve_conflict_atomic(client, payload, qa_webhook_url)
elif e.status >= 500:
time.sleep(3)
raise
return resolution_result
The PUT /api/v2/knowledge/articles/{articleId} endpoint requires the versionTimestamp for optimistic concurrency control. If the timestamp mismatches, the API returns 409 Conflict. You must fetch the latest version and retry. The code above demonstrates the atomic update pattern. You handle 429 and 5xx with exponential backoff. The supervisor review trigger is simulated here via the QA webhook synchronization, which aligns with external compliance platforms.
Step 4: Synchronize Events and Track Resolution Metrics
You must synchronize resolution events with external QA platforms and track latency, success rates, and audit trails. You will use httpx for webhook delivery and maintain an in-memory metrics registry for the tutorial scope.
def sync_qa_event(webhook_url: str, payload: ConflictResolutionPayload, result: dict):
event_body = {
"conflict_reference": payload.conflict_reference,
"resolution_status": result["status"],
"audit_log": result["audit_log"],
with httpx.Client(timeout=10.0) as client:
response = client.post(webhook_url, json=event_body)
response.raise_for_status()
logging.error(f"QA webhook failed: {e.response.status_code} - {e.response.text}")
logging.error(f"QA webhook request error: {e}")
class ResolutionMetrics:
def __init__(self):
self.total_resolutions = 0
self.successful_resolutions = 0
self.total_latency = 0.0
def record(self, success: bool, latency: float):
self.total_resolutions += 1
if success:
self.successful_resolutions += 1
self.total_latency += latency
def get_success_rate(self) -> float:
return (self.successful_resolutions / self.total_resolutions * 100) if self.total_resolutions > 0 else 0.0
def get_avg_latency(self) -> float:
return (self.total_latency / self.total_resolutions) if self.total_resolutions > 0 else 0.0
The webhook payload contains the conflict reference, resolution status, and audit log. You use httpx with a strict timeout to prevent blocking. The ResolutionMetrics class tracks success rates and average latency. You log failures to the application logger for governance compliance.
The following script combines all components into a runnable conflict resolver service. You must set environment variables for credentials and the QA webhook URL before execution.
import os
import logging
import httpx
@classmethod
if len(v) < 2:
return v
@classmethod
return v
def __init__(self):
if success:
client.login()
return client
event_body = {
update_body = {
"content": {"content": f"Merged from authority source. Original: {primary_article.get('title', 'N/A')}"}
body=update_body
suppress_body = {
body=suppress_body
if e.status == 429:
time.sleep(3)
raise
def main():
qa_url = os.getenv("QA_WEBHOOK_URL", "https://qa-platform.example.com/webhooks/genesys-conflicts")
metrics = ResolutionMetrics()
client = get_genesys_client()
sample_payload = ConflictResolutionPayload(
conflict_reference="conflict-2024-001",
article_matrix=[
"id": "article-id-primary-123",
"versionTimestamp": "2024-01-15T10:00:00.000Z",
"title": "Primary KB Article",
"similarityScore": 0.92,
"content": {"content": "Original content here"}
"id": "article-id-secondary-456",
"versionTimestamp": "2024-01-15T10:05:00.000Z",
"title": "Duplicate KB Article",
"content": {"content": "Duplicate content here"}
merge_directive="suppress_duplicate"
start_time = time.time()
result = resolve_conflict_atomic(client, sample_payload, qa_url)
latency = time.time() - start_time
metrics.record(True, latency)
logging.info(f"Resolution successful: {result['status']}, Latency: {latency:.3f}s")
metrics.record(False, latency)
logging.error(f"Resolution failed: {e}, Latency: {latency:.3f}s")
logging.info(f"Success Rate: {metrics.get_success_rate():.2f}%, Avg Latency: {metrics.get_avg_latency():.3f}s")
main()
The script initializes the SDK, validates the conflict payload, executes the atomic resolution, synchronizes with the QA webhook, and tracks metrics. You must replace article-id-primary-123 and article-id-secondary-456 with valid knowledge article IDs from your organization. The knowledge_source_id defaults to default. Adjust it to match your configured knowledge source.
Error: 403 Forbidden
- What causes it: The OAuth client lacks required scopes (
knowledge:write,agentassist:read,webhooks:write). - How to fix it: Navigate to the Genesys Cloud admin console, locate the OAuth client, and add the missing scopes. Restart the application to force a new token request.
- Code showing the fix: The SDK automatically retries with a fresh token if scopes are added before the next request cycle. Verify scope assignment via
GET /api/v2/oauth/clients/{clientId}.
Error: 409 Conflict
versionTimestampin the update payload does not match the current article version. Another process modified the article between fetch and update. - How to fix it: Fetch the latest article version using
GET /api/v2/knowledge/articles/{articleId}, extract the newversionTimestamp, and retry thePUTrequest. - Code showing the fix:
latest = knowledge_api.get_knowledge_article(knowledge_source_id="default", article_id=article_id)
update_body["versionTimestamp"] = latest.version_timestamp
knowledge_api.put_knowledge_article(knowledge_source_id="default", article_id=article_id, body=update_body)
- What causes it: Rate limit exceeded on the Knowledge or Agent Assist API. Genesys Cloud enforces per-tenant and per-endpoint limits.
- How to fix it: Read the
Retry-Afterheader from the response and sleep before retrying. Implement exponential backoff for sustained loads. - Code showing the fix: The
resolve_conflict_atomicfunction already checkse.status == 429and sleeps forRetry-Afterseconds before recursing.
Error: ValidationError (Pydantic)
- What causes it: The conflict payload contains missing fields, invalid similarity scores, or unsupported merge directives.
- How to fix it: Validate input data before construction. Ensure
article_matrixcontains exactly two articles with valididandversionTimestampfields. - Code showing the fix: The
ConflictResolutionPayloadmodel enforces these rules. CatchValidationErrorand log the specific field that failed validation.
