Resolving 403 Forbidden on /api/v2/routing/queues: Scope and Permission Analysis
  • A diagnostic script that verifies OAuth token validity and scope presence before calling the Genesys Cloud Queues API.
  • A working Python implementation using the genesyscloud SDK to fetch queues, handling specific 403 errors caused by missing scopes versus missing user permissions.
  • A detailed breakdown of the routing:queue scope hierarchy and how it interacts with User Group permissions.
  • OAuth Client Type: Machine-to-Machine (JWT) or Username/Password (Client Credentials) flow.
  • Required Scopes: routing:queue, routing:queue:read, or routing:queue:view.
  • SDK Version: genesyscloud-python-sdk version 130.0.0 or higher.
  • Language/Runtime: Python 3.8+.
  • Dependencies:
    pip install genesyscloud
The most common cause of a 403 Forbidden error on /api/v2/routing/queues is not a missing scope on the API call itself, but an OAuth token that was issued without the necessary scope claims. Genesys Cloud uses scope-based access control for API endpoints. If your OAuth client does not have the routing:queue scope (or its subsets) assigned, the token will not contain the required claim, and the API gateway will reject the request before it reaches the routing service.
Step 1: Configure OAuth Client Scopes
Before writing code, you must ensure your OAuth client in the Genesys Cloud Admin Console has the correct scopes.
  1. Navigate to Admin > Security > OAuth Clients.
  2. Select your client.
  3. In the Scopes tab, search for routing:queue.
  4. Add the following scopes if they are not present:
    • routing:queue (Full access: read, write, delete)
    • routing:queue:read (Read-only access)
    • routing:queue:view (Legacy/limited view access)
Critical Note: If you are using a Machine-to-Machine (JWT) client, the scopes must be explicitly listed in the client configuration. If you are using Username/Password flow, the user account associated with the client must belong to a group that has permissions for queues, and the client must have the scope.
Step 2: Generate and Validate the Token
Use the following Python code to generate a token and inspect its scopes. This step isolates authentication failures from authorization failures.
import os
import json
from genesyscloud.platform_client_v2 import PlatformClient
from genesyscloud.auth_client import AuthClient
def get_oauth_token():
    Authenticates using environment variables and returns the platform client.
    Raises an exception if scopes are missing.
    client_id = os.environ.get('GENESYS_CLOUD_CLIENT_ID')
    client_secret = os.environ.get('GENESYS_CLOUD_CLIENT_SECRET')
    base_url = os.environ.get('GENESYS_CLOUD_BASE_URL', 'https://api.mypurecloud.com')
        raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET must be set.")
    # Initialize PlatformClient with credentials
    platform_client = PlatformClient(base_url)
    auth_client = platform_client.auth_client
    # Authenticate
        auth_client.authenticate_client_credentials(client_id, client_secret)
        raise RuntimeError(f"Authentication failed: {e}")
    # Inspect the token to verify scopes
    token = auth_client.get_access_token()
    # Note: The SDK handles token parsing, but for debugging, we can check the raw token if needed.
    # The SDK's AuthClient stores the token data.
    # Check if the token has the required scope
    # The SDK does not expose a direct 'has_scope' method easily, so we rely on the API response.
    # However, we can log the token expiration for debugging.
    print(f"Token expires at: {auth_client.get_token_expiration()}")
    return platform_client
# Execute authentication
pc = get_oauth_token()
Step 1: Fetch Queues with Explicit Scope Checking
The /api/v2/routing/queues endpoint requires the routing:queue:read scope at a minimum. If your token lacks this, you receive a 403. If your token has the scope, but the associated user (in Username/Password flow) or the service user (in JWT flow, if mapped to a user context) does not have the User Group Permission to view queues, you also receive a 403.
We will use the RoutingApi class from the SDK.
from genesyscloud.routing_api import RoutingApi
def fetch_queues(platform_client: PlatformClient) -> list:
    Fetches all queues using the Genesys Cloud SDK.
    Handles 403 errors by distinguishing between scope issues and permission issues.
    routing_api = RoutingApi(platform_client)
        # The SDK handles pagination automatically if we iterate,
        # but for a simple fetch, we call get_routing_queues.
        # We set a reasonable page size to avoid performance hits.
        response = routing_api.get_routing_queues(
            page_size=100,
            page_token=None
        if response and response.entities:
            print(f"Successfully fetched {len(response.entities)} queues.")
            return response.entities
        else:
            print("No queues found or empty response.")
            return []
    except ApiException as e:
        if e.status == 403:
            error_body = e.body
                error_json = json.loads(error_body)
                error_code = error_json.get('errorCode', 'Unknown')
                error_description = error_json.get('message', 'No message')
                # Diagnostic logic for 403
                if 'scope' in error_description.lower() or 'insufficient_scope' in error_code:
                    print(f"ERROR: Insufficient Scope. The OAuth token does not have 'routing:queue:read'.")
                    print(f"Fix: Add 'routing:queue:read' to your OAuth Client scopes in Admin Console.")
                else:
                    print(f"ERROR: Permission Denied. The user/service account lacks Queue permissions.")
                    print(f"Fix: Ensure the user belongs to a group with 'View Queues' permission.")
                print(f"Full Error: {error_description}")
            except json.JSONDecodeError:
                print(f"ERROR: 403 Forbidden. Could not parse error body. Raw: {error_body}")
        elif e.status == 401:
            print("ERROR: Unauthorized. Token is invalid or expired.")
        else:
            print(f"API Error {e.status}: {e.body}")
        return []
        print(f"Unexpected error: {e}")
        return []
# Execute fetch
queues = fetch_queues(pc)
Step 2: Understanding the Scope Hierarchy
Genesys Cloud scopes are hierarchical. Understanding this prevents over-provisioning and helps debug 403s.
  1. routing:queue: This is the parent scope. It grants full CRUD access. If this is present, routing:queue:read is implicitly granted.
  2. routing:queue:read: Grants read-only access to queue details, metrics, and membership. This is the minimum scope required for GET /api/v2/routing/queues.
  3. routing:queue:view: A legacy scope that may provide limited view access. It is recommended to use routing:queue:read for new integrations.
Common Mistake: Adding routing:queue:view but not routing:queue:read. While view might work for some endpoints, get_routing_queues specifically checks for read permissions in many contexts. Always prefer routing:queue:read for read operations.
Step 3: Handling User Group Permissions (Username/Password Flow)
If you are using the Username/Password OAuth flow, the OAuth scope is only the first layer of security. The second layer is the User Group Permission.
Even if your OAuth client has routing:queue:read, if the user account user@example.com is not in a group that has the “View Queues” permission enabled, the API returns 403.
How to Verify User Permissions:
  1. Go to Admin > Users > Groups.
  2. Find the group the user belongs to.
  3. Check the Permissions tab.
  4. Ensure Queues > View Queues is checked.
For Machine-to-Machine (JWT) flows, there is no “user” to check permissions for. The scope is the only gatekeeper. If you get a 403 with a JWT token and the correct scope, the issue is likely that the token was generated before the scope was added to the client, and the token cache has not refreshed.
Step 4: Refreshing the Token Cache
SDKs cache tokens to avoid repeated authentication calls. If you add a scope to an OAuth client, existing cached tokens will still be invalid. You must force a refresh.
def force_token_refresh(platform_client: PlatformClient):
    Forces the SDK to re-authenticate and fetch a new token with updated scopes.
    # Invalidate the current token
    auth_client.invalidate_access_token()
    # Re-authenticate
        print("Token refreshed successfully.")
        print(f"Failed to refresh token: {e}")
# Use this if you recently updated scopes in Admin Console
# force_token_refresh(pc)
# queues = fetch_queues(pc)
This script combines authentication, scope validation, queue fetching, and error diagnosis. It is designed to be run as a standalone diagnostic tool.
#!/usr/bin/env python3
Genesys Cloud Queue Access Diagnostic Script
This script tests access to /api/v2/routing/queues and diagnoses 403 errors
by distinguishing between missing OAuth scopes and missing user permissions.
Requirements:
Environment Variables:
    GENESYS_CLOUD_BASE_URL (Optional, defaults to https://api.mypurecloud.com)
import os
import json
import sys
def setup_platform_client() -> PlatformClient:
    """Initializes and authenticates the Genesys Cloud Platform Client."""
        print("ERROR: Missing required environment variables GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET")
        sys.exit(1)
        # Authenticate using Client Credentials Flow
        print(f"Authenticator: {auth_client.get_authentication_mode()}")
        print(f"Token Expires: {auth_client.get_token_expiration()}")
        print(f"Authentication failed: {e}")
        sys.exit(1)
def diagnose_queue_access(platform_client: PlatformClient):
    Attempts to fetch queues and provides detailed error messages for 403s.
    print("\n--- Attempting to fetch queues ---")
        # Get the first page of queues
        response = routing_api.get_routing_queues(page_size=1)
            print(f"SUCCESS: Accessed {len(response.entities)} queue(s).")
            print(f"First Queue ID: {response.entities[0].id}")
            print(f"First Queue Name: {response.entities[0].name}")
            return True
        else:
            print("SUCCESS: Endpoint accessible, but no queues returned.")
            return True
        if e.status == 403:
            print(f"\nDIAGNOSTIC: 403 Forbidden Received")
            print("="*40)
                error_data = json.loads(e.body)
                error_code = error_data.get('errorCode', '')
                error_message = error_data.get('message', '')
                # Check for scope-related errors
                if 'insufficient_scope' in error_code.lower() or 'scope' in error_message.lower():
                    print("CAUSE: Missing OAuth Scope")
                    print("SOLUTION:")
                    print("1. Go to Admin > Security > OAuth Clients")
                    print("2. Select your client")
                    print("3. Add scope: 'routing:queue:read'")
                    print("4. Restart your application to get a new token")
                # Check for permission-related errors (common in Username/Password flow)
                elif 'permission' in error_message.lower() or 'access denied' in error_message.lower():
                    print("CAUSE: Missing User Group Permission")
                    print("SOLUTION:")
                    print("1. Ensure the user associated with the OAuth client is in a group")
                    print("2. Go to Admin > Users > Groups")
                    print("3. Edit the group and enable 'View Queues' permission")
                else:
                    print(f"CAUSE: Unknown 403 Error")
                    print(f"Error Code: {error_code}")
                    print(f"Message: {error_message}")
                print(f"CAUSE: Could not parse error response")
                print(f"Raw Body: {e.body}")
            print(f"\nDIAGNOSTIC: 401 Unauthorized")
            print("CAUSE: Invalid or Expired Token")
            print("SOLUTION: Check client credentials or force a token refresh.")
        else:
            print(f"\nDIAGNOSTIC: API Error {e.status}")
            print(f"Message: {e.body}")
        return False
        print(f"\nUNEXPECTED ERROR: {e}")
        return False
def main():
    print("Genesys Cloud Queue Access Diagnostic")
    print("="*40)
    # 1. Setup Authentication
    pc = setup_platform_client()
    # 2. Diagnose Access
    success = diagnose_queue_access(pc)
    if success:
        print("\nResult: Queue access is functional.")
    else:
        print("\nResult: Queue access failed. Please review the diagnostic output above.")
    main()
Error: 403 Forbidden with insufficient_scope
What causes it:
The OAuth token presented in the Authorization: Bearer <token> header does not contain the routing:queue:read claim. This happens when the OAuth Client configuration in Genesys Cloud lacks the scope, or the token was generated before the scope was added.
How to fix it:
  1. Log in to Genesys Cloud Admin.
  2. Navigate to Security > OAuth Clients.
  3. Select your client.
  4. In the Scopes tab, add routing:queue:read.
  5. Crucial: Invalidate your existing token cache or restart your application to force a new token request.
Error: 403 Forbidden with access_denied or permission
What causes it:
The OAuth token has the correct scope, but the identity associated with the token lacks the necessary User Group Permission. This is common in Username/Password flows where the user is not in a group with “View Queues” enabled. For JWT flows, this is rare unless the JWT is mapped to a specific user context.
How to fix it:
  1. Identify the user account used for authentication.
  2. Go to Admin > Users > Groups.
  3. Find the group the user belongs to.
  4. In the Permissions tab, locate Queues.
  5. Enable View Queues.
  6. Wait for permission propagation (usually immediate, but can take up to 5 minutes).
What causes it:
The token is invalid, expired, or the client credentials are wrong.
How to fix it:
  1. Verify GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET.
  2. Check if the token has expired. The SDK usually handles refresh, but if you are caching tokens manually, ensure you are using a fresh token.
  3. Ensure the OAuth Client is Enabled in the Admin Console.
