Resolving 403 Forbidden on /api/v2/routing/queues: Required OAuth Scopes and Implementation
- A Python script that successfully retrieves a list of queues from Genesys Cloud CX using the PureCloudPlatformClientV2 SDK.
- The code demonstrates the correct OAuth scope configuration (
routing:queue:view) to eliminate403 Forbiddenerrors. - The tutorial covers authentication, error handling, and pagination logic in Python.
- OAuth Client Type: Public or Confidential client registered in Genesys Cloud.
- Required Scopes:
routing:queue:viewis the minimum scope. For writing queues, you would needrouting:queue:write. - SDK Version:
genesyscloudPython SDK version 114.0.0 or higher. - Language/Runtime: Python 3.8+.
- External Dependencies:
genesyscloud(installed via pip).
The 403 Forbidden error on /api/v2/routing/queues almost always stems from one of two causes:
- The OAuth token used in the
Authorizationheader lacks therouting:queue:viewscope. - The user associated with the OAuth token does not have the “View Queues” permission in their Genesys Cloud security profile.
This tutorial assumes the user has the correct permissions and focuses on the OAuth scope configuration and SDK implementation.
Installing the SDK
Install the official Genesys Cloud Python SDK:
pip install genesyscloud
Configuring the Client
The SDK handles the OAuth 2.0 Client Credentials flow automatically if you provide the client ID and client secret. You must explicitly specify the scopes during the client creation or when fetching the token. If the scope is missing, the API will return a 403 Forbidden because the token is valid but insufficient for the requested resource.
Step 1: Initialize the Platform Client with Correct Scopes
The first step is to initialize the PureCloudPlatformClientV2 object. You must pass the scopes parameter to ensure the generated access token includes routing:queue:view.
import os
from genesyscloud.platform.client import PureCloudPlatformClientV2
from genesyscloud.configuration import Configuration
# Configuration constants
ORGANIZATION_ID = os.getenv("GENESYS_ORG_ID")
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
# Define the required scope explicitly
REQUIRED_SCOPES = ["routing:queue:view"]
def create_platform_client():
Creates and returns a configured PureCloudPlatformClientV2 instance.
if not ORGANIZATION_ID or not CLIENT_ID or not CLIENT_SECRET:
raise ValueError("Missing required environment variables: GENESYS_ORG_ID, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET")
# Initialize the client
client = PureCloudPlatformClientV2(
org_id=ORGANIZATION_ID,
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET,
scopes=REQUIRED_SCOPES
return client
Why this matters: If you omit scopes=REQUIRED_SCOPES or pass an empty list, the SDK may default to a minimal set of scopes or fail to include routing:queue:view. The resulting token will be rejected by the /api/v2/routing/queues endpoint with a 403 status.
Step 2: Retrieve Queues Using the SDK
Once the client is initialized, use the queue_api module to fetch the queues. The SDK method get_routing_queues corresponds to the GET /api/v2/routing/queues endpoint.
from genesyscloud.api import QueueApi
def get_all_queues(client: PureCloudPlatformClientV2) -> list:
Retrieves all queues from the Genesys Cloud organization.
Handles pagination automatically if needed.
queue_api = QueueApi(client)
all_queues = []
# Initial request parameters
# expand: 'members' is optional but useful for debugging.
# We omit it here to reduce payload size for a simple list.
params = {
'expand': None,
'size': 250, # Max page size
'page': 1
while True:
# Call the API
response = queue_api.get_routing_queues(
expand=params['expand'],
size=params['size'],
page=params['page']
# Append the results from this page
if response.entities:
all_queues.extend(response.entities)
# Check if there are more pages
if response.next_uri:
# The SDK does not automatically follow next_uri for list endpoints in all versions.
# We must manually increment the page or parse the next_uri.
# For simplicity, we increment the page number.
params['page'] += 1
else:
break
except ApiException as e:
print(f"Exception when calling QueueApi->get_routing_queues: {e}")
print(f"HTTP Status Code: {e.status}")
print(f"Response Body: {e.body}")
# Specific handling for 403
if e.status == 403:
print("ERROR: 403 Forbidden. Check the following:")
print("1. Does the OAuth token have the 'routing:queue:view' scope?")
print("2. Does the user have the 'View Queues' permission in Genesys Cloud?")
raise e
return all_queues
Step 3: Processing and Displaying Results
After retrieving the queues, process the data. The response contains a list of Queue objects. Each object includes id, name, description, outbound_enabled, and other properties.
def display_queues(queues: list) -> None:
Prints a formatted list of queues.
if not queues:
print("No queues found.")
return
print(f"Found {len(queues)} queues:")
print("-" * 60)
print(f"{'ID':<30} {'Name':<30}")
print("-" * 60)
for queue in queues:
queue_id = queue.id or "N/A"
queue_name = queue.name or "Unnamed Queue"
# Truncate long names for display
if len(queue_name) > 28:
queue_name = queue_name[:25] + "..."
print(f"{queue_id:<30} {queue_name:<30}")
print("-" * 60)
Below is the complete, runnable Python script. It combines authentication, API calls, error handling, and result display.
import os
import sys
def main():
# 1. Load Configuration
print("ERROR: Missing environment variables.")
print("Please set GENESYS_ORG_ID, GENESYS_CLIENT_ID, and GENESYS_CLIENT_SECRET.")
sys.exit(1)
# 2. Define Required Scopes
# This is the critical fix for 403 Forbidden on /api/v2/routing/queues
# 3. Initialize Client
print("Successfully authenticated with Genesys Cloud.")
print(f"Authentication failed: {e}")
sys.exit(1)
# 4. Fetch Queues
all_queues = []
page = 1
page_size = 250
while True:
size=page_size,
page=page
# Check for pagination
page += 1
else:
break
print(f"API Exception: {e}")
if e.status == 403:
print("DEBUG: 403 Forbidden received.")
print("ACTION: Verify that 'routing:queue:view' is in the OAuth scopes.")
print("ACTION: Verify the user has 'View Queues' permission.")
sys.exit(1)
# 5. Display Results
if not all_queues:
print("No queues found in the organization.")
return
print(f"\nRetrieved {len(all_queues)} queues:")
print("-" * 80)
print(f"{'Queue ID':<35} {'Queue Name':<45}")
print("-" * 80)
for queue in all_queues:
q_id = queue.id if queue.id else "N/A"
q_name = queue.name if queue.name else "Unnamed"
# Truncate for display
if len(q_name) > 43:
q_name = q_name[:40] + "..."
print(f"{q_id:<35} {q_name:<45}")
print("-" * 80)
main()
Error: 403 Forbidden
What causes it:
The server understood the request but refuses to authorize it. In the context of /api/v2/routing/queues, this is caused by:
- Missing Scope: The OAuth token does not include
routing:queue:view. - Missing Permission: The Genesys Cloud user associated with the OAuth client does not have the “View Queues” permission in their security profile.
How to fix it:
- Check Scopes: Ensure your code passes
scopes=["routing:queue:view"]to thePureCloudPlatformClientV2constructor. - Check Permissions: Log in to the Genesys Cloud Admin portal. Navigate to Admin > Users. Select the user linked to your OAuth client. Go to Security Profiles. Ensure the profile assigned to the user includes the “Routing” section with “View Queues” checked.
Code showing the fix:
# WRONG: May result in 403 if default scopes do not include routing:queue:view
# CORRECT: Explicitly includes the required scope
What causes it:
The OAuth token is invalid, expired, or missing.
How to fix it:
- Verify the
CLIENT_IDandCLIENT_SECRETare correct. - Verify the
ORGANIZATION_IDis correct. - The SDK automatically handles token refresh for valid credentials. If the token is expired, the SDK will attempt to refresh it. If the refresh fails, check the client credentials.
What causes it:
You have exceeded the rate limit for the API.
How to fix it:
Implement exponential backoff and retry logic. The SDK does not automatically retry 429 errors.
def api_call_with_retry(func, *args, max_retries=3, **kwargs):
return func(*args, **kwargs)
if e.status == 429:
wait_time = (2 ** attempt) + 1 # Exponential backoff
print(f"Rate limited. Retrying in {wait_time} seconds...")
time.sleep(wait_time)
else:
raise e
raise Exception("Max retries exceeded")
# Usage
# response = api_call_with_retry(queue_api.get_routing_queues, size=250, page=1)
